Smart Security System Kits: Easy Setup & Mobile Alerts
Smart Security System Kits with Easy Installation and Mobile Alerts
Protecting your home has never been easier with smart security system kits designed for quick setup and real-time mobile alerts. Whether you're looking for a comprehensive starter kit or an enhanced security solution, these Wyze bundles offer everything you need to monitor your home effortlessly. Discover the perfect smart security system kit that combines easy installation, mobile notifications, and advanced features to keep your home safe 24/7.
Whole Home Security Starter Kit: Simple Setup, Powerful Protection
The
Whole Home Security Starter Kit is ideal for those who want a straightforward, all-in-one solution to begin securing their home. This kit includes:
- Wyze Cam v4: Offers 2.5K QHD resolution with color night vision and a wide field of view, ensuring clear video day and night.
- Wyze Video Doorbell v2: Monitor your front door with crisp 1080p HD video and two-way audio, so you never miss a visitor or delivery.
- Wyze Home Monitoring Starter Kit: Adds entry sensors, motion detection, and keypad control for comprehensive home monitoring.
Key Features:
- Easy Installation: Mount cameras and sensors with included hardware and adhesive options—no professional help needed.
- Mobile Alerts: Receive instant notifications on your smartphone for motion, sound, or doorbell rings.
- Versatile Camera Options: Choose from white, grey, or black Wyze Cam v4 to match your home décor.
Experience peace of mind with a kit designed for quick setup and reliable home security.
Wyze Cam v4 providing smart home monitoring
Whole Home Security Enhanced Kit: Advanced Lighting and Surveillance
For those seeking enhanced security with added lighting, the
Whole Home Security Enhanced Kit combines the power of the Wyze Cam v4 with the Wyze Cam Floodlight v2. This kit includes:
- Wyze Cam v4: High-resolution 2.5K QHD video with night vision and wide dynamic range.
- Wyze Cam Floodlight v2: Bright floodlights with motion-activated lighting to deter intruders and illuminate your property.
Why Choose the Enhanced Kit?
- Integrated Floodlight Security: Illuminate dark areas automatically when motion is detected.
- Color Options: Available in combinations of white, grey, and black to suit your exterior style.
- Mobile Alerts & App Control: Stay connected with real-time alerts and remote control via the Wyze app.
Upgrade your home security with smart lighting and crystal-clear video surveillance.
Essential Security Bundle: Comprehensive Protection with Smart Lock and Cameras
The
Essential Security Bundle is a thoughtfully curated package that covers all angles of home security, perfect for users wanting a robust system with smart access control.
Bundle Includes:
- Wyze Video Doorbell v2: 1080p HD video with two-way audio and person detection.
- Wyze Lock Bolt: Smart lock with fast fingerprint sensor, backlit keypad, and Bluetooth connectivity for keyless entry.
- Wyze Cam Pan v3: Pan-and-tilt camera with 360° horizontal and 180° vertical coverage, automatic motion tracking, and color night vision.
- Two Wyze Cam OG Cameras: Plug-in cameras with motion-activated spotlights and color night vision for indoor or outdoor use.
Highlights:
- Smart Lock Convenience: Secure your doors with fingerprint or keypad access, eliminating the need for physical keys.
- Wide Coverage: Pan and tilt camera ensures no blind spots.
- Weather-Resistant Cameras: Rated IP65 for reliable outdoor use.
- Mobile Alerts & Cloud Recording: Receive instant notifications and store footage securely.
This bundle offers a complete security ecosystem with smart locks and versatile cameras for total home protection.
Wyze cameras mounted outdoors for comprehensive home security
Wyze Home Monitoring Core Starter Kit: Essential Sensors for Smart Alerts
The
Wyze Home Monitoring Core Starter Kit is perfect for those who want to add smart sensors to their home security setup. It includes:
- Wyze Sense Hub: Central hub connecting all sensors.
- Entry Sensors: Wireless sensors for doors and windows with 18-month battery life.
- Motion Sensor: Detects movement up to 25 feet, ideal for indoor monitoring.
