Buy Affordable Genuine Wyze Robot Vacuum Kits & Dustbins
Affordable Genuine Wyze Robot Vacuum Replacement Kit and Dustbin
If you're looking to buy an affordable and genuine replacement kit or dustbin for your Wyze Robot Vacuum, you've come to the right place. Wyze offers authentic replacement parts designed specifically for their robot vacuum to keep your smart cleaning device running smoothly and efficiently. Below, we highlight the key replacement products that will help maintain your Wyze Robot Vacuum’s performance without breaking the bank.
Wyze Robot Vacuum - Replacement Parts Kit
Complete Maintenance Kit for Your Wyze Robot Vacuum
The Wyze Robot Vacuum Replacement Parts Kit is an all-in-one maintenance solution that includes essential components to keep your vacuum operating at peak efficiency. This kit is perfect for routine upkeep or when you notice a drop in cleaning performance. Included in the Kit:
  • 4 Edge Brushes: Perfect for cleaning corners and edges.
  • 2 Main Brushes: The primary brushes that pick up dirt and debris.
  • 4 HEPA Filters: High-efficiency particulate air filters that trap fine dust and allergens.
  • Price: $22.99
  • Stock: Available
  • Return Policy: 30-day hassle-free returns
This kit ensures your Wyze Robot Vacuum continues to clean effectively by replacing worn-out brushes and filters, which are critical for optimal suction and dust capture.
Keep your home spotless and allergen-free with genuine replacement parts designed specifically for your Wyze Robot Vacuum.
Wyze Robot Vacuum lifestyle Maintain a clean and smart home effortlessly with Wyze Robot Vacuum.
Wyze Robot Vacuum - Dustbin Replacement
Genuine Dustbin for Efficient Dirt Collection
If your Wyze Robot Vacuum’s dustbin is damaged or full beyond cleaning, replacing it with a genuine Wyze dustbin is the best choice. This replacement dustbin is designed to fit perfectly and maintain the vacuum’s suction power and dirt-holding capacity.
  • Price: $9.99
  • Stock: Available
  • Compatibility: Specifically made for Wyze Robot Vacuum
Replacing your dustbin regularly ensures that your vacuum can collect dirt efficiently without leaks or loss of suction, keeping your floors cleaner.
Additional Replacement Parts for Wyze Robot Vacuum
HEPA Filter Replacement
For those who need just the HEPA filter, Wyze offers a standalone replacement filter to maintain air quality and filtration efficiency.
  • Price: $4.99
  • Stock: Available
  • Compatibility: Wyze Robot Vacuum
Charging Station Replacement
If your charging station is lost or malfunctioning, Wyze provides a replacement charging dock to keep your vacuum powered and ready.
  • Price: $19.99
  • Stock: Available
Why Choose Genuine Wyze Replacement Parts?
Using genuine Wyze replacement parts guarantees compatibility, durability, and optimal performance. These parts are designed to fit perfectly and work seamlessly with your Wyze Robot Vacuum, ensuring long-lasting cleaning efficiency and protecting your investment.
Affordable, genuine, and easy to install — Wyze replacement parts keep your smart vacuum running like new.
Summary of Wyze Robot Vacuum Replacement Products
ProductPriceIncluded Items / FeaturesStock
Wyze Robot Vacuum Replacement Kit$22.994 Edge Brushes, 2 Main Brushes, 4 HEPA FiltersAvailable
Wyze Robot Vacuum Dustbin$9.99Genuine dustbin for dirt collectionAvailable
Wyze Robot Vacuum HEPA Filter$4.99Replacement HEPA filterAvailable
Wyze Robot Vacuum Charging Station$19.99Replacement charging dockAvailable
By choosing these affordable and genuine Wyze replacement parts, you ensure your robot vacuum continues to deliver the smart, efficient cleaning you expect.
FeatureWyze Robot Vacuum - Replacement Parts KitWyze Robot Vacuum - Dustbin
TypeReplacement PartsReplacement Parts
Price$22.99 USD$9.99 USD
In the BoxEdge brush x4, Main brush x2, HEPA filter x4Dustbin
CompatibilityOnly for Wyze Robot VacuumOnly for Wyze Robot Vacuum
Return Policy30-day hassle-free returns30-day hassle-free returns
Active CollectionsSmart Home Accessories, Replacement Parts, Shop AllSmart Home Accessories, Replacement Parts, Shop All
Quantity AvailableNot specifiedNot specified
What is included in the Wyze Robot Vacuum Replacement Parts Kit?The Wyze Robot Vacuum Replacement Parts Kit includes 4 edge brushes, 2 main brushes, and 4 HEPA filters. This all-in-one kit is designed to help maintain your vacuum’s cleaning performance and efficiency.
Are Wyze Robot Vacuum replacement parts genuine and compatible?Yes, all Wyze Robot Vacuum replacement parts are genuine and specifically designed for the Wyze Robot Vacuum, ensuring perfect compatibility, durability, and optimal performance.
How much does the Wyze Robot Vacuum Replacement Parts Kit cost?The Wyze Robot Vacuum Replacement Parts Kit is priced at $22.99 and is currently available in stock.
What is the price of the Wyze Robot Vacuum dustbin replacement?The genuine Wyze Robot Vacuum dustbin replacement costs $9.99 and is available for purchase.
Why should I use genuine Wyze replacement parts for my robot vacuum?Using genuine Wyze replacement parts ensures compatibility, long-lasting durability, and optimal cleaning performance. These parts are designed to fit and function seamlessly with your Wyze Robot Vacuum, protecting your investment.
How often should I replace the HEPA filter in my Wyze Robot Vacuum?It is recommended to replace the HEPA filter regularly to maintain air quality and filtration efficiency. Wyze offers standalone HEPA filter replacements for $4.99.
Is there a replacement charging station available for the Wyze Robot Vacuum?Yes, Wyze offers a replacement charging station for the Wyze Robot Vacuum at $19.99. It is designed to keep your vacuum powered and ready for cleaning.
What is the return policy for Wyze Robot Vacuum replacement parts?All Wyze Robot Vacuum replacement parts come with a 30-day hassle-free return policy, allowing you to shop with confidence.
How do I know if the replacement dustbin is compatible with my Wyze Robot Vacuum?The Wyze Robot Vacuum dustbin replacement is specifically made for the Wyze Robot Vacuum, ensuring a perfect fit and maintaining suction power and dirt-holding capacity.
Where can I buy affordable Wyze Robot Vacuum replacement parts?You can purchase affordable and genuine Wyze Robot Vacuum replacement parts, including kits, dustbins, HEPA filters, and charging stations, directly from Wyze’s official website.
What are the key components included in the Wyze Robot Vacuum Replacement Parts Kit?How does the genuine dustbin for the Wyze Robot Vacuum ensure efficient dirt collection?What is the return policy for the Wyze Robot Vacuum replacement parts?
