Outdoor IP65 Security Cameras with MicroSD & Solar Power
Outdoor IP65 Security Cameras with MicroSD Recording and Solar Power Options
When it comes to securing your outdoor spaces, choosing the right security camera is essential. For those seeking durable, weather-resistant cameras with local MicroSD recording and options for battery or solar power, Wyze offers a range of IP65-rated outdoor cameras designed to meet these needs. Below, we explore the top Wyze outdoor security cameras that combine advanced features like high-resolution video, color night vision, two-way audio, and flexible power solutions to keep your property safe around the clock.
Wyze Cam v4: The Ultimate Outdoor Security Camera
Superior Video Quality and Night Vision
Wyze Cam v4 delivers crystal-clear 2.5K QHD resolution, providing sharp and detailed footage day or night. Its enhanced color night vision uses advanced hardware to reveal vibrant colors even in low-light conditions, far surpassing traditional black-and-white night vision.
Robust IP65 Weather Resistance
Built to withstand the elements, the Wyze Cam v4 is rated IP65, making it fully weather-resistant. Whether rain, snow, or dust, this camera keeps recording without interruption, perfect for any outdoor environment.
Continuous Local Recording with MicroSD Support
Enjoy 24/7 local recording directly to a MicroSD card (up to 256GB supported), ensuring you never miss a moment without relying on cloud subscriptions. This feature offers privacy and convenience with no monthly fees.
Motion-Activated Spotlight and Siren
The integrated motion-activated spotlight illuminates your property when movement is detected, deterring intruders and lighting your way. Additionally, a loud 99 dB siren can be triggered remotely for extra security.
Smart Home Integration and Easy Setup
Wyze Cam v4 supports Wi-Fi 6 for a stronger connection and integrates seamlessly with Alexa, Google Assistant, and IFTTT. Its screw-free magnetic mount allows for quick and tool-free installation.
"Wyze Cam v4 is the clearest Wyze Cam ever made, combining high resolution, color night vision, and IP65 weather resistance for unmatched outdoor security."
Wyze Cam v4 Outdoor Lifestyle Wyze Cam v4 installed outdoors, showcasing its sleek design and smart home integration.
Wyze Cam Pan v3: Dynamic 360° Outdoor Surveillance
Full Pan and Tilt Coverage
Wyze Cam Pan v3 offers 360° horizontal pan and 180° vertical tilt, allowing you to monitor wide outdoor areas with a single camera. Its upgraded tracking motor quietly follows motion automatically, ensuring nothing escapes its view.
IP65 Weatherproof Design
Designed for outdoor use with the Wyze Outdoor Power Adapter (sold separately), this camera withstands rain, snow, and dust, making it a reliable choice for all seasons.
Color Night Vision and Motion Alerts
Equipped with a Starlight sensor, the Pan v3 provides vivid color night vision and sends instant alerts to your phone when motion or sound is detected. Custom detection zones help reduce false alarms.
Two-Way Audio and Privacy Mode
Communicate directly through the camera with two-way audio, perfect for greeting visitors or deterring unwanted guests. Privacy Mode lets you disable the camera’s view when needed by pointing it downward.
"Wyze Cam Pan v3 combines weather resistance with 360° pan and tilt, making it ideal for comprehensive outdoor monitoring."
Wyze Cam Pan v3 in Snowy Outdoor Setting Wyze Cam Pan v3 enduring snowy weather, demonstrating its IP65 rating and outdoor durability.
Wyze Cam OG and Wyze Cam OG Telephoto: Reliable Outdoor Options
Wyze Cam OG: Compact and Weather-Resistant
The Wyze Cam OG is a versatile indoor/outdoor camera with IP65 weather resistance. It features 1080p HD video, a 120° field of view, and a built-in 40-lumen spotlight. It supports local MicroSD storage up to 256GB and includes a 90 dB siren for added security.
Wyze Cam OG Telephoto: Zoomed-In Clarity
For users needing detailed close-up views, the Wyze Cam OG Telephoto offers a 3x telephoto lens with a narrower field of view, perfect for focusing on specific outdoor areas. It shares the same IP65 rating and local MicroSD recording capabilities.
Enhanced Audio and Smart Features
Both models include upgraded two-way audio with noise and echo cancellation, faster live streaming, and compatibility with Alexa, Google Assistant, and IFTTT.
