Buy High Speed Class 10 MicroSD Cards for Wyze Cam
When it comes to enhancing your Wyze Cam experience, choosing the right microSD card is essential. A high-speed Class 10 microSD card ensures smooth, reliable local recording of your security footage, whether you use the Wyze Battery Cam Pro, Wyze Cam OG, or other Wyze camera models. This guide will help you understand the compatibility, recommended specifications, and best practices for using microSD cards with your Wyze Cam.
Why Use a Class 10 MicroSD Card with Wyze Cam?
Wyze cameras support local recording to microSD cards, allowing you to save motion events or continuous footage directly on the device. Class 10 microSD cards are recommended because they provide the necessary write speed to handle high-definition video recording without lag or dropped frames.
Key Benefits of Class 10 MicroSD Cards:
  • Fast write speeds for smooth video capture
  • Reliable performance for continuous or event-based recording
  • Compatibility with Wyze cameras’ recording formats (FAT32 and exFAT)
MicroSD Card Compatibility with Wyze Cameras
  • Supports microSD cards in sizes:
  • 8 GB, 16 GB, 32 GB (FAT32 format)
  • 64 GB, 128 GB, 256 GB (exFAT format)
  • Class 10 cards are recommended for optimal performance.
  • Continuous recording is supported but will drain battery quickly; recommended to use with AC power.
  • Motion-only recording helps preserve battery life.
  • Cards up to 256 GB have been tested and work reliably.
Wyze Cam OG and Telephoto 3x
  • Compatible with:
  • 8 GB, 16 GB, 32 GB microSD cards (FAT32)
  • Up to 256 GB microSD cards (exFAT)
  • Class 10 cards ensure smooth HD recording.
Wyze Cam Outdoor (v1 and v2)
  • Supports Class 10 microSD cards.
  • Recommended formats:
  • FAT32 for 8 GB, 16 GB, 32 GB cards
  • exFAT for 64 GB, 128 GB, 256 GB cards
Wyze Cam Pan v3 and Wyze Cam v4
  • Support the same microSD card sizes and formats as above.
  • Class 10 cards recommended for consistent recording quality.
How to Use and Manage Your MicroSD Card with Wyze Cam
1. Insert the microSD Card: Ensure the card is properly inserted into your Wyze Cam’s microSD slot until it clicks. 2. Format the Card: If the card has been used before, format it via the Wyze app to ensure compatibility.
  • Go to your camera’s live stream > Settings > Advanced Settings > Manage MicroSD Card > Format.
3. Enable Local Recording:
  • In the Wyze app, tap your camera’s live stream.
  • Go to Settings > Event Recording and enable motion detection.
  • Then go to Settings > Advanced Settings and toggle on "Record to MicroSD Card."
  • Choose between Continuous or Events Only recording.
4. View Recordings:
  • Playback footage directly in the Wyze app via the SD Card button.
  • Or remove the microSD card and view raw MP4 files on your computer.
Note: Continuous recording will consume more battery and storage. For battery-powered cameras like Wyze Battery Cam Pro, event-only recording is recommended to extend battery life.
Tips for Optimal Performance
  • Use a Class 10 or higher microSD card to ensure smooth video recording.
  • Format your microSD card regularly to prevent errors.
  • For continuous recording, connect your Wyze Battery Cam Pro to a 5V 2A AC power source.
  • Keep your Wyze app and camera firmware updated to avoid compatibility issues.
  • When the microSD card is full, the camera will overwrite the oldest footage automatically.
Conclusion
Choosing a high-speed Class 10 microSD card is crucial for maximizing your Wyze Cam’s local recording capabilities. Whether you want continuous footage or motion-triggered event recording, a compatible microSD card ensures your security videos are captured reliably and accessible whenever you need them. Remember to select the right size and format for your specific Wyze camera model and follow best practices for formatting and managing your card. Enhance your home security setup today with the perfect microSD card tailored for your Wyze Cam!
