Wyze Cam OG Outdoor Weatherproof Security Camera Systems
When it comes to securing your home or business with reliable, weatherproof outdoor cameras, the Wyze Cam OG series and its related models offer an unbeatable combination of advanced features, durability, and affordability. Whether you want crystal-clear video, smart alerts, or versatile mounting options, Wyze has you covered with multiple outdoor-ready cameras designed to fit your security needs.
Wyze Cam OG: The Original Outdoor Weatherproof Camera
The Wyze Cam OG is a robust, weather-resistant security camera designed for both indoor and outdoor use. It features an IP65 rating, ensuring it withstands rain, snow, and dust, making it perfect for year-round outdoor surveillance.
Key Features:
  • 1080p Full HD Video with a 120° field of view for wide coverage.
  • CMOS-Starlight Sensor for clear images even in low light.
  • Built-in 40 Lumen Spotlight and a 90-decibel siren to deter intruders.
  • Upgraded Two-Way Audio with noise and echo cancellation for clear communication.
  • Faster Live Streaming and 3X quicker notifications compared to previous models.
  • Supports up to 256 GB microSD local storage and works with 2.4 GHz Wi-Fi.
  • Operates in temperatures from -20°C to 55°C (-4°F to 131°F).
This camera is ideal for users who want a straightforward, reliable outdoor camera with essential smart features and weatherproof durability. Wyze Cam Pan v3 in snowy outdoor setting Wyze Cam Pan v3 shown outdoors in snowy weather, demonstrating weather resistance and rugged design.
Wyze Cam OG Telephoto: Zoom In on Details
For those who need more precise monitoring, the Wyze Cam OG Telephoto offers all the benefits of the OG model but adds a powerful 3x telephoto lens. This allows you to zoom in on distant objects without losing image quality.
Highlights:
  • 3x Telephoto Lens with a narrower field of view (27° diagonal) for focused surveillance.
  • Same 1080p HD resolution and CMOS-Starlight Sensor for excellent day and night clarity.
  • Enhanced two-way audio and built-in spotlight.
  • Weatherproof IP65 rating for reliable outdoor use.
  • Supports local microSD storage up to 256 GB.
  • Compatible with Alexa, Google Assistant, and IFTTT for smart home integration.
This camera is perfect for monitoring specific areas like driveways, gates, or backyards where zoomed-in detail is critical.
Wyze Cam Pan v3: 360° Pan and Tilt Outdoor Security
If you want full coverage without blind spots, the Wyze Cam Pan v3 is a standout choice. This camera offers 360° horizontal rotation and 180° vertical tilt, allowing you to remotely control the camera’s view to cover every angle.
Features at a Glance:
  • IP65 Weather Resistance for dependable outdoor use (requires Wyze Outdoor Power Adapter sold separately).
  • 1080p HD Video with 120° field of view.
  • 4 IR LEDs for Night Vision and 8x digital zoom.
  • Built-in Speaker and Microphone with two-way audio and noise cancellation.
  • Fast rotation speed up to 110° per second for quick repositioning.
  • Supports up to 256 GB microSD card storage.
  • Integrates with Alexa, Google Assistant, and IFTTT.
The Pan v3 is ideal for users who want a versatile camera that can actively scan large outdoor areas like yards, patios, or parking lots.
Wyze Cam v4: Advanced Outdoor Security with Spotlight and 2.5K Resolution
For those seeking higher resolution and enhanced night vision, the Wyze Cam v4 is a premium outdoor camera with a motion-activated spotlight and 2.5K QHD video quality.
Why Choose Wyze Cam v4?
  • 2.5K QHD Video (2560x1440) for crystal-clear images.
  • Enhanced Color Night Vision with 4 IR LEDs plus 2 white spotlight LEDs (72 lumens).
  • Motion-Activated Spotlight to illuminate and deter intruders.
  • Wi-Fi 6 Support for faster, more reliable connectivity.
  • Built-in 99dB Waterproof Speaker and Siren for loud alerts.
  • Multiple mounting options including magnetic adhesive mounts.
  • IP65 weather resistance for all-season outdoor use.
  • Supports local microSD storage up to 512 GB and cloud storage options.
  • Compatible with Alexa, Google Assistant, and IFTTT.
This camera is perfect for users who want the latest technology in outdoor security with superior video quality and smart lighting features.
Wyze Cam Floodlight v2: Illuminate and Secure Your Property
For maximum visibility and security, the Wyze Cam Floodlight v2 combines a powerful 2800 lumen floodlight with a 2K security camera.
Standout Features:
  • 2800 Lumens of Dimmable LED Light with 5000K color temperature.
  • 2K Video Resolution (2304 x 1296) with 160° wide-angle view.
  • Color Night Vision for clear images in the dark.
