Wyze Cam OG Telephoto: The Ultimate Outdoor Telephoto Security Camera
The
Wyze Cam OG Telephoto is the 2023 generation of Wyze’s popular camera line, now enhanced with a powerful 3x telephoto lens perfect for outdoor use. Designed for both indoor and outdoor environments, this camera offers crystal-clear 1080p video with a CMOS-Starlight sensor that excels in low-light conditions.
Key Features for Outdoor Use
- 3x Telephoto Lens: Narrow field of view (27° diagonal) lets you zoom in on distant objects with sharp clarity.
- Weather Resistant: Rated IP65, it withstands rain, snow, and dust, making it ideal for outdoor security.
- Improved Live Streaming: Experience 3x faster notifications and quicker live video streaming to stay instantly informed.
- Night Vision: Equipped with 4 IR LEDs (850nm) for clear black-and-white night vision.
- Two-Way Audio: Built-in speaker and microphone with noise and echo cancellation for seamless communication.
- Local Storage: Supports up to 256 GB microSD card for continuous local recording.
- Flexible Mounting: Can be mounted on walls, ceilings, or placed on a stand for versatile installation.
- Operating Temperature: Works reliably from -4°F to 131°F (-20°C to 55°C).
This camera is perfect for users who want to monitor distant areas like driveways, backyards, or RVs with enhanced zoom capabilities while ensuring durability in harsh weather.
Wyze Cam OG: Reliable Outdoor Spotlight Camera
The
Wyze Cam OG is a versatile indoor/outdoor camera that combines quick live streaming with a built-in 40-lumen spotlight to illuminate your property at night. It’s a great choice for those who want a balance of wide coverage and spotlight security.
Outdoor-Ready Features
- 1080p Full HD Video: Clear and smooth video at 20 FPS during the day and 15 FPS at night.
- Built-in Spotlight: 40 lumens of light brighten dark areas, enhancing night vision and deterring intruders.
- IP65 Weather Resistance: Durable against rain and dust, suitable for outdoor mounting.
- Fast Notifications: 50% faster live streaming and alerts compared to previous Wyze models.
- Two-Way Audio: Enhanced microphone and speaker for clear communication.
- Custom Detection Zones: Focus on specific areas to reduce false alerts.
- Siren: 90-decibel user-activated siren for added security.
- Local Storage: Supports up to 256 GB microSD card.
Ideal for homeowners looking for a dependable outdoor camera with spotlight functionality to secure porches, patios, or entryways.
Wyze Cam Pan v3: 360° Outdoor Surveillance with Pan & Tilt
For comprehensive outdoor coverage, the
Wyze Cam Pan v3 offers a 360° horizontal and 180° vertical field of view with smooth pan and tilt capabilities. This camera is fully IP65 weather resistant, making it a robust choice for outdoor security.
Outdoor Use Highlights
- Full Pan & Tilt: Covers every angle with 360° horizontal rotation and 180° vertical tilt.
- 1080p HD Video: Crisp video quality with 20 FPS daytime and 15 FPS nighttime recording.
- Night Vision: 4 IR LEDs provide clear night footage.
- Weatherproof Design: IP65 rating ensures protection against rain and dust.
- Two-Way Audio: Built-in speaker and microphone with noise and echo cancellation.
- Requires Outdoor Power Adapter: For safe outdoor use, an additional power adapter is needed (sold separately).
This camera is perfect for users who want to monitor large outdoor areas like yards or garages with flexible viewing angles.
Wyze Cam Pan v3 weather resistant outdoor camera in snowy environment
Why Choose Wyze Cameras for Outdoor Use?
Wyze outdoor cameras are designed with durability and smart features to keep your property safe in all conditions. With IP65 weather resistance, they handle rain, snow, and dust effortlessly. Their integration with Alexa, Google Assistant, and IFTTT allows seamless smart home connectivity. Whether you need telephoto zoom, wide-angle pan-tilt, or spotlight illumination, Wyze offers a camera tailored to your outdoor security needs.
"Wyze Cam OG Telephoto brings the power of zoom to your outdoor security, while the Wyze Cam OG and Pan v3 provide versatile coverage and illumination for any environment."
