Wyze Lock Bolt: Smart Security at Your Fingertips
Upgrade your home security with the
Wyze Lock Bolt, a Bluetooth-enabled smart lock designed to replace your existing deadbolt seamlessly. Say goodbye to fumbling for keys and enjoy ultra-fast access with its advanced fingerprint sensor and backlit keypad featuring anti-peep technology. Whether you prefer the sleek Matte Black or elegant Satin Nickel finish, this lock combines style with cutting-edge functionality.
- Ultra-Fast Fingerprint Sensor: Unlock your door instantly with a simple touch.
- Backlit Keypad with Anti-Peep: Enter your code discreetly, even in low light.
- Auto-Lock Feature: Never worry about forgetting to lock your door again.
- Lock and Unlock History: Monitor access through the Wyze app for enhanced security.
- Built-in Jam Detection Alarm: Alerts you if the lock is tampered with.
- Emergency One-Time Codes: Grant temporary access to guests or service providers.
- Weather Resistant (IPX5): Durable for various climates and outdoor conditions.
- Long Battery Life: Powered by 4 AA batteries lasting 10-12 months.
The Wyze Lock Bolt fits standard door thicknesses (1-3/8” to 1-3/4”) and backsets, making installation straightforward. Control your door lock remotely via Bluetooth within a 16-foot range, ensuring convenience and peace of mind.
Secure your home effortlessly with Wyze Lock Bolt.
Wyze Video Doorbell v2: Keep an Eye on Your Front Door
Included in the
Essential Security Bundle, the Wyze Video Doorbell v2 offers crystal-clear 1080p HD video to monitor your front entrance. Stay connected with visitors or delivery personnel through two-way audio, ensuring you never miss an important moment.
- 1080p HD Video Quality: Crisp and clear visuals day and night.
- Two-Way Audio: Speak directly to visitors from your smartphone.
- Person Detection: Receive alerts when someone approaches your door.
- MicroSD Local Storage: Save video footage locally for easy access.
- Weather Resistant: Built to withstand outdoor conditions.
This doorbell integrates seamlessly with other Wyze devices, providing a comprehensive security solution for your home.
Wyze Cam Pan v3 + 30-Day Cam Plus Subscription: Watch Every Angle
The
Wyze Cam Pan v3 is a versatile indoor/outdoor security camera that offers 360° horizontal pan and 180° vertical tilt, allowing you to monitor large areas with ease. With the included 30-day Cam Plus subscription, you gain access to advanced cloud recording features and intelligent alerts.
- 360° Pan & 180° Tilt: Complete coverage with automatic motion tracking.
- Color Night Vision: See vivid details even in low light.
- Two-Way Audio: Communicate through the built-in microphone and speaker.
- IP65 Weather Resistance: Durable for outdoor use (requires separate outdoor power adapter).
- 1080p Full HD Video: High-quality streaming and recording.
- Smart Alerts: Receive push notifications for motion and sound events.
- Cam Plus Subscription: Extended cloud storage, person detection, and event tagging.
This camera is perfect for keeping an eye on your home’s perimeter or busy indoor spaces, enhancing your security setup.
Monitor your home with Wyze Cam Pan v3’s dynamic coverage.
Essential Security Bundle: All-in-One Home Protection
For those seeking a comprehensive security solution, the
Essential Security Bundle combines the power of the Wyze Video Doorbell v2, Wyze Lock Bolt, Wyze Cam Pan v3, and two Wyze Cam OG cameras. This bundle offers multi-angle surveillance, smart access control, and real-time alerts to keep your home safe and connected.
- Wyze Video Doorbell v2: Front door monitoring with 2K resolution.
- Wyze Lock Bolt: Keyless entry with fingerprint and keypad access.
- Wyze Cam Pan v3: Pan, tilt, and color night vision with motion tracking.
- Two Wyze Cam OG Cameras: Plug-in cameras with motion-activated spotlights and color night vision.
- Cloud & Local Recording: Flexible storage options for all cameras.
- Real-Time Alerts & Voice Deterrence: Stay informed and deter unwanted visitors instantly.
- IP65 Weather Resistance: Reliable performance indoors and outdoors.
This bundle is an excellent choice for homeowners who want a robust, easy-to-manage security system with smart home integration.
"Secure your home effortlessly with Wyze’s smart lock and camera solutions, combining convenience, advanced technology, and peace of mind."
### Summary of Products Mentioned
What is the Wyze Lock Bolt and how does it enhance home security?
The Wyze Lock Bolt is a Bluetooth-enabled smart lock designed to replace your existing deadbolt. It enhances home security with features like an ultra-fast fingerprint sensor, backlit keypad with anti-peep technology, auto-lock, lock and unlock history via the Wyze app, built-in jam detection alarm, and emergency one-time codes for guests. Its weather-resistant design and long battery life make it a reliable choice for any home.How does the fingerprint sensor on the Wyze Lock Bolt work?
The Wyze Lock Bolt features an ultra-fast fingerprint sensor that allows you to unlock your door instantly with a simple touch. This provides quick, secure, and keyless access to your home.What is anti-peep technology on the Wyze Lock Bolt keypad?
Anti-peep technology on the Wyze Lock Bolt's backlit keypad allows you to enter your access code discreetly, even in low light. This feature helps prevent others from seeing your code and enhances your security.Can I monitor who accesses my door with the Wyze Lock Bolt?
Yes, the Wyze Lock Bolt provides lock and unlock history through the Wyze app, allowing you to monitor access and enhance your home’s security.Is the Wyze Lock Bolt weather resistant?
Yes, the Wyze Lock Bolt is IPX5 weather resistant, making it durable and suitable for various climates and outdoor conditions.How long does the Wyze Lock Bolt battery last?
The Wyze Lock Bolt is powered by 4 AA batteries, which typically last between 10 to 12 months, ensuring long-term, reliable operation.What is included in the Wyze Essential Security Bundle?
The Wyze Essential Security Bundle includes the Wyze Video Doorbell v2, Wyze Lock Bolt, Wyze Cam Pan v3, and two Wyze Cam OG cameras. This bundle provides comprehensive home protection with multi-angle surveillance, smart access control, and real-time alerts.What features does the Wyze Video Doorbell v2 offer?
The Wyze Video Doorbell v2 offers 1080p HD video quality, two-way audio, person detection, microSD local storage, and weather resistance. It allows you to monitor your front entrance and communicate with visitors directly from your smartphone.How does the Wyze Cam Pan v3 improve home monitoring?
The Wyze Cam Pan v3 provides 360° horizontal pan and 180° vertical tilt for complete coverage, color night vision, two-way audio, IP65 weather resistance, and 1080p full HD video. With the included 30-day Cam Plus subscription, you also get advanced cloud recording and intelligent alerts.Are Wyze security products easy to install?
Yes, Wyze security products like the Lock Bolt are designed to fit standard door thicknesses and backsets, making installation straightforward. The cameras and doorbell are also user-friendly and integrate seamlessly with other Wyze devices.Can I control the Wyze Lock Bolt remotely?
You can control the Wyze Lock Bolt remotely via Bluetooth within a 16-foot range, allowing you to lock or unlock your door and monitor access conveniently from your smartphone.What storage options are available for Wyze security cameras?
Wyze security cameras offer both cloud and local recording options. You can use microSD cards for local storage or subscribe to Cam Plus for extended cloud storage, person detection, and event tagging.
