Replacement Foldable Vacuum Tube for Wyze Cordless Vacuum S
If you own the Wyze Cordless Vacuum S, keeping your vacuum in top shape with genuine replacement parts is essential. The Wyze Cordless Vacuum - Foldable Vacuum Tube is the perfect accessory designed specifically for your Wyze vacuum, allowing you to maintain its flexibility and ease of use without hassle.
"Bends so you do not have to."
This foldable tube accessory is engineered to provide effortless maneuverability, making your cleaning routine smoother and more comfortable.
Wyze Cordless Vacuum S: Powerful, Lightweight, and Smart
The Wyze Cordless Vacuum S is a standout in the cordless vacuum market, combining impressive suction power with a featherlight design.
Key Features:
  • Suction Power: Up to 20,000 Pa in Turbo Mode, with 100 AW for deep cleaning.
  • Lightweight Design: Weighs only 2.8 lbs for the main unit, and 4.9 lbs when fully assembled, making it easy to carry and use around the house.
  • Battery Life: Interchangeable 6-cell lithium-ion battery offering up to 40 minutes of runtime in ECO mode.
  • Dual Motors: Two motors ensure powerful suction and efficient cleaning.
  • 3-Stage Filtration System: Keeps dust and allergens contained.
  • LED Screen & Brush Head Lights: Six daylight-bright LEDs illuminate your cleaning path for better visibility.
  • Attachments Included: Comes with a crevice tool, floor brush, dust cap, HEPA filter, filter housing, and the standard tube.
Dimensions & Design:
  • Main unit: 12.4 x 4.5 x 8.7 inches
  • Assembled unit length: 41.1 inches
  • Color: Steel grey with Wyze green accents
This vacuum is perfect for pet owners, hardwood floors, and quick cleanups around the home. Wyze Cordless Vacuum in Use Effortless vacuuming with Wyze Cordless Vacuum S
Why Choose the Wyze Cordless Vacuum - Foldable Vacuum Tube?
The foldable vacuum tube is a must-have replacement part for your Wyze Cordless Vacuum S. Over time, the original tube may wear out or lose its flexibility, impacting your vacuuming experience.
Benefits:
  • Perfect Compatibility: Designed exclusively for the Wyze Cordless Vacuum.
  • Enhanced Flexibility: The foldable design allows you to reach tight spaces and awkward angles without bending yourself.
  • Affordable Replacement: Priced reasonably to keep your vacuum functioning like new.
  • Durable Build: Made to withstand regular use and maintain its shape.
At just $15.99 (compared to the original $29.99), this replacement tube is a smart investment to extend the life of your vacuum.
Additional Accessories for Wyze Cordless Vacuum
To keep your vacuum performing at its best, consider also replacing the Wyze Cordless Vacuum - HEPA Filter regularly. This ensures optimal filtration and air quality during cleaning.
  • HEPA Filter 2-Pack: Designed for the Wyze Cordless Vacuum, these filters trap fine dust and allergens effectively.
Summary
Maintaining your Wyze Cordless Vacuum S with genuine replacement parts like the Foldable Vacuum Tube ensures you enjoy the full benefits of its powerful suction, lightweight design, and smart features. Whether you’re cleaning pet hair, hardwood floors, or tight corners, the foldable tube accessory makes your vacuuming easier and more efficient. Upgrade your cleaning experience today with the Wyze Cordless Vacuum and its compatible foldable vacuum tube! Wyze Cordless Vacuum Lifestyle Wyze Cordless Vacuum S in action, perfect for everyday home cleaning
FeatureWyze Cordless Vacuum SWyze Cordless Vacuum - Foldable Vacuum TubeWyze Cordless Vacuum - HEPA Filter
TypeConnected HomeAccessoriesAccessories
DescriptionCordless vacuum with 20,000 Pa suction power, 40-minute interchangeable lithium-ion battery, two motors, weighs 2.8 lbsFoldable vacuum tube accessory for Wyze Cordless VacuumReplacement HEPA filter for Wyze Cordless Vacuum, sold in 2-pack
Price$139.99$15.99$15.99 (2 Pack)
Suction PowerUp to 20,000 PaN/AN/A
Battery LifeUp to 40 minutesN/AN/A
Weight2.8 lbsN/AN/A
CompatibilityWyze Cordless Vacuum SOnly for Wyze Cordless VacuumOnly for Wyze Cordless Vacuum
FeaturesTwo motors, 3 cleaning speeds, LED display, 6 LED lights on brush head, 3-stage filtration with HEPA filter, washable dust cup and filtersFoldable design for easier cleaningHEPA filter removes 95% of particles <0.3 µm, replace regularly
Return Policy30-day hassle-free returns30-day hassle-free returnsNot specified
What is the Wyze Cordless Vacuum - Foldable Vacuum Tube?The Wyze Cordless Vacuum - Foldable Vacuum Tube is a genuine replacement accessory designed specifically for the Wyze Cordless Vacuum S. It provides enhanced flexibility and maneuverability, allowing you to clean tight spaces and awkward angles with ease.
Is the foldable vacuum tube compatible with all Wyze vacuums?No, the foldable vacuum tube is designed exclusively for the Wyze Cordless Vacuum S. It ensures a perfect fit and optimal performance for this specific model.
Why should I replace my Wyze Cordless Vacuum tube?Over time, the original vacuum tube may wear out or lose its flexibility, which can impact your vacuuming experience. Replacing it with a genuine foldable vacuum tube restores your vacuum’s maneuverability and efficiency.
What are the benefits of using the foldable vacuum tube for Wyze Cordless Vacuum S?The foldable vacuum tube offers enhanced flexibility, allowing you to reach tight spaces without bending yourself. It is durable, affordable, and maintains the vacuum’s ease of use and cleaning performance.
How much does the Wyze Cordless Vacuum - Foldable Vacuum Tube cost?The replacement foldable vacuum tube is priced at $15.99, making it an affordable way to keep your Wyze Cordless Vacuum S functioning like new.
What are the key features of the Wyze Cordless Vacuum S?The Wyze Cordless Vacuum S features up to 20,000 Pa suction power in Turbo Mode, a lightweight design (2.8 lbs for the main unit), up to 40 minutes of battery life in ECO mode, dual motors, a 3-stage filtration system, LED screen and brush head lights, and multiple attachments including a crevice tool, floor brush, dust cap, HEPA filter, filter housing, and the standard tube.
Are there other replacement parts available for the Wyze Cordless Vacuum S?Yes, in addition to the foldable vacuum tube, you can also purchase genuine Wyze Cordless Vacuum HEPA filters. Regularly replacing the HEPA filter ensures optimal filtration and air quality during cleaning.
How do I maintain my Wyze Cordless Vacuum S for best performance?To keep your Wyze Cordless Vacuum S performing at its best, use genuine replacement parts like the foldable vacuum tube and HEPA filters. Regular maintenance and timely replacement of these parts ensure powerful suction, efficient cleaning, and improved air quality.
Is the foldable vacuum tube easy to install?Yes, the foldable vacuum tube is designed for easy installation and perfect compatibility with the Wyze Cordless Vacuum S, allowing you to quickly replace the old tube and resume cleaning.
What are the benefits of using the foldable vacuum tube with my Wyze Cordless Vacuum S?Can you tell me more about the HEPA filter for the Wyze Cordless Vacuum?What is the warranty policy for the Wyze Cordless Vacuum S?
