Tidy 20ft Wyze Cam USB Extension Cable for Baseboard Setup
Tidy Cable Solution for Running Wyze Cam Along Baseboards
When setting up your Wyze Cam along baseboards, managing cables neatly is essential for both aesthetics and safety. The Wyze Cam USB Extension Cable - 20ft is the perfect accessory to extend your camera’s reach without clutter or the need for unsightly power strips. This guide highlights the best products to help you achieve a clean, organized installation with reliable power and connectivity.
Wyze Cam USB Extension Cable - 20ft: Freedom to Place Your Camera Anywhere
The Wyze Cam USB Extension Cable - 20ft is designed to solve the common problem of short cables limiting camera placement. Whether you have a Wyze Cam v2, v3, v4, or Pan models, this extension cable gives you the freedom to run your camera’s power cable discreetly along baseboards or walls without stretching or awkward positioning.
Key Features:
  • Length: 20 feet of flexible USB extension cable.
  • Compatibility: Works seamlessly with Wyze Cam v2, v3, v4, v3 Pro, Pan v2/v3, OG Standard, and OG Telephoto.
  • Installation: Easily run the cable along baseboards, tucking it into corners or under trim for a tidy look.
  • Durability: Designed for indoor use with reliable USB connectivity to maintain power and data integrity.
Say goodbye to short cables and enjoy the freedom to place your Wyze Cam exactly where you want it, with a neat and professional cable run.
Wyze Cam v4: The Ultimate Camera for Clear, Colorful Security
Pairing your tidy cable setup with the Wyze Cam v4 ensures you get the best video quality and smart features in a compact, weather-resistant design. The v4 model is perfect for indoor or outdoor use, making it versatile for any home security setup.
Why Choose Wyze Cam v4?
  • 2.5K Quad HD Resolution: Capture crystal-clear video with vibrant colors and wide dynamic range (WDR).
  • Color Night Vision: See more details in low light with enhanced color night vision that outperforms traditional black-and-white infrared.
  • IP65 Weather Resistance: Place your camera anywhere, even outdoors, without worrying about rain or dust.
  • Integrated Spotlight & Siren: Motion-activated spotlight and a loud siren help deter intruders.
  • Easy Setup: Bluetooth-enabled for quick installation and screw-free magnetic mounting.
  • Smart Features: Motion and sound detection, smoke and CO alerts, and AI-powered auto-zoom tracking.
The Wyze Cam v4’s compact size and magnetic base make it easy to mount along baseboards or walls, and with the 20ft USB extension cable, you can position it exactly where you need it without cable clutter. Wyze Cam v4 installed indoors Alt text: Wyze Cam v4 mounted neatly along a baseboard in a modern living room
Lamp Socket v2 Bundle: Power Your Wyze Cam Without an Outlet
For even more flexible placement, consider the Cam v4 + Lamp Socket v2 Bundle. This innovative solution allows you to power your Wyze Cam v4 through a standard lamp socket, eliminating the need for nearby power outlets and reducing visible cables.
Bundle Highlights:
  • Convenient Power Source: Use existing lamp sockets (E26 type) to power your camera.
  • Motion-Activated Lights: The lamp socket supports dusk-to-dawn scheduling and motion activation, enhancing security lighting.
  • Compact & Lightweight: Measures 56.5mm x 56.5mm x 65mm and weighs only 80g.
  • Compatibility: Works with Wyze Cam v3, v3 Pro, v4, OG, and Pan v3.
  • Connectivity: Supports 2.4GHz Wi-Fi and Bluetooth for easy setup.
  • Safe & Certified: FCC, IC, UL496, CA65, TSCA, and RoHS certified for peace of mind.
This bundle is ideal for running your Wyze Cam along baseboards near lamp sockets, keeping cables out of sight and power sources convenient.
Summary: Achieve a Clean, Professional Wyze Cam Setup
To run your Wyze Cam neatly along baseboards with a tidy cable solution, the Wyze Cam USB Extension Cable - 20ft is your go-to accessory. Pair it with the Wyze Cam v4 for superior video quality and smart features, and consider the Lamp Socket v2 Bundle for flexible, outlet-free power options.
With these products, you can enjoy a clutter-free, secure, and visually appealing camera installation that blends seamlessly into your home environment.
Product Highlights Recap
Wyze Cam USB Extension Cable - 20ft Extend your camera’s reach with a long, reliable USB cable. Wyze Cam v4 High-resolution, color night vision, weather-resistant smart camera. Cam v4 + Lamp Socket v2 Bundle Power your camera through lamp sockets for cable-free convenience.
Optimize your Wyze Cam setup today with these essential accessories for a neat, efficient, and powerful home security solution.
