Smart Doorbell & Lock Bolt Combo for Secure Front Door Entry
Secure Front Door Smart Doorbell and Lock Bolt Combo
Enhance your home’s security with a seamless combination of smart doorbell and lock bolt technology. Whether you want to monitor your front porch or secure your door with keyless convenience, these smart devices offer advanced features designed for modern living. Discover how Wyze’s smart lock bolt and video doorbell solutions provide peace of mind, effortless access, and comprehensive protection for your home.
Wyze Lock Bolt: The Ultimate Smart Deadbolt Replacement
Key Features and Benefits
  • Ultra-Fast Fingerprint Sensor: Unlock your door instantly with a quick fingerprint scan, eliminating the need for keys.
  • Backlit Keypad with Anti-Peep: Enter your access code securely even in the dark, with a keypad designed to prevent prying eyes.
  • Bluetooth 5.0 Connectivity: Control your lock remotely within a 16 ft range using the Wyze app.
  • Auto-Lock Function: Never worry about forgetting to lock your door; the lock automatically secures itself.
  • Built-in Jam Detection Alarm: Alerts you if the lock mechanism is jammed or tampered with.
  • Emergency One-Time Codes: Grant temporary access to guests or service providers safely.
  • Weather Resistant (IPX5): Durable enough to withstand outdoor conditions with operating temperatures from -13°F to 122°F.
Specifications
  • Power Source: 4x AA batteries (included) with 10-12 months battery life.
  • Door Compatibility: Fits doors 1-3/8” to 1-3/4” thick with backset options of 2-3/8” or 2-3/4”.
  • Colors Available: Matte Black and Satin Nickel.
  • Installation: Replaces existing deadbolt easily without complicated wiring.
Experience the convenience of keyless entry combined with robust security features that keep your home safe and accessible.
Wyze Lock Bolt Lifestyle Secure your front door with Wyze Lock Bolt’s smart fingerprint and keypad technology.
Wyze Video Doorbell: Crystal Clear Front Porch Monitoring
Why Choose Wyze Video Doorbell?
  • 1080p HD Video Quality: See visitors clearly with high-definition video.
  • Two-Way Audio: Communicate with guests or delivery personnel directly from your smartphone.
  • Motion Detection & Alerts: Receive instant notifications when motion is detected at your front door.
  • Weather Resistant (IP65): Built to withstand rain, snow, and extreme temperatures.
  • Wide Field of View: 120° vertical by 88° horizontal coverage to capture your entire porch area.
  • Local and Cloud Storage: Save video clips securely with microSD card support and optional cloud recording.
Integration with Wyze Lock Bolt
Pairing the Wyze Video Doorbell with the Wyze Lock Bolt creates a powerful front door security system. Monitor who’s at your door and unlock it remotely for trusted visitors—all from the Wyze app.
Essential Security Bundle: All-in-One Front Door Protection
What’s Included?
  • Wyze Video Doorbell v2: Crisp 1080p HD video and two-way audio for front porch monitoring.
  • Wyze Lock Bolt: Smart deadbolt with fingerprint sensor and backlit keypad.
  • Wyze Cam Pan v3: Pan-and-tilt camera with 360° horizontal and 180° vertical coverage, color night vision, and motion tracking.
  • Two Wyze Cam OG Cameras: Versatile indoor/outdoor cameras with motion-activated spotlights and color night vision.
Bundle Benefits
  • Comprehensive home security from your front door to wider property areas.
  • Real-time alerts and remote control via a single app.
  • Weather-resistant devices designed for reliable outdoor use.
  • Save with a bundled price compared to purchasing devices separately.
This bundle is perfect for homeowners seeking a complete, easy-to-install smart security solution.
Wyze Plug-In Cam Outdoor Keep an eye on your home’s exterior with Wyze’s versatile security cameras.
The Front Porch Security Bundle: Smart Doorbell and Lock Combo
Features at a Glance
  • Wyze Video Doorbell and Chime: View your front porch in 1080p HD with two-way audio and customizable chime sounds.
  • Wyze Lock Bolt: Remote locking/unlocking and lock history tracking via the Wyze app.
  • Works with Alexa and Google Assistant: Voice control your lock and doorbell for hands-free convenience.
  • Motion Event History: Review recorded motion events and lock activity to stay informed.
  • Weather-Resistant Doorbell (IP65): Reliable performance in all weather conditions.
Why Choose This Bundle?
This combo is designed specifically for front porch security, combining video monitoring and smart locking in one affordable package. It’s ideal for anyone wanting to upgrade their home’s entryway with smart technology that’s easy to use and install. Wyze Lock Bolt with Smartphone Control your front door lock remotely with the Wyze app for ultimate convenience.
Replacement Parts for Wyze Lock Bolt
To keep your Wyze Lock Bolt functioning smoothly, replacement parts are available:
  • Interior Assembly Metal Plate: Anchors the interior lock assembly securely to your door.
  • Interior Assembly Battery Cover: Protects the battery compartment inside the lock.
  • Screws Set: Replacement screws compatible with Wyze Lock Bolt installation.
These parts ensure your smart lock remains durable and easy to maintain over time.