  • AI-Powered Light Control and dusk-to-dawn automation.
  • Built-in 105dB siren and two-way audio.
  • Hardwired power supply for continuous operation.
  • IP65 weather resistance for outdoor durability.
  • Integrates seamlessly with Alexa, Google Assistant, and IFTTT.
Ideal for front porches, driveways, and large outdoor areas where bright lighting and high-quality video are essential. Wyze Cam Floodlight v2 lifestyle image showing driveway security Wyze Cam Floodlight v2 providing bright, motion-activated lighting and security coverage.
Accessories: Wyze Cam OG Stack Kit
Enhance your Wyze Cam OG or OG Telephoto setup with the Wyze Cam OG Stack Kit. This accessory allows you to stack and power two cameras together neatly, saving space and simplifying installation.
Kit Includes:
  • Stack Mount for vertical camera stacking.
  • Dual Micro USB Power Cable (6 ft).
  • 5V/1.5A Indoor Power Adapter.
  • Quick Start Guide.
Perfect for users who want to monitor multiple angles or areas with a compact, organized setup.
Why Choose Wyze Outdoor Cameras?
Wyze outdoor cameras combine affordability, advanced features, and rugged weatherproof designs to keep your property safe in any environment. With options ranging from wide-angle pan-tilt cameras to telephoto zoom lenses and floodlight integration, Wyze offers a comprehensive security solution tailored to your needs.
Summary of Wyze Outdoor Security Cameras
ModelResolutionField of ViewWeatherproofSpecial Features
Wyze Cam OG1080p HD120°IP65Built-in spotlight, siren, fast live stream
Wyze Cam OG Telephoto1080p HD27° (telephoto zoom)IP653x telephoto lens
Wyze Cam Pan v31080p HD360° pan, 180° tiltIP65360° coverage, 8x digital zoom
Wyze Cam v42.5K QHD115.8° DFOVIP65Color night vision, spotlight, Wi-Fi 6
Wyze Cam Floodlight v22K (2304x1296)160°IP652800 lumens floodlight, AI light control
Invest in Wyze outdoor cameras today to enjoy peace of mind with smart, weatherproof security solutions that keep your home safe day and night.
FeatureWyze Cam OGWyze Cam v4Wyze Cam Pan v3Wyze Cam OG TelephotoWyze Cam Floodlight v2
Resolution1080p (1920 x 1080)2.5K QHD (2560 x 1440)1080p (1920 x 1080)1080p (1920 x 1080)2K (2304 x 1296)
Field of View (FOV)120° diagonal115.9° (D) x 98.5° (H) x 53.1° (V)360° horizontal, 180° vertical27° (D) / 23.6° (H) / 13.6° (V)160° diagonal
Night VisionColor Night VisionEnhanced Color Night VisionIR LEDs (4x 850 nm)IR LEDs (4x 850 nm)Color Night Vision
SpotlightBuilt-in 40-lumen spotlightMotion-activated spotlightNoNoYes, integrated
Siren90 dB user-activated siren99 dB sirenNoNo105 dB siren
Two-Way AudioUpgraded 2-way audioEnhanced two-way talkBuilt-in speaker & mic; 2-way audioBuilt-in speaker & mic; 2-way audioBuilt-in speaker & mic; 2-way audio
Weather ResistanceIP65IP65IP65IP65IP65
Connectivity2.4 GHz Wi-Fi2.4 GHz Wi-Fi, Wi-Fi 6 support2.4 GHz Wi-Fi (no 5 GHz)2.4 GHz Wi-Fi2.4 GHz Wi-Fi
Local Storage SupportmicroSD up to 256GBmicroSD up to 256GB (512GB in hidden variant)microSD up to 256GBmicroSD up to 256GBmicroSD up to 256GB
Continuous RecordingNo24/7 local recordingNoNo24/7 local recording
Motion DetectionYes, 3x faster notificationsYes, advanced with zonesYesYesYes
Audio FeaturesNoise & echo cancellationAAC, noise & echo cancellationNoise & echo cancellationNoise & echo cancellationNoise & echo cancellation
Dimensions (approx.)Not specified2in x 2in x 2 3/8in124mm x 60mm x 63mm48mm x 48mm x 48mm9.5in x 7.7in x 7.0in
WeightNot specified0.49 lb (222 g)11.29 oz (320 g)4.1 oz (116 g)2.76 lbs (1.25 kg)
Mounting OptionsStand, wall mountStand, wall mount, ceiling mount, magnetic mountScrew 1/4" - 20Stand, wall mount, ceiling mountWall, ceiling
Power SourceWiredWiredWiredWiredHardwired
Operating TemperatureNot specified-4°F to 122°F (-20°C to 50°C)-20°C to 50°C (-4°F to 122°F)-4°F to 131°F (-20°C to 55°C)-4°F to 140°F (-20°C to 60°C)
Smart Assistant IntegrationAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTT
Price (1 Pack)$29.98$35.98$39.98$25.98$89.98
What makes Wyze Cam OG a good outdoor security camera?Wyze Cam OG is designed for both indoor and outdoor use, featuring an IP65 weather-resistant rating to withstand rain, snow, and dust. It offers 1080p Full HD video, a 120° field of view, a CMOS-Starlight Sensor for low-light clarity, a built-in 40 lumen spotlight, a 90-decibel siren, upgraded two-way audio, and supports up to 256 GB microSD local storage. These features make it a reliable and affordable choice for year-round outdoor surveillance.
