Wireless Doorbell Pro Starter Kit with Battery Powered Lock Bolt
Upgrade your home security and convenience with the ultimate wireless doorbell pro starter kit paired with a battery-powered lock bolt. This combination offers seamless access management and smart monitoring, ensuring your front door is both secure and smartly connected. Explore the top products designed to enhance your home’s safety and ease of use.
Wyze Lock Bolt: The Smart Battery-Powered Lock Bolt
Experience keyless entry like never before with the
Wyze Lock Bolt, a Bluetooth-enabled smart lock that replaces your traditional deadbolt. Designed for effortless security, this lock bolt offers:
- Ultra-fast fingerprint sensor for instant unlocking.
- Backlit keypad with anti-peep technology for secure code entry even in the dark.
- Auto-lock function that secures your door automatically if you forget.
- Lock and unlock history accessible via the Wyze app.
- Built-in alarm for jam detection to alert you of tampering.
- Emergency one-time codes for guest access without sharing permanent credentials.
Key Specifications:
- Power Source: 4x AA batteries (included) with 10-12 months battery life.
- Communication: Bluetooth 5.0 with a 16 ft range.
- Weather Resistance: IPX5 rating, suitable for various climates.
- Operating Temperature: Keypad works from -13°F to 122°F.
- Door Compatibility: Fits doors 1-3/8” to 1-3/4” thick with standard deadbolt dimensions.
Available in
Matte Black and
Satin Nickel, the Wyze Lock Bolt blends modern aesthetics with robust security.
Say goodbye to fumbling for keys and hello to quick, secure access with just a fingerprint or app tap.
Secure your home effortlessly with Wyze Lock Bolt.
Wyze Video Doorbell Pro and Front Porch Security Bundles
Complement your smart lock with a high-definition wireless doorbell system. The
Wyze Video Doorbell Pro offers:
- Crisp 2K resolution video for clear visitor identification.
- Two-way audio with noise and echo cancellation to communicate with guests.
- 120° vertical and 88° horizontal field of view to cover your porch area.
- IP65 weather resistance for reliable outdoor performance.
- Multiple chime sounds and integration with Alexa and Google Assistant.
For a comprehensive solution, the
Front Porch Security Bundle pairs the Wyze Lock Bolt with the Wyze Video Doorbell and Chime, providing:
- Remote locking/unlocking and lock history monitoring.
- 1080p HD video with two-way audio.
- Motion event alerts and smart home assistant compatibility.
This bundle is perfect for those seeking an all-in-one front door security upgrade.
Smart lock and video doorbell working together for your home’s safety.
Essential Security Bundle: Complete Home Protection
Take your home security further with the
Essential Security Bundle, which includes:
- Wyze Video Doorbell v2: 1080p HD video, two-way audio, and person detection.
- Wyze Lock Bolt: Fast fingerprint sensor and backlit keypad.
- Wyze Cam Pan v3: 360° horizontal and 180° vertical coverage with motion tracking and color night vision.
- Two Wyze Cam OGs: Versatile indoor/outdoor cameras with motion-activated spotlights.
This bundle offers a multi-angle security system, perfect for monitoring your entire home environment with real-time alerts and cloud/local recording options.
Replacement Parts for Wyze Lock Bolt
Maintain your smart lock’s performance with genuine replacement parts:
- Wyze Lock Bolt Interior Assembly Battery Cover: Protects the battery compartment, ensuring longevity and reliability.
- Wyze Lock Bolt Screws: Replacement screw sets for secure installation.
- Wyze Lock Bolt Interior Assembly Metal Plate: Anchors the interior assembly firmly to your door.
These parts ensure your Wyze Lock Bolt stays in optimal condition without hassle.
Why Choose Wyze Wireless Doorbell Pro Starter Kit with Battery Powered Lock Bolt?
Combining the Wyze Lock Bolt with a wireless video doorbell system offers a seamless, secure, and smart home entry experience. Whether you want quick fingerprint access, remote locking, or crystal-clear video monitoring, these products deliver convenience and peace of mind.
- Easy installation and app control.
- Long-lasting battery life with included batteries.
- Weather-resistant designs for outdoor durability.