Conclusion
For a secure front
Feature / ProductWyze Lock BoltEssential Security BundleThe Front Porch Security Bundle
Price$79.98 (New), $59.98 (Refurbished)$199.99$123.99 - $173.97 (varies by variant)
Included DevicesWyze Lock Bolt (Smart Lock)Wyze Video Doorbell v2, Wyze Lock Bolt, Wyze Cam Pan v3, 2× Wyze Cam OGWyze Lock (standard or Bolt), Wyze Video Doorbell, Wyze Chime, optional Wyze Cam V3
Lock FeaturesUltra-fast fingerprint sensor, backlit keypad, auto-lock, built-in alarm, emergency codes, lock/unlock history, Bluetooth 5.0, IPX5 weather resistanceSame Wyze Lock Bolt features as aboveWyze Lock features (Bluetooth, Zigbee), remote lock/unlock, lock history, indoor only
Door CompatibilityFits doors 1-3/8" to 1-3/4" thick, backset 2-3/8" or 2-3/4"Same as Wyze Lock BoltStandard Wyze Lock compatibility
Video Doorbell ResolutionN/AWyze Video Doorbell v2: 1080p HD video, two-way audio, person detection, microSD local storageWyze Video Doorbell: 1080p HD (2K sensor), two-way audio, noise/echo cancellation, IP65 weather resistant
Security Cameras IncludedNoneWyze Cam Pan v3 (360° pan, 180° tilt, color night vision, two-way audio), 2× Wyze Cam OG (motion-activated spotlight, color night vision)Optional Wyze Cam V3 in some variants
Weather ResistanceIPX5 (Lock Bolt)Cameras: IP65 (Wyze Cam Pan v3, Wyze Cam OG)Video Doorbell: IP65, Lock: Indoor only
ConnectivityBluetooth 5.0Wi-Fi for cameras and doorbell, Bluetooth for lockBluetooth, Zigbee for lock; Wi-Fi for doorbell and chime
Power Source4x AA Batteries (included), 10-12 months battery lifeSame as Wyze Lock BoltLock: 4x AA Batteries; Doorbell: 16V-24V AC power; Chime: standard US power outlet
Smart Home IntegrationWyze App, Alexa, Google Assistant (via app)Wyze App, Alexa, Google AssistantWyze App, Alexa, Google Assistant
Additional FeaturesAuto-lock, built-in alarm for jam detection, emergency one-time codes, anti-peep keypadAutomatic motion tracking on cameras, two-way audio on cameras and doorbell, motion-activated spotlights on Wyze Cam OGMotion event alerts, lock history, multiple chime sounds, works with Alexa and Google Assistant
Installation Time~20 minutesBundle includes multiple devices; individual installation times varyIncludes lock, doorbell, chime; installation times vary
WarrantyStandard Wyze warrantyStandard Wyze warrantyStandard Wyze warranty
What is included in the Wyze Front Door Smart Doorbell and Lock Bolt Combo?The Wyze Front Door Smart Doorbell and Lock Bolt Combo includes a Wyze Video Doorbell with chime and a Wyze Lock Bolt. This bundle provides both video monitoring and keyless entry for enhanced front porch security.
How does the Wyze Lock Bolt enhance home security?The Wyze Lock Bolt features an ultra-fast fingerprint sensor, a backlit anti-peep keypad, Bluetooth 5.0 connectivity, auto-lock function, jam detection alarm, and emergency one-time codes. These features provide robust, keyless security and convenient access control for your home.
Can I unlock my door remotely with the Wyze Lock Bolt?Yes, you can unlock your door remotely within a 16 ft Bluetooth range using the Wyze app. The lock also supports remote locking and lock history tracking for added convenience and security.
Is the Wyze Lock Bolt weather resistant?Yes, the Wyze Lock Bolt is weather resistant with an IPX5 rating and operates in temperatures from -13°F to 122°F, making it suitable for outdoor use.
What are the key features of the Wyze Video Doorbell?The Wyze Video Doorbell offers 1080p HD video quality, two-way audio, motion detection and alerts, weather resistance (IP65), a wide field of view, and both local and cloud storage options for video clips.
Can I integrate the Wyze Video Doorbell with the Wyze Lock Bolt?Yes, you can pair the Wyze Video Doorbell with the Wyze Lock Bolt to monitor your front door and unlock it remotely for trusted visitors, all from the Wyze app.
What is included in the Wyze Essential Security Bundle?The Wyze Essential Security Bundle includes a Wyze Video Doorbell v2, Wyze Lock Bolt, Wyze Cam Pan v3, and two Wyze Cam OG Cameras. This bundle provides comprehensive security coverage for your front door and wider property.
Are Wyze security devices compatible with smart home assistants?Yes, Wyze security devices such as the Lock Bolt and Video Doorbell work with Alexa and Google Assistant, allowing for hands-free voice control.
How easy is it to install the Wyze Lock Bolt?The Wyze Lock Bolt is designed for easy installation and replaces your existing deadbolt without complicated wiring. It fits doors 1-3/8” to 1-3/4” thick with standard backset options.
What replacement parts are available for the Wyze Lock Bolt?Replacement parts for the Wyze Lock Bolt include the interior assembly metal plate, interior assembly battery cover, and a set of compatible screws. These parts help maintain the lock’s durability and performance.
How long does the Wyze Lock Bolt battery last?The Wyze Lock Bolt is powered by 4 AA batteries (included) and offers a battery life of 10-12 months under typical usage.
What are the color options for the Wyze Lock Bolt?The Wyze Lock Bolt is available in Matte Black and Satin Nickel finishes to match your home’s style.
Does the Wyze Video Doorbell offer motion event history?Yes, the Wyze Video Doorbell provides motion event history, allowing you to review recorded motion events and stay informed about activity at your front door.
