Wyze Cam Pan v3 for Outdoor Use: Ultimate Weather-Resistant Security
The
Wyze Cam Pan v3 is a versatile indoor/outdoor security camera designed to provide comprehensive coverage with its 360° horizontal pan and 180° vertical tilt. Engineered with an IP65 weather resistance rating, this camera is built to withstand harsh outdoor conditions, making it an excellent choice for monitoring your home exterior, driveway, or backyard.
Key Outdoor Features of Wyze Cam Pan v3
- IP65 Weather Resistance: Durable polycarbonate body and weatherproof design protect the camera from rain, snow, and dust.
- 360° Pan & 180° Tilt: Complete coverage with smooth, fast rotation up to 110° per second to track motion automatically.
- 1080p Full HD Video: Crisp 1920 x 1080 resolution with H.264 encoding ensures clear daytime and nighttime footage.
- Color Night Vision: Equipped with 4 IR LEDs (850 nm) and color night vision to capture vivid images even in low light.
- Two-Way Audio: Built-in speaker and microphone with noise and echo cancellation allow real-time communication.
- Smart Alerts: Receive push notifications on your phone for motion detection and stay connected via the Wyze app.
- Storage Options: Supports up to 256 GB microSD card for local recording and cloud storage options.
- Connectivity: Compatible with 2.4 GHz Wi-Fi networks and integrates with Alexa, Google Assistant, and IFTTT.
For safe and reliable outdoor use, the Wyze Cam Pan v3 requires the Wyze Outdoor Power Adapter (sold separately), ensuring stable power supply in all weather conditions.
Specifications at a Glance
Feature | Specification |
Dimensions | 124mm (H) x 60mm (W) x 63mm (D) |
Weight | 11.29 oz (320 g) |
Lens Material | Glass + Plastic |
CPU | 1.5 GHz |
Video FPS | Day: 20 fps / Night: 15 fps |
Field of View (FOV) | 120° |
Digital Zoom | 8x |
Operating Temperature | -20°C to 50°C (-4°F to 122°F) |
IP Rating | IP65 |
Warranty | 1 Year |
Wyze Cam Pan v3 in snowy outdoor environment, showcasing its weather resistance and durability.
Wyze Cam Pan v3 + 30-Day Cam Plus Bundle: Enhanced Security Package
For those looking to maximize their security setup, the
Wyze Cam Pan v3 + 30-Day Cam Plus Bundle offers the same robust outdoor-ready camera with added value through a 30-day Cam Plus subscription. This bundle includes everything needed for quick installation and extended cloud recording capabilities.
Bundle Highlights
- Includes Wyze Cam Pan v3 with all outdoor features.
- Comes with a 6-foot micro USB cable, power adapter, mounting kit, and quick start guide.
- 30-day Cam Plus subscription for continuous cloud recording and advanced AI detection.
- Same IP65 weather resistance and 1080p video quality.
- Supports two-way audio and smart alerts.
This bundle is perfect for users who want both local and cloud storage options with enhanced motion detection and person alerts.
Why Choose Wyze Cam Pan v3 for Outdoor Surveillance?
The Wyze Cam Pan v3 stands out as a reliable, affordable, and feature-rich outdoor camera option. Its weatherproof design combined with 360° pan and 180° tilt capabilities ensures no blind spots around your property. The camera’s integration with popular smart home assistants like Alexa and Google Assistant adds convenience to your security system.
Whether you want to monitor your front porch, backyard, or garage, the Wyze Cam Pan v3 delivers clear, real-time video and audio communication, making it a top choice for outdoor home security.
Stay connected with two-way audio, perfect for communicating with visitors or deterring intruders.
Additional Outdoor Camera Options from Wyze
While the Wyze Cam Pan v3 is ideal for dynamic, wide-area coverage, Wyze also offers other outdoor camera solutions such as the
Wyze Cam v4 Outdoor Bundle which features 2.5K QHD resolution, enhanced color night vision, and Wi-Fi 6 support for faster connectivity. This bundle includes the outdoor power adapter and a 128GB microSD card for 24/7 local recording.
Conclusion
For outdoor use, the
Wyze Cam Pan v3 is a standout security camera that combines weather resistance, wide-angle coverage, and smart features in a compact, durable design. When paired with the Wyze Outdoor Power Adapter, it becomes a powerful tool to keep your home safe in any weather.
Is the Wyze Cam Pan v3 suitable for outdoor use?
Yes, the Wyze Cam Pan v3 is designed for both indoor and outdoor use. It features an IP65 weather resistance rating, making it durable against rain, snow, and dust, and ideal for monitoring areas like your home exterior, driveway, or backyard.What weather conditions can the Wyze Cam Pan v3 withstand?
The Wyze Cam Pan v3 is built with an IP65 weather resistance rating and can operate in temperatures ranging from -20°C to 50°C (-4°F to 122°F). Its durable polycarbonate body protects it from harsh weather, including rain, snow, and dust.Do I need a special power adapter to use the Wyze Cam Pan v3 outdoors?
Yes, for safe and reliable outdoor use, the Wyze Cam Pan v3 requires the Wyze Outdoor Power Adapter (sold separately). This ensures a stable power supply in all weather conditions.What are the video quality and night vision capabilities of the Wyze Cam Pan v3?
The Wyze Cam Pan v3 records in 1080p Full HD resolution with H.264 encoding for clear footage. It also features color night vision and 4 IR LEDs (850 nm) to capture vivid images even in low-light conditions.Does the Wyze Cam Pan v3 support two-way audio?
Yes, the Wyze Cam Pan v3 is equipped with a built-in speaker and microphone, allowing for real-time two-way audio communication. It also features noise and echo cancellation for clear conversations.What storage options are available for the Wyze Cam Pan v3?
The Wyze Cam Pan v3 supports up to a 256 GB microSD card for local recording and also offers cloud storage options. The Cam Plus subscription provides continuous cloud recording and advanced AI detection.What is included in the Wyze Cam Pan v3 + 30-Day Cam Plus Bundle?
The bundle includes the Wyze Cam Pan v3 camera, a 6-foot micro USB cable, power adapter, mounting kit, quick start guide, and a 30-day Cam Plus subscription for enhanced cloud recording and AI detection.Is the Wyze Cam Pan v3 compatible with smart home systems?
Yes, the Wyze Cam Pan v3 integrates with Alexa, Google Assistant, and IFTTT, allowing you to control and monitor your camera using popular smart home platforms.What is the field of view and pan/tilt range of the Wyze Cam Pan v3?
The Wyze Cam Pan v3 offers a 120° field of view, 360° horizontal pan, and 180° vertical tilt, providing comprehensive coverage and eliminating blind spots around your property.Are there other outdoor camera options available from Wyze?
Yes, Wyze also offers the Wyze Cam v4 Outdoor Bundle, which features 2.5K QHD resolution, enhanced color night vision, Wi-Fi 6 support, an outdoor power adapter, and a 128GB microSD card for 24/7 local recording.What is the warranty period for the Wyze Cam Pan v3?
The Wyze Cam Pan v3 comes with a 1-year warranty, ensuring peace of mind for your purchase.
