Control Your Thermostat Remotely with the Wyze App
How to Control Your Thermostat Remotely Using an App
Controlling your home's temperature remotely has never been easier thanks to smart thermostats. With the Wyze Thermostat and its related accessories, you can manage your heating and cooling from anywhere using your smartphone. This guide will walk you through the features and benefits of the Wyze Thermostat lineup, showing you how to simplify your home environment with smart technology.
Wyze Thermostat: Smart Heating & Cooling Simplified
The Wyze Thermostat is designed to give you full control over your home's climate with ease and efficiency.
Key Features:
  • Remote Control via App: Compatible with Android 9.0+ and iOS 15.0+, the Wyze app lets you adjust your thermostat settings from anywhere using 2.4GHz WiFi or Bluetooth connectivity.
  • Easy Installation: Comes with a C-wire adapter and all necessary mounting hardware for a hassle-free setup.
  • Clear IPS Display: The thermostat features a 120mm x 65mm x 33mm compact design with a 180º viewing angle IPS display, making it easy to read and operate.
  • Voice Assistant Integration: Works seamlessly with Alexa and Google Assistant for hands-free control.
  • Eco-Friendly Design: Packaged with recyclable materials and free from mercury, arsenic, and PVC.
  • Indoor Use: Designed for indoor environments with operating temperatures from 32°F to 130°F (0°C to 55°C).
What’s Included:
  • Wyze Thermostat unit
  • C-Wire Adapter
  • Back Panel and Mounting Plate
  • Wall Cover and Screws
  • Wire Label Sheets and Screwdrivers
  • Quick Start Guide
Priced at $79.98, this thermostat offers a modern, smart solution to managing your home's heating and cooling efficiently.
Affordable Refurbished Wyze Thermostat
For budget-conscious users, the (Refurbished) Wyze Thermostat provides the same smart features at a significantly reduced price of $29.98.
Highlights:
  • Fully tested and guaranteed to work like new.
  • Same compatibility with Android and iOS devices.
  • Includes all original accessories and a 1-year warranty.
  • Ideal for those who want smart home convenience without the full retail price.
Enhance Your System with Wyze Room Sensor
To optimize comfort throughout your home, the Wyze Room Sensor works in tandem with the Wyze Thermostat.
Benefits:
  • Eliminate Hot and Cold Spots: The sensor detects room temperature, humidity, and motion to help balance your home's climate.
  • Remote Monitoring: View real-time room conditions from your phone.
  • Flexible Placement: Use up to 6 sensors anywhere in your home, mounted on walls or placed on tables with magnetic stands.
  • Motion-Sensing Comfort Mode: Automatically adjusts settings based on room occupancy.
Available in packs of 1 or 3, or bundled with the thermostat, the Wyze Room Sensor is a smart addition for granular climate control.
Maintenance Made Easy: Wyze Thermostat Replacement Part Kit
Keep your Wyze Thermostat running smoothly with the Replacement Part Kit, which includes essential screws, cables, and other components.
Features:
  • Affordable at $19.99.
  • Hassle-free 30-day return policy.
  • Perfect for lost or damaged parts to extend the life of your thermostat.
Why Choose Wyze Thermostat for Remote Control?
"Smart heating & cooling - simplified." — Wyze
The Wyze Thermostat offers a user-friendly app experience that puts you in control of your home's temperature no matter where you are. Its compatibility with popular voice assistants and robust connectivity options ensure seamless integration into your smart home ecosystem.
Family enjoying comfortable home environment Control your home's climate remotely for comfort and convenience.
Summary
With the Wyze Thermostat and its accessories, controlling your home's temperature remotely is straightforward and affordable. Whether you choose the brand-new or refurbished thermostat, add room sensors for enhanced comfort, or keep your system maintained with replacement parts, Wyze provides a comprehensive smart home heating and cooling solution.
