Best Smart Cameras Compatible with Google Assistant
Looking for smart cameras that seamlessly integrate with Google Assistant? Whether you want to monitor your home indoors or outdoors, control your security system with voice commands, or automate your smart home, these Wyze cameras offer top-tier features combined with Google Assistant compatibility for ultimate convenience and security.
Wyze Cam v4 Outdoor Bundle: Advanced Outdoor Security
Experience unmatched home security with the
Wyze Cam v4 Outdoor Bundle. Designed for outdoor use, this camera delivers crystal-clear 2.5K QHD resolution and enhanced color night vision, ensuring you never miss a detail, day or night.
Key Features:
- 2.5K QHD Video Resolution for sharp, detailed footage.
- Enhanced Color Night Vision with motion-activated spotlight.
- 24/7 Local Recording with included 128GB microSD card.
- Wi-Fi 6 Support for faster, more reliable connectivity.
- Smart Assistant Compatibility: Works flawlessly with Google Assistant and Alexa.
- Motion & Sound Detection with customizable detection zones.
- Smoke CO Alerts for added safety.
- Weatherproof & Wired Power Source for continuous operation.
This bundle includes the Wyze Outdoor Power Adapter and a microSD card, making it a complete solution for your outdoor security needs.
Stay protected outdoors with Wyze Cam v4’s weather-resistant design.
Wyze Battery Cam Pro: Wire-Free Smart Security
For those who prefer a wireless, flexible security camera, the
Wyze Battery Cam Pro offers powerful features without the hassle of wiring.
Highlights:
- 2.5K HDR Video Resolution with H.264 encoding.
- Wire-Free Design with removable, rechargeable 6200mAh battery packs lasting up to 6 months.
- Integrated Spotlight & Siren for active deterrence.
- Radar + PIR Motion Detection for precise alerts.
- IP65 Weatherproof to withstand harsh outdoor conditions.
- Dual-Band Wi-Fi Support (2.4 & 5 GHz) for stable connections.
- Two-Way Audio with built-in speaker and microphone.
- Google Assistant & Alexa Compatible, plus IFTTT integration.
Ideal for locations where wiring is difficult, this camera offers up to 256GB local storage and easy installation.
Wyze Cam v4: Wired Indoor/Outdoor Versatility
The
Wyze Cam v4 is a versatile wired camera suitable for both indoor and outdoor use, combining high-quality video with smart home integration.
Features:
- 2.5K QHD (2560x1440) Video with 8x digital zoom.
- Enhanced Color Night Vision with 4 IR LEDs and 2 white spotlight LEDs.
- Wide Dynamic Range (WDR) for balanced lighting.
- IP65 Weather Resistance for outdoor durability.
- Multiple Mounting Options: Stand, wall, ceiling, or magnetic mounts.
- 24/7 Local Storage with microSD support up to 512GB.
- Two-Way Audio & Built-in Siren for communication and alerts.
- Wi-Fi 6 and Bluetooth 5.2 for fast, reliable connectivity.
- Google Assistant, Alexa, and IFTTT Compatible for smart home control.
This camera is perfect for users wanting a wired solution with advanced features and flexible installation.
Wyze Bulb Cam: Discreet Security with Smart Lighting
Combine security and lighting with the
Wyze Bulb Cam, a 2-in-1 outdoor security camera and smart LED light bulb.
What Makes It Special:
- 2K HD Video Resolution with color night vision.
- 160° Field of View for wide coverage.
- Standard E26 Socket fits most light fixtures.
- Motion-Activated Light & Push Notifications for instant alerts.
- Supports Local Storage up to 256GB microSD card (no subscription needed).
- Two-Way Audio with built-in microphone and speaker.
- IP65 Weather Resistance for outdoor use.
- Google Assistant & Alexa Compatible for voice control.
- Brightness up to 800 lumens with 3000K color temperature.
This camera is ideal for those who want a subtle security solution integrated into their existing outdoor lighting.
Discreet and smart: Wyze Bulb Cam blends security with lighting.
Wyze Cam Floodlight v2: Powerful Lighting Meets Smart Security
Illuminate and secure your property with the
Wyze Cam Floodlight v2, featuring bright LEDs and smart automation.
Standout Features:
- 2800 Lumens of Bright LED Light with dimmable panels.
- 2K Video with Color Night Vision and 160° wide-angle view.
- AI-Powered Light Control and Ambient Light Mode.
- Dusk-to-Dawn Automation for effortless lighting.
- Built-in 105dB Siren and Two-Way Audio for active deterrence.
- 24/7 Local Recording with microSD support up to 256GB.
- IP65 Weather Resistance for all-season use.
- Google Assistant, Alexa, and IFTTT Compatible for smart home integration.
Perfect for driveways, porches, and backyards, this floodlight camera combines powerful illumination with advanced security.
Brighten and protect your home with Wyze Cam Floodlight v2.
Wyze Cam Pan v3: 360° Coverage with Smart Control
Get full panoramic coverage with the
Wyze Cam Pan v3, an indoor/outdoor camera with pan, tilt, and zoom capabilities.
Features:
- 1080p Full HD Video with 20 FPS daytime and 15 FPS nighttime.
- 360° Horizontal and 180° Vertical View Range for complete room coverage.
- 8x Digital Zoom to focus on details.
- IP65 Weather Resistant for outdoor use (requires outdoor power adapter).
- Two-Way Audio with Noise & Echo Cancellation.
