Early Access Doorbell Lock Bundle for Smart Home Subscribers
Upgrade your smart home security with the exclusive early access to the Doorbell Lock Bundle designed specifically for smart home subscribers. This bundle combines advanced door locking technology with high-definition video doorbell capabilities, giving you complete control and peace of mind right at your front porch.
Wyze Lock Bolt: The Ultimate Smart Lock Solution
Key Features and Benefits
  • Ultra-Fast Fingerprint Sensor: Unlock your door instantly with a quick fingerprint scan, eliminating the need for keys.
  • Backlit Keypad with Anti-Peep: Enter your code securely even in the dark, with a keypad designed to prevent prying eyes.
  • Auto-Lock Function: Never worry about forgetting to lock your door again; the Wyze Lock Bolt automatically locks after a set time.
  • Lock and Unlock History: Monitor who enters and exits your home through the Wyze app, providing real-time access logs.
  • Built-in Jam Detection Alarm: Alerts you immediately if the lock is jammed or tampered with.
  • Emergency One-Time Codes: Share temporary access codes with guests or service providers safely.
Technical Specifications
  • Communication: Bluetooth 5.0 with a 16 ft range.
  • Power Source: 4x AA batteries included, lasting 10-12 months.
  • Weather Resistance: Rated IPX5, suitable for various climates.
  • Door Compatibility: Fits doors 1-3/8” to 1-3/4” thick with backset options of 2-3/8” or 2-3/4”.
  • Operating Temperature: Keypad works from -13°F to 122°F, suitable for most environments.
Available in elegant Matte Black and Satin Nickel finishes, the Wyze Lock Bolt seamlessly blends security with style. Wyze Lock Bolt Lifestyle Secure your home with Wyze Lock Bolt’s smart fingerprint access.
The Front Porch Security Bundle: Comprehensive Smart Home Protection
What’s Included?
  • Wyze Lock Bolt: Control your door lock remotely and enjoy all the smart features described above.
  • Wyze Video Doorbell: See your front porch in crisp 1080p HD with a wide 120° vertical and 88° horizontal field of view.
  • Wyze Chime: Hear your doorbell inside your home with multiple sound options including modern, classic, and animal sounds.
Advanced Features
  • Two-Way Audio: Communicate with visitors or delivery personnel directly through the Wyze app.
  • Remote Lock/Unlock: Manage your door lock from anywhere, ensuring you never miss a visitor or delivery.
  • Motion Detection & Alerts: Receive instant notifications when motion is detected on your porch.
  • Smart Assistant Compatibility: Works seamlessly with Alexa and Google Assistant for voice control.
  • Weather-Resistant Design: The video doorbell is IP65 rated, built to withstand outdoor conditions.
Technical Details
  • Video Doorbell Sensor: 2K resolution (2048 x 1536) with F2.0 aperture for clear images day and night.
  • Power Requirements: Doorbell operates on 16V-24V AC, ≥10VA.
  • Connectivity: Direct WiFi connection (802.11 b/g/n, 2.4GHz).
  • Operating Temperature: -4°F to 122°F, suitable for most climates.
This bundle offers a complete front porch security solution, combining smart locking and video monitoring for enhanced safety and convenience. Wyze Video Doorbell Lifestyle Monitor and secure your front porch with Wyze Video Doorbell.
Essential Replacement Parts for Wyze Lock Bolt
To keep your Wyze Lock Bolt functioning flawlessly, consider these genuine replacement parts designed specifically for your smart lock:
Wyze Lock Replacement Part Kit
  • Includes essential components to replace worn or lost parts.
  • Hassle-free 30-day return policy.
  • Compatible only with Wyze Lock.
Wyze Lock Bolt Screws
  • Set of screws designed for secure installation and maintenance.
  • Affordable and easy to replace.
Wyze Lock Bolt Interior Assembly Battery Cover
  • Replacement battery cover to protect your lock’s power source.
  • Ensures longevity and reliable battery performance.
Wyze Lock Bolt Interior Assembly Metal Plate
  • Metal plate anchors the interior assembly firmly to your door.
  • Provides added stability and security.
These parts ensure your smart lock remains in top condition, extending the life and reliability of your smart home security system.
Why Choose the Early Access Doorbell Lock Bundle?