Summary of Outdoor Wyze Cameras
Model | Resolution | Special Feature | Weather Resistance | Night Vision | Audio | Storage Support |
Wyze Cam OG Telephoto | 1080p | 3x Telephoto Lens | IP65 | 4 IR LEDs (850nm) | 2-way, noise cancel | Up to 256 GB microSD |
Wyze Cam OG | 1080p | Built-in 40-lumen spotlight | IP65 | 4 IR LEDs (850nm) | 2-way, noise cancel | Up to 256 GB microSD |
Wyze Cam Pan v3 | 1080p | 360° Pan & 180° Tilt | IP65 | 4 IR LEDs (850nm) | 2-way, noise cancel | Up to 256 GB microSD |
Enhance Your Outdoor Security with Wyze
Choosing the right Wyze camera depends on your specific outdoor needs. For detailed zoomed-in views, the
Wyze Cam OG Telephoto is unmatched. If you want a spotlight to brighten your property, the
Wyze Cam OG is ideal. For full panoramic coverage, the
Wyze Cam Pan v3 offers flexible and wide surveillance.
Invest in Wyze outdoor cameras to enjoy reliable, weatherproof security with smart features that keep you connected and protected.
What makes the Wyze Cam OG Telephoto ideal for outdoor security?
The Wyze Cam OG Telephoto is designed for outdoor use with a 3x telephoto lens, providing a narrow 27° field of view for zooming in on distant objects. It features IP65 weather resistance, 1080p video quality, night vision, and operates reliably in temperatures from -4°F to 131°F, making it perfect for monitoring driveways, backyards, or RVs.Is the Wyze Cam OG Telephoto weatherproof?
Yes, the Wyze Cam OG Telephoto is rated IP65, meaning it is weather resistant and can withstand rain, snow, and dust, making it suitable for both indoor and outdoor environments.Does the Wyze Cam OG Telephoto have night vision?
Yes, the Wyze Cam OG Telephoto is equipped with 4 IR LEDs (850nm) that provide clear black-and-white night vision for effective monitoring in low-light conditions.What storage options are available for Wyze outdoor cameras?
All Wyze outdoor cameras, including the Cam OG Telephoto, Cam OG, and Cam Pan v3, support local storage with microSD cards up to 256 GB for continuous recording.What is the difference between Wyze Cam OG and Wyze Cam OG Telephoto?
The Wyze Cam OG Telephoto features a 3x telephoto lens for zooming in on distant objects, while the Wyze Cam OG has a built-in 40-lumen spotlight for illuminating dark areas. Both offer 1080p video, IP65 weather resistance, night vision, and two-way audio.Does the Wyze Cam OG have a built-in spotlight?
Yes, the Wyze Cam OG includes a built-in 40-lumen spotlight that brightens dark areas, enhances night vision, and helps deter intruders.Can Wyze outdoor cameras be used with smart home systems?
Yes, Wyze outdoor cameras integrate with Alexa, Google Assistant, and IFTTT, allowing for seamless smart home connectivity and control.What is the Wyze Cam Pan v3 and how does it enhance outdoor surveillance?
The Wyze Cam Pan v3 is an outdoor camera with 360° horizontal rotation and 180° vertical tilt, providing full panoramic coverage. It features 1080p HD video, night vision, IP65 weather resistance, and requires an outdoor power adapter for safe outdoor use.Do Wyze outdoor cameras support two-way audio?
Yes, all Wyze outdoor cameras come with built-in speakers and microphones featuring noise and echo cancellation, allowing for clear two-way communication.What areas are best suited for each Wyze outdoor camera model?
The Wyze Cam OG Telephoto is ideal for monitoring distant areas like driveways or backyards. The Wyze Cam OG is perfect for porches, patios, or entryways needing spotlight illumination. The Wyze Cam Pan v3 is best for large outdoor spaces like yards or garages that require flexible, wide-angle surveillance.What is the operating temperature range for Wyze outdoor cameras?
Wyze outdoor cameras, including the Cam OG Telephoto, are designed to operate reliably in temperatures ranging from -4°F to 131°F (-20°C to 55°C).Do I need an additional power adapter for the Wyze Cam Pan v3 outdoors?
Yes, for safe outdoor use, the Wyze Cam Pan v3 requires an outdoor power adapter, which is sold separately.How fast are notifications and live streaming on Wyze outdoor cameras?
Wyze outdoor cameras offer improved live streaming and notifications, with the Cam OG Telephoto providing 3x faster notifications and the Cam OG delivering 50% faster alerts compared to previous models.
