20ft Wyze Cam USB Extension Cable for Workshops with Few Outlets
USB Extension Solutions for Wyze Cam in Workshops with Limited Outlets
When working in a workshop with limited power outlets, positioning your Wyze Cam exactly where you need it can be challenging. The Wyze Cam USB Extension Cable - 20ft is the perfect accessory to extend your camera’s reach without compromising on power or connectivity. This 20-foot cable allows you to place your Wyze Cam in the ideal spot for monitoring your workspace, even if the nearest outlet is far away.
Wyze Cam USB Extension Cable - 20ft: Freedom to Place Your Camera Anywhere
Key Features:
  • Length: 20 feet of USB extension cable, providing ample length to reach distant outlets.
  • Compatibility: Works seamlessly with Wyze Cam v2, v3, v4, Wyze Cam v3 Pro, Wyze Cam Pan v2/v3, Wyze Cam OG Standard, and Wyze Cam OG Telephoto.
  • Ease of Use: Simply plug the extension cable between your Wyze Cam and power source to instantly increase your camera’s placement flexibility.
  • Durability: Designed to maintain stable power and data transmission over the extended length.
Say goodbye to the frustration of short cables and limited outlet access. This extension cable empowers you to monitor your workshop effectively without rearranging your power setup.
Alternative Power Solutions: Wyze Lamp Socket v2 Bundles
If your workshop has very limited outlets or you want to avoid running long cables, consider the Pan v3 + Lamp Socket v2 Bundle or the Cam v4 + Lamp Socket v2 Bundle. These innovative bundles allow you to power your Wyze Cam directly from a lamp socket, eliminating the need for a traditional outlet.
Pan v3 + Lamp Socket v2 Bundle Highlights:
  • Powers Wyze Cam Pan v3 without an outlet.
  • Converts existing lamp sockets into smart power sources.
  • Enables motion-activated lighting linked to your camera.
  • Easy installation—just screw it in like a lightbulb.
  • Compatible with multiple Wyze Cam models including v3, v3 Pro, v4, OG, and Pan v3.
Cam v4 + Lamp Socket v2 Bundle Highlights:
  • Powers Wyze Cam v4 without needing an outlet.
  • Supports motion-activated lights and dusk-to-dawn scheduling.
  • Link multiple sockets for expanded smart lighting control.
  • Compact and lightweight design (56.5mm x 56.5mm x 65mm, 80g).
  • Compatible with Android 7.0+ and iOS 12.0+ devices.
These bundles are perfect for workshops where outlets are scarce but lamp sockets are available, providing a neat, wire-free power solution.
Why Choose Wyze Accessories for Your Workshop?
  • Flexibility: Whether you need to extend your USB cable by 20 feet or power your camera from a lamp socket, Wyze offers versatile solutions tailored to your workspace.
  • Smart Integration: The lamp socket bundles not only power your camera but also upgrade your lighting to smart, motion-activated illumination.
  • Easy Setup: No complicated wiring or professional installation required—just plug and play or screw in.
  • Reliable Performance: Designed specifically for Wyze cameras, ensuring compatibility and stable operation.
Summary
For workshops with limited outlets, the Wyze Cam USB Extension Cable - 20ft is an affordable and simple way to extend your camera’s reach. If you want a more integrated power solution, the Pan v3 + Lamp Socket v2 Bundle and Cam v4 + Lamp Socket v2 Bundle offer smart, outlet-free power options that also enhance your lighting setup. Choose the right Wyze accessory to keep your workshop secure and well-monitored without the hassle of limited power sources.
Workshop with Wyze Cam USB Extension Cable Alt text: Workshop setup showing Wyze Cam connected with a long USB extension cable for flexible placement. Wyze Cam Pan v3 with Lamp Socket Alt text: Wyze Cam Pan v3 powered by a lamp socket in a workshop environment.