FeatureWyze Cam USB Extension Cable - 20ftWyze Cam v4Cam v4 + Lamp Socket v2 Bundle
Product TypeAccessory (USB Extension Cable)CameraBundle (Camera + Lamp Socket)
Price$7.99$100.00 (regular), $35.98 (some bundles)$49.96
CompatibilityWyze Cam v2/v3/v4, v3 Pro, Pan v2/v3, OG Standard, OG TelephotoWyze Cam v4Wyze Cam v3, v3 Pro, v4, OG, Pan v3
Cable Length20 ft USB extension6 ft flat micro USB to USB-A cableIncluded (camera cable + lamp socket power)
ResolutionN/A2.5K QHD (2560x1440)2.5K QHD (2560x1440)
Night VisionN/AEnhanced Color Night VisionEnhanced Color Night Vision
Weather ResistanceN/AIP65Lamp Socket: Not weatherproof, suitable for damp locations
Power SourceUSB powered extensionWired (5V/1A adapter)Wired (camera) + Lamp Socket (120V~, 60Hz)
Special FeaturesExtends USB cable lengthMotion-activated spotlight, Wi-Fi 6, AI Auto-ZoomPowers Cam v4 without outlet, motion-activated lights, dusk to dawn scheduling
DimensionsN/A2in x 2in x 2 3/8in56.5mm x 56.5mm x 65mm
WeightN/A0.49 lb (222 g)80 g
ConnectivityUSBWi-Fi 6, Bluetooth 5.2Wi-Fi 2.4GHz, Bluetooth
Warranty30-day hassle-free returns1 Year1 Year
Included Items1 x 20ft USB extension cableWyze Cam v4Wyze Cam v4 + Lamp Socket v2
What is the best way to run Wyze Cam cables neatly along baseboards?The best way to run Wyze Cam cables neatly along baseboards is by using the Wyze Cam USB Extension Cable - 20ft. This flexible, long cable allows you to discreetly tuck the power cable into corners or under trim, ensuring a tidy and professional look without clutter.
Which Wyze Cam models are compatible with the 20ft USB Extension Cable?The Wyze Cam USB Extension Cable - 20ft is compatible with Wyze Cam v2, v3, v4, v3 Pro, Pan v2/v3, OG Standard, and OG Telephoto models, providing reliable power and connectivity for a wide range of Wyze cameras.
What are the key features of the Wyze Cam USB Extension Cable - 20ft?Key features of the Wyze Cam USB Extension Cable - 20ft include a 20-foot length for extended reach, flexible and durable design for indoor use, seamless compatibility with multiple Wyze Cam models, and easy installation along baseboards or walls for a clean setup.
How can I power my Wyze Cam without a nearby outlet?You can power your Wyze Cam without a nearby outlet by using the Cam v4 + Lamp Socket v2 Bundle. This solution allows you to use a standard E26 lamp socket as a power source, eliminating the need for visible cables and nearby power outlets.
What are the benefits of the Wyze Cam v4 for home security?The Wyze Cam v4 offers 2.5K Quad HD resolution for clear video, color night vision for enhanced low-light performance, IP65 weather resistance for indoor and outdoor use, integrated spotlight and siren for security, and smart features like motion and sound detection, smoke and CO alerts, and AI-powered auto-zoom tracking.
Is the Wyze Cam v4 easy to install along baseboards?Yes, the Wyze Cam v4 is easy to install along baseboards thanks to its compact size, magnetic base for screw-free mounting, and compatibility with the 20ft USB extension cable, allowing for flexible and neat placement.
What certifications does the Lamp Socket v2 Bundle have?The Lamp Socket v2 Bundle is certified by FCC, IC, UL496, CA65, TSCA, and RoHS, ensuring safety and compliance for home use.
Can I use the Lamp Socket v2 Bundle with other Wyze Cam models?Yes, the Lamp Socket v2 Bundle is compatible with Wyze Cam v3, v3 Pro, v4, OG, and Pan v3, making it a versatile power solution for various Wyze cameras.
How does the Lamp Socket v2 enhance security lighting?The Lamp Socket v2 supports dusk-to-dawn scheduling and motion-activated lighting, which helps enhance your home security by automatically illuminating areas when motion is detected.
What is the advantage of using a 20ft USB extension cable for Wyze Cam?Using a 20ft USB extension cable for Wyze Cam allows you to place your camera exactly where you need it, even if the nearest power source is far away. It helps maintain a clean, organized look by running the cable along baseboards or walls without stretching or clutter.
Can you tell me more about the installation process for the Wyze Cam USB Extension Cable?What are the compatibility details for the Wyze Cam USB Extension Cable?Are there any ongoing promotions or discounts available for Wyze products?
