WiFi Sprinkler Controllers for North American Residential Irrigation Systems
Efficient and smart irrigation is essential for maintaining a healthy lawn while conserving water. For North American homeowners, WiFi sprinkler controllers offer the convenience of remote management, personalized watering schedules, and weather-adaptive watering to optimize irrigation. Below, we explore the top Wyze WiFi sprinkler controllers and accessories designed specifically for residential irrigation systems.
Wyze Sprinkler Controller: Smart Zoned Irrigation Management
Smarter, Simpler, and Greener Lawn Care
The Wyze Sprinkler Controller is a cutting-edge connected home device that transforms your traditional irrigation system into a smart, WiFi-enabled watering solution. It supports up to 8 customizable irrigation zones, allowing you to tailor watering schedules to different parts of your lawn or garden.
- Remote Control: Manage your sprinklers from anywhere using the Wyze app.
- Personalized Schedules: Set weekly routines that fit your lifestyle and plant needs.
- WeatherSense Certified: EPA WaterSense certification ensures water-efficient operation.
- Weather-Based Watering: Unlock Sprinkler Plus for intelligent weather skips and hyper-local weather data integration.
- Peace of Mind: Integrates with Wyze Cam for monitoring your yard.
- Quick Installation: Most users can install the controller in about 20 minutes.
Available in two styles: the standalone Sprinkler Controller or the Sprinkler Controller bundled with the weatherproof Sprinkler Controller Box for enhanced outdoor durability.
"Control your lawn watering smarter and greener with Wyze’s smart zoned irrigation."
Manage your lawn watering remotely with Wyze Sprinkler Controller.
Wyze Weatherproof Sprinkler Controller Box: Durable Outdoor Protection
Rugged and Reliable for Outdoor Use
For homeowners who want to mount their Wyze Sprinkler Controller outdoors, the Wyze Weatherproof Sprinkler Controller Box offers an IP65-rated enclosure that protects your device from rain, dust, and harsh weather conditions.
- IP65 Weatherproof Rating: Ensures protection against water jets and dust ingress.
- Durability Features: Equipped with 4 secure clasps and a gridded cover for extra toughness.
- Power Options: Supports both hardwired power and outdoor outlet connections.
- Compatibility: Designed exclusively for the Wyze Sprinkler Controller.
This accessory is perfect for those who want to install their smart irrigation controller in exposed outdoor locations without worrying about damage.
Refurbished Wyze Sprinkler Controller: Affordable Smart Irrigation
Budget-Friendly Smart Watering Solution
If you're looking for a cost-effective way to upgrade your irrigation system, the refurbished Wyze Sprinkler Controller offers the same smart features at a reduced price.
- Supports Up to 8 Zones: Customize watering for different areas of your yard.
- Personalized Schedules: Tailor watering routines to your needs.
- Weather-Based Watering: Includes 1-year free subscription to Sprinkler Plus for weather-adaptive watering.
- Easy App Control: Manage your irrigation remotely with the Wyze app.
- Quick Setup: Installation typically takes about 20 minutes.
- Compatibility: Works with most residential irrigation systems in North America, including those with master valves or pump relays.
This refurbished option is ideal for homeowners who want smart irrigation without the full retail price.
Why Choose Wyze WiFi Sprinkler Controllers?
"Wyze sprinkler controllers combine smart technology with user-friendly design to help you save water, time, and money."
- Water Conservation: EPA WaterSense certification and weather-based watering reduce unnecessary water use.
- Convenience: Control your irrigation system from your smartphone anytime, anywhere.
- Customization: Up to 8 zones allow precise watering tailored to your landscape.
- Durability: Optional weatherproof enclosure ensures reliable outdoor operation.
- Integration: Works seamlessly with other Wyze smart home products for enhanced home automation.
Summary of Wyze WiFi Sprinkler Products
Product | Key Features | Price (USD) |
Wyze Sprinkler Controller | 8 zones, remote app control, weather-based watering, WaterSense certified | $59.99 (controller only) / $99.98 (with box) |
Wyze Weatherproof Sprinkler Controller Box | IP65 rating, durable, outdoor power options | $39.99 |
Refurbished Wyze Sprinkler Controller | Same smart features, budget-friendly | $24.99 |
Enhance Your Smart Home Irrigation Today
Upgrade your North American residential irrigation system with Wyze’s WiFi sprinkler controllers and accessories. Enjoy smarter watering, water savings, and the convenience of remote control — all designed to keep your lawn lush and healthy with minimal effort.
Personalize your watering schedule easily with the Wyze app.
What is the Wyze WiFi Sprinkler Controller and how does it work?
The Wyze WiFi Sprinkler Controller is a smart device that upgrades your traditional irrigation system, allowing you to manage up to 8 irrigation zones remotely via the Wyze app. It offers personalized watering schedules, weather-based watering with Sprinkler Plus, and EPA WaterSense certification for efficient water use.How do I control my Wyze Sprinkler Controller remotely?
You can control your Wyze Sprinkler Controller from anywhere using the Wyze app on your smartphone. The app allows you to set schedules, start or stop watering, and monitor your irrigation system remotely.What is Sprinkler Plus and what are its benefits?
Sprinkler Plus is a subscription service that enhances your Wyze Sprinkler Controller with intelligent weather-based watering. It uses hyper-local weather data to automatically skip watering when rain is expected, helping you save water and keep your lawn healthy.Is the Wyze Sprinkler Controller compatible with North American residential irrigation systems?
Yes, the Wyze Sprinkler Controller is designed specifically for most North American residential irrigation systems, including those with master valves or pump relays.How many zones does the Wyze Sprinkler Controller support?
The Wyze Sprinkler Controller supports up to 8 customizable irrigation zones, allowing you to tailor watering schedules for different areas of your lawn or garden.What is the Wyze Weatherproof Sprinkler Controller Box?
The Wyze Weatherproof Sprinkler Controller Box is an IP65-rated enclosure designed to protect your Wyze Sprinkler Controller from rain, dust, and harsh weather. It is ideal for outdoor installations and offers both hardwired and outdoor outlet power options.Can I install the Wyze Sprinkler Controller outdoors?
Yes, you can install the Wyze Sprinkler Controller outdoors by using the Wyze Weatherproof Sprinkler Controller Box, which provides durable protection against the elements.How long does it take to install the Wyze Sprinkler Controller?
Most users can install the Wyze Sprinkler Controller in about 20 minutes, thanks to its user-friendly design and straightforward setup process.What is the difference between the new and refurbished Wyze Sprinkler Controller?
The refurbished Wyze Sprinkler Controller offers the same smart features as the new model but at a lower price. It is a budget-friendly option for homeowners looking to upgrade their irrigation system affordably.Is the Wyze Sprinkler Controller water-efficient?
Yes, the Wyze Sprinkler Controller is EPA WaterSense certified, ensuring water-efficient operation. It also supports weather-based watering to reduce unnecessary water use.Does the Wyze Sprinkler Controller integrate with other Wyze smart home products?
Yes, the Wyze Sprinkler Controller integrates seamlessly with other Wyze smart home products, such as Wyze Cam, for enhanced home automation and yard monitoring.What are the main benefits of using a Wyze WiFi Sprinkler Controller?
Wyze WiFi Sprinkler Controllers offer water conservation, remote control via smartphone, customizable watering for up to 8 zones, durable outdoor installation options, and integration with other Wyze smart home devices.
