Buy Genuine HEPA Filters for All Wyze Vacuum Models Online
Genuine Replacement HEPA Filters for All Wyze Vacuum Models
If you own a Wyze vacuum, keeping it running at peak performance means regularly replacing its HEPA filters with genuine parts designed specifically for your model. Wyze offers a range of authentic HEPA filters tailored to fit all their vacuum models, including cordless, handheld, and robot vacuums. This ensures optimal air filtration, dust capture, and overall cleaning efficiency.
Wyze Cordless Vacuum Replacement HEPA Filters
Designed for Wyze Cordless Vacuum
Wyze provides a dedicated HEPA filter replacement pack exclusively for the Wyze Cordless Vacuum. These filters are engineered to fit perfectly and maintain the vacuum’s powerful suction and filtration capabilities.
  • Product: Wyze Cordless Vacuum - HEPA Filter
  • Pack Size: 2 Pack
  • Price: $15.99
Key Features:
  • Genuine Wyze replacement part
  • Easy to install and replace
  • Maintains HEPA filtration efficiency for cleaner air
  • Helps trap fine dust, allergens, and particles
Replacing your cordless vacuum’s HEPA filter regularly ensures your home stays cleaner and your vacuum performs at its best.
Wyze Handheld Vacuum Replacement Filters
Perfect Fit for Wyze Handheld Vacuum
For the compact and versatile Wyze Handheld Vacuum, genuine HEPA filters are available to keep your device running smoothly and filtering air effectively.
  • Product: Wyze Handheld Vacuum Filter
  • Variants: 1 Pack or 3 Pack
  • Price: $13.99 (1 Pack), $9.99 (3 Pack)
Key Features:
  • Specifically designed for Wyze Handheld Vacuum
  • Easy filter replacement to maintain suction power
  • Captures allergens and dust for healthier indoor air
Regular filter replacement is essential to prolong the life of your handheld vacuum and maintain its cleaning power.
Wyze Robot Vacuum HEPA Filters and Maintenance Kit
Genuine HEPA Filter for Wyze Robot Vacuum
Wyze offers a dedicated HEPA filter replacement for the Wyze Robot Vacuum, ensuring your robot vacuum continues to trap dust and allergens effectively.
  • Product: Wyze Robot Vacuum - HEPA Filter
  • Price: $4.99
Key Features:
  • Compatible only with Wyze Robot Vacuum
  • Genuine replacement part for optimal filtration
  • Easy to swap out for continued performance
  • 30-day hassle-free return policy
Comprehensive Replacement Parts Kit
For thorough maintenance, Wyze also provides a full replacement parts kit for the Robot Vacuum, which includes multiple HEPA filters along with brushes to keep your vacuum in top shape.
  • Product: Wyze Robot Vacuum - Replacement Parts Kit
  • Price: $22.99
Includes:
  • 4 Edge brushes
  • 2 Main brushes
  • 4 HEPA filters
Benefits:
  • Complete maintenance solution
  • Extends vacuum lifespan
  • Ensures consistent cleaning and filtration
Keeping your Wyze Robot Vacuum’s HEPA filter fresh is key to maintaining clean floors and healthy air quality in your home.
Wyze Vacuum Lifestyle Replacing your Wyze vacuum filter regularly keeps your home clean and air fresh.
Why Choose Genuine Wyze HEPA Filters?
Using genuine Wyze replacement HEPA filters guarantees compatibility and performance. These filters are designed to meet Wyze’s high standards for air purification and dust capture, ensuring your vacuum operates efficiently and your indoor air remains clean.
  • Perfect Fit: Designed specifically for each Wyze vacuum model
  • High Filtration Efficiency: Captures fine dust, allergens, and particles
  • Easy Installation: Quick and hassle-free filter swaps
  • Affordable Pricing: Cost-effective packs and kits for all models
Regularly replacing your vacuum’s HEPA filter is essential for maintaining suction power and air quality, making genuine Wyze filters the best choice for your home cleaning needs.
