WiFi Sprinkler Controllers for Smart Residential Irrigation
WiFi Enabled Sprinkler Controllers for Residential Irrigation Systems
Efficiently managing your residential irrigation system has never been easier with WiFi-enabled sprinkler controllers. These smart devices allow you to control your lawn watering remotely, customize schedules, and conserve water by adapting to weather conditions. Below, we explore the top Wyze products designed to bring smarter, greener, and simpler irrigation control to your home.
Wyze Sprinkler Controller: Smart, Connected Lawn Care
Overview
The Wyze Sprinkler Controller is an 8-zone WiFi-enabled smart controller that replaces your existing irrigation system’s timer. It offers full control over your sprinklers from anywhere using the Wyze app, making lawn care convenient and water-efficient.
Key Features
  • Remote Control Anywhere: Start or stop watering sessions from your smartphone, no matter where you are.
  • Customizable Zones: Manage up to 8 irrigation zones with unique names and photos for easy identification.
  • Personalized Schedules: Create fixed or smart watering schedules tailored to your weekly routine.
  • WeatherSense Certified: Earned EPA WaterSense certification for water-saving weather-based watering schedules.
  • Sprinkler Plus Service: Includes 1 year free subscription to Sprinkler Plus, which provides hyper-local weather data, smart schedules, weather skips, cycle/soak watering, and advanced moisture insights.
  • Easy DIY Installation: Replace your existing controller in under 20 minutes with simple wiring and setup.
  • Peace of Mind with Wyze Cam Integration: Monitor your lawn watering live and receive notifications if your system is running.
“Wyze Sprinkler Controller is a good value” – Wirecutter
“#1 Affordable Smart Sprinkler Controller” – ZDNet
Technical Specs
  • Supports up to 8 zones
  • Compatible with most residential irrigation systems in North America
  • Requires WiFi connection and power source (hardwired or outdoor outlet)
  • Includes 1 year of Sprinkler Plus weather service
Smartphone controlling sprinkler system outdoors
Wyze Weatherproof Sprinkler Controller Box: Durable Outdoor Protection
Overview
Designed exclusively for the Wyze Sprinkler Controller, this weatherproof box ensures your controller stays safe and functional in any outdoor environment.
Key Features
  • IP65 Weatherproof Rating: Fully protects your controller from rain, dust, and harsh weather.
  • Durable Construction: Features 4 secure clasps and a gridded cover for extra toughness.
  • Flexible Power Options: Supports hardwired power or outdoor outlet connection.
  • Easy Mount Anywhere: Install your Wyze Sprinkler Controller outdoors without worry.
This accessory is essential for homeowners who want to install their sprinkler controller outside while ensuring long-term durability and protection. Outdoor sprinkler controller mounted on wall
Refurbished Wyze Sprinkler Controller: Affordable Smart Irrigation
Overview
For budget-conscious users, the refurbished Wyze Sprinkler Controller offers the same smart features at a reduced price. It provides smart zoned control and app-based management for your irrigation system.
Key Features
  • Personalized watering schedules for up to 8 zones
  • Easy app control with weather-based watering enabled via Sprinkler Plus (1-year free subscription included)
  • Compatible with systems that have master valves or pump relays
  • Quick installation in about 20 minutes
While it lacks the EPA WaterSense certification, it still delivers intelligent watering with weather skips and cycle/soak features through Sprinkler Plus.
Why Choose Wyze WiFi Sprinkler Controllers?
“A green yard doesn’t have to be hard.” – Wyze
Wyze’s WiFi sprinkler controllers transform traditional irrigation systems into smart, connected devices that save water and simplify lawn care. With features like weather-based watering, remote control, and easy installation, these controllers help you maintain a healthy lawn while reducing water waste.
Additional Benefits
  • Smart Schedules: Automatically adjust watering based on weather forecasts and soil moisture.
  • Offline Operation: Continues to run saved schedules for up to 14 days without internet.
  • Cycle/Soak Watering: Breaks watering into cycles to improve soil absorption and prevent runoff.
  • Integration with Wyze Ecosystem: Works seamlessly with Wyze cameras for monitoring and other Wyze smart home devices.
Summary of Wyze WiFi Sprinkler Products
ProductKey FeaturesPrice (New)Zones SupportedWeatherproof
Wyze Sprinkler Controller8 zones, Sprinkler Plus, app control$59.998No
Wyze Weatherproof Controller BoxIP65 rated, outdoor mounting$39.99N/AYes
Refurbished Wyze SprinklerBudget option, same smart features$24.998No
Conclusion
For homeowners seeking a reliable, WiFi-enabled sprinkler controller for residential irrigation, Wyze offers a comprehensive solution. Whether you want the full new controller with weatherproof protection or a refurbished option, Wyze’s smart irrigation products provide water-saving technology, easy app control, and seamless integration with your smart home.
Product Tags and Highlights
Images used are lifestyle-oriented to showcase real-world use of Wyze sprinkler controllers and accessories, enhancing SEO by connecting product features with user experience.
