Wyze Battery Cam Pro vs Solar Panel Bundle: Full Comparison Guide
Wyze Battery Cam Pro vs Wyze Battery Cam Pro + Solar Panel: A Detailed Comparison
When choosing a reliable wireless security camera, the Wyze Battery Cam Pro and the Wyze Battery Cam Pro + Solar Panel bundle stand out as top contenders. Both offer advanced features, excellent video quality, and weatherproof designs, but they cater to slightly different needs. This comparison will help you understand their key specifications and benefits to make an informed decision.
Wyze Battery Cam Pro: Powerful Wireless Security Camera
Stunning 2.5K HDR Video Quality
The Wyze Battery Cam Pro delivers crystal-clear 2.5K HDR video resolution (2560 x 1440), ensuring sharp and vibrant footage day or night. Its CMOS-Starlight sensor combined with an F1.6 lens captures more light, enhancing image clarity even in low-light conditions.
Advanced Motion Detection and Alerts
Equipped with Radar + PIR motion detection, this camera accurately senses movement and reduces false alarms. The integrated spotlight and 100 dB siren provide active deterrence against intruders.
Long-Lasting Battery and Weatherproof Design
Powered by a removable, rechargeable 6200mAh battery, the camera can last up to 6 months on a single charge. Its IP65 weather resistance rating means it withstands rain, dust, and extreme temperatures from -20°C to 50°C (-4°F to 122°F), making it ideal for outdoor use.
Connectivity and Smart Home Integration
Supports dual-band WiFi (2.4 GHz & 5 GHz) and Bluetooth BLE 5.1 for seamless connectivity. It integrates smoothly with Alexa, Google Assistant, and IFTTT, allowing voice control and automation.
Additional Features
  • Two-way audio with built-in microphone and speaker
  • Local storage support up to 256 GB microSD cards
  • Wide field of view: 134° diagonal, 108° horizontal, 56° vertical
  • Compact and lightweight design (2.5 x 1.8 x 3.5 inches, 0.94 lbs)
  • Includes wall mount for easy installation
Wyze Battery Cam Pro + Solar Panel: Extended Power for Continuous Security
All Features of Wyze Battery Cam Pro
This bundle includes the same powerful Wyze Battery Cam Pro camera with all the features mentioned above: 2.5K HDR video, radar + PIR motion detection, integrated spotlight, siren, and smart home compatibility.
Solar Panel for Unlimited Power
The key difference is the included Wyze Battery Cam Solar Panel accessory, designed to extend the camera’s battery life by harnessing solar energy. This IP65-rated solar panel is weather resistant and mounts easily with a 360° adjustable bracket.
Solar Panel Specifications
  • Power rating: 2.5W, 5V DC
  • Dimensions: 173 mm x 120 mm x 17 mm
  • Includes a 13-foot USB-C power cable for flexible installation
  • Compatible with Wyze Battery Cam Pro and Wyze Cam Outdoor v1/v2
Benefits of the Solar Panel
  • Continuous charging from sunlight reduces the need for manual battery recharging
  • Ideal for remote or hard-to-reach locations where frequent charging is inconvenient
  • Environmentally friendly, using renewable energy to keep your camera powered
Which Should You Choose?
FeatureWyze Battery Cam ProWyze Battery Cam Pro + Solar Panel
Video Resolution2.5K HDR (2560 x 1440)2.5K HDR (2560 x 1440)
Motion DetectionRadar + PIRRadar + PIR
Battery LifeUp to 6 monthsExtended with solar charging
Power SourceRechargeable battery packsRechargeable battery + solar panel
Weather ResistanceIP65IP65 (camera and solar panel)
Connectivity2.4 & 5 GHz WiFi, BLE 5.12.4 & 5 GHz WiFi, BLE 5.1
Smart Home IntegrationAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTT
Ideal UseGeneral outdoor securityLong-term outdoor monitoring without hassle
If you want a straightforward, high-quality wireless camera with excellent battery life, the Wyze Battery Cam Pro is a great choice. However, if you prefer a more hands-off approach to power management and want to ensure your camera stays charged indefinitely, the Wyze Battery Cam Pro + Solar Panel bundle is the perfect solution.
Enhance Your Setup with Accessories
To maximize your Wyze Battery Cam Pro experience, consider these accessories:
Extend your camera’s battery life with this weatherproof solar panel. It’s easy to mount and comes with a long USB-C cable for flexible placement.
Wyze Removable Battery Pack
Keep a spare 6200mAh rechargeable battery on hand for quick swaps, ensuring your camera never goes offline during charging.
Wyze Battery Charging Dock
Charge two batteries simultaneously with this compact dock, reducing downtime and keeping your security system ready.
Pro Tip: Combining the Wyze Battery Cam Pro with the solar panel accessory is ideal for locations with ample sunlight, such as porches, gardens, or remote cabins, where frequent battery charging is inconvenient.
Summary
Both the Wyze Battery Cam Pro and the Wyze Battery Cam Pro + Solar Panel offer exceptional video quality, smart features, and durable outdoor performance. The solar panel bundle adds the convenience of continuous solar charging, making it a smart investment for long-term, maintenance-free security. Choose the model that best fits your lifestyle and security needs to enjoy peace of mind with Wyze’s trusted technology.
