Best Video Doorbells with Alexa and Google Home Integration for Live View
Looking for a reliable video doorbell that works seamlessly with Alexa and Google Home for live video viewing? Whether you want to answer your door remotely, get real-time alerts, or integrate your smart home devices, Wyze offers top-notch solutions that combine crystal-clear video, smart features, and easy voice assistant compatibility. Below, we highlight the best Wyze products designed to enhance your home security with live view capabilities through Alexa and Google Home.
Wyze Video Doorbell v2: Wired 2K Video Doorbell with Smart Home Integration
Experience the clearest wired video doorbell from Wyze with the
Wyze Video Doorbell v2. This smart doorbell offers:
- 2K HD Video Quality: Capture every detail on your porch with stunning 2K resolution, providing a head-to-toe view of visitors.
- Local microSD Storage: Continuous 24/7 local recording lets you review footage anytime without relying solely on cloud storage.
- Two-Way Audio: Speak directly to visitors or delivery personnel through the Wyze app.
- Motion-Activated Voice Deterrence: Automatically warn unwanted visitors with a voice prompt when motion is detected (requires Cam Plus subscription).
- Pre-Roll Motion Recording: Get 3-6 seconds of video before motion events to see the full context.
- Works with Alexa and Google Home: View live video feeds on your Echo Show, Google Nest Hub, or other compatible devices.
- Weatherproof (IP65 Rated): Built to withstand rain, snow, and harsh weather conditions.
- Easy Installation: Includes a chime controller to keep your existing doorbell chime functional.
“Answer your door from anywhere with our clearest and most capable wired video doorbell yet.”
Enjoy seamless smart home integration and clear porch monitoring.
Wyze Cam v4: Versatile 2.5K QHD Smart Camera with Alexa & Google Assistant
While not a doorbell, the
Wyze Cam v4 is a powerful smart camera that complements your home security setup with:
- 2.5K Quad HD Resolution: Ultra-clear video quality for indoor or outdoor use.
- Enhanced Color Night Vision: See vibrant colors even in low-light conditions, thanks to an advanced starlight sensor and spotlight.
- Motion-Activated Spotlight: Automatically lights up when motion is detected to deter intruders.
- 24/7 Local Recording: Supports continuous recording with a microSD card.
- Wi-Fi 6 Support: Ensures a stronger, more reliable connection.
- Alexa and Google Home Compatible: View live streams and receive alerts on your smart displays.
- Weather Resistant (IP65): Perfect for outdoor installation.
- Multiple Mounting Options: Wall, ceiling, stand, or magnetic mounts for flexible placement.
This camera is ideal for monitoring areas around your home that complement your video doorbell’s coverage.
Wyze Cam v4 Outdoor Bundle: Complete Outdoor Security Solution
For those wanting an all-in-one outdoor security package, the
Wyze Cam v4 Outdoor Bundle includes:
- Wyze Cam v4 with all the features above.
- Wyze Outdoor Power Adapter for reliable outdoor power.
- 128GB microSD card for extensive local storage.
This bundle is perfect for users who want to expand their smart home security with Alexa and Google Home integration, ensuring you never miss a moment outside your front door or around your property.
The Front Porch Security Bundle: Ultimate Smart Home Entryway Protection
If you want a comprehensive front porch security system, the
Front Porch Security Bundle combines:
- Wyze Video Doorbell (1080p HD) with two-way audio and motion detection.
- Wyze Lock for remote locking/unlocking and lock history monitoring.
- Wyze Chime to keep your traditional doorbell sound alive.
- Alexa and Google Assistant Compatibility for voice control and live view.
This bundle offers a complete smart home entry solution, allowing you to monitor, communicate, and control access to your home—all from your smartphone or voice assistant.
Why Choose Wyze for Your Video Doorbell and Smart Home Integration?
Wyze products stand out for their:
- Affordable Pricing without compromising on quality.
