Wyze Camera 128GB UHS 3 MicroSD Card for Seamless Recording
Wyze Camera 128GB MicroSD Card with UHS 3 Speed
When it comes to enhancing your Wyze camera experience, pairing your device with a high-quality microSD card is essential. For users searching for a 128GB microSD card with UHS 3 speed compatibility, Wyze offers the perfect solution designed specifically to unlock continuous recording and advanced features for your Wyze cameras.
Wyze MicroSD Card: Reliable Storage for Wyze Cameras
The Wyze MicroSD Card is engineered to provide seamless local storage for your Wyze cameras, including the popular 128GB microSDXC variant. This card supports continuous recording and time-lapse video capture, allowing you to save every moment without interruption.
Key Features:
  • Capacity Options: Available in 32GB, 128GB, and 256GB sizes to suit your storage needs.
  • Continuous Local Recording: Enables 24/7 video capture directly on the card without monthly fees.
  • Easy Playback: Access recorded footage anytime via the Wyze app or by removing the card to view on your computer.
  • No Subscription Required: Enjoy powerful camera features like timeline controls and calendar view without extra costs.
  • Compatibility: Designed specifically for Wyze cameras with built-in microSD card slots.
This card is ideal for users who want to maximize their Wyze camera's potential with reliable, high-capacity storage.
Wyze Cam v4 Outdoor Bundle: Ultimate Security with 128GB MicroSD Card Included
For those seeking a complete security solution, the Wyze Cam v4 Outdoor Bundle is a standout choice. This bundle includes the Wyze Cam v4, the Wyze Outdoor Power Adapter, and a 128GB Wyze MicroSD Card — perfectly matching your requirement for a high-capacity, fast microSD card.
Why Choose the Wyze Cam v4 Outdoor Bundle?
  • 2.5K QHD Resolution: Crystal-clear video quality for detailed surveillance.
  • Enhanced Color Night Vision: See vibrant colors even in low-light conditions.
  • Motion-Activated Spotlight: Adds an extra layer of security by illuminating detected movement.
  • 24/7 Local Recording: Continuous video capture stored directly on the included 128GB microSD card.
  • Wi-Fi 6 Support: Ensures a stronger, more reliable connection.
  • Smart Home Compatibility: Works seamlessly with Alexa and Google Assistant.
  • Outdoor Ready: Weather-resistant design with wired power for uninterrupted operation.
  • Advanced Detection: Motion and sound detection with customizable zones and smoke/CO alerts.
This bundle is perfect for outdoor security needs, combining high-quality video, smart features, and ample local storage. Wyze Cam v4 Outdoor Security Alt text: Wyze Cam v4 installed outdoors providing home security
Wyze Cam v4 + FREE 32GB MicroSD Card: Best Value with Essential Storage
If you are looking for the latest Wyze Cam with included storage, the Wyze Cam v4 + FREE 32GB MicroSD Card bundle offers excellent value. While it comes with a smaller 32GB card, it supports microSD cards up to 512GB, so upgrading to a 128GB UHS 3 microSD card like the Wyze MicroSD Card is straightforward.
Highlights of Wyze Cam v4:
  • 2.5K Quad HD Video: Superior clarity for indoor or outdoor use.
  • Enhanced Color Night Vision: Capture vivid nighttime footage.
  • Motion and Sound Detection: Receive instant alerts on your phone.
  • Wi-Fi 6 Connectivity: Faster and more stable wireless performance.
  • Smart Home Integration: Compatible with Alexa and Google Assistant.
  • Local Storage Support: Use your own microSD card for continuous recording.
This camera is ideal for users who want a high-performance indoor/outdoor camera with the flexibility to add a 128GB microSD card for extended recording. Wyze Cam v4 Indoor Use Alt text: Wyze Cam v4 monitoring a cozy living room
Why Choose Wyze MicroSD Cards with UHS 3 Speed?
While Wyze does not explicitly list UHS 3 speed on their microSD cards, their cards are optimized for continuous video recording and time-lapse features, ensuring smooth performance with Wyze cameras. The 128GB microSDXC card offers ample space and reliable speed to handle high-resolution 2.5K video streams without lag or dropped frames.
Pro Tip: Always verify your Wyze camera model supports the microSD card size and speed for optimal performance. The Wyze Cam v4 and Outdoor Bundle both support up to 512GB microSD cards, making the 128GB option a perfect balance of capacity and cost.
