Best Waterproof Extension Cable & Adapter for Wyze Balcony Cameras
Best Waterproof Extension Cable and Power Adapter for Wyze Cameras on Balconies
When setting up Wyze cameras on balconies or outdoor spaces, having a reliable, weather-resistant power solution is essential. This guide highlights the Wyze Outdoor Power Adapter and compatible Wyze cameras that pair perfectly for balcony installations, ensuring your security setup withstands rain, snow, and all weather conditions.
Wyze Outdoor Power Adapter: The Ultimate Weatherproof Power Solution
Designed for Outdoor Durability
The Wyze Outdoor Power Adapter is specifically engineered to keep your Wyze cameras powered safely outdoors. With an IP67 weather-resistant rating, it is ready to face rain, snow, or shine without compromising performance. This makes it an ideal choice for balcony setups where exposure to the elements is unavoidable.
Compatibility and Convenience
  • Works seamlessly with Wyze Cam v4, Wyze Cam Pan v3, Wyze Cam v3 Pro, and Wyze Battery Cam Pro (with appropriate adapters).
  • Requires pairing with the L-shaped Micro USB Adapter for Cam v3 Pro and Pan v3.
  • USB-C adapter needed for Wyze Battery Cam Pro.
  • Note: Not compatible with the OG Stack Kit.
Key Features
  • IP67 weather resistance for reliable outdoor use.
  • Multiple adapter bundles available to fit your camera model.
  • 30-day hassle-free returns for peace of mind.
Ready for rain, snow, or shine, the Wyze Outdoor Power Adapter ensures your balcony camera setup stays powered and protected.
Wyze Cam Pan v3: 360° Pan and Tilt Outdoor Camera
Perfect Match for Balcony Surveillance
The Wyze Cam Pan v3 is a versatile indoor/outdoor camera designed for comprehensive coverage. Its IP65 weather resistance rating makes it suitable for balcony use when paired with the Wyze Outdoor Power Adapter.
Outstanding Features
  • 360° horizontal pan and 180° vertical tilt for full-area monitoring.
  • Crisp 1080p HD video resolution with color night vision.
  • Built-in two-way audio with noise and echo cancellation.
  • Supports up to 256 GB microSD storage for local recording.
  • Compatible with Alexa, Google Assistant, and IFTTT for smart home integration.
  • Operating temperature range from -4°F to 122°F (-20°C to 50°C).
Installation and Power
  • Requires the Wyze Outdoor Power Adapter for safe outdoor power.
  • Comes with a 6-foot micro USB cable and mounting kit for easy balcony installation.
Wyze Cam Pan v3 in snowy outdoor setting Wyze Cam Pan v3 ready for all weather conditions on your balcony
Why Choose Wyze Outdoor Power Adapter with Wyze Cameras?
Seamless Integration
The Wyze Outdoor Power Adapter is designed to perfectly complement Wyze cameras, especially the Pan v3 and Cam v3 Pro models. This ensures your balcony camera setup is not only weatherproof but also easy to install and maintain.
Enhanced Safety and Reliability
  • IP67 rating means the adapter is dust-tight and can withstand immersion in water up to 1 meter.
  • Durable construction protects against outdoor hazards.
  • Provides consistent power supply to keep your cameras running 24/7.
Additional Outdoor Power Options: Wyze Plug Outdoor
For those looking to power other outdoor devices alongside cameras, the Wyze Plug Outdoor offers a smart, weather-resistant solution with IP64 rating. While not a direct power source for Wyze cameras, it complements your outdoor setup by controlling garden lights, inflatables, or other electronics via app control.
Summary: Ideal Setup for Balcony Wyze Cameras
  • Use the Wyze Outdoor Power Adapter to ensure your Wyze cameras stay powered and protected outdoors.
  • Pair with Wyze Cam Pan v3 for full 360° coverage and smart home compatibility.
  • Enjoy peace of mind with weatherproof, reliable power and high-quality video surveillance.
Protect your balcony with Wyze’s weather-resistant power and camera solutions — designed to keep an eye on what matters, no matter the weather.