- Integration with popular smart home assistants.
- Comprehensive security bundles for all-around protection.
Enhance your home’s security today with Wyze’s innovative wireless doorbell pro starter kit and battery-powered lock bolt solutions.
Product Images Summary
- Wyze Lock Bolt securing a front door in a lifestyle setting.
- Wyze Lock Bolt paired with the Wyze Video Doorbell showcasing smart home integration.
What is included in the Wyze Wireless Doorbell Pro Starter Kit with Battery Powered Lock Bolt?
The Wyze Wireless Doorbell Pro Starter Kit includes the Wyze Lock Bolt, a battery-powered smart lock, and the Wyze Video Doorbell Pro. This combination provides seamless access management, smart monitoring, and enhanced front door security.How does the Wyze Lock Bolt work?
The Wyze Lock Bolt is a Bluetooth-enabled smart lock that replaces your traditional deadbolt. It features an ultra-fast fingerprint sensor, a backlit keypad with anti-peep technology, auto-lock functionality, lock and unlock history via the Wyze app, a built-in alarm for jam detection, and emergency one-time codes for guest access.What are the key features of the Wyze Video Doorbell Pro?
The Wyze Video Doorbell Pro offers 2K resolution video, two-way audio with noise and echo cancellation, a 120° vertical and 88° horizontal field of view, IP65 weather resistance, multiple chime sounds, and integration with Alexa and Google Assistant.What is the battery life of the Wyze Lock Bolt?
The Wyze Lock Bolt is powered by 4 AA batteries (included) and offers a battery life of 10-12 months, depending on usage.Is the Wyze Lock Bolt weather resistant?
Yes, the Wyze Lock Bolt has an IPX5 weather resistance rating, making it suitable for various climates and outdoor use.Can I control the Wyze Lock Bolt remotely?
The Wyze Lock Bolt connects via Bluetooth with a 16 ft range. While direct remote control is limited to Bluetooth range, you can view lock and unlock history and manage access codes through the Wyze app.What door sizes are compatible with the Wyze Lock Bolt?
The Wyze Lock Bolt fits doors that are 1-3/8” to 1-3/4” thick and have standard deadbolt dimensions.What is included in the Wyze Front Porch Security Bundle?
The Wyze Front Porch Security Bundle includes the Wyze Lock Bolt, Wyze Video Doorbell, and Chime. It provides remote locking/unlocking, lock history monitoring, 1080p HD video, two-way audio, motion event alerts, and smart home assistant compatibility.What does the Wyze Essential Security Bundle offer?
The Wyze Essential Security Bundle includes the Wyze Video Doorbell v2, Wyze Lock Bolt, Wyze Cam Pan v3, and two Wyze Cam OGs. This bundle provides comprehensive home protection with multi-angle video coverage, motion tracking, person detection, and both cloud and local recording options.Are replacement parts available for the Wyze Lock Bolt?
Yes, genuine replacement parts for the Wyze Lock Bolt are available, including the interior assembly battery cover, replacement screw sets, and the interior assembly metal plate.Does the Wyze Lock Bolt support keyless entry?
Yes, the Wyze Lock Bolt supports keyless entry through its fingerprint sensor and backlit keypad, allowing you to unlock your door quickly and securely without a physical key.Can the Wyze Lock Bolt and Video Doorbell be integrated with smart home assistants?
Yes, the Wyze Video Doorbell Pro integrates with Alexa and Google Assistant, allowing for voice control and smart home automation. The Wyze Lock Bolt can be managed via the Wyze app.How easy is it to install the Wyze Lock Bolt and Video Doorbell Pro?
Both the Wyze Lock Bolt and Video Doorbell Pro are designed for easy installation, with included instructions and all necessary hardware for a hassle-free setup.What security features does the Wyze Lock Bolt offer?
The Wyze Lock Bolt offers an ultra-fast fingerprint sensor, backlit keypad with anti-peep technology, auto-lock function, lock and unlock history, built-in alarm for jam detection, and emergency one-time codes for secure guest access.What are the color options for the Wyze Lock Bolt?
The Wyze Lock Bolt is available in Matte Black and Satin Nickel finishes, blending modern aesthetics with robust security.