Summary
For users searching for a Wyze camera 128GB microSD card with UHS 3 speed, the Wyze MicroSD Card 128GB variant is the ideal choice, offering reliable, high-capacity local storage tailored for Wyze cameras. Pair it with the Wyze Cam v4 Outdoor Bundle for a complete security system with enhanced features and included 128GB storage. Alternatively, the Wyze Cam v4 + FREE 32GB MicroSD Card bundle provides a great starting point with the option to upgrade to a 128GB card for extended recording. Enhance your Wyze camera setup today with the perfect microSD card for uninterrupted, high-quality video recording.
FeatureWyze MicroSD CardWyze Cam v4 Outdoor BundleWyze Cam v4 + FREE 32GB MicroSD Card
Product TypeAccessory (MicroSD Card)Camera BundleCamera with Free MicroSD Card
Storage Options32GB microSDHC, 128GB microSDXC, 256GB microSDXCIncludes 128GB MicroSD CardIncludes free 32GB MicroSD Card
Price$8.99 (32GB), $16.99 (128GB), $29.99 (256GB)$69.99$35.98
Camera ResolutionN/A2.5K QHD (2560x1440)2.5K QHD (2560x1440)
Night VisionN/AEnhanced Color Night VisionEnhanced Color Night Vision
Motion-Activated SpotlightN/AYesYes
Local RecordingEnables continuous local recording24/7 local recording with included microSD card24/7 local recording with included microSD card
Wi-Fi SupportN/AWi-Fi 6Wi-Fi 6
CompatibilityFor Wyze Cams with microSD slotWyze Cam v4Wyze Cam v4
Weather ResistanceN/AIP65IP65
Additional FeaturesContinuous recording, timelapseMotion & sound detection, smoke & CO alerts, Alexa & Google Assistant compatibilityMotion & sound detection, smoke & CO alerts, Alexa & Google Assistant compatibility
WarrantyNot specifiedNot specifiedNot specified
Return Policy30-day hassle-free returns30-day hassle-free returns30-day hassle-free returns
What is the best microSD card for Wyze cameras?The Wyze MicroSD Card is specifically designed for Wyze cameras, offering reliable local storage. The 128GB microSDXC variant is ideal for continuous recording and time-lapse video capture, ensuring seamless performance and easy playback through the Wyze app or your computer.
Does the Wyze Cam v4 support a 128GB microSD card?Yes, the Wyze Cam v4 supports microSD cards up to 512GB, including the 128GB Wyze MicroSD Card. This allows for extended continuous recording and easy access to your footage without a subscription.
What are the benefits of using a 128GB microSD card with Wyze cameras?A 128GB microSD card enables 24/7 continuous local recording, time-lapse video capture, and easy playback of footage. It provides ample storage for high-resolution video, reducing the need to frequently delete or transfer files.
Is the Wyze MicroSD Card UHS 3 speed compatible?While Wyze does not explicitly list UHS 3 speed on their microSD cards, their 128GB microSDXC card is optimized for continuous video recording and time-lapse features, ensuring smooth performance with high-resolution Wyze cameras.
Do I need a subscription to use local recording with Wyze cameras?No subscription is required to use local recording features with Wyze cameras. Simply insert a compatible microSD card, such as the Wyze 128GB MicroSD Card, to enable continuous recording, timeline controls, and calendar view at no extra cost.
What is included in the Wyze Cam v4 Outdoor Bundle?The Wyze Cam v4 Outdoor Bundle includes the Wyze Cam v4, Wyze Outdoor Power Adapter, and a 128GB Wyze MicroSD Card. This bundle provides 2.5K QHD video, enhanced color night vision, motion-activated spotlight, Wi-Fi 6 support, and weather-resistant design for complete outdoor security.
Can I upgrade the microSD card in the Wyze Cam v4 + FREE 32GB MicroSD Card bundle?Yes, the Wyze Cam v4 supports microSD cards up to 512GB. You can easily upgrade from the included 32GB card to a 128GB Wyze MicroSD Card for longer recording times and more storage capacity.
How do I access recorded footage from my Wyze camera’s microSD card?You can access recorded footage directly through the Wyze app or by removing the microSD card from your camera and viewing the files on your computer. This makes it easy to review, save, or share important video clips.
Are Wyze MicroSD Cards compatible with all Wyze camera models?Wyze MicroSD Cards are designed for Wyze cameras with built-in microSD card slots. Always check your specific camera model’s compatibility and supported card capacity for optimal performance.
Why should I choose a Wyze MicroSD Card for my Wyze camera?Wyze MicroSD Cards are engineered for seamless integration with Wyze cameras, offering reliable, high-capacity storage for continuous recording and advanced features. They provide a cost-effective solution for local video storage without monthly fees.
What are the key features of the Wyze MicroSD Card?Can I use a different brand of microSD card with my Wyze camera?Do you have any deals, ongoing sales, discounts, or promotions?