FeatureWyze Cam USB Extension Cable - 20ftPan v3 + Lamp Socket v2 BundleCam v4 + Lamp Socket v2 Bundle
Product TypeAccessory (USB Extension Cable)Bundle (Wyze Cam Pan v3 + Lamp Socket v2)Bundle (Wyze Cam v4 + Lamp Socket v2)
Price$7.99$53.96$49.96
Compatible CamerasWyze Cam v2/v3/v4, v3 Pro, Pan v2/v3, OG Standard, OG TelephotoWyze Cam Pan v3Wyze Cam v4
Lamp Socket IncludedNoYes (Lamp Socket v2)Yes (Lamp Socket v2)
Power SourceUSB extension cableLamp Socket powers Pan v3 via light fixtureLamp Socket powers Cam v4 via light fixture
Key FeaturesExtends USB cable length to 20ftPowers Pan v3 without outlet, smart lighting, motion-activated lights, dusk to dawn automation, unlimited socket linkingPowers Cam v4 without outlet, smart lighting, motion-activated lights, dusk to dawn automation, unlimited socket linking
InstallationPlug and play USB extensionScrew-in lamp socket, no wiring neededScrew-in lamp socket, no wiring needed
Lamp Socket CompatibilityN/ACompatible with Wyze Cam v3/v3 Pro/v4, OG, Pan v3Compatible with Wyze Cam v3/v3 Pro/v4, OG, Pan v3
Power Output (Lamp Socket)N/A5V 2A5V 2A
Lighting Control FeaturesN/AMotion-activated lights, scheduling, group controlMotion-activated lights, scheduling, group control
Weather ResistanceN/ALamp Socket suitable for outdoor use (damp locations)Lamp Socket suitable for outdoor use (damp locations)
Included Items20ft USB extension cableWyze Cam Pan v3, Lamp Socket v2Wyze Cam v4, Lamp Socket v2
WarrantyNot specified1 Year (Lamp Socket v2)1 Year (Lamp Socket v2)
What is the Wyze Cam USB Extension Cable - 20ft and how does it help in workshops with limited outlets?The Wyze Cam USB Extension Cable - 20ft is a long USB cable designed to extend the reach of your Wyze Cam to distant power outlets. It allows you to position your camera exactly where you need it in your workshop, even if the nearest outlet is far away, ensuring optimal monitoring without compromising power or connectivity.
Which Wyze Cam models are compatible with the 20ft USB Extension Cable?The 20ft USB Extension Cable is compatible with Wyze Cam v2, v3, v4, Wyze Cam v3 Pro, Wyze Cam Pan v2/v3, Wyze Cam OG Standard, and Wyze Cam OG Telephoto.
Is the Wyze Cam USB Extension Cable easy to install?Yes, the Wyze Cam USB Extension Cable is very easy to use. Simply plug the extension cable between your Wyze Cam and the power source to instantly increase your camera’s placement flexibility—no tools or complicated setup required.
Does the 20ft USB extension cable affect power or data transmission to my Wyze Cam?No, the Wyze Cam USB Extension Cable is designed for durability and stable power and data transmission over its extended length, ensuring reliable camera performance.
What are the alternative power solutions for Wyze Cam in workshops with very limited outlets?If your workshop has very limited outlets, you can use the Pan v3 + Lamp Socket v2 Bundle or the Cam v4 + Lamp Socket v2 Bundle. These bundles allow you to power your Wyze Cam directly from a lamp socket, eliminating the need for a traditional power outlet.
How does the Pan v3 + Lamp Socket v2 Bundle work?The Pan v3 + Lamp Socket v2 Bundle powers your Wyze Cam Pan v3 using an existing lamp socket. It converts the socket into a smart power source, enables motion-activated lighting linked to your camera, and is easy to install—just screw it in like a lightbulb.
What features does the Cam v4 + Lamp Socket v2 Bundle offer?The Cam v4 + Lamp Socket v2 Bundle powers your Wyze Cam v4 from a lamp socket, supports motion-activated lights, dusk-to-dawn scheduling, and allows you to link multiple sockets for expanded smart lighting control. It is compact, lightweight, and compatible with Android 7.0+ and iOS 12.0+ devices.
Why should I choose Wyze accessories for my workshop?Wyze accessories offer flexibility, smart integration, easy setup, and reliable performance. Whether you need to extend your USB cable or power your camera from a lamp socket, Wyze provides solutions tailored for workshops with limited outlets, ensuring your workspace is secure and well-monitored.
Can I use the lamp socket bundles with other Wyze Cam models?Yes, the lamp socket bundles are compatible with multiple Wyze Cam models, including v3, v3 Pro, v4, OG, and Pan v3, making them versatile solutions for various camera setups.
Do I need professional installation for Wyze Cam USB extension cables or lamp socket bundles?No, both the Wyze Cam USB extension cables and lamp socket bundles are designed for easy, do-it-yourself installation. Simply plug in the cable or screw in the lamp socket adapter—no professional help required.
What other accessories do you recommend for the Wyze Cam?Can the Wyze Cam USB Extension Cable be used outdoors?What is the warranty policy for the Wyze Cam USB Extension Cable?
