Bluetooth Wireless Gaming Headsets with Multi-Source Connectivity
Bluetooth Wireless Gaming Headset with Multi-Source Connectivity
Looking for the perfect Bluetooth wireless gaming headset that offers seamless multi-source connectivity? Whether you're a dedicated gamer or a multitasker who switches between devices, the right headset can elevate your audio experience to new heights. Below, we explore two outstanding Wyze audio products designed to meet your gaming and everyday audio needs with advanced wireless technology, comfort, and crystal-clear sound.
Wyze Wireless Gaming Headset: Ultimate Gaming Audio with Multi-Source Connectivity
Ultra-Low Latency for Competitive Edge
Experience gaming without delay thanks to the ultra-low 20ms wireless latency via the included 2.4 GHz dongle. This lightning-fast connection ensures you hear every footstep, gunshot, and in-game cue before your opponents do, giving you a real competitive advantage.
Multi-Source Bluetooth and Dongle Connection
Switch effortlessly between your gaming console and mobile device. The Wyze Wireless Gaming Headset supports Bluetooth 5.2 and a dedicated 2.4 GHz wireless dongle, allowing you to connect to two devices simultaneously. Use the on-board Multi-Function button to toggle between devices without missing a beat.
Podium-Worthy Comfort for Marathon Sessions
Designed for gamers who wear headsets for hours, this model features memory foam ear pads and a lightweight, extra-wide frame with premium leatherette for a fatigue-free fit. Say goodbye to discomfort and hello to extended gaming marathons.
Long-Lasting Battery Life
Stay in the game longer with up to 20 hours of battery life on a full charge. Plus, a quick 10-minute charge provides 2 hours of playtime, so you can jump back into action fast.
Versatile Microphone Options
Communicate clearly with your squad using two microphone options: a detachable boom mic for crystal-clear team chat or a built-in mic for hands-free calls and casual use.
Broad Platform Compatibility
Compatible with PC, Mac, PlayStation, Nintendo Switch, Steam Deck, Android, and iOS devices. (Note: Not compatible with Xbox.)
"Hear them approaching with high-fidelity audio and zero lag."
Wyze Wireless Gaming Headset Lifestyle Enjoy immersive gaming audio on the go.
Wyze Noise-Cancelling Headphones: Premium Sound Meets Smart Connectivity
Advanced Hybrid Active Noise Cancellation (ANC)
Block out distractions with 40dB Quick On/Off Hybrid ANC powered by four noise-cancelling microphones and an ultra-fast processor. Perfect for focusing on your game or music in noisy environments.
Multi-Device Bluetooth 5.0 Connectivity
Connect to two devices simultaneously and switch seamlessly between them. Whether you're gaming on your laptop and need to take a call on your phone, or streaming music while chatting, these headphones keep you connected without interruption.
Superior Audio Quality
Equipped with dual 40mm TPU composite diaphragm drivers, these headphones deliver deep bass, stable mids, and crisp highs with a frequency range up to 38kHz. Enjoy a rich, concert-like soundstage whether gaming, watching movies, or listening to music.
Comfort Designed for Long Wear
Responsive memory foam and elongated ear pads provide a fatigue-free fit that you'll forget you're wearing. Ideal for long gaming sessions or daily commutes.
Intuitive Touch Controls & Voice Assistant Integration
Easily control volume, playback, calls, and activate voice assistants like Alexa or Google Assistant with simple touch gestures on the earcups. Manage your smart home or get information hands-free while gaming.
Transparency Mode & Quick Conversations
Quickly switch to Transparency Mode to hear your surroundings without removing your headphones. Pause audio and join conversations instantly with a gentle tap.
"Like a symphony playing just for you, wherever you go."
Wyze Noise-Cancelling Headphones Lifestyle Experience immersive sound and noise cancellation in style.
Why Choose Wyze for Your Wireless Gaming Headset?
  • Multi-source connectivity lets you stay connected to multiple devices without hassle.
  • Comfort-first design ensures you can game or listen for hours without fatigue.
  • High-fidelity audio with low latency and noise cancellation for crystal-clear sound.
  • Smart features like voice assistant integration and intuitive controls enhance your experience.
  • Affordable pricing without compromising on quality or performance.
Summary of Key Features
FeatureWyze Wireless Gaming HeadsetWyze Noise-Cancelling Headphones
Wireless TechnologyBluetooth 5.2 + 2.4 GHz DongleBluetooth 5.0
LatencyUltra-low 20ms (gaming optimized)Standard latency, ANC enabled
Battery LifeUp to 20 hoursLong-lasting, wear detection enabled
Microphone OptionsDetachable boom mic + built-in micDual voice-isolating microphones
Noise CancellationNo (focus on gaming latency)40dB Hybrid Active Noise Cancellation
ComfortMemory foam ear pads, lightweight frameResponsive memory foam, elongated pads
Multi-device ConnectivityYes, switch between two devicesYes, connect two devices simultaneously
Platform CompatibilityPC, Mac, PlayStation, Switch, iOS, AndroidUniversal Bluetooth devices
Elevate your gaming and audio experience with Wyze's cutting-edge wireless headsets designed for multi-source connectivity, comfort, and superior sound quality. Whether you need ultra-low latency for competitive gaming or immersive noise-cancelling headphones for everyday use, Wyze has you covered.
