Weather Resistant Indoor Outdoor Security Camera Bundles 24/7
Weather Resistant Indoor Outdoor Security Camera Bundle for Constant Recording
When it comes to securing your home or business, having reliable, weather-resistant cameras that offer constant recording is essential. Whether you need indoor monitoring or outdoor surveillance that withstands the elements, Wyze offers a range of advanced security cameras designed to keep you connected and protected 24/7. This guide highlights the best Wyze camera options for indoor and outdoor use, focusing on weather resistance, continuous recording capabilities, and smart features that enhance your security setup.
Wyze Cam Pan v3: Versatile 360° Weatherproof Security
Wyze Cam Pan v3 in snowy outdoor setting Experience full 360° coverage with Wyze Cam Pan v3, built for all-weather protection. The Wyze Cam Pan v3 is a redesigned indoor/outdoor security camera that offers a full 360° pan and 180° tilt, allowing you to monitor every corner of your property effortlessly. Its IP65 weather resistance rating means it can brave rain, snow, and dust, making it perfect for outdoor use when paired with the Wyze Outdoor Power Adapter (sold separately).
Key Features:
  • 360° Pan & 180° Tilt: Complete room or yard coverage with smooth, quiet motorized movement.
  • IP65 Weather Resistant: Durable against rain and snow for reliable outdoor surveillance.
  • Automatic Motion Tracking: The camera detects and follows motion automatically, ensuring nothing escapes its view.
  • Color Night Vision: See vivid details even in low light with the Starlight Sensor.
  • Two-Way Audio: Communicate through the camera using the Wyze app.
  • Privacy Mode: Easily disable the camera’s view when you want privacy.
  • Local Storage & Cloud Options: Supports microSD cards for continuous recording and optional Cam Plus subscription for advanced notifications.
This camera is ideal for users who want a flexible, weatherproof solution that can be used both indoors and outdoors with constant recording capabilities.
Wyze Cam v4: Crystal-Clear 2.5K QHD with Spotlight and Weatherproof Design
Wyze Cam v4 is the clearest Wyze camera yet, delivering 2.5K Quad HD resolution and enhanced color night vision. It’s designed for both indoor and outdoor use with an IP65 weather resistance rating, making it a perfect all-around security camera for constant monitoring.
Highlights:
  • 2.5K QHD Resolution: Capture sharp, detailed video footage day and night.
  • Enhanced Color Night Vision: See vibrant colors in low light, improving nighttime security.
  • Motion-Activated Spotlight & Siren: Deter intruders with a bright spotlight and loud siren.
  • 24/7 Local Recording: Supports continuous recording to microSD cards up to 256GB without subscription.
  • Wi-Fi 6 Support: Enjoy a stronger, more reliable connection.
  • Smart Assistant Compatibility: Works seamlessly with Alexa, Google Assistant, and IFTTT.
  • Easy Setup: Bluetooth-enabled setup and magnetic mount for hassle-free installation.
Wyze Cam v4 is perfect for users seeking high-resolution video and smart features in a weatherproof camera that records continuously.
Wyze Cam Floodlight v2: Brighten and Secure Your Outdoor Spaces
Wyze Cam Floodlight v2 illuminating driveway at night Illuminate and protect your property with Wyze Cam Floodlight v2’s powerful 2800 lumens. For those who want to combine lighting and security, the Wyze Cam Floodlight v2 offers a powerful 2800 lumens LED floodlight integrated with a 2K resolution camera. This camera is designed specifically for outdoor use with IP65 weather resistance and advanced AI-powered light control.
Features:
  • 2K Video with Color Night Vision: Clear, colorful footage even in darkness.
  • 160° Wide-Angle View: Covers large outdoor areas like driveways and backyards.
  • Dusk-to-Dawn Automation: Automatically turns lights on and off based on ambient light.
  • Two-Way Audio & Siren: Communicate and deter unwanted visitors with built-in speaker and 105dB siren.
  • AI-Powered Light Control: Lights adjust intelligently based on detected motion.
  • 24/7 Local Recording: Supports microSD cards up to 256GB for continuous video capture.
  • Smart Home Integration: Compatible with Alexa, Google Assistant, and IFTTT.
This floodlight camera is ideal for outdoor areas requiring bright illumination and constant surveillance.
Wyze Battery Cam Pro: Wire-Free, Weatherproof Security with Long Battery Life
Wyze Battery Cam Pro offers a wire-free solution with 2.5K HDR video quality and IP65 weatherproofing, making it perfect for flexible indoor or outdoor placement without the need for power cables.