How is the Wyze Cam OG Telephoto different from the standard Wyze Cam OG?The Wyze Cam OG Telephoto includes all the features of the standard OG model but adds a powerful 3x telephoto lens with a 27° diagonal field of view. This allows for focused surveillance and zooming in on distant objects without losing image quality, making it ideal for monitoring specific areas like driveways or gates.
What are the key features of the Wyze Cam Pan v3 outdoor camera?Wyze Cam Pan v3 offers 360° horizontal rotation and 180° vertical tilt for complete coverage without blind spots. It features 1080p HD video, 120° field of view, 4 IR LEDs for night vision, 8x digital zoom, two-way audio with noise cancellation, and supports up to 256 GB microSD card storage. It is IP65 weather-resistant (with the Wyze Outdoor Power Adapter) and integrates with Alexa, Google Assistant, and IFTTT.
What advantages does the Wyze Cam v4 offer for outdoor security?Wyze Cam v4 provides 2.5K QHD video resolution for crystal-clear images, enhanced color night vision with 4 IR LEDs and 2 white spotlight LEDs, a motion-activated spotlight, Wi-Fi 6 support for faster connectivity, a built-in 99dB waterproof speaker and siren, multiple mounting options, IP65 weather resistance, and supports up to 512 GB microSD storage. It is compatible with Alexa, Google Assistant, and IFTTT.
How does the Wyze Cam Floodlight v2 enhance outdoor security?Wyze Cam Floodlight v2 combines a powerful 2800 lumen dimmable LED floodlight with a 2K security camera. It features a 160° wide-angle view, color night vision, AI-powered light control, dusk-to-dawn automation, a built-in 105dB siren, two-way audio, hardwired power supply, and IP65 weather resistance. It integrates with Alexa, Google Assistant, and IFTTT, making it ideal for illuminating and securing large outdoor areas.
What is the Wyze Cam OG Stack Kit and how does it work?The Wyze Cam OG Stack Kit is an accessory that allows you to stack and power two Wyze Cam OG or OG Telephoto cameras together for a compact and organized setup. The kit includes a stack mount, dual micro USB power cable, 5V/1.5A indoor power adapter, and a quick start guide, making it easy to monitor multiple angles or areas.
Are Wyze outdoor cameras weatherproof?Yes, all Wyze outdoor cameras mentioned, including Wyze Cam OG, OG Telephoto, Pan v3, v4, and Floodlight v2, have an IP65 weather resistance rating. This ensures they are protected against rain, snow, and dust, making them suitable for year-round outdoor use.
Do Wyze outdoor cameras support local storage?Yes, Wyze outdoor cameras support local microSD card storage. Wyze Cam OG, OG Telephoto, and Pan v3 support up to 256 GB microSD cards, while Wyze Cam v4 supports up to 512 GB. This allows for continuous recording and easy access to footage without relying solely on cloud storage.
Can Wyze outdoor cameras be integrated with smart home systems?Yes, Wyze outdoor cameras are compatible with popular smart home platforms including Alexa, Google Assistant, and IFTTT. This allows for voice control, automation, and integration with other smart devices in your home.
What is the video resolution of Wyze outdoor security cameras?Wyze outdoor cameras offer various video resolutions: Wyze Cam OG, OG Telephoto, and Pan v3 provide 1080p HD video; Wyze Cam v4 offers 2.5K QHD (2560x1440) resolution; and Wyze Cam Floodlight v2 delivers 2K (2304x1296) resolution for clear and detailed footage.
Why should I choose Wyze outdoor cameras for my home or business security?Wyze outdoor cameras combine advanced features, affordability, and rugged weatherproof designs. With options for wide-angle, pan-tilt, telephoto zoom, and floodlight integration, Wyze offers comprehensive security solutions tailored to various needs, ensuring reliable protection for your property in any environment.
What are the key features of the Wyze Cam OG?Can you tell me more about the Wyze Cam Pan v3 and its capabilities?Are there any ongoing sales or discounts for Wyze cameras?
