Wyze Cam v4: Best IR Night Vision Cameras for Home Security
Cameras with Built-In IR Lights for Clear Night Vision Recordings: Wyze Cam v4 and More
When it comes to home security, having a camera that performs exceptionally well in low-light or nighttime conditions is crucial. Cameras equipped with built-in infrared (IR) lights ensure clear night vision recordings, providing peace of mind around the clock. Wyze offers a range of smart cameras with advanced IR lighting technology, including the highly popular Wyze Cam v4 and the innovative Wyze Bulb Cam. This page highlights these cameras’ night vision capabilities, specs, and features to help you choose the perfect security solution.
Wyze Cam v4: Advanced Night Vision with IR and Spotlight
Crystal-Clear 2.5K QHD Resolution and Enhanced Color Night Vision
Wyze Cam v4 delivers stunning 2.5K QHD (2560x1440) video quality, ensuring every detail is captured with clarity. Its standout feature is the Enhanced Color Night Vision, which uses a combination of 4 IR LEDs (850 nm) and 2 white spotlight LEDs (72 lumens) to illuminate dark scenes in vibrant color rather than traditional black and white. This makes it easier to identify people, objects, and activities at night.
Powerful IR Lighting and Motion-Activated Spotlight
The camera’s built-in 4x 850 nm IR LEDs provide invisible infrared illumination for clear black-and-white night vision when color mode is not active. The motion-activated spotlight automatically lights up the area when movement is detected, enhancing visibility and deterring intruders.
Wide Field of View and Smart Features
With a diagonal field of view of 115.8°, horizontal 98.5°, and vertical 53.1°, Wyze Cam v4 covers a broad area. It supports person detection, motion zones, and sound detection to reduce false alerts. The camera is compatible with Alexa, Google Assistant, and IFTTT for seamless smart home integration.
Durable and Weather-Resistant
Rated IP65, Wyze Cam v4 is suitable for both indoor and outdoor use, withstanding temperatures from -4°F to 122°F (-20°C to 50°C). Its polycarbonate body and glass/plastic lens ensure durability.
Storage and Connectivity
Supports local storage via microSD cards up to 512 GB and cloud storage with subscription. It connects over Wi-Fi 6 and Bluetooth 5.2 for fast, reliable streaming.
"Wyze Cam v4 combines high-resolution video, powerful IR night vision, and smart spotlighting to keep your home safe day and night."
Wyze Cam v4 Outdoor Night Vision Wyze Cam v4 providing clear night vision outdoors
Wyze Cam v4 Home Security Bundle: Complete Night Vision Solution
All the Features of Wyze Cam v4 Plus Added Value
The Wyze Cam v4 Home Security Bundle includes the same advanced camera with 2.5K QHD resolution, enhanced color night vision, and IR LEDs, bundled with a 128GB microSD card for extended local recording. This bundle is perfect for users who want a ready-to-go security setup with ample storage.
Improved Two-Way Audio and Versatile Mounting
The bundle offers improved 2-way audio quality, allowing clear communication through the camera’s waterproof 99dB speaker and microphone. Multiple mounting options (stand, wall, ceiling, magnetic adhesive) make installation flexible.
Long Video Storage Capacity
With the included microSD card, you can store approximately 192 hours of HD video locally, ensuring you never miss important footage.
"Get a full security package with Wyze Cam v4 Home Security Bundle — enhanced night vision and extended storage in one."
Wyze Bulb Cam: 2-in-1 Security Camera and Smart LED Light with IR Night Vision
Unique Bulb Design with Built-In IR Lights
The Wyze Bulb Cam is a smart LED light bulb combined with a 2K HD security camera. It features 4x 850 nm IR LEDs for night vision, enabling clear black-and-white recordings in total darkness. Additionally, it supports color night vision using its bright 800-lumen LED light.
Wide Field of View and Easy Installation
With a 160° field of view, the Bulb Cam covers a wide area, ideal for outdoor lighting fixtures. It fits standard E26 sockets, making installation as simple as screwing in a light bulb.
Smart Lighting Controls and Alerts
Control the light manually or set it to motion-activated, ambient light sensing, or scheduled modes via the Wyze app. Receive instant motion alerts and enjoy two-way audio for communication.
