Smart Sensor for Home Temperature Balance & Motion Detection
Sensor That Balances Home Temperature with Motion Sensing Function
Creating a comfortable and energy-efficient home environment requires smart devices that can monitor temperature and detect motion seamlessly. If you're looking for a sensor system that balances home temperature while incorporating motion sensing capabilities, Wyze offers an integrated solution designed to meet these needs.
Wyze Sense Climate Sensor: Precise Temperature & Humidity Monitoring
The Wyze Sense Climate Sensor is engineered to track temperature and humidity levels throughout your home, helping you maintain an ideal indoor climate effortlessly.
  • Accurate Climate Tracking: Monitors temperature and humidity in real-time.
  • Wide Range: Operates up to 500 feet from the Wyze Sense Hub, allowing placement in distant rooms, basements, or attics.
  • Sleek & Compact Design: Its unobtrusive white finish blends into any home décor.
  • Flexible Installation: Place it on any surface or use the peel-and-stick adhesive backing to mount it on walls.
  • App Integration: View and manage climate data conveniently through the Wyze app.
This sensor is designed to work exclusively with the Wyze Sense v2 system and requires the Wyze Sense Hub to function.
Wyze Sense Motion Sensor: Intelligent Motion Detection for Your Home
Complementing the climate sensor, the Wyze Sense Motion Sensor adds motion detection capabilities to your home monitoring setup, enabling smart automation based on presence and movement.
  • Motion Detection Range: Detects motion up to 25 feet with a 120° field of view.
  • Adjustable Sensitivity: Customize detection sensitivity to suit your environment.
  • Long Battery Life: Operates up to 18 months on a single battery.
  • Installation Options: Easily mount with adhesive backing or secure with screws.
  • Indoor Use: Perfect for rooms, hallways, or entryways.
  • Compatibility: Works with Wyze Sense v2 and Wyze Home Monitoring systems.
By combining motion sensing with temperature monitoring, you can automate your home's heating or cooling systems to adjust based on occupancy, optimizing comfort and energy savings.
Wyze Sense Hub: The Central Control Unit
At the heart of this smart sensor ecosystem is the Wyze Sense Hub, which connects all Wyze Sense sensors and manages communication between devices and your smartphone.
  • Core of the System: Acts as the brains behind all connected sensors.
  • Real-Time Alerts: Sends instant notifications to your phone for motion or climate changes.
  • Easy Setup: Simple plug-and-play design to get your home monitoring up and running quickly.
  • Supports Multiple Sensors: Connects up to 100 sensors for comprehensive home coverage.
The hub is essential for enabling the climate and motion sensors to work together, providing a unified smart home experience.
Why Choose Wyze Sensors for Home Temperature and Motion Sensing?
Combining the Wyze Sense Climate Sensor and Motion Sensor with the Wyze Sense Hub creates a powerful system that balances your home's temperature intelligently by detecting motion and occupancy. This integration helps reduce energy waste by adjusting heating or cooling only when rooms are in use.
  • Energy Efficiency: Automatically optimize HVAC usage based on room occupancy.
  • Convenience: Monitor and control your home's environment remotely via the Wyze app.
  • Scalability: Add multiple sensors to cover every room or area in your home.
  • Affordable Smart Home Solution: High-quality sensors at budget-friendly prices.
Cozy Living Room with Smart Sensors Smart home environment enhanced by Wyze sensors for comfort and security
Summary of Key Specs
ProductKey FeaturesCompatibilityPrice (USD)
Wyze Sense Climate SensorTemperature & humidity tracking, 500 ft rangeWyze Sense v2, Hub$41.98 (3 Pack)
Wyze Sense Motion SensorMotion detection up to 25 ft, adjustable sensitivityWyze Sense v2, Hub$20.98 (1 Pack)
Wyze Sense HubCentral control, connects up to 100 sensorsAll Wyze Sense devices$45.98
Enhance Your Smart Home Today
Integrate the Wyze Sense Climate Sensor and Motion Sensor with the Wyze Sense Hub to create a smart environment that balances temperature intelligently based on motion detection. This system not only improves comfort but also helps you save on energy costs by heating or cooling rooms only when needed.