- Supports up to 256GB microSD local storage.
- Google Assistant, Alexa, and IFTTT Compatible.
- Fast 1.5 GHz CPU for smooth operation.
Ideal for monitoring large indoor spaces or outdoor areas with flexible movement and smart voice control.
Why Choose Wyze Smart Cameras with Google Assistant?
Integrating your smart camera with Google Assistant allows you to control your home security hands-free. From viewing live streams on your smart display to receiving alerts and controlling camera settings with voice commands, Wyze cameras make home monitoring effortless and smart.
All these Wyze cameras support Google Assistant, ensuring you can easily add them to your smart home ecosystem for enhanced security, convenience, and peace of mind.
Summary Table of Wyze Smart Cameras Compatible with Google Assistant
Model | Resolution | Power Source | Weatherproof | Key Feature | Price Range (USD) |
Wyze Cam v4 Outdoor | 2.5K QHD | Wired | Yes (IP65) | Enhanced Color Night Vision | $69.99 |
Wyze Battery Cam Pro | 2.5K HDR | Rechargeable Battery | Yes (IP65) | Wire-Free, Spotlight & Siren | $89.98 - $219.98 |
Wyze Cam v4 | 2.5K QHD | Wired | Yes (IP65) | Versatile Indoor/Outdoor Use | $35.98 - $107.94 |
Wyze Bulb Cam | 2K HD | Wired (Light Socket) | Yes (IP65) | 2-in-1 Camera & Smart Light | $49.98 |
Wyze Cam Floodlight v2 | 2K HD | Hardwired | Yes (IP65) | 2800 Lumens Floodlight + Siren | $89.98 |
Wyze Cam Pan v3 | 1080p HD | Wired | Yes (IP65) | 360° Pan & 180° Tilt | $39.98 - $114.94 |
Enhance your home security with these smart cameras that combine high-quality video, smart assistant compatibility, and innovative features tailored to your lifestyle. Choose the Wyze camera that fits your needs and enjoy the convenience of Google Assistant voice control today!
Which Wyze smart cameras are compatible with Google Assistant?
All current Wyze smart cameras, including the Wyze Cam v4 Outdoor Bundle, Wyze Battery Cam Pro, Wyze Cam v4, Wyze Bulb Cam, Wyze Cam Floodlight v2, and Wyze Cam Pan v3, are fully compatible with Google Assistant. This allows you to control your cameras and view live feeds using voice commands and smart displays.Can Wyze cameras be used both indoors and outdoors?
Yes, many Wyze cameras are designed for both indoor and outdoor use. Models like the Wyze Cam v4, Wyze Cam v4 Outdoor Bundle, Wyze Battery Cam Pro, Wyze Bulb Cam, Wyze Cam Floodlight v2, and Wyze Cam Pan v3 all feature IP65 weather resistance, making them suitable for outdoor environments as well as indoor spaces.Do Wyze cameras require a subscription for local video storage?
No, Wyze cameras support local video storage via microSD cards without the need for a subscription. Depending on the model, you can use microSD cards up to 256GB or 512GB for continuous or event-based recording.What are the video resolutions offered by Wyze smart cameras?
Wyze smart cameras offer high-definition video resolutions, including 2.5K QHD (Wyze Cam v4, Wyze Cam v4 Outdoor Bundle, Wyze Battery Cam Pro), 2K HD (Wyze Bulb Cam, Wyze Cam Floodlight v2), and 1080p Full HD (Wyze Cam Pan v3). These resolutions ensure clear and detailed footage for home security.How do Wyze cameras enhance night vision and low-light performance?
Wyze cameras feature enhanced color night vision, infrared LEDs, and motion-activated spotlights to provide clear video even in low-light or nighttime conditions. Models like the Wyze Cam v4 Outdoor Bundle and Wyze Cam Floodlight v2 offer advanced night vision capabilities for reliable 24/7 monitoring.Are Wyze cameras easy to install and set up?
Yes, Wyze cameras are designed for easy installation and setup. Options include wired, battery-powered, and light socket-powered models. Many cameras offer flexible mounting options such as wall, ceiling, stand, or magnetic mounts, and the Wyze app guides you through the setup process.What smart home features do Wyze cameras offer with Google Assistant?
With Google Assistant integration, you can use voice commands to view live camera feeds on smart displays, receive motion and sound alerts, control camera settings, and automate your home security system for hands-free convenience.Do Wyze cameras support two-way audio?
Yes, most Wyze cameras, including the Wyze Cam v4, Wyze Battery Cam Pro, Wyze Bulb Cam, Wyze Cam Floodlight v2, and Wyze Cam Pan v3, feature two-way audio with built-in microphones and speakers. This allows you to communicate with visitors or deter intruders remotely.What is the difference between the Wyze Cam v4 Outdoor Bundle and the Wyze Battery Cam Pro?
The Wyze Cam v4 Outdoor Bundle is a wired outdoor camera with 2.5K QHD resolution, enhanced color night vision, and continuous power. The Wyze Battery Cam Pro is a wire-free, battery-powered camera with 2.5K HDR video, integrated spotlight and siren, and up to 6 months of battery life, making it ideal for locations without easy access to power outlets.Can Wyze cameras be integrated with other smart home platforms?
Yes, in addition to Google Assistant, Wyze cameras are compatible with Amazon Alexa and IFTTT, allowing you to integrate them into a wide range of smart home automation routines and voice control systems.