Weather-Resistant and Energy Efficient
Rated IP65 for outdoor use, the Bulb Cam withstands harsh weather while consuming only 15 watts of power.
"Wyze Bulb Cam combines smart lighting with IR night vision for a discreet, effective outdoor security solution."
Wyze Bulb Cam Installed Outdoor Wyze Bulb Cam installed in an outdoor light fixture
Why Choose Wyze Cameras with Built-In IR Lights?
  • Clear Night Vision: IR LEDs provide invisible illumination for crisp black-and-white night recordings.
  • Color Night Vision: Enhanced lighting and spotlight features allow color video even in low light.
  • Smart Features: Motion detection, person alerts, two-way audio, and voice assistant compatibility.
  • Durability: Weather-resistant designs suitable for indoor and outdoor use.
  • Flexible Storage: Local microSD and cloud options for continuous recording.
Wyze Cam v4 Lifestyle Wyze Cam v4 mounted outdoors, securing a home environment
Summary of Wyze Cameras with Built-In IR Lights
ProductVideo ResolutionIR LEDsColor Night VisionField of ViewWeather ResistanceStorage OptionsPrice Range
Wyze Cam v42.5K QHD4x 850 nm + 2 spotlightsYes115.8° diagonalIP65microSD up to 512GB, Cloud$35.98 - $107.94
Wyze Cam v4 Home Security Bundle2.5K QHD4x 850 nm + 2 spotlightsYes115.8° diagonalIP65128GB microSD included$169.99
Wyze Bulb Cam2K HD4x 850 nmYes160° horizontalIP65microSD up to 256GB, Cloud$49.98
Wyze’s lineup of cameras with built-in IR lights offers reliable, high-quality night vision recordings to keep your home safe and secure. Whether you prefer the versatile Wyze Cam v4 with its spotlight or the innovative Wyze Bulb Cam that doubles as a smart light, these cameras deliver exceptional performance in all lighting conditions. Choose Wyze for smart, affordable, and effective night vision security solutions.
FeatureWyze Cam v4Wyze Cam v4 + FREE 32GB MicroSD CardWyze Cam v4 Home Security BundleWyze Bulb Cam
Price$35.98 (single pack)$35.98$169.99$49.98
Video Resolution2.5K QHD (2560x1440)2.5K QHD (2560x1440)2.5K QHD (2560x1440)2K HD (2304x1296)
Night VisionEnhanced Color Night VisionEnhanced Color Night VisionEnhanced Color Night VisionColor Night Vision + IR Night Vision
Field of View (Diagonal)115.8°115.8°115.8°160°
AudioEnhanced Two-Way Talk, 99 dB SirenEnhanced Two-Way Talk, 99 dB SirenImproved 2-way audio, 99 dB SirenTwo-Way Audio, 95 dB Siren
SpotlightMotion-activated spotlightMotion-activated spotlightMotion-activated spotlightMotion-Activated Light (LED bulb)
Weather ResistanceIP65IP65IP65IP65
Local RecordingmicroSD card support up to 512GB (sold separately)Includes FREE 32GB microSD cardIncludes 128GB microSD cardSupports microSD cards up to 256GB (sold separately)
Continuous 24/7 RecordingYesYesYesYes
Wi-Fi SupportWi-Fi 6 (requires Wi-Fi 6 router)Wi-Fi 6 (requires Wi-Fi 6 router)Wi-Fi 6 (requires Wi-Fi 6 router)Wi-Fi 2.4 GHz b/g/n
Smart Assistant CompatibilityAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google Assistant
Motion & Sound DetectionYesYesYesYes
Motion Detection ZonesYesYesYesNo
Smoke & CO AlertsYesYesYesNo
Mounting OptionsStand, Wall, Ceiling, Magnetic MountStand, Wall, Ceiling, Magnetic MountStand, Wall, Ceiling, Magnetic MountStandard E26 Socket (screw-in bulb)
Power SourceWired (USB power adapter included)Wired (USB power adapter included)Wired (includes Outdoor Power Adapter)120V AC (bulb socket power)
Dimensions2in x 2in x 2 3/8in2in x 2in x 2 3/8in2in x 2in x 2 3/8inBulb size fits standard E26 socket
Weight0.49 lb (222 g)0.49 lb (222 g)0.49 lb (222 g)Not specified
Warranty1 Year1 Year1 Year1 Year
Included ItemsWyze Cam v4, power adapter, mounts, cableWyze Cam v4, FREE 32GB microSD card, power adapter, mounts, cableWyze Cam v4, Outdoor Power Adapter, 128GB microSD card, mounts, cableWyze Bulb Cam (camera + smart LED bulb)
What are the benefits of cameras with built-in IR lights for night vision?Cameras with built-in infrared (IR) lights provide clear night vision recordings by illuminating dark areas with invisible IR light. This ensures your security camera captures crisp footage even in complete darkness, offering peace of mind and enhanced home security around the clock.
