Weather-Protected 20ft USB Cable for Wyze Cam Outdoor Use
When setting up your Wyze Cam outdoors, having a reliable, weather-protected USB extension cable is essential to ensure uninterrupted power and connectivity. The
Wyze Cam USB Extension Cable - 20ft is designed to extend your camera’s reach, allowing flexible placement without compromising on performance or safety.
Wyze Cam USB Extension Cable - 20ft: Extend Your Outdoor Setup
- Length & Compatibility: This 20-foot USB extension cable is perfect for outdoor Wyze Cam installations, providing ample length to position your camera exactly where you need it. It supports Wyze Cam models including v2, v3, v4, v3 Pro, Pan v2/v3, and OG versions.
- Durability: Built to withstand outdoor conditions, this cable ensures your Wyze Cam remains powered even in challenging environments.
- Easy Installation: Simply plug into your existing Wyze Cam USB power adapter and enjoy extended reach without signal loss or power issues.
Say goodbye to short cables and enjoy the freedom of a 20ft cable for your outdoor Wyze Cam.
Wyze Cam v4: The Ultimate Outdoor Security Camera
Pair your 20ft USB extension cable with the
Wyze Cam v4 Outdoor Bundle for a complete, weather-resistant security solution.
Key Features of Wyze Cam v4 Outdoor Bundle
- Crystal-Clear 2.5K QHD Resolution: Capture every detail with stunning clarity, day or night.
- Enhanced Color Night Vision: See vibrant colors even in low-light conditions, thanks to advanced hardware and image processing.
- Motion-Activated Spotlight: Automatically illuminates when motion is detected, deterring intruders and improving video quality.
- Weather Resistance: Rated IP65, the Wyze Cam v4 is built to withstand rain, snow, and extreme temperatures (-4ºF to 122ºF), making it ideal for outdoor use.
- Wi-Fi 6 Support: Enjoy a stronger, more reliable connection at greater distances, perfect for outdoor setups.
- 24/7 Local Recording: With a microSD card slot, record continuously to never miss a moment.
- Smart Home Integration: Compatible with Alexa and Google Assistant for voice control and automation.
What’s Included in the Outdoor Bundle?
- Wyze Cam v4 camera
- Wyze Outdoor Power Adapter (weatherproof)
- 128GB Wyze MicroSD Card for local storage
This bundle ensures your Wyze Cam v4 is fully equipped for outdoor deployment, especially when combined with the 20ft USB extension cable for flexible placement.
Why Choose Wyze for Your Outdoor Security Needs?
Wyze offers a comprehensive ecosystem of security products designed to work seamlessly together. Whether you’re expanding your outdoor camera coverage or setting up a full home security system, Wyze provides reliable, affordable, and easy-to-install solutions.
- Flexible Mounting Options: Wyze Cam v4 supports stand, wall, ceiling, and magnetic mounts, allowing you to position your camera optimally.
- Robust Weather Protection: Both the camera and outdoor power adapter are designed to endure harsh weather conditions.
- Extended Cable Length: The 20ft USB extension cable removes the hassle of limited cable reach, enabling you to place your camera in the best vantage points without worrying about power access.
Summary
For a weather-protected, extended USB connection to your Wyze Cam outdoors, the
Wyze Cam USB Extension Cable - 20ft is the perfect accessory. When paired with the
Wyze Cam v4 Outdoor Bundle, you get a powerful, high-resolution security camera system that performs flawlessly in all weather conditions.
Invest in these products to enhance your outdoor security setup with flexibility, durability, and crystal-clear video quality.
Product Highlights
- Wyze Cam USB Extension Cable - 20ft
- Wyze Cam v4 Outdoor Bundle
- Wyze Cam v4
What is the Wyze Cam USB Extension Cable - 20ft used for?
The Wyze Cam USB Extension Cable - 20ft is designed to extend the reach of your Wyze Cam's power supply, making it ideal for outdoor installations where you need extra length to position your camera in the best location.Is the 20ft USB extension cable compatible with all Wyze Cam models?
Yes, the 20ft USB extension cable is compatible with Wyze Cam models including v2, v3, v4, v3 Pro, Pan v2/v3, and OG versions.Is the Wyze Cam USB Extension Cable weather-protected for outdoor use?
Yes, the Wyze Cam USB Extension Cable is built to withstand outdoor conditions, ensuring reliable power and connectivity for your camera even in challenging weather.How do I install the Wyze Cam USB Extension Cable outdoors?
Installation is simple—just plug the extension cable into your existing Wyze Cam USB power adapter and connect it to your camera. The cable is designed for easy setup without signal loss or power issues.What are the key features of the Wyze Cam v4 Outdoor Bundle?
The Wyze Cam v4 Outdoor Bundle includes a Wyze Cam v4 camera, a weatherproof outdoor power adapter, and a 128GB Wyze MicroSD Card. Key features include 2.5K QHD resolution, enhanced color night vision, motion-activated spotlight, IP65 weather resistance, Wi-Fi 6 support, 24/7 local recording, and smart home integration with Alexa and Google Assistant.Is the Wyze Cam v4 suitable for outdoor use?
Yes, the Wyze Cam v4 is rated IP65 for weather resistance, making it suitable for outdoor use in rain, snow, and extreme temperatures ranging from -4ºF to 122ºF.Does the Wyze Cam v4 support continuous local recording?
Yes, the Wyze Cam v4 features a microSD card slot that allows for 24/7 continuous local recording, so you never miss a moment.Can I use voice assistants with the Wyze Cam v4?
Yes, the Wyze Cam v4 is compatible with Alexa and Google Assistant, allowing for convenient voice control and smart home automation.What mounting options are available for the Wyze Cam v4?
The Wyze Cam v4 supports flexible mounting options, including stand, wall, ceiling, and magnetic mounts, so you can position your camera for optimal coverage.Why should I choose Wyze for my outdoor security camera needs?
Wyze offers a comprehensive ecosystem of reliable, affordable, and easy-to-install security products. Their outdoor cameras and accessories, like the weather-protected 20ft USB extension cable, are designed for durability, flexibility, and seamless integration with smart home systems.
