Stress-Free Wyze Camera Power Solution for Rental Backyards
Stress-Free Cable Solution for Wyze Cameras in Rental Property Backyards
When it comes to securing your rental property's backyard with a Wyze camera, having a reliable, weather-resistant power solution is essential. The Wyze Outdoor Power Adapter is designed specifically to provide a hassle-free, durable power connection for your Wyze outdoor cameras, ensuring continuous operation regardless of weather conditions. This guide highlights the best products to create a stress-free cable setup for your Wyze camera, focusing on compatibility, weather resistance, and ease of installation.
Wyze Outdoor Power Adapter: The Ultimate Weatherproof Power Solution
Designed for Outdoor Durability and Compatibility
The Wyze Outdoor Power Adapter is built to withstand rain, snow, and shine with an IP67 weather-resistant rating, making it perfect for outdoor use in rental properties where permanent wiring might not be an option. This adapter ensures your Wyze cameras stay powered without the worry of weather damage.
  • Compatibility: Works with Wyze Cam v3, v4, Pan v3, and Battery Cam Pro (requires additional adapters).
  • Cable Lengths: 12.5 ft (3.8 m) total cable length, including 3.9 ft AC cable and 8.5 ft DC cable, providing flexible placement options.
  • Operating Temperature: From -30°C to 50°C (-22°F to 122°F), suitable for all seasons.
  • Included Accessories: Comes with wire clips, screws, anchors, and weatherproof L-shaped Micro-USB adapter for neat, secure installation.
  • Power Output: 5V 2A, ensuring stable power delivery to your camera.
The adapter’s L-shaped connector helps reduce cable strain, making it ideal for rental properties where you want to avoid damaging walls or fixtures.
Why It’s Perfect for Rental Properties
  • Non-invasive installation: Use the included clips and screws to route cables along fences or eaves without drilling into walls.
  • Weatherproof: No need to worry about rain or snow disrupting your camera’s power.
  • Flexible compatibility: Supports multiple Wyze camera models, so you can upgrade or change cameras without replacing the power solution.
Wyze Cam Pan v3: A Versatile Outdoor Security Camera
Features That Complement the Outdoor Power Adapter
The Wyze Cam Pan v3 is a highly versatile security camera designed for both indoor and outdoor use. When paired with the Wyze Outdoor Power Adapter, it becomes a powerful tool for monitoring your rental property's backyard.
  • 360° horizontal and 180° vertical pan and tilt: Covers every angle with smooth, fast rotation (up to 110° per second).
  • 1080p Full HD video: Clear, detailed footage day and night with 4 IR LEDs for night vision.
  • IP65 weather resistance: Durable enough for outdoor environments.
  • Two-way audio: Built-in speaker and microphone with noise and echo cancellation.
  • Easy mounting: Screw mount with a compact circular base (1.69" diameter).
  • Connectivity: 2.4 GHz Wi-Fi compatible with Android and iOS devices.
  • Storage: Supports up to 256 GB microSD cards for local recording.
Note: For safe outdoor use, the Pan v3 requires the Wyze Outdoor Power Adapter.
Wyze Cam Pan v3 in snowy backyard Wyze Cam Pan v3 powered outdoors, ready for all weather
Bundles for Convenience: Pan v3 Security Bundle
All-in-One Package for Easy Setup
If you want a complete solution, the Pan v3 Security Bundle includes two Wyze Cam Pan v3 cameras, power adapters, mounting kits, and 32GB microSD cards. This bundle is perfect for rental property owners who want to cover multiple outdoor areas with minimal setup hassle.
  • Includes: 2 cameras, 2 power adapters, mounting kits, and microSD cards.
  • Weatherproof: Cameras and power adapters rated for outdoor use.
  • Easy installation: Everything you need to get started right away.
  • Push notifications: Stay informed with instant alerts on your phone.
This bundle ensures you have a reliable, weatherproof power and camera setup that’s easy to install and maintain in a rental backyard.
Why Choose Wyze Outdoor Power Solutions for Rental Properties?
Installing outdoor security cameras in rental properties can be tricky due to restrictions on drilling and wiring. The Wyze Outdoor Power Adapter offers a non-invasive, weatherproof, and reliable power source that keeps your cameras running smoothly without permanent modifications.
  • Stress-free cable management: Use included clips and L-shaped adapters to reduce cable strain and keep wiring tidy.
  • Weather resistance: IP67 rating means your power adapter can handle harsh outdoor conditions.
  • Compatibility: Works with multiple Wyze camera models, future-proofing your investment.
  • Warranty: 1-year warranty for peace of mind.
Summary
For a stress-free cable solution powering your Wyze camera in a rental property's backyard, the Wyze Outdoor Power Adapter is the best choice. Pair it with the Wyze Cam Pan v3 for a versatile, weatherproof security system that’s easy to install and maintain. For added convenience, consider the Pan v3 Security Bundle to cover multiple areas with everything you need in one package. With these products, you can enjoy reliable outdoor surveillance without worrying about weather damage or complicated wiring, making your rental property safer and easier to manage.