"Wyze Cam OG series provides dependable IP65-rated outdoor security with spotlight and siren, plus local MicroSD recording for privacy."
Wyze Cam v4 Home Security Bundle: Complete Outdoor Protection
All-in-One Security Solution
The Wyze Cam v4 Home Security Bundle includes multiple Wyze Cam v4 cameras with 128GB MicroSD cards, offering extended local storage for continuous recording. This bundle is perfect for securing multiple outdoor zones with high-quality 2.5K video and color night vision.
Flexible Mounting and Power Options
Each camera in the bundle supports various mounting options including magnetic wall mounts and stands. While the cameras are wired for continuous power, pairing with solar power adapters (sold separately) can provide sustainable outdoor power solutions.
"The Wyze Cam v4 Home Security Bundle is ideal for comprehensive outdoor surveillance with local storage and IP65 durability."
Powering Your Outdoor Security Camera: Battery and Solar Options
While Wyze’s outdoor cameras like the Cam v4 and Pan v3 are primarily wired for continuous power, they can be paired with accessories such as the Wyze Outdoor Power Adapter and compatible solar panels (available separately) to enable solar-powered setups. This flexibility allows for installations in remote locations without direct access to power outlets, ensuring your security system remains operational and eco-friendly.
Why Choose Wyze Outdoor IP65 Security Cameras?
  • Weatherproof Durability: IP65 rating ensures cameras withstand rain, snow, and dust.
  • Local MicroSD Recording: Store footage locally up to 256GB without monthly fees.
  • High-Resolution Video: From 1080p HD to 2.5K QHD for crystal-clear images.
  • Color Night Vision: See vibrant colors even in low light for better identification.
  • Smart Features: Motion tracking, two-way audio, sirens, and spotlight integration.
  • Smart Home Compatibility: Works with Alexa, Google Assistant, and IFTTT.
  • Flexible Power Options: Wired with support for outdoor power adapters and solar solutions.
Secure your home with Wyze’s advanced outdoor IP65 security cameras that combine cutting-edge technology, weather resistance, and flexible recording options. Whether you need a single camera or a full bundle, Wyze has the perfect solution for your outdoor security needs.
FeatureWyze Cam v4Wyze Cam Pan v3Wyze Cam OGWyze Cam OG TelephotoWyze Cam v4 Home Security Bundle
Resolution2.5K QHD (2560x1440)1080p (1920x1080)Not specifiedNot specified2.5K QHD (2560x1440)
Field of View (FOV)DFOV 115.8°, HFOV 98.5°, VFOV 53.1°120° FOVNot specifiedNot specifiedDFOV 115.8°, HFOV 98.5°, VFOV 53.1°
Night VisionEnhanced Color Night Vision + IR LEDs4 IR LEDs (850 nm)Not specifiedNot specifiedEnhanced Color Night Vision + IR LEDs
AudioEnhanced Two-Way Talk, 99dB SirenBuilt-in speaker & mic, 2-way audioNot specifiedNot specifiedImproved 2-way audio
SpotlightMotion-activated spotlightNoNoNoMotion-activated spotlight
SirenBuilt-in siren (99 dB)NoNoNoBuilt-in siren
Video FPSDay: 20 FPS / Night: 15 FPSDay: 20 FPS / Night: 15 FPSNot specifiedNot specifiedDay: 20 FPS / Night: 15 FPS
Zoom8x digital zoom8x digital zoomNot specifiedNot specified8x digital zoom
Weather ResistanceIP65IP65Not specifiedNot specifiedIP65
ConnectivityWi-Fi 6, Bluetooth 5.22.4 GHz Wi-Fi (802.11 b/g/n), BluetoothNot specifiedNot specifiedWi-Fi 6, Bluetooth 5.2
Local StoragemicroSD card up to 512 GBmicroSD up to 256 GBNot specifiedNot specifiedmicroSD card 128 GB included
Cloud StorageAvailable with subscriptionAvailable with subscriptionNot specifiedNot specifiedAvailable with subscription
Mounting OptionsStand, Wall, Ceiling, Magnetic mountScrew mountNot specifiedNot specifiedStand, Wall, Ceiling, Magnetic mount
Dimensions2in x 2in x 2 3/8in124mm x 60mm x 63mmNot specifiedNot specified2in x 2in x 2 3/8in
Weight0.49 lb (222 g)11.29 oz (320 g)Not specifiedNot specified0.49 lb (222 g)
Power Adapter Output5V/1A Indoor5V/2000mANot specifiedNot specified5V/1A Indoor
Operating Temperature-4°F to 122°F (-20°C to 50°C)-4°F to 122°F (-20°C to 50°C)Not specifiedNot specified-4°F to 122°F (-20°C to 50°C)
Warranty1 Year1 YearNot specifiedNot specified1 Year
Included in PackageCamera onlyCamera onlyCamera onlyCamera only1x Wyze Cam v4, 1x Wyze Video Doorbell v2, 1x Wyze Home Monitoring Starter Kit
Price (USD)From $69.99 (varies by pack/color)From $114.94Not specifiedNot specified$169.99
What does IP65 weather resistance mean for Wyze outdoor security cameras?IP65 weather resistance means Wyze outdoor security cameras are protected against dust and can withstand low-pressure water jets from any direction. This makes them ideal for outdoor use in rain, snow, and dusty environments, ensuring reliable performance year-round.
