Discover the Best Wyze Cameras for Night Vision
When it comes to home security, having a camera with excellent night vision is essential. Wyze offers a range of cameras equipped with advanced night vision technologies, ensuring clear and colorful footage even in the darkest conditions. Whether you want an indoor camera, an outdoor floodlight camera, or a versatile pan-tilt model, Wyze has you covered with cutting-edge features designed to keep your property safe 24/7.
Wyze Cam v4 – Superior Color Night Vision and 2.5K QHD Clarity
The Wyze Cam v4 stands out as one of the best options for night vision in the Wyze lineup. It features a
CMOS Starlight Sensor combined with
4 IR LEDs (850 nm) and
2 white spotlight LEDs (72 lumens) that enable
color night vision. This means you get vibrant, detailed video even in low-light or no-light environments.
Key Features:
- Video Resolution: 2.5K QHD (2560x1440) for crystal-clear images day and night
- Field of View: Wide 115.8° diagonal, 98.5° horizontal, and 53.1° vertical
- Night Vision: 4 IR LEDs plus 2 white spotlight LEDs for enhanced color night vision
- Connectivity: Supports Wi-Fi 6 and 2.4 GHz Wi-Fi for reliable streaming
- Audio: 99dB waterproof speaker with two-way talk and built-in siren
- Weather Resistance: IP65 rating for indoor/outdoor use
- Mounting Options: Stand, wall, ceiling, and magnetic mounts for versatile placement
- Storage: Local microSD card support up to 512 GB and optional cloud storage
Experience peace of mind with Wyze Cam v4’s advanced night vision that captures vivid color footage, making it easier to identify people and objects in the dark.
Wyze Cam Pan v3 – 360° Pan and Tilt with Night Vision
For those who want full coverage with night vision, the
Wyze Cam Pan v3 offers a 360° horizontal and 180° vertical view with a
120° field of view. It uses
4 IR LEDs (850 nm) for clear black-and-white night vision, perfect for monitoring large indoor or outdoor areas.
Highlights:
- Video Resolution: Full HD 1080p (1920x1080)
- Night Vision: 4 IR LEDs for reliable night monitoring
- Pan & Tilt: 360° horizontal and 180° vertical rotation with up to 110° per second speed
- Weatherproof: IP65 rating for outdoor durability (requires separate outdoor power adapter)
- Audio: Two-way talk with noise and echo cancellation
- Storage: Supports up to 256 GB microSD card
- Connectivity: 2.4 GHz Wi-Fi (no 5 GHz support)
The Wyze Cam Pan v3 is ideal for users who want to cover every angle with smooth pan and tilt controls, combined with dependable night vision for round-the-clock security.
Wyze Cam Pan v3 offers weather-resistant, 360° coverage with night vision.
Wyze Battery Cam Pro – Wire-Free Night Vision with Spotlight
If you prefer a wireless solution, the
Wyze Battery Cam Pro delivers 2.5K HDR video with
color night vision thanks to its
2 IR LEDs (850 nm) and
2 powerful white LEDs (187 lumens). This camera is perfect for flexible placement without worrying about power cords.
Features at a Glance:
- Resolution: 2560 x 1440 (2.5K) HDR video
- Night Vision: Color night vision with IR and white LEDs
- Power: Removable rechargeable battery packs lasting up to 6 months
- Field of View: Wide 134° diagonal, 108° horizontal, 56° vertical
- Connectivity: Dual-band Wi-Fi (2.4 GHz & 5 GHz)
- Audio: Two-way audio with built-in speaker and MEMS digital mic
- Weatherproof: IP65 rating for all-weather use
- Storage: Supports up to 256 GB microSD cards
Enjoy the freedom of wire-free installation combined with bright, clear night vision and integrated spotlight to illuminate your property when motion is detected.
Wyze Cam Floodlight v2 – Brightest Night Vision with 2800 Lumens
For ultimate outdoor security with night vision, the
Wyze Cam Floodlight v2 combines a 2K camera with
color night vision and
2800 lumens of LED lighting. This floodlight camera not only records clear video but also lights up your driveway or yard with a wide 160° diagonal field of view.
Standout Specs:
- Video Quality: 2K (2304 x 1296) with color night vision
- Lighting: Two dimmable LED panels producing 2800 lumens at 5000K color temperature
- Field of View: Ultra-wide 160° diagonal
- Audio: Two-way talk with built-in speaker and microphone
- Siren: Loud 105dB siren for deterrence
- Weather Resistance: IP65 for reliable outdoor use
- Smart Features: AI-powered light control, dusk-to-dawn automation, and integrations with Alexa, Google Assistant, and IFTTT
The Wyze Cam Floodlight v2 is perfect for those who want to dominate the dark with powerful lighting and crystal-clear color night vision, enhancing both security and visibility.
Wyze Cam Floodlight v2 lights up your property with bright color night vision.
