Affordable Wireless Bluetooth Headphones with Hybrid ANC & Memory Foam
Affordable Wireless Bluetooth Headphones with Hybrid ANC and Memory Foam Cushions
If you're searching for affordable wireless Bluetooth headphones that combine hybrid active noise cancellation (ANC) with memory foam cushions for superior comfort, the Wyze Noise-Cancelling Headphones stand out as the perfect choice. Designed to deliver premium sound quality, advanced noise-cancelling technology, and all-day comfort, these headphones offer exceptional value without compromising on features.
Wyze Noise-Cancelling Headphones: Premium Features at an Affordable Price
Hybrid Active Noise Cancellation for Immersive Sound
Experience the power of 40dB Quick On/Off Hybrid ANC technology that effectively reduces outside noise to a whisper. Equipped with four noise-cancelling microphones and an ultra-fast processor, these headphones let you focus on your music, calls, or podcasts without distractions.
  • Hybrid ANC combines feedforward and feedback microphones for superior noise reduction.
  • Transparency Mode lets you amplify outside sounds with a simple touch, perfect for hearing announcements or conversations without removing your headphones.
  • Quick Conversations feature pauses your audio and activates Transparency Mode instantly by gently touching the right earcup.
Superior Comfort with Memory Foam Cushions
Enjoy hours of wear without fatigue thanks to responsive memory foam earpads that delicately embrace your ears. The elongated cushions provide a snug yet gentle fit, making these headphones ideal for commuting, working, or relaxing.
High-Fidelity Audio Performance
Wyze headphones feature dual TPU composite diaphragm drivers (40mm) delivering deep bass, stable mids, and crisp highs across a wide frequency range up to 38kHz. Whether you're into music, movies, or gaming, these headphones bring a rich, concert-like experience.
Smart and Intuitive Controls
  • Touch and tap controls on the earcups allow you to answer calls, adjust volume, skip tracks, and activate voice assistants like Alexa or Google Assistant.
  • Wear Detection automatically pauses audio when you remove the headphones and resumes playback when you put them back on.
  • Bluetooth 5.0 supports connection to two devices simultaneously, enabling seamless switching between your phone and laptop.
Additional Highlights
  • Voice-isolating microphones ensure crystal-clear calls even in noisy environments.
  • Compatible with the Wyze app for customizable sound profiles tailored to music, movies, or gaming.
  • Available in Black and White, with or without a travel case.
  • Priced affordably starting at $89.99, making premium ANC headphones accessible.
"Put the outside world on mute and enjoy your own private symphony with Wyze Noise-Cancelling Headphones."
Wyze Noise-Cancelling Headphones Lifestyle Relaxing with Wyze headphones and memory foam cushions
Why Choose Wyze Noise-Cancelling Headphones?
  • Affordable price point for hybrid ANC headphones with premium features.
  • Memory foam cushions for fatigue-free comfort during extended use.
  • Advanced noise cancellation technology for immersive listening.
  • Smart touch controls and voice assistant integration.
  • Dual device Bluetooth connectivity for versatile use.
These headphones are perfect for commuters, remote workers, students, and anyone who values high-quality sound and comfort without breaking the bank.
Summary
When it comes to affordable wireless Bluetooth headphones with hybrid ANC and memory foam cushions, the Wyze Noise-Cancelling Headphones deliver unmatched value. Combining cutting-edge noise cancellation, premium audio drivers, and plush memory foam earpads, they provide a listening experience that rivals much more expensive models. Upgrade your audio gear today and enjoy crystal-clear sound, all-day comfort, and smart features designed to fit your lifestyle.
