Wireless Gaming Headset with USB Dongle and Quick Charge
For gamers seeking a high-performance wireless gaming headset that combines ultra-low latency, comfort, and fast charging, the
Wyze Wireless Gaming Headset stands out as an excellent choice. Designed specifically for immersive gaming sessions, this headset offers a seamless wireless experience with a USB dongle and a rapid 10-minute quick charge feature to keep you in the game longer.
Wyze Wireless Gaming Headset: Key Features and Benefits
Ultra-Low Latency Wireless Connection
Experience gaming without audio lag thanks to the included 2.4 GHz USB dongle that delivers an ultra-low 20ms wireless latency. This means your in-game sounds, from footsteps to gunfire, arrive almost instantly, giving you a competitive edge.
- 20ms wireless latency — 5 times faster than a blink of an eye
- Included 2.4 GHz dongle for stable, lag-free connection
- Compatible with PC, Mac, PlayStation, Nintendo Switch, Steam Deck, Android, and iOS (Note: Not compatible with Xbox)
Podium-Worthy Comfort for Long Sessions
Comfort is critical during extended gaming marathons. The Wyze Wireless Gaming Headset features:
- Memory foam ear pads wrapped in premium soft leatherette for fatigue-free wear
- A lightweight, extra-wide frame that fits comfortably without pressure
- Two microphone options: a detachable boom mic for clear team communication and a built-in mic for casual calls
Long Battery Life with 10-Minute Quick Charge
Never get caught off guard by a dead battery mid-game. The Wyze headset offers:
- Up to 20 hours of battery life on a full 3-hour charge
- A 10-minute quick charge that provides 2 hours of playtime, perfect for quick breaks
- Ability to use the headset while charging, so your gameplay is never interrupted
Multi-Source Connectivity and Customization
Switch effortlessly between devices with the on-board Multi-Function button, connecting via Bluetooth® 5.2 or the wireless dongle. Customize your audio experience through the Wyze app to fine-tune sound levels and microphone settings.
"Play on (and on), player." — Wyze’s promise of comfort and endurance for gamers who demand more.
Why Choose Wyze Wireless Gaming Headset?
- Versatile compatibility across multiple gaming platforms
- Fast and reliable wireless connection with USB dongle
- Comfort-first design for marathon gaming sessions
- Quick charge technology to minimize downtime
- Two microphone options for flexible communication needs
Additional Support and Accessories
To keep your headset in top shape, Wyze offers replacement parts such as the
Wyze Gaming Headset Boom Mic Cover, ensuring your mic stays clear and functional.
Summary
The Wyze Wireless Gaming Headset is the ideal wireless gaming companion for players who want:
- Ultra-low latency wireless audio with a USB dongle
- Comfortable, fatigue-free wear with memory foam ear pads
- Long-lasting battery life with a rapid 10-minute quick charge
- Multi-platform compatibility and easy device switching
Elevate your gaming experience with a headset designed to keep you connected, comfortable, and ready for action.
Experience immersive gaming with Wyze Wireless Gaming Headset
What platforms is the Wyze Wireless Gaming Headset compatible with?
The Wyze Wireless Gaming Headset is compatible with PC, Mac, PlayStation, Nintendo Switch, Steam Deck, Android, and iOS devices. Please note that it is not compatible with Xbox.How does the Wyze Wireless Gaming Headset achieve ultra-low latency?
The Wyze Wireless Gaming Headset uses a 2.4 GHz USB dongle to deliver an ultra-low 20ms wireless latency, ensuring that in-game audio is transmitted almost instantly for a lag-free gaming experience.How long does the battery last on the Wyze Wireless Gaming Headset?
The Wyze Wireless Gaming Headset offers up to 20 hours of battery life on a full 3-hour charge, allowing for extended gaming sessions without frequent recharging.What is the quick charge feature on the Wyze Wireless Gaming Headset?
The Wyze Wireless Gaming Headset features a 10-minute quick charge that provides up to 2 hours of playtime, so you can get back to gaming quickly even during short breaks.Can I use the Wyze Wireless Gaming Headset while charging?
Yes, you can use the Wyze Wireless Gaming Headset while it is charging, ensuring your gameplay is never interrupted.What makes the Wyze Wireless Gaming Headset comfortable for long gaming sessions?
The headset features memory foam ear pads wrapped in premium soft leatherette and a lightweight, extra-wide frame, providing fatigue-free comfort during marathon gaming sessions.Does the Wyze Wireless Gaming Headset have multiple microphone options?
Yes, the Wyze Wireless Gaming Headset comes with two microphone options: a detachable boom mic for clear team communication and a built-in mic for casual calls.How can I switch between devices with the Wyze Wireless Gaming Headset?
You can easily switch between devices using the on-board Multi-Function button, connecting via Bluetooth 5.2 or the included wireless USB dongle.Can I customize the audio settings on the Wyze Wireless Gaming Headset?
Yes, you can customize your audio experience through the Wyze app, which allows you to fine-tune sound levels and microphone settings.Are replacement parts available for the Wyze Wireless Gaming Headset?
Yes, Wyze offers replacement parts such as the Wyze Gaming Headset Boom Mic Cover to help keep your headset in top condition.