- Seamless Alexa and Google Home Integration for hands-free live view and alerts.
- Robust Video Quality with 2K and 2.5K resolutions.
- Local and Cloud Storage Options for flexible video retention.
- Weatherproof Designs suitable for all climates.
- Smart Features like motion zones, voice deterrence, and quick preset responses.
Enhance your home security with smart video doorbells and cameras that keep you connected and in control, wherever you are.
Summary of Featured Products
Product Name | Video Resolution | Alexa & Google Home | Storage Options | Weatherproof | Special Features |
Wyze Video Doorbell v2 | 2K HD | Yes | Local microSD + Cloud | IP65 | Two-way audio, voice deterrence, chime |
Wyze Cam v4 | 2.5K QHD | Yes | Local microSD + Cloud | IP65 | Color night vision, spotlight, Wi-Fi 6 |
Wyze Cam v4 Outdoor Bundle | 2.5K QHD | Yes | Local microSD + Cloud | IP65 | Includes power adapter and 128GB card |
Front Porch Security Bundle | 1080p HD | Yes | Local + Cloud | IP65 | Doorbell, lock, chime, full entry control |
Enhance your home’s security with Wyze’s smart video doorbells and cameras that integrate effortlessly with Alexa and Google Home for live video viewing and smart alerts.
Which Wyze video doorbells work with Alexa and Google Home for live view?
Wyze Video Doorbell v2 and the Front Porch Security Bundle both offer seamless integration with Alexa and Google Home, allowing you to view live video feeds on devices like Echo Show and Google Nest Hub.What are the key features of the Wyze Video Doorbell v2?
The Wyze Video Doorbell v2 features 2K HD video quality, local microSD storage for 24/7 recording, two-way audio, motion-activated voice deterrence (with Cam Plus), pre-roll motion recording, weatherproof IP65 rating, and easy installation with a chime controller. It also works with Alexa and Google Home for live video streaming.Can I use Wyze cameras with Alexa and Google Home for live streaming?
Yes, Wyze Cam v4 and Wyze Cam v4 Outdoor Bundle are compatible with Alexa and Google Home, allowing you to view live streams and receive alerts on your smart displays.Does the Wyze Video Doorbell v2 support local storage?
Yes, the Wyze Video Doorbell v2 supports continuous 24/7 local recording via a microSD card, so you can review footage anytime without relying solely on cloud storage.Is the Wyze Video Doorbell v2 weatherproof?
Yes, the Wyze Video Doorbell v2 is IP65 rated, making it weatherproof and suitable for use in rain, snow, and harsh weather conditions.What is included in the Wyze Cam v4 Outdoor Bundle?
The Wyze Cam v4 Outdoor Bundle includes the Wyze Cam v4, a Wyze Outdoor Power Adapter for reliable outdoor power, and a 128GB microSD card for extensive local storage.What makes the Front Porch Security Bundle a complete smart home entry solution?
The Front Porch Security Bundle includes a Wyze Video Doorbell (1080p HD), Wyze Lock for remote locking and monitoring, Wyze Chime for traditional doorbell sounds, and full Alexa and Google Assistant compatibility for voice control and live view, providing comprehensive entryway protection.What are the benefits of choosing Wyze for smart home security?
Wyze offers affordable pricing, robust video quality (2K and 2.5K resolutions), seamless Alexa and Google Home integration, both local and cloud storage options, weatherproof designs, and smart features like motion zones, voice deterrence, and quick preset responses.Can Wyze cameras be used outdoors?
Yes, both the Wyze Cam v4 and Wyze Cam v4 Outdoor Bundle are IP65 weather resistant, making them suitable for outdoor installation and monitoring.Does Wyze offer two-way audio on their video doorbells?
Yes, the Wyze Video Doorbell v2 and the doorbell included in the Front Porch Security Bundle both feature two-way audio, allowing you to speak directly to visitors through the Wyze app.
