Wyze Cam Pan V1 & V2 Replacement Mounting Kit Options
Wyze Cam Pan Replacement Mounting Kit for V1 and V2
If you own a Wyze Cam Pan V1 or V2 and are looking for a reliable replacement mounting kit, this guide will help you understand your options and how to enhance your camera setup. While Wyze does not currently offer a dedicated replacement mounting kit specifically labeled for V1 and V2, there are compatible accessories and bundles that can improve your camera’s installation and functionality.
Understanding Wyze Cam Pan Models and Mounting Options
Wyze Cam Pan V1 and V2 Overview
Wyze Cam Pan V1 and V2 are popular pan-and-tilt security cameras designed to cover wide areas with 360° horizontal and 93° vertical rotation. These cameras are ideal for indoor surveillance, offering motion tracking and two-way audio.
  • V1 and V2 Mounting: Both versions come with a standard mounting bracket that can be attached to walls or ceilings using screws. The mounting kit typically includes screws, anchors, and a bracket designed to hold the camera securely.
Replacement Mounting Kit Considerations
  • Compatibility: Replacement mounting kits for V1 and V2 are generally compatible with each other due to similar form factors.
  • Third-Party Options: Some third-party mounting kits offer adjustable arms, magnetic mounts, or adhesive options for more flexible placement.
  • DIY Solutions: Using universal camera mounts or adjustable brackets can also serve as replacements if the original kit is lost or damaged.
Recommended Wyze Products to Enhance Your Cam Pan Setup
While a direct replacement mounting kit for V1 and V2 is not listed, Wyze offers newer camera models and accessories that can complement or upgrade your current setup.
Wyze Cam Pan v3 + Lamp Socket v2 Bundle
This bundle is a smart solution for powering and mounting your Wyze Cam Pan v3, which shares similar mounting compatibility with earlier Pan models.
  • Flexible Power Source: The Lamp Socket v2 allows you to power your camera directly from an outdoor light fixture, eliminating the need for an outlet or visible wires.
  • Smart Lighting Integration: Control your outdoor lights via the Wyze app, set motion-activated lighting, and schedule automation.
  • Easy Installation: The lamp socket screws into standard light bulb sockets, making installation as simple as changing a bulb.
  • Compatibility: Works with Wyze Cam Pan v3, v4, OG, and others.
This bundle is perfect if you want to upgrade your Pan camera’s mounting and power options with minimal hassle.
Outdoor Security Camera Mounted on Porch Alt text: Wyze Cam Pan mounted on a porch light fixture with smart lamp socket
Wyze Cam OG – Versatile Mounting and Weather Resistance
If you are considering an upgrade or alternative to the Pan V1 or V2, the Wyze Cam OG offers:
  • Indoor/Outdoor Use: IP65 weather resistance rating for reliable outdoor mounting.
  • Built-in Stand and Wall Mount: Comes with a versatile mounting system including a built-in stand and wall mount.
  • Spotlight and Two-Way Audio: Enhanced security features with a built-in spotlight and clear audio.
  • Wide Compatibility: Can be mounted using standard camera mounts or adhesive solutions.
This camera’s mounting flexibility makes it a great option if you want a robust replacement or companion camera.
Tips for Mounting Your Wyze Cam Pan V1 and V2
  • Use Original Hardware: If possible, retain the original screws and anchors for secure installation.
  • Wall or Ceiling Mount: Choose a location that maximizes the camera’s pan and tilt range.
  • Avoid Obstructions: Ensure the camera has a clear line of sight for motion tracking.
  • Consider Power Access: Plan your mounting location near a power source or use accessories like the Lamp Socket v2 for outdoor setups.
Summary
While Wyze does not currently offer a dedicated replacement mounting kit specifically for the Cam Pan V1 and V2, you can:
  • Use original or third-party mounting brackets compatible with these models.
  • Upgrade to the Wyze Cam Pan v3 and use the Pan v3 + Lamp Socket v2 Bundle for smarter, wire-free mounting.
  • Consider the Wyze Cam OG for versatile mounting options and outdoor durability.
These options ensure your Wyze Cam Pan remains securely mounted and fully functional, enhancing your home security setup.