Advantages:
  • Wire-Free Design: No hub required, powered by removable rechargeable batteries lasting up to 6 months.
  • 2.5K HDR Video: High-resolution footage with excellent dynamic range.
  • Integrated Spotlight & Siren: Built-in lighting and 100dB siren for deterrence.
  • Radar + PIR Motion Detection: Advanced motion sensing for accurate alerts.
  • Two-Way Audio: Talk and listen through the camera.
  • Supports 2.4 & 5 GHz Wi-Fi: Reliable connectivity options.
  • Local Storage: Supports microSD cards up to 256GB for continuous recording.
Perfect for users who want a flexible, battery-powered camera that can be placed anywhere and withstands harsh weather conditions.
Wyze Cam v4 Home Security Bundle: Complete Indoor/Outdoor Protection
For those looking for an all-in-one package, the Wyze Cam v4 Home Security Bundle combines multiple Wyze Cam v4 cameras with accessories to provide comprehensive indoor and outdoor coverage.
Bundle Benefits:
  • Multiple Cameras Included: Extend your security coverage with several cameras.
  • 2.5K QHD Video & Enhanced Night Vision: High-quality video for all cameras.
  • IP65 Weather Resistance: Suitable for both indoor and outdoor use.
  • Motion-Activated Spotlight & Person Detection: Advanced security features to keep you informed.
  • 128GB MicroSD Card Included: Supports up to 192 hours of continuous HD video recording.
  • Multiple Mounting Options: Stand, wall, ceiling, or magnetic mounts for versatile installation.
This bundle is ideal for users who want a ready-to-go, weatherproof security system with constant recording and smart features.
Why Choose Wyze for Your Indoor/Outdoor Security Needs?
Wyze cameras combine affordability with advanced technology, offering weather-resistant designs, continuous local recording, and smart features like motion tracking, color night vision, and two-way audio. Whether you want wired or wireless options, floodlight integration, or a complete security bundle, Wyze has you covered for constant, reliable surveillance indoors and outdoors.
Summary Table of Key Specs
ProductResolutionWeather ResistanceRecording TypeSpecial Features
Wyze Cam Pan v31080pIP65Local (microSD)360° pan/180° tilt, motion tracking
Wyze Cam v42.5K QHDIP6524/7 Local (microSD)Spotlight, siren, Wi-Fi 6
Wyze Cam Floodlight v22KIP6524/7 Local (microSD)2800 lumens floodlight, AI lighting
Wyze Battery Cam Pro2.5K HDRIP65Local (microSD)Wire-free, radar + PIR detection
Wyze Cam v4 Bundle2.5K QHDIP6524/7 Local (microSD)Multiple cams, spotlight, person detection
Secure your home or business with Wyze’s weather-resistant indoor/outdoor cameras designed for constant recording and smart home integration. Choose the model that fits your needs and enjoy peace of mind with crystal-clear video and reliable protection in any weather.
FeatureWyze Cam Pan v3Wyze Cam v4Wyze Cam Floodlight v2Wyze Battery Cam ProWyze Cam v4 Home Security Bundle
Video Resolution1080p2.5K QHD (2560x1440)2K (2304x1296)2.5K HDR (2560x1440)2.5K QHD (2560x1440)
Field of View360° pan, 180° tilt115.9° (D) x 98.5° (H) x 53.1° (V)160° diagonal134° (DFOV), 108° (HFOV), 56° (VFOV)DFOV 115.8°, HFOV 98.5°, VFOV 53.1°
Night VisionColor Night Vision (Starlight Sensor)Enhanced Color Night VisionColor Night VisionIR LEDs + White LEDs (Color Night Vision)Color Night Vision + IR LEDs + Spotlight LEDs
Weather ResistanceIP65 (requires Outdoor Power Adapter)IP65IP65IP65IP65
Power SourceWired (requires Outdoor Power Adapter for outdoor)WiredHardwiredBattery (Removable, Rechargeable)Wired
AudioTwo-Way AudioEnhanced Two-Way TalkTwo-Way AudioTwo-Way AudioImproved Two-Way Audio
SpotlightNo (sold separately)Yes (motion-activated)Yes (2 dimmable LED panels)Integrated SpotlightYes (motion-activated)
SirenNoYes (99 dB)Yes (105 dB)Yes (100 dB)Not specified
Motion DetectionYes (automatic motion tracking)Yes (motion and sound detection)YesRadar + PIR Motion DetectionYes (person detection)
Local Storage SupportmicroSD up to 256GBmicroSD up to 256GBmicroSD up to 256GBmicroSD up to 256GBmicroSD up to 128GB
Cloud Storage SubscriptionCam Plus availableCam Plus availableCam Plus availableCam Plus availableCam Plus available