FeatureWyze Sense Climate SensorWyze Sense Motion SensorWyze Sense Hub
PurposeTracks temperature and humidityDetects motionConnects monitoring components and sends alerts
RequiresWyze Sense HubWyze Sense HubN/A
CompatibilityWyze Sense v2, Wyze Home MonitoringWyze Sense v2, Wyze Home MonitoringSupports up to 100 sensors
Range500 ft25 ft detection range, 120° FOV500 ft RF range to sensors
DesignSleek, white, unobtrusiveSmall, adhesive back, option for screwsWhite base with grey speaker top, matte finish
InstallationSet on surface or peel-and-stick adhesive backingAdhesive back or screwsIndoor use only
BatteryNot specified (sensor powered)Not specified (sensor powered)Built-in rechargeable battery (3.7V, 2600mAh)
Battery Backup LifeN/AN/A10 hours
Communication MethodsRF (via Hub)RF (via Hub)Ethernet, WiFi 2.4 GHz, Bluetooth 4.1+ BLE, 915MHz RF
Operating TemperatureIndoor use onlyIndoor use only32°F - 104°F (0°C - 40°C)
Indoor/Outdoor UseIndoor onlyIndoor onlyIndoor only
Alerts/NotificationsVia Wyze appMotion detected notifications via Wyze appSends alerts from connected sensors
Pack Size & Price3 Pack - $41.981 Pack - $20.98Default - $45.98
Additional FeaturesTracks temperature and humidityAdjustable sensitivity, pet immunity modeSiren (88db @ 2 ft), supports up to 100 sensors
What is the Wyze Sense Climate Sensor and how does it work?The Wyze Sense Climate Sensor is a smart device designed to monitor temperature and humidity levels in your home. It provides real-time climate tracking and can be placed up to 500 feet from the Wyze Sense Hub. The sensor helps you maintain an ideal indoor environment and integrates with the Wyze app for easy monitoring and control.
How does the Wyze Sense Motion Sensor enhance home automation?The Wyze Sense Motion Sensor detects motion up to 25 feet with a 120° field of view, allowing you to automate your home's heating or cooling systems based on occupancy. It features adjustable sensitivity, long battery life, and can be easily installed in rooms, hallways, or entryways for intelligent motion detection.
What is the Wyze Sense Hub and why is it necessary?The Wyze Sense Hub is the central control unit that connects all Wyze Sense sensors, including the Climate and Motion Sensors. It manages communication between devices and your smartphone, sends real-time alerts, and supports up to 100 sensors for comprehensive home coverage. The hub is required for the sensors to function together.
Can I monitor and control Wyze sensors remotely?Yes, you can monitor and control all Wyze sensors remotely through the Wyze app. The app allows you to view real-time temperature, humidity, and motion data, as well as receive instant notifications for any changes detected by the sensors.
Are Wyze sensors compatible with other smart home systems?Wyze Sense Climate and Motion Sensors are designed to work exclusively with the Wyze Sense v2 system and require the Wyze Sense Hub. They are also compatible with Wyze Home Monitoring systems, but not with other third-party smart home platforms.
How do Wyze sensors help save energy in my home?Wyze sensors help save energy by automating your HVAC system to adjust heating or cooling based on room occupancy. By only conditioning rooms when motion is detected, the system reduces unnecessary energy usage and lowers utility costs.
What are the installation options for Wyze sensors?Wyze sensors offer flexible installation options. Both the Climate and Motion Sensors can be placed on any surface or mounted using the included peel-and-stick adhesive backing. The Motion Sensor can also be secured with screws for added stability.
How many Wyze sensors can I connect to one Wyze Sense Hub?You can connect up to 100 Wyze Sense sensors to a single Wyze Sense Hub, allowing you to monitor and automate multiple rooms or areas throughout your home.
What is the battery life of the Wyze Sense Motion Sensor?The Wyze Sense Motion Sensor features a long battery life, operating for up to 18 months on a single battery, ensuring reliable performance with minimal maintenance.
What is the price of Wyze Sense Climate Sensor, Motion Sensor, and Hub?The Wyze Sense Climate Sensor is priced at $41.98 for a 3-pack, the Wyze Sense Motion Sensor is $20.98 for a single pack, and the Wyze Sense Hub costs $45.98.
Can you tell me more about the Wyze Sense Hub and its features?How does the Wyze Sense Climate Sensor integrate with the Wyze app?Do you have any ongoing promotions or discounts for the Wyze Sense products?