Home Security with Wyze Cam Alt text: Wyze Cam installed in a modern home for security monitoring
FeatureWyze Battery Cam ProWyze Cam OGWyze Cam Pan v3Wyze Cam v4
TypeBattery Camera (Wireless)Wired Camera (Indoor/Outdoor*)Wired Camera (Indoor/Outdoor, Pan & Tilt)Wired Camera (Indoor/Outdoor)
Video Resolution2.5K HDR (2560x1440 approx.)HD (not specified, likely 1080p)1080p (1920x1080)2.5K QHD (2560x1440)
Field of View (FOV)Not explicitly stated120°120°DFOV 115.8°, HFOV 98.5°, VFOV 53.1°
Night VisionColor Night Vision, Integrated Spotlight (150 lumens)Color Night Vision, Built-in Spotlight (40 lumens)4 IR LEDs (850 nm)Enhanced Color Night Vision, 4 IR LEDs + 2 white spotlight LEDs (72 lumens)
Motion DetectionRadar + PIR Motion DetectionYes, with 3x faster notificationsYesYes, with motion detection zones
AudioTwo-way audio with built-in mic & speakerImproved two-way audioTwo-way audio with noise & echo cancellationTwo-way audio, built-in speaker (99dB), noise & echo cancellation
SirenIntegrated sirenUser-activated 90 dB mini-sirenNo explicit siren mentionedBuilt-in siren
Power SourceBattery (Removable, Rechargeable)WiredWired (requires outdoor power adapter for outdoor use)Wired
Weather ResistanceIP65IP65IP65IP65
Wi-Fi SupportDual-band 2.4 & 5 GHzNot specified2.4 GHz only2.4 GHz & Wi-Fi 6
Local StorageMicroSD card support (local recording)Supports microSD cards up to 256GBSupports microSD cards up to 256GBMicroSD card support up to 512GB
Cloud StorageCam Plus subscription availableCam Plus subscription availableCam Plus subscription availableCam Plus subscription available
Special FeaturesRemovable battery packs, solar panel compatible, radar + PIR sensors, integrated spotlight & siren3x faster notifications, built-in spotlight & siren, smoke & CO alerts360° pan, 180° tilt, 8x digital zoomWi-Fi 6 support, 8x digital zoom, wide dynamic range (WDR), color night vision
DimensionsNot specifiedNot specified124mm x 60mm x 63mm2in x 2in x 2 3/8in
WeightNot specifiedNot specified11.29 oz (320 g)0.49 lb (222 g)
Price Range (1 Pack)$89.98$29.98$39.98$35.98
What type of microSD card is recommended for Wyze Cam?A high-speed Class 10 microSD card is recommended for Wyze Cam to ensure smooth, reliable local recording of high-definition security footage. Class 10 cards provide fast write speeds and consistent performance for both continuous and event-based recording.
Which microSD card sizes are compatible with Wyze Cam models?Wyze Cam models support microSD cards in the following sizes: 8 GB, 16 GB, 32 GB (FAT32 format), and 64 GB, 128 GB, 256 GB (exFAT format). Cards up to 256 GB have been tested and work reliably with Wyze Battery Cam Pro, Wyze Cam OG, Wyze Cam Outdoor, Wyze Cam Pan v3, and Wyze Cam v4.
Why should I use a Class 10 microSD card with my Wyze Cam?Class 10 microSD cards are recommended for Wyze Cams because they offer the necessary write speeds to handle high-definition video recording without lag or dropped frames. This ensures smooth video capture and reliable performance for both continuous and motion event recording.
How do I format a microSD card for use with Wyze Cam?To format a microSD card for Wyze Cam, insert the card into the camera, open the Wyze app, go to your camera’s live stream, tap Settings > Advanced Settings > Manage MicroSD Card, and select Format. This ensures the card is compatible and ready for recording.
Can I use continuous recording with Wyze Battery Cam Pro?Yes, continuous recording is supported on Wyze Battery Cam Pro, but it will drain the battery quickly. For best results, use continuous recording with the camera connected to a 5V 2A AC power source. For battery conservation, event-only recording is recommended.
How do I view footage recorded on my Wyze Cam’s microSD card?You can view recorded footage directly in the Wyze app by tapping the SD Card button on your camera’s live stream. Alternatively, you can remove the microSD card from the camera and view the raw MP4 files on your computer.
What file formats do Wyze Cams support for microSD cards?Wyze Cams support FAT32 format for 8 GB, 16 GB, and 32 GB microSD cards, and exFAT format for 64 GB, 128 GB, and 256 GB cards. Formatting your card in the correct file system ensures compatibility and optimal performance.
What happens when my Wyze Cam’s microSD card is full?When the microSD card is full, Wyze Cam will automatically overwrite the oldest footage to make space for new recordings. This ensures continuous local recording without manual intervention.
How can I maintain optimal performance of my Wyze Cam’s microSD card?To maintain optimal performance, use a Class 10 or higher microSD card, format the card regularly, keep your Wyze app and camera firmware updated, and connect battery-powered cameras to AC power for continuous recording.
Are there any best practices for using microSD cards with Wyze Cam?Yes, best practices include using a Class 10 or higher microSD card, formatting the card via the Wyze app before use, enabling the appropriate recording mode (continuous or events only), and regularly updating your camera’s firmware for compatibility and security.
What are the recommended sizes for microSD cards to use with Wyze cameras?How do I format the microSD card for my Wyze Cam?Can I use a microSD card larger than 256 GB with my Wyze Cam?