FeatureWyze Noise-Cancelling Headphones (New)(Refurbished) Wyze Noise-Cancelling Headphones
Price$80.99 - $99.99 (varies by color and travel case option)$34.99
Color OptionsBlack, WhiteBlack
Style VariantsNo Travel Case, With Travel CaseNo Travel Case
Noise Cancellation40dB Quick On/Off Hybrid Active Noise Cancellation (ANC)Hybrid Active Noise Cancellation, 40 dB
Microphones6 total (4 for noise cancellation, 2 for voice pickup)6 total (4 for noise cancellation, 2 for voice pickup)
Battery LifeUp to 20 hoursUp to 20 hours
Charging MethodUSB Type-CUSB Type-C
Charging TimeNot specifiedAround 2 hours
Quick ChargeNot specified10 minutes for up to 4 hours playback
Bluetooth VersionBluetooth 5.0Bluetooth 5.0
Bluetooth RangeNot specified33 ft (10 m)
Speaker Driver SizeDual 40mm drivers40 mm dome type driver
Frequency Response20 - 38,000 Hz (line-in), 20 - 20,000 Hz (Bluetooth)20 - 38,000 Hz (line-in), 20 - 20,000 Hz (Bluetooth)
Sensitivity113 dB/mW @1 kHz113 dB/mW @1 kHz
Total Harmonic Distortion<0.5%<0.5%
Impedance32 Ω32 Ω
Ear Cushion MaterialMemory foam covered in protein leatherMemory foam covered in protein leather
Headband MaterialMultilayer composite of stainless steel, EVA foam, plastic, protein leatherMultilayer composite of stainless steel, EVA foam, plastic, protein leather
WeightNot specified9.9 oz
Transparency ModeYesYes
Wear DetectionYesNot specified
Quick ConversationsYesNot specified
Voice Assistant IntegrationAlexa, Google Assistant, Siri, BixbyNot specified
Dual Voice-Isolating MicsYesYes
App CustomizationYes, via Wyze appNot specified
Included AccessoriesNot specifiedSoft Carrying Pouch, USB Type-C Cable, Audio Cable, Quick Start Guide
What makes Wyze Noise-Cancelling Headphones affordable compared to other wireless Bluetooth headphones with hybrid ANC?Wyze Noise-Cancelling Headphones offer premium features such as hybrid active noise cancellation, memory foam cushions, and high-fidelity audio at an affordable starting price of $89.99. This makes them accessible to more users without compromising on quality or advanced technology.
How does the hybrid active noise cancellation (ANC) work on Wyze Noise-Cancelling Headphones?The Wyze Noise-Cancelling Headphones use 40dB Quick On/Off Hybrid ANC technology, which combines feedforward and feedback microphones to effectively reduce outside noise. This allows for an immersive listening experience by minimizing distractions from your environment.
Are the Wyze Noise-Cancelling Headphones comfortable for long-term use?Yes, the Wyze Noise-Cancelling Headphones feature responsive memory foam earpads and elongated cushions that provide a snug yet gentle fit. This design ensures fatigue-free comfort, making them ideal for extended wear during commuting, working, or relaxing.
What audio quality can I expect from Wyze Noise-Cancelling Headphones?Wyze headphones are equipped with dual TPU composite diaphragm drivers (40mm) that deliver deep bass, stable mids, and crisp highs across a wide frequency range up to 38kHz. This ensures a rich, high-fidelity audio experience for music, movies, and gaming.
What smart features do Wyze Noise-Cancelling Headphones offer?Wyze Noise-Cancelling Headphones include touch and tap controls for answering calls, adjusting volume, skipping tracks, and activating voice assistants like Alexa or Google Assistant. They also feature wear detection, which automatically pauses audio when you remove the headphones and resumes playback when you put them back on.
Can I connect Wyze Noise-Cancelling Headphones to multiple devices at once?Yes, with Bluetooth 5.0 technology, Wyze Noise-Cancelling Headphones support connection to two devices simultaneously. This allows you to seamlessly switch between your phone and laptop without needing to disconnect and reconnect.
Do Wyze Noise-Cancelling Headphones have a transparency mode?Yes, the headphones feature a Transparency Mode that lets you amplify outside sounds with a simple touch. This is perfect for hearing announcements or having conversations without removing your headphones.
Are Wyze Noise-Cancelling Headphones suitable for making calls in noisy environments?Absolutely. The headphones are equipped with voice-isolating microphones that ensure crystal-clear calls, even in noisy environments.
Is there an app for customizing the sound profile of Wyze Noise-Cancelling Headphones?Yes, the Wyze app allows you to customize sound profiles tailored to music, movies, or gaming, giving you control over your listening experience.
What color options and accessories are available for Wyze Noise-Cancelling Headphones?Wyze Noise-Cancelling Headphones are available in Black and White, and you can choose to purchase them with or without a travel case.
What are the key features of the Wyze Noise-Cancelling Headphones?How does the hybrid active noise cancellation work in these headphones?Are there any ongoing sales or discounts for the Wyze Noise-Cancelling Headphones?