Summary of Wyze Vacuum HEPA Filter Options
Vacuum ModelProduct NamePack SizePrice
Wyze Cordless VacuumWyze Cordless Vacuum - HEPA Filter2 Pack$15.99
Wyze Handheld VacuumWyze Handheld Vacuum Filter1 Pack / 3 Pack$13.99 / $9.99
Wyze Robot VacuumWyze Robot Vacuum - HEPA FilterSingle$4.99
Wyze Robot VacuumWyze Robot Vacuum - Replacement KitFull Kit (filters + brushes)$22.99
Ensure your Wyze vacuum continues to deliver powerful cleaning and fresh air by choosing genuine replacement HEPA filters designed for your specific model.
Product NameCompatible WithTypePack Size / ContentsPrice (USD)Description / NotesReturn Policy
Wyze Cordless Vacuum - HEPA FilterWyze Cordless VacuumAccessories2 Pack15.99Replace regularly. Only for Wyze Cordless Vacuum.30-day hassle-free returns
Wyze Handheld Vacuum FilterWyze Handheld VacuumAccessories1 Pack, 3 Pack9.99, 13.99Replace regularly. Only for Wyze Handheld Vacuum.30-day hassle-free returns
Wyze Robot Vacuum - HEPA FilterWyze Robot VacuumReplacement PartsDefault (1 filter)4.99Replacement HEPA vacuum filter.30-day hassle-free returns
Wyze Robot Vacuum - Replacement Parts KitWyze Robot VacuumReplacement PartsEdge brush4, Main brush2, HEPA filter*422.99Full maintenance kit including brushes and filters30-day hassle-free returns
What types of Wyze vacuum HEPA filters are available?Wyze offers genuine HEPA replacement filters for all their vacuum models, including the Wyze Cordless Vacuum, Wyze Handheld Vacuum, and Wyze Robot Vacuum. Each filter is specifically designed to fit its respective model for optimal performance and air filtration.
Why should I use genuine Wyze HEPA filters for my vacuum?Genuine Wyze HEPA filters are engineered to fit perfectly and maintain the high filtration efficiency of your Wyze vacuum. Using authentic filters ensures optimal dust and allergen capture, maintains suction power, and helps keep your indoor air clean.
How often should I replace my Wyze vacuum HEPA filter?For best performance and air quality, it is recommended to replace your Wyze vacuum HEPA filter regularly. The frequency depends on usage, but replacing the filter every 1-3 months is a good guideline to ensure your vacuum continues to operate efficiently.
Are Wyze HEPA filters easy to install and replace?Yes, all genuine Wyze HEPA filters are designed for quick and hassle-free installation. Simply remove the old filter and insert the new one to maintain your vacuum’s cleaning power and filtration efficiency.
What is included in the Wyze Cordless Vacuum HEPA filter pack?The Wyze Cordless Vacuum HEPA filter pack includes two genuine replacement filters for $15.99. These filters are specifically designed for the Wyze Cordless Vacuum and help maintain powerful suction and air filtration.
What options are available for Wyze Handheld Vacuum replacement filters?Wyze Handheld Vacuum replacement filters are available in a 1 Pack for $13.99 or a 3 Pack for $9.99. These filters are designed to fit the Wyze Handheld Vacuum and help capture dust and allergens for healthier indoor air.
What replacement parts are available for the Wyze Robot Vacuum?For the Wyze Robot Vacuum, you can purchase a single HEPA filter for $4.99 or a comprehensive Replacement Parts Kit for $22.99. The kit includes 4 edge brushes, 2 main brushes, and 4 HEPA filters, providing a complete maintenance solution.
Are Wyze HEPA filters compatible with all Wyze vacuum models?Wyze offers specific HEPA filters for each vacuum model—Cordless, Handheld, and Robot. It is important to choose the filter designed for your specific Wyze vacuum to ensure compatibility and optimal performance.
What are the benefits of regularly replacing my Wyze vacuum HEPA filter?Regularly replacing your Wyze vacuum HEPA filter helps maintain strong suction power, ensures effective dust and allergen capture, prolongs the life of your vacuum, and keeps your home’s air fresh and clean.
Is there a return policy for Wyze Robot Vacuum HEPA filters?Yes, Wyze Robot Vacuum HEPA filters come with a 30-day hassle-free return policy, allowing you to shop with confidence.
What are the key features of the genuine HEPA filters for the Wyze Cordless Vacuum?How often should I replace the HEPA filters in my Wyze vacuum?Are there any discounts or promotions available for Wyze vacuum filters?