Outdoor Security Camera in Use Wyze Battery Cam Pro providing reliable outdoor security Solar Panel Mounted Outdoors Wyze Solar Panel extending camera battery life with solar power Home Security Setup Smart home integration with Wyze Battery Cam Pro
FeatureWyze Battery Cam ProWyze Battery Cam Pro + Solar PanelWyze Battery Cam Solar Panel
TypeCameraCamera + Accessory BundleAccessory
Video Resolution2.5K HDR2.5K HDRN/A
PowerRemovable, Rechargeable Battery PacksRemovable, Rechargeable Battery Packs + Solar PanelSolar Panel (extends battery life)
WirelessWire-Free, No Hub RequiredWire-Free, No Hub RequiredN/A
Motion DetectionRadar + PIR Motion DetectionRadar + PIR Motion DetectionN/A
Integrated Spotlight & SirenYesYesN/A
WeatherproofIP65IP65IP65
WiFi Support2.4 & 5 GHz2.4 & 5 GHzN/A
Local RecordingYes (with microSD card)Yes (with microSD card)N/A
Battery Life ExtensionRemovable battery packsSolar Panel extends battery lifeExtends battery life for Wyze Battery Cam Pro and Wyze Cam Outdoor v1/v2
Solar Power RatingN/AIncluded (2.5W, 5VDC)2.5W, 5VDC
Solar Panel DimensionsN/AIncluded (173 mm x 120 mm x 17 mm)173 mm x 120 mm x 17 mm
Solar Panel Cable LengthN/AIncluded (13 ft / 4 m)13 ft (4 m)
MountingFlexible mounting optionsFlexible mounting optionsEasy 360° mount
Price (USD)$89.98 (1 Pack)$109.98$24.99
Color VariantsBlack, WhiteBlack, WhiteWhite frame and mount, Black solar cells
Included ItemsCamera onlyCamera + Solar PanelSolar panel, wall mount, USB cables, screws, anchors, guide
Charging OptionsRemovable battery packs, Charging dock (sold separately)Removable battery packs, Solar PanelSolar Panel
What is the difference between Wyze Battery Cam Pro and Wyze Battery Cam Pro + Solar Panel?The main difference is that the Wyze Battery Cam Pro + Solar Panel bundle includes a weatherproof solar panel that continuously charges the camera using sunlight, reducing the need for manual battery recharging. Both options offer the same advanced camera features, but the solar panel bundle is ideal for long-term, maintenance-free outdoor security.
How long does the Wyze Battery Cam Pro battery last on a single charge?The Wyze Battery Cam Pro features a removable, rechargeable 6200mAh battery that can last up to 6 months on a single charge, depending on usage and environmental conditions.
What video quality does the Wyze Battery Cam Pro offer?The Wyze Battery Cam Pro delivers stunning 2.5K HDR video resolution (2560 x 1440), providing sharp and vibrant footage both day and night, even in low-light conditions.
Is the Wyze Battery Cam Pro weatherproof?Yes, the Wyze Battery Cam Pro has an IP65 weather resistance rating, making it suitable for outdoor use in rain, dust, and extreme temperatures ranging from -20°C to 50°C (-4°F to 122°F).
What smart home platforms does the Wyze Battery Cam Pro support?The Wyze Battery Cam Pro integrates with Alexa, Google Assistant, and IFTTT, allowing for voice control and smart home automation.
How does the Wyze Battery Cam Pro detect motion?The camera uses advanced Radar + PIR (Passive Infrared) motion detection to accurately sense movement and reduce false alarms. It also features an integrated spotlight and a 100 dB siren for active deterrence.
What are the benefits of adding a solar panel to the Wyze Battery Cam Pro?Adding the Wyze Battery Cam Solar Panel provides continuous charging from sunlight, reducing or eliminating the need for manual battery recharging. This is especially useful for remote or hard-to-reach locations and is environmentally friendly.
What accessories are available for the Wyze Battery Cam Pro?Available accessories include the Wyze Battery Cam Solar Panel for extended battery life, a removable 6200mAh battery pack for quick swaps, and a battery charging dock that can charge two batteries simultaneously.
Can I use local storage with the Wyze Battery Cam Pro?Yes, the Wyze Battery Cam Pro supports local storage with microSD cards up to 256 GB, allowing you to record and store footage directly on the device.
What is included in the Wyze Battery Cam Pro + Solar Panel bundle?The bundle includes the Wyze Battery Cam Pro camera and the Wyze Battery Cam Solar Panel, which comes with a 13-foot USB-C power cable and a 360° adjustable mounting bracket.
Is the Wyze Battery Cam Solar Panel compatible with other Wyze cameras?Yes, the Wyze Battery Cam Solar Panel is compatible with the Wyze Battery Cam Pro and Wyze Cam Outdoor v1/v2 models.
What is the field of view for the Wyze Battery Cam Pro?The Wyze Battery Cam Pro offers a wide field of view: 134° diagonal, 108° horizontal, and 56° vertical, ensuring comprehensive coverage of your property.
How do I install the Wyze Battery Cam Pro and solar panel?The Wyze Battery Cam Pro comes with a wall mount for easy installation. The solar panel includes a 360° adjustable bracket and a long USB-C cable, allowing flexible placement to maximize sunlight exposure.
What are the key differences in battery life between the Wyze Battery Cam Pro and the Wyze Battery Cam Pro + Solar Panel?Can you explain how the solar panel extends the battery life of the Wyze Battery Cam Pro?Do you have any deals, ongoing sales, discounts, or promotions for the Wyze Battery Cam Pro?
