Weatherproof Outdoor Security Cameras with Auto Motion Tracking
Weatherproof Outdoor Security Camera Systems with Automatic Motion Tracking
When it comes to securing your home or business outdoors, having a reliable, weatherproof security camera system with automatic motion tracking is essential. Wyze offers a range of cutting-edge cameras designed to withstand the elements while providing smart, real-time tracking and crystal-clear video quality. Below, we explore the top Wyze outdoor security cameras that combine durability, advanced features, and seamless smart home integration.
Wyze Cam v4: The Ultimate Outdoor Security Camera
Superior Video Quality and Night Vision
Wyze Cam v4 delivers stunning 2.5K QHD resolution, providing crystal-clear images and videos that capture every detail. Its enhanced color night vision uses advanced hardware to reveal vibrant colors even in low-light conditions, far surpassing traditional black-and-white night vision.
Weatherproof and Durable
Rated IP65 for weather resistance, the Wyze Cam v4 is built to perform in rain, snow, or shine. Whether mounted on your porch or backyard, it stands up to harsh outdoor conditions without compromising performance.
Smart Features for Enhanced Security
  • Automatic Motion Tracking: The camera intelligently detects motion and zooms in to track moving objects, ensuring you never miss important activity.
  • Motion-Activated Spotlight & Siren: A built-in spotlight lights up your property when motion is detected, while a 99 dB siren can be activated to deter intruders.
  • 24/7 Local Recording: Supports continuous recording to a microSD card (up to 256GB), so you can review footage anytime without a subscription.
  • Wi-Fi 6 Support: Enjoy a stronger, more reliable connection for seamless streaming and alerts.
  • Smart Assistant Compatibility: Works with Alexa and Google Assistant for voice control and automation.
Easy Installation and Mounting
The Wyze Cam v4 features a screw-free magnetic mount, making installation quick and tool-free. It also supports multiple mounting options including wall, ceiling, and stand mounts. Wyze Cam v4 Outdoor Lifestyle Experience smart outdoor security with Wyze Cam v4 in your home environment.
Wyze Cam Pan v3: Weatherproof 360° Pan & Tilt with Auto Motion Tracking
Full Coverage with Pan and Tilt
Wyze Cam Pan v3 offers a 360° horizontal pan and 180° vertical tilt, allowing you to monitor every corner of your property. Its upgraded tracking motor quietly follows motion automatically, providing continuous coverage without missing a beat.
Built for Outdoor Use
With an IP65 weather resistance rating, the Pan v3 is ready for outdoor deployment when paired with the Wyze Outdoor Power Adapter. It withstands rain, snow, and extreme temperatures, making it a versatile choice for any climate.
Advanced Motion Tracking and Smart Alerts
  • Automatic Motion Tracking: The camera detects movement and smoothly follows the subject, capturing detailed footage of any activity.
  • Custom Patrol Routes: Set up to 4 waypoints with Pan Scan™ to automate patrols of your property.
  • Privacy Mode: When enabled, the camera points downward and disables recording, giving you peace of mind when privacy is needed.
  • Color Night Vision: Equipped with a Starlight Sensor, it delivers vibrant color images even at night.
Two-Way Audio and Smart Integration
Communicate directly through the camera with two-way audio, perfect for greeting visitors or warning intruders. Compatible with Alexa, Google Assistant, and IFTTT for smart home automation. Wyze Cam Pan v3 in Snowy Outdoor Setting Wyze Cam Pan v3 braves the elements with IP65 weather resistance and automatic motion tracking.
Wyze Cam v4 Home Security Bundle: Comprehensive Outdoor Protection
All-in-One Security Solution
The Wyze Cam v4 Home Security Bundle includes multiple Wyze Cam v4 cameras with a 128GB microSD card, providing extensive coverage and ample local storage for continuous recording.
Enhanced Features for Peace of Mind
  • 2.5K QHD Video with Wide Dynamic Range: Capture vibrant, detailed footage in all lighting conditions.
  • Motion-Activated Spotlight and Siren: Illuminate and protect your property automatically.
  • Person Detection: Receive smart alerts that distinguish people from other motion events.
  • Multiple Mounting Options: Includes stand, wall, ceiling, and magnetic mounts for flexible installation.
Ideal for Larger Properties
This bundle is perfect for those who want to secure multiple outdoor areas with high-quality cameras that offer automatic motion tracking and weatherproof durability.
Why Choose Wyze for Outdoor Security?
"Wyze cameras combine affordability with advanced technology, making professional-grade outdoor security accessible to everyone."
  • IP65 Weather Resistance: All featured cameras are built to withstand outdoor conditions including rain, snow, and dust.
  • Automatic Motion Tracking: Stay informed with cameras that follow movement intelligently, capturing critical moments.
  • Smart Home Compatibility: Integrate seamlessly with Alexa, Google Assistant, and IFTTT for a connected security ecosystem.
  • Local and Cloud Storage Options: Choose between continuous local recording or cloud storage plans for flexible video management.
  • Easy Setup and Mounting: Magnetic mounts and Bluetooth setup simplify installation without the need for professional help.