Why Choose Wyze Cameras for Night Vision?
Wyze cameras are designed with advanced sensors and LED technology to provide
clear, colorful, and detailed night vision. Whether you need a compact indoor camera, a pan-tilt model for full coverage, a wireless battery-powered option, or a floodlight camera for outdoor security, Wyze offers reliable, affordable solutions with:
- High-resolution video (up to 2.5K QHD)
- Color night vision for better identification
- Weather-resistant designs for outdoor use
- Smart home integrations with Alexa, Google Assistant, and IFTTT
- Flexible storage options including local microSD and cloud plans
Protect your home day and night with Wyze’s best night vision cameras — clarity and security you can trust.
Wyze Cam v4 supports two-way talk and color night vision for indoor security.
Summary of Wyze Cameras with Best Night Vision
Model | Night Vision Type | Resolution | Field of View | Weather Resistance | Power Source |
Wyze Cam v4 | 4 IR LEDs + 2 white spotlights (Color Night Vision) | 2.5K QHD (2560x1440) | 115.8° DFOV | IP65 | Wired (USB) |
Wyze Cam Pan v3 | 4 IR LEDs (Black & White Night Vision) | 1080p HD | 120° FOV | IP65 | Wired (USB) |
Wyze Battery Cam Pro | 2 IR LEDs + 2 white LEDs (Color Night Vision) | 2.5K HDR | 134° DFOV | IP65 | Battery (Rechargeable) |
Wyze Cam Floodlight v2 | Color Night Vision + 2800 Lumens LED Floodlight | 2K (2304x1296) | 160° Diagonal | IP65 | Hardwired |
Choose the Wyze camera that fits your needs and enjoy the best night vision technology to keep your home safe and secure.
# End of Page
What are the best Wyze cameras for night vision?
The best Wyze cameras for night vision include the Wyze Cam v4 (color night vision with 2.5K QHD), Wyze Cam Pan v3 (360° pan and tilt with black-and-white night vision), Wyze Battery Cam Pro (wire-free color night vision), and Wyze Cam Floodlight v2 (2K color night vision with 2800 lumens floodlight). Each model offers advanced night vision features to suit different security needs.Which Wyze camera offers color night vision?
Wyze Cam v4, Wyze Battery Cam Pro, and Wyze Cam Floodlight v2 all offer color night vision. These cameras use a combination of advanced sensors, IR LEDs, and white LEDs or floodlights to deliver vibrant, detailed color footage even in low-light or no-light conditions.Does the Wyze Cam Pan v3 have night vision?
Yes, the Wyze Cam Pan v3 features night vision using 4 IR LEDs (850 nm) for clear black-and-white footage in the dark. It also offers 360° horizontal and 180° vertical pan and tilt for comprehensive coverage.Are Wyze night vision cameras weatherproof for outdoor use?
Yes, many Wyze cameras with night vision are weather-resistant with an IP65 rating, making them suitable for both indoor and outdoor use. Models like Wyze Cam v4, Wyze Cam Pan v3 (with outdoor power adapter), Wyze Battery Cam Pro, and Wyze Cam Floodlight v2 are designed to withstand various weather conditions.What is the video resolution of Wyze night vision cameras?
Wyze night vision cameras offer high-resolution video: Wyze Cam v4 and Wyze Battery Cam Pro provide 2.5K QHD (2560x1440), Wyze Cam Floodlight v2 offers 2K (2304x1296), and Wyze Cam Pan v3 delivers Full HD 1080p (1920x1080) resolution.Can Wyze night vision cameras record in color at night?
Yes, select Wyze cameras such as the Wyze Cam v4, Wyze Battery Cam Pro, and Wyze Cam Floodlight v2 are equipped with color night vision technology, allowing them to capture full-color video even in low-light or nighttime conditions.Do Wyze night vision cameras support local storage?
Yes, Wyze night vision cameras support local storage via microSD cards. Wyze Cam v4 supports up to 512 GB, while Wyze Cam Pan v3, Wyze Battery Cam Pro, and Wyze Cam Floodlight v2 support up to 256 GB microSD cards. Cloud storage options are also available.Are Wyze night vision cameras compatible with smart home systems?
Yes, Wyze night vision cameras integrate with popular smart home platforms such as Amazon Alexa, Google Assistant, and IFTTT, allowing for voice control and automation.Which Wyze camera is best for wire-free night vision security?
The Wyze Battery Cam Pro is the best wire-free option for night vision security. It features 2.5K HDR video, color night vision, a rechargeable battery lasting up to 6 months, and weatherproof design for flexible placement.What is the brightest Wyze camera for night vision?
The Wyze Cam Floodlight v2 is the brightest Wyze camera for night vision, featuring two dimmable LED panels that produce 2800 lumens of light, combined with a 2K camera and color night vision for maximum outdoor security and visibility.
