Upgrade to Refurbished Wyze Video Doorbell v2 with Alexa
Upgrade to Refurbished Wyze Video Doorbell v2 with Alexa Integration
Enhance your home security with the Refurbished Wyze Video Doorbell v2, a smart, reliable, and budget-friendly solution that offers all the premium features of the latest Wyze Video Doorbell v2. Perfect for those looking to upgrade their home entry monitoring system with Alexa compatibility, this refurbished model delivers crystal-clear 2K video, two-way audio, and seamless smart home integration.
Why Choose the Refurbished Wyze Video Doorbell v2?
Premium Features at a Great Price
The refurbished Wyze Video Doorbell v2 is a like-new product, fully tested and guaranteed to work flawlessly, now available at a more affordable price point. It offers:
  • 2K (2048 x 1536) video resolution for sharp, detailed footage.
  • Wide 166.8° diagonal field of view to capture every visitor and activity at your doorstep.
  • Two-way audio with noise cancellation, allowing you to speak with visitors from anywhere.
  • Motion-activated voice deterrence to help ward off unwanted guests.
  • Local microSD storage support up to 256GB, plus optional cloud storage with Wyze Security Plan.
  • Weather-resistant IP65 rating, built to withstand harsh outdoor conditions.
  • Alexa integration for hands-free voice control and live video streaming on Echo Show devices.
Technical Specifications
  • Sensor: CMOS Starlight Sensor with F2.0 aperture and 2.1mm focal length.
  • Frame Rate: 20 FPS during the day, 15 FPS at night.
  • Night Vision: 6 x 940nm IR lights for clear nighttime monitoring.
  • Connectivity: Wi-Fi 2.4 GHz (IEEE802.11 b/g/n).
  • Power: Requires 16V-24V AC, ≥10VA.
  • Dimensions: 4.3in x 1.7in x 0.9in (110mm x 44mm x 24mm).
  • Included Items: Doorbell unit, chime controller, wall plate, wedge (30°), installation kit, wire caps, extension wires, screws, anchors, and quick start guide.
The refurbished Wyze Video Doorbell v2 offers the same trusted performance as the new model, making it an excellent choice for upgrading your home security without breaking the bank.
Enhance Your Installation with the Wyze Video Doorbell v2 Wedge Kit
For optimal coverage and to eliminate blind spots, consider the Wyze Video Doorbell v2 Wedge Kit accessory. This kit is designed specifically for the Doorbell v2 and is perfect for angled door frames or porches with stairs.
Key Benefits of the Wedge Kit
  • Adjustable viewing angles: Includes a 15° horizontal bracket and two 7.5° vertical brackets.
  • Weather-resistant and durable: Made from sturdy plastic with a black finish to match your doorbell.
  • Easy installation: Comes with all necessary screws and a quick start guide.
  • Improves security coverage: Ensures you capture every visitor and movement clearly.
This accessory is ideal for maximizing your doorbell’s field of view and enhancing your home’s security footprint.
Seamless Alexa Integration for Smart Home Control
The Wyze Video Doorbell v2, including the refurbished model, integrates effortlessly with Alexa-enabled devices. This integration allows you to:
  • View live video feeds on Echo Show or Fire TV devices.
  • Receive real-time alerts and notifications via Alexa.
  • Use voice commands to check who’s at your door without lifting a finger.
  • Control your doorbell hands-free, enhancing convenience and safety.
Alexa compatibility makes the Wyze Video Doorbell v2 a smart addition to any connected home, providing peace of mind and easy access to your front door from anywhere.
Summary: Upgrade Your Home Security Today
Upgrading to the Refurbished Wyze Video Doorbell v2 is a smart, cost-effective way to boost your home security with advanced features like 2K video, two-way audio, and Alexa integration. Pair it with the Wyze Video Doorbell v2 Wedge Kit for perfect installation angles and superior coverage. Experience the convenience of answering your door from anywhere, enhanced by smart voice control and reliable performance — all while saving money with a certified refurbished product.
Homeowner using smart doorbell with Alexa Enjoy hands-free control of your front door with Wyze Video Doorbell v2 and Alexa.
Product Highlights
Refurbished Wyze Video Doorbell v2 2K video, two-way audio, Alexa integration, local & cloud storage, IP65 weather resistance. Wyze Video Doorbell v2 Wedge Kit Adjustable angles, weather-resistant, easy installation, eliminates blind spots.
Upgrade your home security with Wyze’s trusted technology and Alexa compatibility today!