FeaturePan v3 + Lamp Socket v2 BundleBird Feeder Plug-in Cam v4 BundleWyze Cam OG
Price$53.96$89.98$29.98 (1 Pack)
Product ComponentsWyze Cam Pan v3 + Lamp Socket v2Wyze Bird Feeder, Wyze Cam v4, Wyze Outdoor Power AdapterWyze Cam OG camera only
Camera TypePan-and-tilt security cameraFixed camera integrated with bird feederFixed security camera
Camera ResolutionNot specified (Pan v3 standard is 1080p)Wyze Cam v4 (1080p)1920 x 1080 (1080p)
Field of ViewPan v3: 360° horizontal pan, 93° vertical tiltWyze Cam v4: Not specified121.4° diagonal, 102.3° horizontal, 54.1° vertical
Night VisionColor night visionColor night vision4 IR LEDs (850nm)
AudioTwo-way audioTwo-way audioBuilt-in speaker & microphone; noise & echo cancellation
Power SourcePowered via Lamp Socket v2 (no outlet needed)Wyze Outdoor Power AdapterPlug-in (5V/1A adapter)
Weather ResistanceCompatible with outdoor use (Pan v3)Bird Feeder: Weather-resistant polycarbonateIP65 rated (indoor/outdoor)
Special FeaturesMotion-activated lights, dusk to dawn automationMacro Lens Adapter for close-up bird viewing, multiple mounting optionsBuilt-in spotlight (40 lumens), 3X faster notifications
CompatibilityLamp Socket v2 works with Pan v3, Cam v3/v3 Pro/v4, OGCompatible with Wyze Battery Cam Pro, Cam v3/v4, Cam OutdoorStandalone camera
Bundle PurposeSmart exterior lighting and security cameraBirdwatching with live video and recordingAffordable plug-in security camera
Return Policy30-day hassle-free returns30-day hassle-free returnsNot specified
Is there an official Wyze Cam Pan V1 or V2 replacement mounting kit?Wyze does not currently offer a dedicated replacement mounting kit specifically labeled for the Cam Pan V1 or V2. However, compatible third-party mounting kits and universal camera mounts can be used as alternatives.
Are Wyze Cam Pan V1 and V2 mounting kits interchangeable?Yes, the Wyze Cam Pan V1 and V2 use similar form factors, making their mounting kits generally compatible with each other.
What are the best third-party mounting options for Wyze Cam Pan V1 and V2?Third-party mounting kits for Wyze Cam Pan V1 and V2 include adjustable arms, magnetic mounts, and adhesive options, offering flexible placement and easy installation.
Can I use universal camera mounts for my Wyze Cam Pan V1 or V2?Yes, universal camera mounts or adjustable brackets can serve as effective replacements if the original Wyze mounting kit is lost or damaged.
What is the Wyze Cam Pan v3 + Lamp Socket v2 Bundle and is it compatible with older Pan models?The Wyze Cam Pan v3 + Lamp Socket v2 Bundle allows you to power and mount your camera using a standard light fixture. While designed for the Pan v3, it shares similar mounting compatibility with earlier Pan models, making it a smart upgrade option.
How can I mount my Wyze Cam Pan V1 or V2 securely?For secure mounting, use the original screws and anchors if available, choose a wall or ceiling location that maximizes the camera’s pan and tilt range, and ensure a clear line of sight for motion tracking. Consider power access or use accessories like the Lamp Socket v2 for outdoor setups.
What are the benefits of upgrading to the Wyze Cam OG for mounting?The Wyze Cam OG offers versatile mounting options with a built-in stand and wall mount, IP65 weather resistance for outdoor use, and compatibility with standard camera mounts or adhesive solutions, making it a robust alternative to the Pan V1 or V2.
Can I use the Wyze Cam Pan v3 mounting accessories with V1 or V2 models?Many mounting accessories designed for the Wyze Cam Pan v3 are compatible with V1 and V2 models due to their similar mounting systems, but always check product specifications for compatibility.
What should I consider when choosing a mounting location for my Wyze Cam Pan?Choose a location that provides a clear line of sight, maximizes the camera’s pan and tilt range, and is near a power source. For outdoor setups, consider using accessories like the Lamp Socket v2 for convenient power and mounting.
Are there any third-party mounting kits that you recommend for the Wyze Cam Pan V1 and V2?Can you explain how to install the Wyze Cam Pan using the original mounting hardware?Do you have any deals, ongoing sales, discounts, or promotions for Wyze products?
