Wyze Home Monitoring Service: 24/7 Smart Home Security
Wyze Home Monitoring Service: Complete Protection for Your Home
When it comes to safeguarding your home, Wyze offers a robust and easy-to-use Home Monitoring Service designed to keep you secure 24/7. Whether you want to detect motion, monitor climate conditions, or get alerts for leaks, Wyze’s suite of smart devices works seamlessly together to provide peace of mind. Explore the key products that make up the Wyze Home Monitoring ecosystem and discover how they can protect your home efficiently and affordably.
Core of Your Security: Wyze Home Monitoring Core Starter Kit
The Wyze Home Monitoring Core Starter Kit is the foundation of your home security system. This all-in-one kit is designed to protect your home from unwanted intrusions and potential hazards around the clock.
  • 24/7 Professional Monitoring Included: Comes bundled with 3 months of professional monitoring to ensure immediate response to emergencies.
  • Simple Setup: Easy to install and manage through the Wyze app, making home security accessible to everyone.
  • Color Options: Available in White and Grey to blend seamlessly with your home décor.
  • Comprehensive Protection: Detects unauthorized entry and alerts you instantly, so you can act fast.
Stay worry-free knowing your home is guarded by a trusted system that works day and night.
Wyze Home Monitoring Lifestyle Wyze Home Monitoring Core Starter Kit in action – easy installation and reliable entry detection.
The Brain Behind the System: Wyze Sense Hub
The Wyze Sense Hub acts as the central control unit connecting all your monitoring devices. It ensures that every sensor and alert is communicated promptly to your smartphone.
  • Seamless Connectivity: Links all Wyze Sense components for smooth operation.
  • Instant Alerts: Sends notifications directly to your phone when sensors detect unusual activity.
  • Compact Design: White base with a grey speaker top fits discreetly in any room.
  • Affordable Price: Priced at just $45.98, it’s an essential part of your home monitoring setup.
Detect Motion with Precision: Wyze Sense Motion Sensor
Keep an eye on movement inside your home with the Wyze Sense Motion Sensor. It’s perfect for detecting any unexpected activity and triggering alerts.
  • Wide Detection Range: Covers up to 25 feet with a 120° field of view.
  • Adjustable Sensitivity: Customize detection settings to reduce false alarms.
  • Flexible Installation: Comes with adhesive backing and screws for secure mounting.
  • Compatibility: Requires Wyze Sense Hub or Wyze Home Monitoring system to function.
Motion Sensor Lifestyle Wyze Sense Motion Sensor providing reliable motion detection for your home.
Protect Your Home from Water Damage: Wyze Sense Leak Sensor & Probe
Water leaks can cause serious damage if left unnoticed. The Wyze Sense Leak Sensor & Probe alerts you immediately to prevent costly repairs.
  • Early Leak Detection: Detects water presence and sends instant alerts.
  • Versatile Options: Available in packs with multiple sensors and probes to cover various areas.
  • Long Range: Operates up to 500 feet from the Wyze Sense Hub.
  • Durable Design: Works within a temperature range of 32-104°F and humidity up to 85%.
Additional Smart Monitoring Accessories
Wyze Sense Climate Sensor
Monitor temperature and humidity throughout your home with the Wyze Sense Climate Sensor. Ideal for basements, attics, or any room where climate control is important.
  • 500 ft Range: Place it anywhere in your home for accurate readings.
  • Sleek and Unobtrusive: White design blends into any environment.
  • Easy Placement: Use peel-and-stick adhesive or place on surfaces.
Wyze Sense Keypad
Arm or disarm your security system remotely with the Wyze Sense Keypad.
  • Remote Control: Manage your home security system from anywhere.
  • Indoor Use: Designed for convenient indoor placement.
  • Requires Wyze Sense Hub: Works as part of the Wyze Home Monitoring system.
Why Choose Wyze Home Monitoring?
Wyze Home Monitoring Service offers a comprehensive, affordable, and easy-to-use solution for protecting your home. With professional monitoring, smart sensors, and seamless app integration, you can rest assured your home is safe and secure.
Experience peace of mind with Wyze’s smart home security ecosystem that adapts to your lifestyle and keeps you connected to what matters most.
