Wired Video Doorbells with Motion-Activated Voice Deterrence
Wired Video Doorbells with Motion Activated Voice Deterrence for Your Porch
Enhance your home security with advanced wired video doorbells that not only provide crystal-clear video but also feature motion-activated voice deterrence to keep your porch safe and secure. Whether you want detailed 2K video, two-way audio, or smart alerts, these wired video doorbells deliver superior performance and peace of mind.
Wyze Video Doorbell v2: The Ultimate Wired Doorbell Experience
Wyze Video Doorbell v2 lifestyle Capture every visitor with clarity and confidence.
Key Features
  • 2K Crystal-Clear Video: Enjoy immaculate head-to-toe viewing with 2K resolution, capturing every detail on your porch.
  • Motion-Activated Voice Deterrence: Automatically play a voice prompt when motion is detected, warning visitors that they are being recorded. This feature helps deter unwanted activity.
  • Local MicroSD Storage: Continuous 24/7 local recording with onboard microSD card slot means you never miss a moment before or after motion events.
  • Two-Way Audio: Speak directly to visitors from anywhere using the Wyze app.
  • Works with Existing Chime: Includes a chime controller so you can keep your traditional doorbell sound.
  • Pre-Roll Motion Recording: Capture 3-6 seconds before motion starts for full context.
  • Weatherproof (IP65): Built to withstand rain, snow, and harsh weather conditions.
  • Smart Home Integration: Compatible with Alexa and Google Home for voice commands and live feed viewing.
  • Custom Detection Zones & Quick Responses: Tailor motion alerts and use preset voice responses like "Be there shortly" or "Leave the package at the door."
Wyze Video Doorbell v2 is perfect for homeowners seeking a wired doorbell with advanced security features and reliable performance.
The Front Porch Security Bundle: All-in-One Porch Protection
What’s Included?
  • Wyze Video Doorbell (1080p HD): Wired video doorbell with two-way audio and real-time alerts.
  • Wyze Lock: Remotely lock/unlock your door and monitor lock history via the Wyze app.
  • Wyze Chime: Ensures you hear your doorbell inside the home.
Why Choose This Bundle?
This bundle offers a comprehensive front porch security solution combining video monitoring and smart lock control. The Wyze Video Doorbell included provides motion-activated voice deterrence and two-way talk, while the Wyze Lock adds an extra layer of convenience and security by allowing remote access management.
"Lock and monitor your front door seamlessly while keeping an eye on visitors with crisp video and voice alerts."
Note: The bundle is wired and integrates smoothly with your existing home setup.
Wyze Video Doorbell Pro: Wired or Battery-Powered Versatility
Wyze Video Doorbell Pro lifestyle Flexible installation with wired or battery power options.
Highlights
  • Wider Ultra-Wide Viewing Angle: Capture more of your porch area with a broader field of view.
  • Crystal-Clear HD Video: High-definition video quality ensures you see visitors clearly.
  • Motion-Activated Security Light: Automatically lights up your porch when motion is detected.
  • Two-Way Audio & Quick Responses: Communicate instantly with visitors and use preset voice replies.
  • Smart Detection Alerts: Person, package, vehicle, and pet detection with Cam Plus subscription.
  • Dual-Band Wi-Fi Extender Chime: Faster notifications and customizable chime sounds.
  • Easy Installation: Mount with screws or adhesive plate in just 30 seconds.
  • Works with Alexa and Google Assistant: Hands-free control and live feed viewing.
Wyze Video Doorbell Pro is ideal for those who want the flexibility of wired or battery power with advanced smart features and motion-activated voice deterrence.
Why Choose a Wired Video Doorbell with Motion-Activated Voice Deterrence?
Motion-activated voice deterrence is a powerful security feature that warns potential intruders or unwanted visitors that they are being recorded, often preventing suspicious activity before it happens. Wired video doorbells provide reliable power and continuous connectivity, ensuring your porch is always monitored without worrying about battery life.
Additional Accessories for Perfect Installation
  • Designed specifically for the Wyze Video Doorbell v2.
  • Includes a 15° horizontal bracket and two 7.5° vertical brackets.
  • Perfect for angled door frames or porches with stairs to eliminate blind spots.
  • Weather-resistant and easy to install.
  • Helps you achieve the ideal viewing angle for maximum porch coverage.
Summary: Best Wired Video Doorbells with Voice Deterrence for Your Porch
ProductVideo QualityVoice DeterrencePower TypeSpecial Features
Wyze Video Doorbell v22KYesWiredLocal microSD storage, pre-roll recording
The Front Porch Security Bundle1080p HDYesWiredIncludes Wyze Lock and Chime
Wyze Video Doorbell ProHDYesWired/BatteryUltra-wide view, security light
Choose the Wyze Video Doorbell v2 for the clearest wired video with voice deterrence, or opt for the Front Porch Security Bundle for a complete smart home entry solution. For flexible installation, the Wyze Video Doorbell Pro offers wired or battery power with advanced features.
Enhance Your Porch Security Today
Investing in a wired video doorbell with motion-activated voice deterrence is a smart way to protect your home, deter unwanted visitors, and stay connected to your front porch from anywhere. With Wyze’s range of video doorbells and accessories, you get reliable, high-quality security solutions tailored to your needs.
