Surge Protector with Non-Slip Pads for Secure Device Placement
Surge Protector Ideal for Secure Device Placement with Non-Slip Pads
When it comes to protecting your valuable electronics and ensuring a stable, slip-free setup, choosing the right surge protector is essential. The Wyze Surge Protector stands out as an ideal solution designed specifically for secure device placement, featuring non-slip pads that keep your power strip firmly in place while safeguarding your devices from power surges.
Wyze Surge Protector: Power Meets Safety and Stability
Robust Surge Protection and Multiple Charging Options
The Wyze Surge Protector offers comprehensive protection with a 268 joules suppression rating, effectively shielding your devices from unexpected power spikes. It includes 3 grounded outlets and 3 USB ports (total 5V/3.1A output), making it perfect for charging multiple devices simultaneously without clutter.
Secure and Stable Placement with Non-Slip Pads
One of the key features that make this surge protector ideal for secure device placement is its 4 non-slip rubber pads. These pads prevent the power strip from sliding on smooth surfaces, ensuring your devices stay put and reducing the risk of accidental unplugging or damage.
Sleek, Low-Profile Design
The slim, low-profile design with a right-angle flat plug allows the surge protector to fit neatly behind furniture or tight spaces, optimizing your workspace or entertainment area without bulky interference.
Safety and Durability Features
  • Flame resistant materials rated to 1,380°F (750°C)
  • 15A overload protection with automatic shutoff and manual reset
  • 20μA ground fault protection for added electrical safety
  • Certified by UL and FCC for quality assurance
  • Equipped with a soft-white LED light indicator to show power status
  • Scratch-resistant surface for long-lasting appearance
Dimensions and Warranty
  • Size: 8.58" (L) x 1.61" (W) x 1.02" (H)
  • Weight: 0.89 lbs
  • Power Cord Length: 4 feet
  • Comes with a 1-year warranty
The Wyze Surge Protector is the perfect blend of safety, convenience, and stability, making it an excellent choice for anyone looking to secure their devices while keeping their space organized and slip-free.
Modern workspace with secure surge protector Alt text: Modern home workspace with Wyze Surge Protector securely placed on desk
Why Choose a Surge Protector with Non-Slip Pads?
Non-slip pads are a small but crucial feature that enhances the usability and safety of surge protectors. They:
  • Prevent accidental movement or disconnection of devices
  • Protect surfaces from scratches and damage
  • Provide peace of mind when placing power strips on smooth or inclined surfaces
The Wyze Surge Protector’s four rubber pads ensure it stays firmly in place, making it ideal for home offices, entertainment centers, and any environment where device stability is a priority.
Summary: Secure Your Devices with Wyze Surge Protector
The Wyze Surge Protector is a smart investment for anyone who values device safety and a tidy, secure setup. Its combination of surge protection, multiple charging ports, and non-slip pads makes it stand out as the best choice for secure device placement.
What makes the Wyze Surge Protector ideal for secure device placement?The Wyze Surge Protector is designed with four non-slip rubber pads that keep the power strip firmly in place on smooth or inclined surfaces. This prevents accidental movement, unplugging, or damage to your devices, making it perfect for secure device placement in home offices, entertainment centers, and more.
How does the Wyze Surge Protector protect my devices from power surges?The Wyze Surge Protector features a 268 joules suppression rating, which effectively shields your electronics from unexpected power spikes. It also includes 15A overload protection with automatic shutoff and manual reset, as well as 20μA ground fault protection for added electrical safety.
How many devices can I charge with the Wyze Surge Protector?The Wyze Surge Protector offers 3 grounded AC outlets and 3 USB ports (total 5V/3.1A output), allowing you to charge or power up to six devices simultaneously without clutter.
What are the safety and durability features of the Wyze Surge Protector?The Wyze Surge Protector is made from flame-resistant materials rated to 1,380°F (750°C), has 15A overload protection, 20μA ground fault protection, and is certified by UL and FCC for quality assurance. It also features a scratch-resistant surface and a soft-white LED light indicator to show power status.
Does the Wyze Surge Protector fit in tight spaces?Yes, the Wyze Surge Protector has a slim, low-profile design with a right-angle flat plug, making it easy to fit behind furniture or in tight spaces without bulky interference.
What are the dimensions and weight of the Wyze Surge Protector?The Wyze Surge Protector measures 8.58 inches in length, 1.61 inches in width, and 1.02 inches in height. It weighs 0.89 lbs and comes with a 4-foot power cord.
Is the Wyze Surge Protector covered by a warranty?Yes, the Wyze Surge Protector comes with a 1-year warranty, providing peace of mind and assurance of quality.
Why are non-slip pads important on a surge protector?Non-slip pads prevent the surge protector from sliding on smooth surfaces, protect your furniture from scratches, and reduce the risk of accidental disconnection or damage to your devices. This ensures a stable and secure setup for your electronics.
What are the dimensions of the Wyze Surge Protector?Can you tell me more about the safety features of the Wyze Surge Protector?Is there a warranty included with the Wyze Surge Protector?