FeatureWyze Sprinkler ControllerWyze Weatherproof Sprinkler Controller Box(Refurbished) Wyze Sprinkler Controller
TypeConnected HomeAccessoriesRefurbished Connected Home
Price$59.99 (Sold out)$39.99$24.99
DescriptionSmart zoned control for irrigation, 8 zones, Wi-Fi, 1 year Sprinkler Plus includedWeatherproof box for mounting Wyze Sprinkler Controller outdoors, IP65 ratedSame as new controller, smart zoned control, 8 zones, Wi-Fi, 1 year Sprinkler Plus included
Zones SupportedUp to 8 zonesN/AUp to 8 zones
Weatherproof RatingNoIP65 (fully weatherproof for outdoor use)No
CompatibilityMost residential irrigation systems in North AmericaCompatible only with Wyze Sprinkler ControllerMost residential irrigation systems in North America
Installation TimeUnder 20 minutesInstallation required for mounting and wiringUnder 20 minutes
Weather-Based Watering (Sprinkler Plus)Yes, includes free 1-year subscriptionN/AYes, includes free 1-year subscription
Smart FeaturesPersonalized schedules, weather skips, moisture insights, app controlN/APersonalized schedules, weather skips, app control
Power RequirementsRequires power to operate irrigation systemHardwire or outdoor outlet powerRequires power to operate irrigation system
WaterSense CertifiedYesN/ANo
Warranty/Return Policy30-day hassle-free returns30-day hassle-free returnsFinal Sale, no returns
Stock StatusSold outLow stock (86 left)Low inventory
What is a WiFi-enabled sprinkler controller and how does it benefit my residential irrigation system?A WiFi-enabled sprinkler controller, like the Wyze Sprinkler Controller, allows you to manage your lawn watering remotely using a smartphone app. It offers customizable schedules, adapts to weather conditions, and helps conserve water, making your irrigation system more efficient and convenient.
How many zones does the Wyze Sprinkler Controller support?The Wyze Sprinkler Controller supports up to 8 irrigation zones, allowing you to manage different areas of your lawn or garden with unique schedules and settings.
Can I control my Wyze Sprinkler Controller remotely?Yes, you can control your Wyze Sprinkler Controller from anywhere using the Wyze app on your smartphone. This includes starting or stopping watering sessions and adjusting schedules remotely.
What is Sprinkler Plus and what features does it offer?Sprinkler Plus is a subscription service included free for one year with Wyze Sprinkler Controllers. It provides hyper-local weather data, smart watering schedules, weather skips, cycle/soak watering, and advanced moisture insights to optimize your irrigation.
Is the Wyze Sprinkler Controller easy to install?Yes, the Wyze Sprinkler Controller is designed for easy DIY installation. Most users can replace their existing irrigation controller in under 20 minutes with simple wiring and setup instructions.
Does the Wyze Sprinkler Controller work with outdoor installations?For outdoor installations, Wyze offers a Weatherproof Sprinkler Controller Box with an IP65 rating. This accessory protects your controller from rain, dust, and harsh weather, ensuring safe and reliable outdoor use.
What is the difference between the new and refurbished Wyze Sprinkler Controllers?The refurbished Wyze Sprinkler Controller offers the same smart features and app-based control as the new model but at a reduced price. However, the refurbished version does not have EPA WaterSense certification.
Is the Wyze Sprinkler Controller compatible with most residential irrigation systems?Yes, the Wyze Sprinkler Controller is compatible with most residential irrigation systems in North America, including those with master valves or pump relays.
What happens if my WiFi goes down? Will the Wyze Sprinkler Controller still work?Yes, the Wyze Sprinkler Controller can continue to run saved watering schedules for up to 14 days without an internet connection, ensuring your lawn stays healthy even during outages.
How does the Wyze Sprinkler Controller help save water?The Wyze Sprinkler Controller uses weather-based watering schedules, weather skips, and cycle/soak features to optimize irrigation and reduce water waste. The new controller is also EPA WaterSense certified for water efficiency.
Can I monitor my lawn watering with Wyze cameras?Yes, the Wyze Sprinkler Controller integrates with Wyze Cam, allowing you to monitor your lawn watering live and receive notifications when your system is running.
What power options are available for the Wyze Sprinkler Controller and Weatherproof Box?Both the Wyze Sprinkler Controller and the Weatherproof Sprinkler Controller Box support hardwired power or connection to an outdoor outlet, providing flexible installation options.
What is the price of the Wyze Sprinkler Controller and its accessories?The Wyze Sprinkler Controller is priced at $59.99 (new), the Weatherproof Controller Box at $39.99, and the refurbished Wyze Sprinkler Controller at $24.99.
Does the Wyze Sprinkler Controller integrate with other Wyze smart home devices?Yes, the Wyze Sprinkler Controller works seamlessly with other Wyze smart home devices, including Wyze cameras, for a connected and convenient smart home experience.
Can you tell me more about the features of the Wyze Weatherproof Sprinkler Controller Box?How does the Sprinkler Plus service enhance the functionality of the Wyze Sprinkler Controller?Do you have any ongoing sales or discounts for the Wyze Sprinkler Controller?