Feature(Refurbished) Wyze Video Doorbell v2Wyze Video Doorbell v2Wyze Video Doorbell v2 Wedge Kit
Product TypeRefurbishedNewAccessory
Price$29.98$44.98$8.99
Video Resolution2K (2048 x 1536)2K (2048 x 1536)N/A
Local StoragemicroSD card slot for 24/7 local recordingmicroSD card slot for 24/7 local recordingN/A
Two-way AudioYesYesN/A
Motion-activated Voice DeterrenceYes (requires Cam Plus subscription)Yes (requires Cam Plus subscription)N/A
Pre-roll Motion Recording3-6 seconds3-6 secondsN/A
Works with Existing ChimeYes, includes chime controllerYes, includes chime controllerN/A
Weather ResistanceIP65IP65Weather resistant
Night VisionColor Night Vision with starlight sensorColor Night Vision with starlight sensorN/A
CompatibilityWired doorbell setupWired doorbell setupCompatible with Doorbell v2 only
Included AccessoriesDoorbell + Chime ControllerDoorbell + Chime Controller1x 15° Horizontal Bracket, 2x 7.5° Vertical Brackets, Screws, Quick Start Guide
InstallationWired, includes chime controllerWired, includes chime controllerQuick installation
WarrantyNot specified30-day hassle-free returns1 year
Return PolicyFinal sale, no returns30-day hassle-free returnsNot specified
ColorNot specifiedNot specifiedBlack
MaterialNot specifiedNot specifiedPlastic
PurposeVideo doorbellVideo doorbellAdjust viewing angle for Doorbell v2
What is the Refurbished Wyze Video Doorbell v2?The Refurbished Wyze Video Doorbell v2 is a like-new, fully tested smart doorbell that offers all the premium features of the latest Wyze Video Doorbell v2 at a more affordable price. It includes 2K video resolution, two-way audio, motion detection, and seamless Alexa integration.
Does the Refurbished Wyze Video Doorbell v2 work with Alexa?Yes, the Refurbished Wyze Video Doorbell v2 is fully compatible with Alexa. You can view live video feeds on Echo Show or Fire TV devices, receive real-time alerts, and use voice commands for hands-free control.
What are the main features of the Refurbished Wyze Video Doorbell v2?Key features include 2K (2048 x 1536) video resolution, a 166.8° diagonal field of view, two-way audio with noise cancellation, motion-activated voice deterrence, local microSD storage up to 256GB, optional cloud storage, IP65 weather resistance, and Alexa integration.
Is the refurbished model as reliable as a new Wyze Video Doorbell v2?Yes, the refurbished Wyze Video Doorbell v2 is fully tested and guaranteed to work flawlessly, offering the same trusted performance and features as the new model.
What is included with the Refurbished Wyze Video Doorbell v2?The package includes the doorbell unit, chime controller, wall plate, 30° wedge, installation kit, wire caps, extension wires, screws, anchors, and a quick start guide.
What are the technical specifications of the Wyze Video Doorbell v2?The doorbell features a CMOS Starlight Sensor with F2.0 aperture, 2.1mm focal length, 20 FPS daytime and 15 FPS nighttime frame rates, 6 x 940nm IR lights for night vision, Wi-Fi 2.4 GHz connectivity, and requires 16V-24V AC power (≥10VA). Dimensions are 4.3in x 1.7in x 0.9in (110mm x 44mm x 24mm).
Is the Wyze Video Doorbell v2 weather-resistant?Yes, the Wyze Video Doorbell v2 has an IP65 weather-resistant rating, making it suitable for outdoor use in various weather conditions.
What is the Wyze Video Doorbell v2 Wedge Kit and why should I use it?The Wyze Video Doorbell v2 Wedge Kit is an accessory designed to optimize your doorbell’s viewing angle, especially for angled door frames or porches with stairs. It includes adjustable brackets for horizontal and vertical angles, is weather-resistant, and helps eliminate blind spots for improved security coverage.
How easy is it to install the Wyze Video Doorbell v2 and Wedge Kit?Both the Wyze Video Doorbell v2 and the Wedge Kit are designed for easy installation. The package includes all necessary hardware, screws, and a quick start guide to help you set up quickly and efficiently.
Does the Wyze Video Doorbell v2 support local and cloud storage?Yes, the Wyze Video Doorbell v2 supports local microSD storage up to 256GB and offers optional cloud storage through the Wyze Security Plan.
What are the key features of the refurbished Wyze Video Doorbell v2?Can you tell me more about the Wyze Video Doorbell v2 Wedge Kit?What is the warranty policy for the refurbished Wyze Video Doorbell v2?