Comfort FitExtra-wide lightweight frame, memory foam ear padsResponsive memory foam, elongated earpads
Speaker Drivers50mmDual 40mm TPU composite diaphragm drivers
Battery LifeUp to 20 hoursUp to 20 hours
Quick Charge10 minutes for 2 hours playback10 minutes for up to 4 hours playback
Wireless ConnectivityBluetooth 5.2, 2.4 GHz USB dongleBluetooth 5.0
CompatibilityPC, Mac, PlayStation, Nintendo Switch, Steam Deck, Android, iOS (Not Xbox)PC, Mac, Android, iOS
Microphone OptionsBuilt-in mic and detachable boom micBuilt-in dual voice-isolating microphones
Noise CancellingNo (Passive noise cancelling)Yes, 40dB Hybrid Active Noise Cancellation
Voice Assistant IntegrationNoYes (Amazon Alexa built-in, Siri, Google Assistant, Bixby)
App IntegrationNoYes (Wyze app for custom sound profiles)
Multi-Device ConnectionYes, switch between Bluetooth and dongleYes, connect to two devices simultaneously
LatencyUltra-low 20ms wireless latency via dongleNot specified
Color OptionsBlackBlack, White
Price (Regular)$59.99 (Sold out)$89.99 - $99.99
What is the Wyze Wireless Gaming Headset?The Wyze Wireless Gaming Headset is a Bluetooth wireless gaming headset designed for gamers and multitaskers. It features ultra-low 20ms latency via a 2.4 GHz dongle, multi-source connectivity, memory foam ear pads, long battery life, and versatile microphone options for a superior gaming and audio experience.
How does multi-source connectivity work on Wyze headsets?Both the Wyze Wireless Gaming Headset and Wyze Noise-Cancelling Headphones support multi-source connectivity, allowing you to connect to two devices simultaneously. You can easily switch between devices, such as a gaming console and a mobile phone, using the on-board controls or touch gestures.
What devices are compatible with the Wyze Wireless Gaming Headset?The Wyze Wireless Gaming Headset is compatible with PC, Mac, PlayStation, Nintendo Switch, Steam Deck, Android, and iOS devices. Please note that it is not compatible with Xbox.
Does the Wyze Wireless Gaming Headset have noise cancellation?No, the Wyze Wireless Gaming Headset does not feature active noise cancellation. It is optimized for ultra-low latency gaming audio. For noise cancellation, consider the Wyze Noise-Cancelling Headphones, which offer 40dB Hybrid Active Noise Cancellation.
What is the battery life of the Wyze Wireless Gaming Headset?The Wyze Wireless Gaming Headset offers up to 20 hours of battery life on a full charge. Additionally, a quick 10-minute charge provides up to 2 hours of playtime.
What microphone options are available on the Wyze Wireless Gaming Headset?The Wyze Wireless Gaming Headset comes with two microphone options: a detachable boom mic for clear team communication and a built-in mic for hands-free calls and casual use.
What are the key features of the Wyze Noise-Cancelling Headphones?The Wyze Noise-Cancelling Headphones feature 40dB Hybrid Active Noise Cancellation, dual 40mm TPU composite diaphragm drivers for superior sound, multi-device Bluetooth 5.0 connectivity, responsive memory foam ear pads, intuitive touch controls, voice assistant integration, and Transparency Mode for quick conversations.
Can I use Wyze Noise-Cancelling Headphones for gaming?Yes, the Wyze Noise-Cancelling Headphones can be used for gaming, music, and calls. They offer high-quality audio, noise cancellation, and multi-device connectivity, making them versatile for various uses, though they are not optimized for ultra-low latency gaming like the Wyze Wireless Gaming Headset.
How do I control music and calls on Wyze Noise-Cancelling Headphones?You can control music playback, adjust volume, answer calls, and activate voice assistants like Alexa or Google Assistant using intuitive touch controls located on the earcups of the Wyze Noise-Cancelling Headphones.
What makes Wyze headsets comfortable for long-term use?Wyze headsets are designed with comfort in mind, featuring memory foam ear pads, lightweight and extra-wide frames, and premium materials. These features ensure a fatigue-free fit, making them ideal for long gaming sessions or daily use.
Why should I choose Wyze for a wireless gaming headset?Wyze offers wireless gaming headsets with multi-source connectivity, comfort-first design, high-fidelity audio, low latency, smart features like voice assistant integration, and affordable pricing without compromising on quality or performance.
What are the key features of the Wyze Wireless Gaming Headset?Can you tell me more about the battery life of the Wyze Wireless Gaming Headset?Are there any ongoing sales or discounts for the Wyze Wireless Gaming Headset?
