Affordable Smart WiFi Sprinkler Controllers with Zoned Irrigation and Weather-Based Features
Looking for an affordable, smart WiFi sprinkler controller that offers zoned irrigation and weather-based watering? Discover the Wyze Sprinkler Controller lineup, designed to bring smarter, greener, and simpler irrigation control to your lawn or garden. Whether you want a brand-new unit, a budget-friendly refurbished option, or accessories to protect your system outdoors, Wyze has you covered.
Wyze Sprinkler Controller: Smart, Zoned, and Weather-Aware Irrigation
The Wyze Sprinkler Controller is an 8-zone WiFi-enabled irrigation controller that replaces your existing wired sprinkler system, adding smart control and weather intelligence to your watering routine.
Key Features:
- 8 Customizable Irrigation Zones: Tailor watering schedules for up to 8 zones, each with unique names and photos in the Wyze app for easy identification.
- Remote Control Anywhere: Start, stop, or adjust watering schedules from anywhere using the Wyze app on your smartphone.
- Weather-Based Watering with Sprinkler Plus: Includes 1 year free of Sprinkler Plus, a weather service that uses hyper-local weather data to skip watering when it’s raining or when soil moisture is sufficient.
- WaterSense Certified: Earned EPA WaterSense certification for efficient water use, helping save billions of gallons of water nationwide.
- Advanced Insights: View historical, current, and forecasted moisture levels per zone, plus upcoming weather and watering activities.
- Easy DIY Installation: Replace your existing controller in under 20 minutes with simple wiring and automatic schedule creation.
- Peace of Mind with Wyze Cam Integration: Monitor your lawn watering live via Wyze Cam to ensure your system runs smoothly and avoid surprises like pets playing in wet zones.
“Smarter. Simpler. Greener.” — Wyze Sprinkler Controller brings affordable smart irrigation to your home.
Control your lawn watering remotely with Wyze Sprinkler Controller and app.
Budget-Friendly Option: (Refurbished) Wyze Sprinkler Controller
For those seeking the same smart features at a lower price point, the refurbished Wyze Sprinkler Controller offers the full 8-zone WiFi control and 1 year of Sprinkler Plus weather service at a fraction of the cost.
Highlights:
- Same smart zoned irrigation and weather-based watering features as the new controller.
- Priced affordably to fit tighter budgets without sacrificing performance.
- Note: This is a final sale product and not eligible for returns.
- Perfect for eco-conscious users wanting to save water and money.
Protect Your Investment: Wyze Weatherproof Sprinkler Controller Box
To ensure your Wyze Sprinkler Controller withstands outdoor conditions, the Wyze Weatherproof Sprinkler Controller Box offers durable, weather-resistant housing.
Features:
- IP65 Weatherproof Rating: Fully protects your controller from rain, dust, and outdoor elements.
- Durable Design: Equipped with 4 clasps and a gridded cover for extra toughness.
- Flexible Power Options: Supports hardwiring or outdoor outlet power.
- Compatibility: Designed exclusively for Wyze Sprinkler Controller.
This accessory is essential for outdoor installations, extending the life and reliability of your smart irrigation system.
Enhance Efficiency with Wyze Sprinkler Plus Subscription
Wyze Sprinkler Plus is a subscription service that unlocks advanced weather-based features to optimize your watering schedule.
Benefits Include:
- Smart Schedules: Automatically calculates watering needs per zone based on weather and soil moisture.
- Weather Skips: Avoid watering during rain, cold, or windy conditions to conserve water.
- Cycle/Soak: Breaks watering into multiple cycles to improve soil absorption and reduce runoff.
- Advanced Zone Moisture Data: Monitor exact moisture levels to keep plants healthy.
- **5-Day Weather
What is the Wyze Sprinkler Controller and how does it work?
The Wyze Sprinkler Controller is an 8-zone WiFi-enabled irrigation controller that replaces your existing wired sprinkler system. It allows you to control and customize watering schedules for up to 8 zones using the Wyze app, and leverages weather intelligence to optimize watering based on local weather conditions.How many irrigation zones does the Wyze Sprinkler Controller support?
The Wyze Sprinkler Controller supports up to 8 customizable irrigation zones, each of which can be named and assigned a photo in the Wyze app for easy identification and management.Can I control my Wyze Sprinkler Controller remotely?
Yes, you can start, stop, or adjust your watering schedules from anywhere using the Wyze app on your smartphone, giving you full remote control over your irrigation system.What is Sprinkler Plus and what features does it offer?
Sprinkler Plus is a subscription service included free for one year with your Wyze Sprinkler Controller. It uses hyper-local weather data to automatically skip watering when it’s raining or when soil moisture is sufficient, and provides advanced features like smart scheduling, weather skips, cycle/soak, and detailed zone moisture data.Is the Wyze Sprinkler Controller WaterSense certified?
Yes, the Wyze Sprinkler Controller is EPA WaterSense certified, ensuring efficient water use and helping to conserve water while maintaining a healthy lawn or garden.How easy is it to install the Wyze Sprinkler Controller?
The Wyze Sprinkler Controller is designed for easy DIY installation. You can replace your existing controller in under 20 minutes with simple wiring and automatic schedule creation through the Wyze app.What is the difference between the new and refurbished Wyze Sprinkler Controller?
The refurbished Wyze Sprinkler Controller offers the same smart features, 8-zone WiFi control, and 1 year of Sprinkler Plus as the new unit, but at a lower price. However, refurbished units are final sale and not eligible for returns.How can I protect my Wyze Sprinkler Controller for outdoor use?
You can protect your Wyze Sprinkler Controller with the Wyze Weatherproof Sprinkler Controller Box. It features an IP65 weatherproof rating, durable design, and supports both hardwiring and outdoor outlet power, ensuring your controller is safe from rain, dust, and other outdoor elements.Is the Wyze Weatherproof Sprinkler Controller Box compatible with other controllers?
No, the Wyze Weatherproof Sprinkler Controller Box is designed exclusively for use with the Wyze Sprinkler Controller.Can I monitor my lawn watering with a Wyze Cam?
Yes, you can integrate your Wyze Sprinkler Controller with a Wyze Cam to monitor your lawn watering live, ensuring your system runs smoothly and helping you avoid surprises like pets playing in wet zones.What are the benefits of using Wyze Sprinkler Plus for my irrigation system?
Wyze Sprinkler Plus provides smart schedules based on weather and soil moisture, weather skips to avoid unnecessary watering, cycle/soak to improve soil absorption, and advanced zone moisture data to keep your plants healthy while conserving water.