FeatureWyze Video Doorbell v2The Front Porch Security BundleWyze Video Doorbell ProWyze Duo Cam Battery Doorbell
Price$44.98$123.99 - $173.97 (varies by variant)$99.98$89.98 - $109.99
Video Resolution2K (2048 x 1536)1080p HD (Doorbell)HD (exact resolution not specified)Front: 2K (2048 x 1536), Bottom: 1080p
PowerWired (16V-24V AC)Bundle includes wired and wireless devicesWired or Wireless (battery-powered)Battery-powered, also supports hardwired power
InstallationWired, includes wedge for angle adjustmentBundle includes multiple devices, installation variesWired or wireless, install in 30 secondsBattery-powered, includes removable battery pack
Field of View135° horizontal, 103° vertical1080p HD doorbell view (field of view not specified)Ultra-wide viewing angle (head-to-toe coverage)Front camera: 132° horizontal, Bottom camera: 121° horizontal
Two-way AudioYesYesYesYes
Motion DetectionYesYesYesYes
Smart Detection AlertsPerson detection (with Cam Plus)Person detection (with Cam Plus)Person, Package, Vehicle, Pet detection (with Cam Plus)AI detections and alerts
Cloud StorageWith Wyze Security PlanWith Wyze Security PlanCam Plus subscription for unlimited cloud storageAWS Cloud storage
Local StoragemicroSD up to 256GBNot specifiedNot specifiedSupports microSD up to 256GB
IntegrationAlexa, Google Assistant, IFTTTAlexa, Google AssistantAlexa, Google AssistantAlexa, Google Assistant, IFTTT
Security LightNoNot specifiedMotion-activated blue security lightNo
Chime IncludedYes (Chime Controller included)Yes (Wyze Video Doorbell and Chime included)Yes (Wi-Fi Extender chime included)Yes (Wyze Wi-Fi Chime included)
Unlock IntegrationNoYes (Wyze Lock Bolt or Wyze Lock included in bundle)Yes (Pair with Wyze Lock Bolt for remote unlock)No
Battery Life / Power SourceWiredWired and wireless devices in bundleBattery-powered or wiredBattery-powered with removable battery pack
Dimensions4.3in x 1.7in x 0.9in (110mm x 44mm x 24mm)Varies by deviceNot specified5.90in x 1.88in x 1.18in (150mm x 48mm x 30mm)
Weather ResistanceIP65IP65 (for cameras and doorbells in bundle)Not explicitly stated, likely weather resistantIP65
Warranty1 YearNot specifiedNot specified1 Year
What is a wired video doorbell with motion-activated voice deterrence?A wired video doorbell with motion-activated voice deterrence is a security device that connects to your home's wiring for continuous power and features a built-in speaker that automatically plays a voice prompt when motion is detected. This warns visitors that they are being recorded, helping to deter unwanted activity and enhance your porch security.
What are the key features of the Wyze Video Doorbell v2?The Wyze Video Doorbell v2 offers 2K crystal-clear video, motion-activated voice deterrence, local microSD storage for 24/7 recording, two-way audio, compatibility with existing chimes, pre-roll motion recording, weatherproof IP65 rating, smart home integration with Alexa and Google Home, and customizable detection zones and quick responses.
How does motion-activated voice deterrence improve home security?Motion-activated voice deterrence automatically plays a warning message when motion is detected, alerting visitors that they are being recorded. This proactive feature can discourage suspicious behavior and prevent potential intruders from approaching your porch.
What is included in the Wyze Front Porch Security Bundle?The Wyze Front Porch Security Bundle includes a Wyze Video Doorbell (1080p HD) with two-way audio and real-time alerts, a Wyze Lock for remote door locking and monitoring, and a Wyze Chime to ensure you hear your doorbell inside your home. This bundle provides comprehensive front porch security and smart lock control.
Can I use the Wyze Video Doorbell Pro with both wired and battery power?Yes, the Wyze Video Doorbell Pro offers flexible installation options, allowing you to power it with either your existing doorbell wiring or its built-in battery. This makes it easy to install in any home setup.
What smart home systems are Wyze video doorbells compatible with?Wyze video doorbells are compatible with Alexa and Google Home, allowing you to use voice commands and view live feeds directly from your smart home devices.
What is pre-roll motion recording and why is it important?Pre-roll motion recording captures 3-6 seconds of video before a motion event is triggered. This provides important context for each alert, ensuring you see what happened just before the motion was detected.
Are Wyze video doorbells weatherproof?Yes, Wyze video doorbells such as the Wyze Video Doorbell v2 are rated IP65 weatherproof, making them suitable for use in rain, snow, and harsh weather conditions.
What accessories are available for Wyze video doorbells?Accessories like the Wyze Video Doorbell v2 Wedge Kit are available, which include horizontal and vertical brackets to help you achieve the ideal viewing angle, especially for angled door frames or porches with stairs. These accessories are weather-resistant and easy to install.
How does local microSD storage work with Wyze Video Doorbell v2?The Wyze Video Doorbell v2 features an onboard microSD card slot for continuous 24/7 local recording. This ensures you never miss a moment before or after motion events, and you can review footage directly from the Wyze app.
What are the differences between Wyze Video Doorbell v2, the Front Porch Security Bundle, and Wyze Video Doorbell Pro?Wyze Video Doorbell v2 offers 2K video, motion-activated voice deterrence, and local storage. The Front Porch Security Bundle includes a 1080p HD video doorbell, Wyze Lock, and Chime for a complete entry solution. Wyze Video Doorbell Pro provides HD video, ultra-wide viewing angle, motion-activated security light, and the flexibility of wired or battery power.
Why should I choose a wired video doorbell over a battery-powered one?Wired video doorbells provide reliable power and continuous connectivity, ensuring your porch is always monitored without worrying about battery life. This makes them ideal for homeowners seeking uninterrupted security and peace of mind.
What are the key features of the Wyze Video Doorbell v2?Can the Wyze Video Doorbell v2 work with my existing doorbell chime?Do you have any ongoing sales or discounts for the Wyze Video Doorbell?
