USB Surge Protector: 268 Joule, Overload Protection & 3 USB Ports
USB Surge Protector with 268 Joule Suppression Rating and Overload Protection
When it comes to protecting your valuable electronic devices from power surges and overloads, choosing the right surge protector is essential. A USB surge protector with a high joule suppression rating and built-in overload protection ensures your devices stay safe while providing convenient charging options. Among the available options, the Wyze Surge Protector stands out as a reliable and feature-rich choice designed for modern homes.
Wyze Surge Protector: Power and Protection Combined
Robust Surge Suppression and Safety Features
The Wyze Surge Protector offers a 268 Joule suppression rating, which means it can absorb a significant amount of energy from power surges, protecting your connected devices from damage caused by unexpected voltage spikes. This level of surge protection is ideal for safeguarding sensitive electronics such as smartphones, tablets, laptops, and other USB-powered gadgets. In addition to surge protection, the Wyze Surge Protector includes:
  • Overload protection that automatically cuts off power when the current exceeds 15A, preventing electrical hazards.
  • 20µA ground fault protection to enhance safety by detecting leakage currents.
  • A scratch-resistant and flame-retardant housing rated to withstand temperatures up to 1,380℉ (750℃), ensuring durability and fire safety.
  • UL listing and FCC certification, confirming compliance with rigorous safety standards.
Convenient Charging and Power Options
This surge protector is designed with practicality in mind, featuring:
  • 3 USB ports equipped with smart IC technology for fast and efficient simultaneous charging of multiple devices. The USB ports deliver a total output of 5V/3.1A, with each port capable of up to 2.1A.
  • 3 grounded Type B outlets to plug in your essential electronics and appliances.
  • A 4-foot long 14 AWG power cord for flexible placement around your home or office.
Compact and User-Friendly Design
The Wyze Surge Protector boasts a low-profile design with dimensions of 8.58” (L) x 1.61” (W) x 1.02” (H) and weighs just 0.89 lbs, making it easy to fit in tight spaces without clutter. Its sleek and modern look complements any environment, from your desk setup to your entertainment center.
"Power for the modern home" is more than a tagline — it reflects the Wyze Surge Protector’s blend of safety, convenience, and smart design.
Modern Home Workspace with Surge Protector Alt text: Modern home workspace with multiple devices plugged into a surge protector
Why Choose a Surge Protector with Overload Protection?
Overload protection is a critical feature that prevents electrical fires and damage by automatically shutting off power when the current exceeds safe limits. The Wyze Surge Protector’s overload protection activates at 15A, ensuring your devices and home wiring remain safe even during unexpected power surges or circuit overloads. This feature is especially important in homes with multiple high-power devices running simultaneously, as it provides peace of mind and reduces the risk of costly repairs or hazards.
Technical Specifications at a Glance
FeatureSpecification
Surge Suppression Rating268 Joules
Overload ProtectionAuto shutoff at 15A
USB Ports3 (5V/3.1A total, max 2.1A each)
Outlets3 grounded Type B outlets
Power Cord Length4 feet (14 AWG)
Power RatingAC 15A, 125V, 60Hz, 1875W
Dimensions8.58” x 1.61” x 1.02”
Weight0.89 lbs
Safety CertificationsUL listed, FCC certified
Housing MaterialScratch-resistant, flame retardant
Summary
For anyone searching for a USB surge protector with a 268 joule suppression rating and overload protection, the Wyze Surge Protector is an excellent choice. It combines high-level surge protection, smart USB charging, and essential safety features in a compact, affordable package. Whether for your home office, entertainment system, or general device charging needs, this surge protector offers reliable power management and peace of mind.
What is the surge suppression rating of the Wyze USB Surge Protector?The Wyze USB Surge Protector features a 268 Joule surge suppression rating, which helps protect your electronic devices from damage caused by unexpected voltage spikes and power surges.
How does the Wyze Surge Protector provide overload protection?The Wyze Surge Protector includes built-in overload protection that automatically shuts off power when the current exceeds 15A, preventing electrical hazards and protecting your devices and home wiring.
How many USB ports does the Wyze Surge Protector have and what is their output?The Wyze Surge Protector is equipped with 3 USB ports featuring smart IC technology. These ports deliver a total output of 5V/3.1A, with each port capable of providing up to 2.1A for fast and efficient charging.
What types of outlets are included on the Wyze Surge Protector?The Wyze Surge Protector includes 3 grounded Type B outlets, allowing you to plug in essential electronics and appliances alongside your USB-powered devices.
Is the Wyze Surge Protector certified for safety?Yes, the Wyze Surge Protector is UL listed and FCC certified, ensuring it meets rigorous safety and quality standards for use in homes and offices.
What additional safety features does the Wyze Surge Protector offer?In addition to surge and overload protection, the Wyze Surge Protector offers 20µA ground fault protection to detect leakage currents, and its housing is scratch-resistant and flame-retardant, rated to withstand temperatures up to 1,380℉ (750℃).
What are the dimensions and weight of the Wyze Surge Protector?The Wyze Surge Protector measures 8.58 inches in length, 1.61 inches in width, and 1.02 inches in height, and weighs just 0.89 lbs, making it compact and easy to fit in tight spaces.
How long is the power cord on the Wyze Surge Protector and what is its rating?The Wyze Surge Protector comes with a 4-foot long, 14 AWG power cord, providing flexibility for placement around your home or office.
Why is overload protection important in a surge protector?Overload protection is crucial because it automatically shuts off power when the current exceeds safe limits, preventing electrical fires, device damage, and costly repairs, especially in homes with multiple high-power devices.
What is the power rating of the Wyze Surge Protector?The Wyze Surge Protector has a power rating of AC 15A, 125V, 60Hz, and supports up to 1875W, making it suitable for a variety of electronic devices and appliances.
What are the safety certifications for the Wyze Surge Protector?Can you explain how the overload protection feature works?Do you have any deals, ongoing sales, discounts, or promotions for the Wyze Surge Protector?
