Compact Desk Surge Protector with USB Ports for Device Charging
Compact Surge Protector for Desk Charging Devices with USB Ports
When it comes to powering and protecting your desk devices, a compact surge protector with USB ports is an essential accessory. It not only safeguards your electronics from power surges but also provides convenient USB charging options, reducing clutter and enhancing workspace efficiency. Among the available options, the Wyze Surge Protector stands out as a top choice for modern home and office setups.
Wyze Surge Protector: Power and Protection in a Compact Design
Key Features
  • 3 USB Ports: Charge multiple USB devices simultaneously with a total output of 5V/3.1A, and each port delivering up to 5V/2.1A max.
  • 3 Grounded Outlets: Safely plug in your essential devices with surge protection.
  • Surge Protection Rating: 268 joules suppression rating to protect your electronics from unexpected power spikes.
  • Safety First: Flame resistant and flame retardant up to 1,380°F (750°C), ensuring reliable safety.
  • Overload Protection: Automatically switches off when current limits are exceeded, requiring a manual reset for reuse.
  • Ground Fault Protection: 20μA ground fault protection for added safety.
  • Low Profile & Slim Design: Measures just 8.58" (L) x 1.61" (W) x 1.02" (H) with a right-angle flat plug, perfect for tight desk spaces.
  • Non-slip Rubber Pads: Keeps the surge protector stable on your desk.
  • Soft-white LED Indicator: Shows power status without being harsh on the eyes.
  • Scratch-resistant Finish: Maintains a clean, professional look.
  • Certifications: UL and FCC certified for quality assurance.
  • Warranty: Comes with a 1-year warranty for peace of mind.
Why Choose Wyze Surge Protector?
This surge protector is designed specifically for the modern home and office environment. Its compact size and multiple USB ports make it ideal for charging smartphones, tablets, and other USB-powered devices right from your desk without the need for bulky adapters. The combination of grounded outlets and USB ports ensures you can power all your essential devices safely and efficiently.
"Power for the modern home" is not just a tagline but a promise of convenience, safety, and smart design.
Modern workspace with compact surge protector and devices
Why a Compact Surge Protector with USB Ports is Essential for Your Desk
Space-Saving Convenience
A compact surge protector like the Wyze Surge Protector fits neatly on your desk or behind your workstation, reducing cable clutter and freeing up valuable space. Its slim profile and right-angle plug design allow it to fit in tight spaces without blocking other outlets.
Multiple Device Charging
With three USB ports alongside three grounded outlets, you can charge your phone, tablet, wireless headphones, and plug in your laptop charger or desk lamp all at once. This eliminates the need for multiple adapters and power strips.
Enhanced Safety Features
Surge protection is critical to prevent damage to your electronics from voltage spikes caused by lightning or power outages. The Wyze Surge Protector’s 268 joules suppression rating and overload protection ensure your devices stay safe. The flame-resistant materials and ground fault protection add extra layers of security.
Summary
For anyone looking to upgrade their desk setup with a reliable, compact surge protector that includes USB charging ports, the Wyze Surge Protector is an excellent choice. It combines safety, convenience, and a sleek design to keep your devices powered and protected without taking up unnecessary space.
What is the Wyze Surge Protector and what makes it ideal for desk charging?The Wyze Surge Protector is a compact power strip designed for modern home and office desks. It features three grounded outlets and three USB ports, allowing you to charge multiple devices simultaneously while protecting them from power surges. Its slim, low-profile design and right-angle flat plug make it perfect for tight desk spaces, reducing clutter and enhancing workspace efficiency.
How many devices can I charge at once with the Wyze Surge Protector?You can charge up to six devices at once with the Wyze Surge Protector—three via the grounded AC outlets and three via the USB ports. Each USB port delivers up to 5V/2.1A, with a total USB output of 5V/3.1A, making it suitable for charging smartphones, tablets, and other USB-powered devices.
What safety features does the Wyze Surge Protector offer?The Wyze Surge Protector offers multiple safety features, including a 268 joules surge suppression rating to protect against power spikes, overload protection that automatically switches off when current limits are exceeded, flame-resistant materials rated up to 1,380°F (750°C), and 20μA ground fault protection. It is also UL and FCC certified for added peace of mind.
Is the Wyze Surge Protector suitable for small or tight desk spaces?Yes, the Wyze Surge Protector is specifically designed for compact spaces. Its slim profile (8.58" x 1.61" x 1.02") and right-angle flat plug allow it to fit neatly on your desk or behind furniture without blocking other outlets. Non-slip rubber pads keep it stable on your workspace.
Does the Wyze Surge Protector have a warranty?Yes, the Wyze Surge Protector comes with a 1-year warranty, providing assurance and support for your purchase.
How does the Wyze Surge Protector help reduce desk clutter?The Wyze Surge Protector combines three AC outlets and three USB charging ports in a single, compact device. This eliminates the need for multiple adapters and power strips, helping you keep your desk organized and free from cable clutter.
What certifications does the Wyze Surge Protector have?The Wyze Surge Protector is UL and FCC certified, ensuring it meets high standards for safety and quality.
What is the surge protection rating of the Wyze Surge Protector?The Wyze Surge Protector has a surge protection rating of 268 joules, which helps safeguard your electronics from unexpected voltage spikes caused by lightning or power outages.
What additional features does the Wyze Surge Protector offer?Additional features include a soft-white LED indicator for power status, a scratch-resistant finish for a clean look, and non-slip rubber pads to keep the surge protector stable on your desk.
What are the safety features included in the Wyze Surge Protector?How does the overload protection work in the Wyze Surge Protector?Do you have any deals, ongoing sales, discounts, or promotions for the Wyze Surge Protector?