Product Highlights
ProductKey FeaturesPrice Range
Wyze Outdoor Power AdapterIP67 weatherproof, compatible with multiple Wyze camerasFrom $19.99
Wyze Cam Pan v3360° pan/tilt, 1080p HD, IP65 ratedFrom $39.98
Wyze Plug OutdoorIP64 rated smart plug, app-controlledFrom $15.99
FeatureWyze Outdoor Power AdapterWyze Cam Pan v3Pan v3 Security Bundle
TypeAccessoryCameraCamera Bundle
Weather ResistanceIP67IP65IP65
CompatibilityWyze Cam v4, OG series, Cam Pan v3, Cam v3 Pro (with L-shaped adapter), Battery Cam Pro (with USB-C adapter)Indoor/outdoor, 360° pan, 180° tilt cameraIncludes 2x Wyze Cam Pan v3
Power Adapter RequiredYes (for outdoor use of compatible cameras)Requires Wyze Outdoor Power Adapter for outdoor useIncluded (2 power adapters)
Price$14.99 - $19.99 (depending on variant)$39.98 (1 pack)$82.99
DimensionsNot specified124mm (H) x 60mm (W) x 63mm (D)Same as Wyze Cam Pan v3 (x2)
WeightNot specified11.29 oz (320 g)Same as Wyze Cam Pan v3 (x2)
Video ResolutionN/A1920 x 1080 (1080p)Same as Wyze Cam Pan v3 (x2)
Pan & Tilt RangeN/A360° horizontal, 180° verticalSame as Wyze Cam Pan v3 (x2)
Night VisionN/AColor Night Vision, 4 IR LEDs (850 nm)Same as Wyze Cam Pan v3 (x2)
AudioN/ABuilt-in speaker and microphone, 2-way audioSame as Wyze Cam Pan v3 (x2)
ConnectivityN/A802.11 b/g/n, 2.4GHz Wi-FiSame as Wyze Cam Pan v3 (x2)
Storage SupportN/AUp to 256 GB microSD (ExFAT)Same as Wyze Cam Pan v3 (x2)
Included ItemsOutdoor Power Adapter and adapters depending on variant1x Wyze Cam Pan v3, 1x 6' micro USB Cable, 1x Power Adapter, 1x Mounting Kit, 1x Quick Start Guide2x Wyze Cam Pan v3, 2x 6' micro USB Cable, 2x Power Adapter, 2x Mounting Kit, 2x 32GB MicroSD Cards, Quick Start Guide
Operating TemperatureNot specified-20°C to 50°C (-4°F to 122°F)Same as Wyze Cam Pan v3 (x2)
WarrantyNot specified1-Year1-Year
What is the best waterproof power adapter for Wyze cameras on balconies?The Wyze Outdoor Power Adapter is the best waterproof power solution for Wyze cameras on balconies. It features an IP67 weather-resistant rating, making it ideal for outdoor use in rain, snow, or shine.
Which Wyze cameras are compatible with the Wyze Outdoor Power Adapter?The Wyze Outdoor Power Adapter is compatible with Wyze Cam v4, Wyze Cam Pan v3, Wyze Cam v3 Pro, and Wyze Battery Cam Pro (with the appropriate adapters). Please note that it is not compatible with the OG Stack Kit.
Do I need any additional adapters to use the Wyze Outdoor Power Adapter with my camera?Yes, some Wyze cameras require additional adapters for compatibility. The Wyze Cam Pan v3 and Cam v3 Pro need the L-shaped Micro USB Adapter, while the Wyze Battery Cam Pro requires a USB-C adapter.
Is the Wyze Outdoor Power Adapter weatherproof?Yes, the Wyze Outdoor Power Adapter is IP67 rated, meaning it is dust-tight and can withstand immersion in water up to 1 meter, making it highly weatherproof for outdoor use.
What are the key features of the Wyze Cam Pan v3 for balcony surveillance?The Wyze Cam Pan v3 offers 360° horizontal pan, 180° vertical tilt, 1080p HD video with color night vision, two-way audio, IP65 weather resistance, and compatibility with Alexa, Google Assistant, and IFTTT. It is ideal for comprehensive balcony surveillance.
Can I use the Wyze Cam Pan v3 outdoors on my balcony?Yes, the Wyze Cam Pan v3 is designed for both indoor and outdoor use with an IP65 weather resistance rating. For safe outdoor power, it should be paired with the Wyze Outdoor Power Adapter.
What is the difference between the Wyze Outdoor Power Adapter and Wyze Plug Outdoor?The Wyze Outdoor Power Adapter is specifically designed to power Wyze cameras outdoors with an IP67 rating. The Wyze Plug Outdoor is an IP64 rated smart plug for controlling other outdoor devices like garden lights or inflatables via app control, but it is not a direct power source for Wyze cameras.
How long is the cable included with the Wyze Cam Pan v3?The Wyze Cam Pan v3 comes with a 6-foot micro USB cable and a mounting kit, making it easy to install on balconies or other outdoor spaces.
What is the return policy for the Wyze Outdoor Power Adapter?The Wyze Outdoor Power Adapter comes with a 30-day hassle-free return policy, giving you peace of mind with your purchase.
Why should I use the Wyze Outdoor Power Adapter with my Wyze camera on a balcony?Using the Wyze Outdoor Power Adapter ensures your Wyze camera setup is weatherproof, reliable, and safe for outdoor use. It provides consistent power and protects your camera from rain, snow, and other outdoor hazards.
What are the key features of the Wyze Outdoor Power Adapter?Can you tell me more about the compatibility of the Wyze Outdoor Power Adapter with different Wyze cameras?Do you have any deals, ongoing sales, discounts, or promotions for the Wyze Outdoor Power Adapter?