ProductPrice (USD)DescriptionRequiresKey FeaturesIndoor/Outdoor UseBattery LifeCompatibility
Wyze Home Monitoring Core Starter Kit111.98Home monitoring system with entry and motion sensors, 3 months professional monitoring includedNoneEntry sensor, motion sensor, 24/7 monitoring option, emergency dispatch, insurance discountsIndoorNot specifiedWyze Home Monitoring
Wyze Sense Hub45.98Connects monitoring components and sends alertsNoneCentral hub for Wyze Sense sensors and monitoring componentsIndoorNot applicableCore of Wyze Home Monitoring
Wyze Sense Motion Sensor20.98Detects motionWyze Sense Hub25 ft detection range, 120° field of view, adjustable sensitivityIndoorUp to 18 monthsWyze Sense v2, Wyze Home Monitoring
Wyze Sense Leak Sensor & Probe13.98 - 55.98Detects leaksWyze Sense HubLeak detection, up to 500 ft sensor range, indoor use onlyIndoorNot specifiedWyze Sense v2, Wyze Home Monitoring
Wyze Sense Climate Sensor41.98Tracks temperature and humidityWyze Sense Hub500 ft range, adhesive or screw mount, indoor use onlyIndoor1.5 yearsWyze Sense v2, Wyze Home Monitoring
Wyze Sense Keypad27.98Remote disarm of home security systemWyze Sense HubArm/disarm system, emergency button, supports up to 100 accessoriesIndoorNot specifiedWyze Home Monitoring
What is the Wyze Home Monitoring Service?The Wyze Home Monitoring Service is a comprehensive, affordable, and easy-to-use home security solution that provides 24/7 professional monitoring, smart sensors, and seamless app integration to keep your home safe and secure.
What is included in the Wyze Home Monitoring Core Starter Kit?The Wyze Home Monitoring Core Starter Kit includes essential devices to protect your home from intrusions and hazards. It comes with 3 months of professional monitoring, is easy to install via the Wyze app, and is available in White and Grey to match your home décor.
How does the Wyze Sense Hub work?The Wyze Sense Hub acts as the central control unit for your Wyze Home Monitoring system. It connects all your sensors and devices, ensuring instant alerts are sent to your smartphone when unusual activity is detected. The hub is compact, discreet, and affordably priced.
What features does the Wyze Sense Motion Sensor offer?The Wyze Sense Motion Sensor provides reliable motion detection with a 25-foot range and a 120° field of view. It features adjustable sensitivity to minimize false alarms and can be easily installed with adhesive backing or screws. It requires the Wyze Sense Hub or Home Monitoring system to operate.
How does the Wyze Sense Leak Sensor & Probe protect my home?The Wyze Sense Leak Sensor & Probe detects water leaks early and sends instant alerts to your phone, helping you prevent costly water damage. It operates up to 500 feet from the Wyze Sense Hub and is designed to withstand a wide range of temperatures and humidity.
What is the Wyze Sense Climate Sensor used for?The Wyze Sense Climate Sensor monitors temperature and humidity in any room of your home, making it ideal for areas like basements and attics. It has a 500-foot range, a sleek design, and can be easily placed using adhesive or on flat surfaces.
How does the Wyze Sense Keypad enhance home security?The Wyze Sense Keypad allows you to arm or disarm your Wyze Home Monitoring system remotely. It is designed for indoor use and requires the Wyze Sense Hub to function as part of the overall security system.
Is professional monitoring included with Wyze Home Monitoring?Yes, the Wyze Home Monitoring Core Starter Kit includes 3 months of professional monitoring, ensuring immediate response to emergencies and providing round-the-clock protection for your home.
Can I control Wyze Home Monitoring devices with my smartphone?Yes, all Wyze Home Monitoring devices can be managed and monitored through the Wyze app, allowing you to receive instant alerts and control your security system from anywhere.
Are Wyze Home Monitoring devices easy to install?Yes, Wyze Home Monitoring devices are designed for simple installation, with many components featuring adhesive backing or easy mounting options. The system is user-friendly and can be set up quickly through the Wyze app.
What features are included in the Wyze Home Monitoring Core Starter Kit?How does the Wyze Sense Hub connect with other devices?Are there any ongoing promotions or discounts for the Wyze Home Monitoring products?