Do Wyze outdoor security cameras support local MicroSD card recording?Yes, Wyze outdoor security cameras such as the Cam v4, Cam Pan v3, and Cam OG series support local MicroSD card recording. You can use MicroSD cards up to 256GB for continuous 24/7 recording without the need for a cloud subscription, offering privacy and convenience.
Can Wyze outdoor cameras be powered by solar panels?Wyze outdoor cameras are primarily wired for continuous power, but they can be paired with compatible solar panels and the Wyze Outdoor Power Adapter (sold separately). This allows for flexible, eco-friendly installations in locations without direct access to power outlets.
What are the video quality options available with Wyze outdoor security cameras?Wyze outdoor security cameras offer high-resolution video options, including 1080p HD on the Cam OG series and up to 2.5K QHD on the Wyze Cam v4. This ensures sharp, detailed footage for clear identification of people and objects.
Do Wyze outdoor cameras have color night vision?Yes, select Wyze outdoor cameras like the Cam v4 and Cam Pan v3 feature advanced color night vision. This technology uses enhanced sensors to provide vibrant, full-color images even in low-light conditions, surpassing traditional black-and-white night vision.
Are Wyze outdoor security cameras compatible with smart home systems?Wyze outdoor security cameras are compatible with popular smart home platforms, including Amazon Alexa, Google Assistant, and IFTTT. This allows for seamless integration and voice control within your smart home ecosystem.
What security features do Wyze outdoor cameras offer?Wyze outdoor cameras include advanced security features such as motion-activated spotlights, loud sirens (up to 99 dB), two-way audio for communication, and customizable motion detection zones. These features help deter intruders and keep your property safe.
How easy is it to install Wyze outdoor security cameras?Wyze outdoor security cameras are designed for easy installation. The Cam v4, for example, features a screw-free magnetic mount for quick, tool-free setup. Other models offer flexible mounting options, including wall mounts and stands.
What is included in the Wyze Cam v4 Home Security Bundle?The Wyze Cam v4 Home Security Bundle includes multiple Wyze Cam v4 cameras, each with a 128GB MicroSD card for extended local storage. This bundle is ideal for comprehensive outdoor surveillance across multiple zones, offering high-quality 2.5K video and color night vision.
Can Wyze outdoor cameras be used for 360° surveillance?Yes, the Wyze Cam Pan v3 offers 360° horizontal pan and 180° vertical tilt, allowing you to monitor wide outdoor areas with a single camera. Its upgraded tracking motor automatically follows motion for complete coverage.
Do Wyze outdoor cameras have two-way audio?Yes, Wyze outdoor cameras such as the Cam v4, Cam Pan v3, and Cam OG series feature two-way audio. This allows you to communicate directly through the camera, greet visitors, or deter unwanted guests.
What are the power options for Wyze outdoor security cameras?Wyze outdoor security cameras are primarily wired for continuous power but support flexible solutions. With accessories like the Wyze Outdoor Power Adapter and compatible solar panels (sold separately), you can set up your cameras in remote locations without direct power access.
What are the key features of the Wyze Cam v4?Can you explain how the local MicroSD recording works for the Wyze cameras?Do you have any deals, ongoing sales, discounts, or promotions?