FeatureWyze Thermostat (Refurbished)Wyze ThermostatWyze Thermostat Replacement Part KitWyze Room Sensor
TypeRefurbishedConnected HomeReplacement PartsConnected Home
Price$29.98 (Regular $79.98)$79.98$19.99$24.99 (3 Pack), $129.98 (1 Pack)
Return PolicyFinal Sale, no returns30-day hassle-free returns30-day hassle-free returnsRefund only (EOL product)
ConditionLike new, fully testedNewReplacement partsNew, discontinued (EOL)
Smart Heating & CoolingYesYesNoNo
Remote Temperature ControlYes, via appYes, via appNoNo
Voice Assistant CompatibilityAlexa, Google AssistantAlexa, Google AssistantNoNo
Room Climate MonitoringWith Wyze Room SensorWith Wyze Room SensorNoYes
Motion-Sensing Comfort ModeYesYesNoYes
Number of Sensors SupportedUp to 6 Wyze Room SensorsUp to 6 Wyze Room SensorsN/AUp to 6 sensors
DisplayAlways-on displayAlways-on displayN/AN/A
Installation20-minute DIY, app-guided20-minute DIY, app-guidedN/AN/A
Included PartsThermostat unit onlyThermostat unit onlyScrews, cables, other partsSensor unit(s)
Energy Saving FeaturesUsage-based tips, schedulingUsage-based tips, schedulingNoNo
SchedulingYes, daily schedulingYes, daily schedulingNoNo
Hot/Cold Spot ManagementWith Room SensorWith Room SensorNoYes
Wireless SetupYesYesNoYes
Wall Mount / Table StandYesYesNoYes
How can I control my Wyze Thermostat remotely?You can control your Wyze Thermostat remotely using the Wyze app, which is compatible with Android 9.0+ and iOS 15.0+ devices. The app allows you to adjust your home's temperature from anywhere using 2.4GHz WiFi or Bluetooth connectivity.
What are the key features of the Wyze Thermostat?The Wyze Thermostat offers remote control via app, easy installation with a C-wire adapter, a clear IPS display, voice assistant integration with Alexa and Google Assistant, eco-friendly design, and is suitable for indoor use with operating temperatures from 32°F to 130°F (0°C to 55°C).
Is the Wyze Thermostat easy to install?Yes, the Wyze Thermostat comes with a C-wire adapter, back panel, mounting plate, wall cover, screws, wire label sheets, screwdrivers, and a quick start guide for hassle-free installation.
Does the Wyze Thermostat work with voice assistants?Yes, the Wyze Thermostat is compatible with Alexa and Google Assistant, allowing for hands-free voice control of your home's heating and cooling.
What is included with the Wyze Thermostat purchase?Each Wyze Thermostat package includes the thermostat unit, C-wire adapter, back panel and mounting plate, wall cover and screws, wire label sheets, screwdrivers, and a quick start guide.
Is there a refurbished Wyze Thermostat available?Yes, the (Refurbished) Wyze Thermostat is available at a reduced price. It is fully tested, guaranteed to work like new, includes all original accessories, and comes with a 1-year warranty.
How does the Wyze Room Sensor improve home comfort?The Wyze Room Sensor detects room temperature, humidity, and motion to help eliminate hot and cold spots. It enables remote monitoring and can automatically adjust your thermostat settings based on room occupancy for optimal comfort.
How many Wyze Room Sensors can I use in my home?You can use up to 6 Wyze Room Sensors throughout your home. They can be mounted on walls or placed on tables using magnetic stands for flexible placement.
What should I do if I lose or damage a part of my Wyze Thermostat?You can purchase the Wyze Thermostat Replacement Part Kit, which includes essential screws, cables, and other components to keep your thermostat running smoothly. The kit is affordable and comes with a 30-day return policy.
Why should I choose the Wyze Thermostat for remote temperature control?The Wyze Thermostat offers a user-friendly app for remote control, seamless integration with popular voice assistants, robust connectivity options, and affordable pricing, making it an excellent choice for smart home heating and cooling.
What are the key features of the Wyze Thermostat?How does the Wyze Room Sensor work with the Wyze Thermostat?Can I use the Wyze Thermostat with voice assistants like Alexa and Google Assistant?