ConnectivityWi-FiWi-Fi 62.4 GHz Wi-Fi2.4 & 5 GHz Wi-FiWi-Fi 6
DimensionsNot specified2in x 2in x 2 3/8in (51 x 51 x 60 mm)9.5in x 7.7in x 7.0in (24.13 x 19.56 x 17.78 cm)2.5 x 1.8 x 3.5 inches (63.5 x 45.7 x 88.9 mm)2in x 2in x 2 3/8in (51 x 51 x 60 mm)
WeightNot specified0.49 lb (222 g)2.76 lbs (1.25 kg)0.94 lbs (426 g)0.49 lb (222 g)
Mounting OptionsIndoor/outdoor (requires adapter)Stand, Wall, Ceiling, Magnetic mountWall, CeilingWall mount includedStand, Wall, Ceiling, Magnetic mount
Special FeaturesPrivacy Mode, Pan Scan™, Quiet motorAuto-zoom with AI, Wi-Fi 6, SpotlightAmbient Light Mode, Dusk-to-Dawn automationRadar + PIR motion detection, Rechargeable batteryBundle includes Wyze Cam v4 with accessories
Price (Single Unit)$39.98$35.98$89.98$159.98$169.99
What makes Wyze security cameras suitable for both indoor and outdoor use?Wyze security cameras are designed with IP65 weather resistance, making them durable against rain, snow, and dust. This ensures reliable performance both indoors and outdoors, providing constant surveillance in any environment.
Which Wyze cameras support continuous 24/7 recording?Wyze Cam Pan v3, Wyze Cam v4, Wyze Cam Floodlight v2, Wyze Battery Cam Pro, and the Wyze Cam v4 Home Security Bundle all support continuous 24/7 recording via local storage on microSD cards.
Do Wyze cameras require a subscription for constant recording?No, Wyze cameras support continuous local recording to microSD cards without a subscription. However, optional cloud services like Cam Plus are available for advanced notifications and cloud storage.
What is the video resolution of Wyze security cameras?Wyze cameras offer various resolutions: Wyze Cam Pan v3 records in 1080p, Wyze Cam v4 and Wyze Battery Cam Pro provide 2.5K QHD/HDR video, and Wyze Cam Floodlight v2 delivers 2K resolution for clear, detailed footage.
Are Wyze cameras compatible with smart home assistants?Yes, Wyze cameras work seamlessly with Alexa, Google Assistant, and IFTTT, allowing for easy integration into your smart home ecosystem.
What special features do Wyze security cameras offer for enhanced security?Wyze cameras include features such as color night vision, motion tracking, two-way audio, motion-activated spotlights, built-in sirens, AI-powered light control, and person detection to enhance your security setup.
Can Wyze cameras be installed wire-free?Yes, the Wyze Battery Cam Pro offers a wire-free design powered by rechargeable batteries, allowing flexible placement without the need for power cables.
How much local storage do Wyze cameras support for continuous recording?Wyze cameras support microSD cards up to 256GB for continuous recording, with the Wyze Cam v4 Home Security Bundle including a 128GB microSD card for up to 192 hours of HD video storage.
What is included in the Wyze Cam v4 Home Security Bundle?The Wyze Cam v4 Home Security Bundle includes multiple Wyze Cam v4 cameras, a 128GB microSD card, and various mounting accessories, providing comprehensive indoor and outdoor security coverage.
How do Wyze cameras perform at night or in low-light conditions?Wyze cameras feature enhanced color night vision and starlight sensors, allowing them to capture vivid, detailed footage even in low-light or nighttime conditions.
What is the benefit of the Wyze Cam Floodlight v2 for outdoor security?The Wyze Cam Floodlight v2 combines a powerful 2800 lumens LED floodlight with a 2K resolution camera, offering bright illumination, wide-angle coverage, AI-powered light control, and constant video recording for superior outdoor security.
How long does the battery last on the Wyze Battery Cam Pro?The Wyze Battery Cam Pro is powered by removable rechargeable batteries that can last up to 6 months on a single charge, depending on usage and settings.
What mounting options are available for Wyze security cameras?Wyze cameras offer versatile mounting options, including stand, wall, ceiling, and magnetic mounts, making installation easy and adaptable to different locations.
What are the key features of the Wyze Cam Pan v3?Can you tell me more about the Wyze Cam v4 and its capabilities?Are there any ongoing sales or discounts for Wyze cameras?