Experience the convenience of keyless entry combined with the security of HD video monitoring. This bundle is perfect for smart home subscribers who want to upgrade their front porch security with cutting-edge technology and seamless app control
FeatureWyze Lock BoltThe Front Porch Security Bundle
Product TypeBluetooth Smart LockSmart Home Security Bundle
Price$79.98$123.99 - $173.97 (varies by variant)
IncludesSmart lock with fingerprint sensor, backlit keypadWyze Lock + Wyze Video Doorbell and Chime (varies by variant)
Lock FeaturesUltra-fast fingerprint reader, backlit keypad, anti-peep technology, auto-lock, emergency one-time codes, local Bluetooth connection, hardware encryption, two-factor authenticationWyze Lock Bolt features included (fingerprint sensor, backlit keypad, auto-lock) plus Video Doorbell and Chime for porch security
App FeaturesLock/unlock history, create/store up to 20 access codes, store up to 50 fingerprints, emergency codes, auto-expiring codes, Bluetooth app controlRemote lock/unlock, view lock history, porch video monitoring with two-way audio, motion events notifications
Installation TimeAbout 20 minutesIncludes Wyze Lock Bolt installation plus Video Doorbell setup
CompatibilityReplaces existing deadbolt, compatible with most exterior doorsIncludes Wyze Lock Bolt compatibility plus Video Doorbell WiFi 2.4GHz
Battery LifeUp to 12 months (4 AA batteries)Wyze Lock Bolt: 4 AA batteries (included), Video Doorbell powered by 16V-24V AC
Weather ResistanceIPX5 (weatherproof)Wyze Lock Bolt: IPX5; Video Doorbell: IP65 weather-resistant
ConnectivityBluetooth 5.0Bluetooth (Lock), WiFi 2.4GHz (Video Doorbell)
Additional Security FeaturesBuilt-in alarm, hardware encryption, two-factor authenticationWorks with Alexa and Google Assistant, porch video with two-way audio
Auto-lock FeatureYesYes (via Wyze Lock Bolt)
Fingerprint CapacityUp to 50 fingerprintsIncluded via Wyze Lock Bolt
Access CodesUp to 20 access codesIncluded via Wyze Lock Bolt
Video Doorbell ResolutionN/A1080p HD (Wyze Video Doorbell)
Video Doorbell FeaturesN/ATwo-way audio, motion events, real-time alerts
What is included in the Early Access Doorbell Lock Bundle for Smart Home Subscribers?The Early Access Doorbell Lock Bundle includes the Wyze Lock Bolt, Wyze Video Doorbell, and Wyze Chime. This bundle provides advanced door locking technology, high-definition video monitoring, and customizable chime sounds for comprehensive front porch security.
What are the key features of the Wyze Lock Bolt smart lock?The Wyze Lock Bolt features an ultra-fast fingerprint sensor, backlit anti-peep keypad, auto-lock function, lock and unlock history via the Wyze app, built-in jam detection alarm, and emergency one-time codes for guest access. It is available in Matte Black and Satin Nickel finishes.
How does the Wyze Lock Bolt enhance home security?The Wyze Lock Bolt enhances home security with instant fingerprint access, secure keypad entry, automatic locking, real-time access logs, jam detection alarms, and the ability to share temporary codes with guests or service providers.
Is the Wyze Lock Bolt compatible with different door types?Yes, the Wyze Lock Bolt fits doors that are 1-3/8” to 1-3/4” thick and supports backset options of 2-3/8” or 2-3/4”.
What are the technical specifications of the Wyze Lock Bolt?The Wyze Lock Bolt uses Bluetooth 5.0 with a 16 ft range, is powered by 4x AA batteries (lasting 10-12 months), is IPX5 weather resistant, and operates in temperatures from -13°F to 122°F.
What features does the Wyze Video Doorbell offer?The Wyze Video Doorbell provides 2K HD video resolution, a 120° vertical and 88° horizontal field of view, two-way audio, motion detection and alerts, and is IP65 weather-resistant. It also supports remote access and works with Alexa and Google Assistant.
Can I control the Wyze Lock Bolt and Video Doorbell remotely?Yes, both the Wyze Lock Bolt and Video Doorbell can be controlled remotely through the Wyze app, allowing you to lock or unlock your door and monitor your front porch from anywhere.
What replacement parts are available for the Wyze Lock Bolt?Available replacement parts for the Wyze Lock Bolt include the Wyze Lock Replacement Part Kit, Wyze Lock Bolt Screws, Wyze Lock Bolt Interior Assembly Battery Cover, and Wyze Lock Bolt Interior Assembly Metal Plate. These parts help maintain and extend the life of your smart lock.
Is the Wyze Lock Bolt weather resistant?Yes, the Wyze Lock Bolt is rated IPX5 for weather resistance, making it suitable for various climates and outdoor conditions.
What are the power requirements for the Wyze Video Doorbell?The Wyze Video Doorbell operates on 16V-24V AC with a minimum of 10VA, and connects directly to WiFi (802.11 b/g/n, 2.4GHz).
Why should I choose the Early Access Doorbell Lock Bundle for my smart home?The Early Access Doorbell Lock Bundle offers the convenience of keyless entry, advanced video monitoring, seamless app control, and compatibility with smart assistants, making it an ideal upgrade for smart home subscribers seeking enhanced front porch security.