What is Enhanced Color Night Vision on the Wyze Cam v4?Enhanced Color Night Vision on the Wyze Cam v4 uses a combination of 4 IR LEDs and 2 white spotlight LEDs to deliver vibrant color video in low-light conditions, instead of the traditional black-and-white night vision. This makes it easier to identify people, objects, and activities at night.
How does the Wyze Cam v4 perform in low-light or nighttime conditions?The Wyze Cam v4 excels in low-light and nighttime conditions thanks to its 2.5K QHD resolution, 4x 850 nm IR LEDs for black-and-white night vision, and motion-activated spotlights for enhanced color night vision. These features ensure clear, detailed footage regardless of lighting.
Is the Wyze Cam v4 suitable for outdoor use?Yes, the Wyze Cam v4 is rated IP65 for weather resistance, making it suitable for both indoor and outdoor use. It can withstand temperatures from -4°F to 122°F (-20°C to 50°C), ensuring reliable performance in various weather conditions.
What storage options are available for Wyze Cam v4?Wyze Cam v4 supports local storage via microSD cards up to 512GB and offers cloud storage with a subscription. This flexibility allows for continuous recording and easy access to your footage.
What is included in the Wyze Cam v4 Home Security Bundle?The Wyze Cam v4 Home Security Bundle includes the advanced Wyze Cam v4 with 2.5K QHD resolution, enhanced color night vision, IR LEDs, and a 128GB microSD card for extended local recording. It also features improved two-way audio and versatile mounting options.
How much video can I store with the included 128GB microSD card in the Wyze Cam v4 Home Security Bundle?With the included 128GB microSD card, you can store approximately 192 hours of HD video locally, ensuring you have ample footage for review and security purposes.
What is the Wyze Bulb Cam and how does it work?The Wyze Bulb Cam is a 2-in-1 smart LED light bulb and 2K HD security camera. It features 4x 850 nm IR LEDs for clear black-and-white night vision and supports color night vision using its 800-lumen LED light. It fits standard E26 sockets for easy installation and offers a wide 160° field of view.
Can the Wyze Bulb Cam be used outdoors?Yes, the Wyze Bulb Cam is rated IP65 for weather resistance, making it suitable for outdoor use. It is designed to withstand harsh weather while providing reliable security and lighting.
What smart features do Wyze cameras with IR lights offer?Wyze cameras with IR lights offer smart features such as motion detection, person alerts, customizable motion zones, sound detection, two-way audio, and compatibility with Alexa, Google Assistant, and IFTTT for seamless smart home integration.
How do I control the lighting and alerts on the Wyze Bulb Cam?You can control the Wyze Bulb Cam’s lighting manually or set it to motion-activated, ambient light sensing, or scheduled modes via the Wyze app. The camera also sends instant motion alerts and supports two-way audio for communication.
What is the field of view for Wyze Cam v4 and Wyze Bulb Cam?The Wyze Cam v4 offers a diagonal field of view of 115.8°, while the Wyze Bulb Cam provides a wide 160° horizontal field of view, allowing both cameras to cover large areas for comprehensive security.
What are the price ranges for Wyze cameras with built-in IR lights?Wyze cameras with built-in IR lights are affordably priced: Wyze Cam v4 ranges from $35.98 to $107.94, the Wyze Cam v4 Home Security Bundle is $169.99, and the Wyze Bulb Cam is $49.98.
What are the key features of the Wyze Cam v4 that enhance its night vision capabilities?How does the Wyze Bulb Cam compare to the Wyze Cam v4 in terms of night vision performance?Are there any ongoing promotions or discounts for the Wyze Cam v4?