Summary of Key Specs
FeatureWyze Cam v4Wyze Cam Pan v3Wyze Cam v4 Home Security Bundle
Video Resolution2.5K QHD (2560x1440)1080p Full HD2.5K QHD (2560x1440)
Field of View115.9° diagonal360° pan / 180° tilt115.9° diagonal
Night VisionEnhanced Color Night VisionColor Night Vision (Starlight Sensor)Enhanced Color Night Vision
Weather ResistanceIP65IP65IP65
Motion TrackingAI Auto-Zoom & TrackingAutomatic Pan & Tilt TrackingAI Auto-Zoom & Tracking
AudioEnhanced Two-Way TalkTwo-Way AudioImproved Two-Way Audio
Spotlight & SirenYes (Spotlight + 99 dB Siren)NoYes (Spotlight + Siren)
Local StorageUp to 256GB microSDUp to 256GB microSD128GB microSD included
Smart Assistant SupportAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTT
Secure your outdoor spaces with Wyze’s weatherproof security cameras featuring automatic motion tracking. Whether you need wide coverage with pan and tilt or crystal-clear 2.5K video with smart spotlighting, Wyze has the perfect solution to keep your property safe around the clock.
TypeWired Security CameraWired Pan & Tilt Security CameraWired Security Camera Bundle
Video Resolution2.5K QHD (2560x1440)1080p (1920x1080)2.5K QHD (2560x1440)
Field of View (FOV)115.8° (D) x 98.5° (H) x 53.1° (V)360° pan, 180° tilt, 120° FOV115.8° (D) x 98.5° (H) x 53.1° (V)
SpotlightMotion-activated spotlightNoMotion-activated spotlight
SirenBuilt-in 99 dB sirenBuilt-in sirenBuilt-in 99 dB siren
AudioEnhanced 2-way talk, noise & echo cancellation2-way audio, noise & echo cancellationImproved 2-way audio
Motion DetectionYes, with detection zonesYes, with motion tracking & detection zonesYes, with detection zones
Sound DetectionYesYesYes
Smoke & CO AlertsYesYesYes
Local StoragemicroSD card up to 512GB (sold separately)microSD card up to 256GB (sold separately)microSD card up to 128GB included
Cloud StorageOptional subscription (Cam Plus)Optional subscription (Cam Plus)Optional subscription (Cam Plus)
Wi-Fi Support2.4 GHz & Wi-Fi 62.4 GHz only2.4 GHz & Wi-Fi 6
Smart Assistant CompatibilityAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTT
Mounting OptionsStand, Wall, Ceiling, MagneticScrew mountStand, Wall, Ceiling, Magnetic
Dimensions2in x 2in x 2 3/8in (51 x 51 x 60 mm)124mm x 60mm x 63mm2in x 2in x 2 3/8in
Weight0.49 lb (222 g)11.29 oz (320 g)0.49 lb (222 g)
Power SourceWired (5V/1A adapter included)Wired (5V/2A adapter included)Wired (5V/1A adapter included)
Outdoor UseYes (with optional outdoor power adapter)Yes (requires outdoor power adapter)Yes (includes outdoor power adapter)
Digital Zoom8x8x8x
Warranty1 Year1 Year1 Year
Price$35.98 (single camera)$39.98 (single camera)$169.99 (bundle)
What makes Wyze outdoor security cameras weatherproof?Wyze outdoor security cameras, including the Wyze Cam v4 and Wyze Cam Pan v3, are rated IP65 for weather resistance. This means they are designed to withstand rain, snow, dust, and extreme temperatures, making them ideal for reliable outdoor use year-round.
How does automatic motion tracking work on Wyze security cameras?Wyze security cameras feature advanced automatic motion tracking technology. The cameras detect movement and intelligently follow the subject, either by zooming in (Wyze Cam v4) or panning and tilting (Wyze Cam Pan v3), ensuring you capture every important moment in real time.
What video quality do Wyze outdoor cameras offer?Wyze Cam v4 and the Home Security Bundle provide stunning 2.5K QHD (2560x1440) resolution for crystal-clear images and videos. Wyze Cam Pan v3 offers 1080p Full HD video, ensuring detailed footage for all your security needs.
Do Wyze outdoor cameras have night vision?Yes, Wyze outdoor cameras are equipped with enhanced color night vision. The Wyze Cam v4 uses advanced hardware for vibrant color images in low-light conditions, while the Wyze Cam Pan v3 features a Starlight Sensor for clear, colorful night vision.
Can Wyze outdoor cameras record continuously without a subscription?Yes, Wyze outdoor cameras support 24/7 continuous local recording to a microSD card (up to 256GB for individual cameras and 128GB included in the Home Security Bundle). This allows you to review footage anytime without needing a subscription.
Are Wyze outdoor security cameras easy to install?Wyze outdoor cameras are designed for easy installation. The Wyze Cam v4 features a screw-free magnetic mount for quick, tool-free setup, and both models support multiple mounting options including wall, ceiling, and stand mounts.
Do Wyze outdoor cameras have smart home integration?Yes, Wyze outdoor security cameras are compatible with Alexa, Google Assistant, and IFTTT. This allows for voice control, automation, and seamless integration into your smart home ecosystem.
What additional security features do Wyze outdoor cameras offer?Wyze outdoor cameras include features such as motion-activated spotlights, a 99 dB siren (on Wyze Cam v4), person detection for smarter alerts, two-way audio for communication, and privacy mode (on Wyze Cam Pan v3) for added peace of mind.
What is included in the Wyze Cam v4 Home Security Bundle?The Wyze Cam v4 Home Security Bundle includes multiple Wyze Cam v4 cameras and a 128GB microSD card, providing comprehensive outdoor coverage and ample local storage for continuous recording.
Why should I choose Wyze for outdoor security?Wyze offers affordable, professional-grade outdoor security cameras with advanced features like weatherproof durability, automatic motion tracking, high-resolution video, smart home compatibility, and easy installation, making them a top choice for protecting your property.
What are the key features of the Wyze Cam v4?How does the automatic motion tracking work on the Wyze cameras?Are there any discounts or promotions currently available for Wyze products?