FeatureWyze Outdoor Power AdapterWyze Cam Pan v3Pan v3 Security Bundle
TypeAccessoryCameraCamera Bundle
Weather ResistanceIP67IP65IP65
CompatibilityWyze Cam v4, OG series, Cam Pan v3, Cam v3 Pro (with L-shaped adapter), Battery Cam Pro (with USB-C adapter)Indoor/outdoor use, requires Outdoor Power Adapter for outdoor useIncludes 2x Wyze Cam Pan v3 cameras
Pan & TiltN/A360° pan, 180° tilt360° pan, 180° tilt
Video ResolutionN/A1080p (1920 x 1080)1080p (1920 x 1080)
Night VisionN/AColor Night Vision with 4 IR LEDs (850 nm)Color Night Vision with 4 IR LEDs (850 nm)
AudioN/ABuilt-in speaker and microphone, 2-way audioBuilt-in speaker and microphone, 2-way audio
ConnectivityN/A802.11 b/g/n 2.4 GHz Wi-Fi802.11 b/g/n 2.4 GHz Wi-Fi
Power Adapter Input/OutputInput: 110-240V AC/DC, Output: 5V/2000mAInput: 110-240V AC/DC, Output: 5V/2000mAInput: 110-240V AC/DC, Output: 5V/2000mA
DimensionsNot specified124mm (H) x 60mm (W) x 63mm (D)Same as Wyze Cam Pan v3 (2 units included)
WeightNot specified11.29 oz (320 g)Approx. double Wyze Cam Pan v3 weight
StorageN/ASupports up to 256 GB microSD (ExFAT format)Supports up to 256 GB microSD (ExFAT format)
Price$14.99 - $19.99 (depending on variant)$39.98 (1 pack)$82.99
Included ItemsOutdoor Power Adapter and adapters depending on variant1x Wyze Cam Pan v3, 1x 6' micro USB cable, 1x Power Adapter, 1x Mounting Kit, 1x Quick Start Guide2x Wyze Cam Pan v3, 2x 6' micro USB cables, 2x Power Adapters, 2x Mounting Kits, 2x 32GB MicroSD Cards, Quick Start Guide
WarrantyNot specified1-Year1-Year
Special NotesRequired for outdoor use of Wyze Cam v3 Pro, Pan v3, Battery Cam Pro; Not compatible with OG Stack KitRequires Outdoor Power Adapter for outdoor useBundle includes 2 cameras with accessories
What is the best way to power a Wyze camera outdoors in a rental property?The Wyze Outdoor Power Adapter is the best solution for powering Wyze cameras outdoors in rental properties. It offers a weather-resistant, non-invasive installation that avoids permanent modifications, making it ideal for renters.
Is the Wyze Outdoor Power Adapter weatherproof?Yes, the Wyze Outdoor Power Adapter has an IP67 weather-resistant rating, making it suitable for use in rain, snow, and extreme temperatures from -30°C to 50°C (-22°F to 122°F).
Which Wyze cameras are compatible with the Wyze Outdoor Power Adapter?The Wyze Outdoor Power Adapter is compatible with Wyze Cam v3, v4, Pan v3, and Battery Cam Pro (with additional adapters).
How long is the cable on the Wyze Outdoor Power Adapter?The Wyze Outdoor Power Adapter features a total cable length of 12.5 ft (3.8 m), including a 3.9 ft AC cable and an 8.5 ft DC cable, allowing flexible camera placement.
Can I install the Wyze Outdoor Power Adapter without drilling into walls?Yes, the adapter comes with wire clips, screws, and anchors, allowing you to route cables along fences or eaves without drilling into walls, making it perfect for rental properties.
What is included with the Wyze Outdoor Power Adapter?The adapter includes wire clips, screws, anchors, and a weatherproof L-shaped Micro-USB adapter for secure and tidy installation.
Why is the Wyze Outdoor Power Adapter recommended for rental properties?It provides a non-invasive, weatherproof, and reliable power source for Wyze cameras, allowing renters to install security cameras without permanent changes to the property.
What features does the Wyze Cam Pan v3 offer for outdoor security?The Wyze Cam Pan v3 offers 360° horizontal and 180° vertical pan and tilt, 1080p Full HD video, IP65 weather resistance, two-way audio, easy mounting, and supports up to 256 GB microSD cards for local recording.
Do I need the Wyze Outdoor Power Adapter to use the Pan v3 camera outdoors?Yes, for safe and reliable outdoor use, the Wyze Cam Pan v3 requires the Wyze Outdoor Power Adapter.
What is included in the Pan v3 Security Bundle?The Pan v3 Security Bundle includes two Wyze Cam Pan v3 cameras, two power adapters, mounting kits, and 32GB microSD cards, providing a complete, weatherproof security solution for rental properties.
Does the Wyze Outdoor Power Adapter come with a warranty?Yes, the Wyze Outdoor Power Adapter comes with a 1-year warranty for added peace of mind.
How does the L-shaped connector on the Wyze Outdoor Power Adapter help with installation?The L-shaped connector reduces cable strain and helps keep wiring tidy, making it easier to install the adapter in rental properties without damaging walls or fixtures.
What are the installation requirements for the Wyze Outdoor Power Adapter?Can the Wyze Outdoor Power Adapter be used with other Wyze camera models besides the ones mentioned?Do you have any deals, ongoing sales, discounts, or promotions for the Wyze Outdoor Power Adapter?
