Refurbished Wyze Video Doorbell v2 with Motion Activated Voice Deterrence
Upgrade your home security with the
Wyze Video Doorbell v2, a smart wired doorbell designed to keep your porch safe and connected. This refurbished model offers all the premium features you expect from Wyze, including crystal-clear 2K video, local storage, and advanced motion detection with voice deterrence to protect your home from unwanted visitors.
Wyze Video Doorbell v2: Key Features and Benefits
Stunning 2K Video Quality
Capture every detail with immaculate 2K resolution, providing a head-to-toe view of your porch. This high-definition video ensures you never miss a visitor or package delivery.
Motion-Activated Voice Deterrence
Enhance your security with an automated voice prompt that activates when motion is detected. This feature warns potential intruders that they are being recorded, helping to deter suspicious activity before it escalates. (Requires Cam Plus or Cam Protect subscription.)
Local MicroSD Storage for 24/7 Recording
Unlike many doorbells that rely solely on cloud storage, the Wyze Video Doorbell v2 includes a microSD card slot for continuous local recording. This means you can review footage anytime without worrying about subscription fees or internet outages.
Works with Your Existing Door Chime
The included chime controller allows you to keep your traditional doorbell sound while upgrading to smart technology. No need to bypass or replace your current chime system.
Two-Way Audio Communication
Speak directly to visitors or delivery personnel from anywhere using the Wyze app. The two-way talk feature lets you respond quickly and conveniently.
Pre-Roll Motion Recording
Thanks to wired power, the doorbell records 3-6 seconds before motion events, capturing the full context of any activity on your porch.
Weatherproof and Durable
Rated IP65, the doorbell withstands rain, snow, and extreme temperatures, ensuring reliable performance year-round.
Night Vision with Color Clarity
Equipped with an award-winning starlight sensor, the doorbell provides clear color night vision, so you can see visitors even in low light.
Smart Home Integration
Compatible with Alexa and Google Home, you can view live feeds and receive smart alerts through your voice assistant devices.
Custom Detection Zones and Quick Responses
Tailor motion alerts to specific areas and use preset quick responses like "Be there shortly" or "Leave the package at the door" for seamless communication.
Why Choose a Refurbished Wyze Video Doorbell v2?
Opting for a refurbished Wyze Video Doorbell v2 is a smart choice for budget-conscious homeowners who want premium security features without paying full price. Each refurbished unit is tested and certified to meet Wyze’s high standards, ensuring you get a reliable product with the same great performance as new.
"Answer your door from anywhere with our clearest and most capable wired video doorbell yet."
Additional Wyze Security Options to Complement Your Doorbell
While the Wyze Video Doorbell v2 is perfect for porch security, consider enhancing your home’s safety with these Wyze products:
Wyze Cam v4
- 2.5K QHD Video Resolution for crystal-clear monitoring indoors or outdoors.
- Enhanced Color Night Vision with motion-activated spotlight.
- Built-in Siren and Two-Way Talk for active deterrence and communication.
- Wi-Fi 6 Support for faster, more reliable connectivity.
- Weather-Resistant IP65 Rating for all-season durability.
- Multiple Mounting Options including wall, ceiling, and magnetic mounts.
This camera pairs well with the doorbell to provide comprehensive coverage around your home.
Cam v4 + Lamp Socket v2 Bundle
- Smart Exterior Lighting powered by your existing outdoor light fixture.
- Motion-Activated Lights that illuminate when motion is detected by the Cam v4.
- Easy Installation by simply screwing into your lamp socket.
- Group Control and Scheduling via the Wyze app for convenient automation.
This bundle is ideal for creating a smart, well-lit security perimeter around your home.
Summary
The
refurbished Wyze Video Doorbell v2 is a feature-packed, reliable smart doorbell solution with advanced motion-activated voice deterrence, 2K video clarity, and local storage. It integrates seamlessly with your existing chime and smart home devices, making it an excellent choice for anyone looking to upgrade their home security affordably.
Enhance your security setup further with Wyze Cam v4 and the Cam v4 + Lamp Socket v2 Bundle for a complete smart home surveillance and lighting system.
Stay connected and secure with Wyze Video Doorbell v2
Smart lighting and security with Wyze Cam v4 and Lamp Socket v2
What features does the refurbished Wyze Video Doorbell v2 offer?
The refurbished Wyze Video Doorbell v2 offers 2K video quality, motion-activated voice deterrence, local microSD storage for 24/7 recording, compatibility with your existing door chime, two-way audio communication, pre-roll motion recording, weatherproof IP65 rating, color night vision, smart home integration with Alexa and Google Home, and customizable detection zones with quick response options.How does motion-activated voice deterrence work on the Wyze Video Doorbell v2?
Motion-activated voice deterrence uses an automated voice prompt that activates when motion is detected, warning potential intruders that they are being recorded. This feature helps deter suspicious activity and requires a Cam Plus or Cam Protect subscription.Does the Wyze Video Doorbell v2 support local storage?
Yes, the Wyze Video Doorbell v2 includes a microSD card slot for continuous local recording, allowing you to review footage anytime without relying solely on cloud storage or paying subscription fees.Can I use my existing door chime with the Wyze Video Doorbell v2?
Yes, the Wyze Video Doorbell v2 comes with a chime controller that allows you to keep your traditional doorbell sound while upgrading to smart technology, so you do not need to bypass or replace your current chime system.Is the refurbished Wyze Video Doorbell v2 weatherproof?
Yes, the Wyze Video Doorbell v2 is rated IP65, making it weatherproof and durable enough to withstand rain, snow, and extreme temperatures for reliable year-round performance.Does the Wyze Video Doorbell v2 have night vision?
Yes, the Wyze Video Doorbell v2 is equipped with a starlight sensor that provides clear color night vision, allowing you to see visitors even in low-light conditions.What smart home systems is the Wyze Video Doorbell v2 compatible with?
The Wyze Video Doorbell v2 is compatible with Alexa and Google Home, enabling you to view live feeds and receive smart alerts through your voice assistant devices.What are the benefits of choosing a refurbished Wyze Video Doorbell v2?
Choosing a refurbished Wyze Video Doorbell v2 allows you to enjoy premium security features at a lower price. Each refurbished unit is tested and certified to meet Wyze’s high standards, ensuring reliable performance comparable to a new product.What is pre-roll motion recording on the Wyze Video Doorbell v2?
Pre-roll motion recording captures 3-6 seconds of video before a motion event occurs, thanks to the doorbell’s wired power. This ensures you see the full context of any activity on your porch.Can I communicate with visitors using the Wyze Video Doorbell v2?
Yes, the Wyze Video Doorbell v2 features two-way audio, allowing you to speak directly to visitors or delivery personnel from anywhere using the Wyze app.What other Wyze products can enhance my home security setup?
You can enhance your home security with the Wyze Cam v4, which offers 2.5K QHD video, color night vision, a built-in siren, and Wi-Fi 6 support. The Cam v4 + Lamp Socket v2 Bundle adds smart exterior lighting and motion-activated lights for a comprehensive security and lighting solution.