- Wyze Keypad: Wireless keypad with backlit keys and emergency button.
Benefits:
- Wireless and Easy to Install: No wiring required, place sensors where needed.
- Long Battery Life: Up to 18 months on sensors, ensuring low maintenance.
- Mobile Alerts: Get notified instantly if doors or windows open unexpectedly.
- Siren Alarm: Loud 88db siren to deter intruders.
Enhance your existing security system or start fresh with this easy-to-install sensor kit.
Wyze entry sensor installed on door frame for smart home security
Why Choose Wyze Smart Security Kits?
- Easy Installation: Most kits come with mounting hardware and adhesive options, allowing you to set up your system in minutes without professional help.
- Mobile Alerts: Stay connected with instant notifications on your smartphone, so you can monitor your home anytime, anywhere.
- Affordable and Scalable: Start with a basic kit and expand your system with additional cameras, sensors, and smart locks as needed.
- Integration: Compatible with Alexa, Google Assistant, and IFTTT for seamless smart home automation.
Secure your home with confidence using Wyze’s smart security kits designed for simplicity, reliability, and peace of mind.
Summary of Featured Smart Security Kits
Kit Name | Key Components | Price Range | Ideal For |
Whole Home Security Starter Kit | Wyze Cam v4, Video Doorbell v2, Monitoring Kit | $155.95 | Beginners, easy setup |
Whole Home Security Enhanced Kit | Wyze Cam v4, Floodlight v2 | $256.91 | Enhanced lighting and security |
Essential Security Bundle | Doorbell, Lock Bolt, Pan v3, 2x Cam OG | $199.99 | Comprehensive home protection |
Wyze Home Monitoring Core Kit | Entry Sensors, Motion Sensor, Keypad | $111.98 | Sensor-based monitoring |
Secure your home effortlessly with these smart security system kits that combine easy installation, mobile alerts, and advanced features to keep your loved ones safe.
Feature / Product | Whole Home Security Starter Kit | Whole Home Security Enhanced Kit | Essential Security Bundle | Wyze Home Monitoring Core Starter Kit |
Price (USD) | $155.95 | $256.91 | $199.99 | $111.98 |
Included Cameras | 1x Wyze Cam v4 | 1x Wyze Cam v4, 1x Wyze Cam Floodlight v2 | 1x Wyze Cam Pan v3, 2x Wyze Cam OG | None |
Video Doorbell Included | 1x Wyze Video Doorbell v2 | None | 1x Wyze Video Doorbell v2 | None |
Home Monitoring Kit Included | 1x Wyze Home Monitoring Starter Kit | None | None | Yes (Core Starter Kit with sensors and keypad) |
Wyze Lock Included | No | No | 1x Wyze Lock Bolt | No |
Camera Features | Wyze Cam v4: 2.5K QHD, Color Night Vision, Spotlight | Wyze Cam v4 + Floodlight v2: Enhanced lighting | Pan v3: 360° pan/180° tilt, motion tracking, color night vision; OG: motion-activated spotlight, color night vision | N/A |
Sensors Included | No | No | No | Yes (Entry sensors, motion sensor, keypad) |
Monitoring & Alerts | Basic | Basic | Cloud/local recording, real-time alerts, motion-activated voice deterrence | Professional monitoring included (3 months) |
Weather Resistance | Wyze Cam v4: IP65 | Wyze Cam v4 & Floodlight v2: IP65 | Wyze Cam OG: IP65 | Indoor use only |
Connectivity | Wi-Fi 6, Bluetooth | Wi-Fi 6, Bluetooth | Cloud and local storage | Wireless sensors, keypad, hub |
Warranty | 30-day hassle-free returns | 30-day hassle-free returns | Not specified | Not specified |
Main Use Case | Whole home security starter bundle | Enhanced whole home security with floodlight | Comprehensive home protection with doorbell, lock, and multiple cameras | Home monitoring with sensors and keypad |
Quantity of Cameras | 1 | 2 | 3 | 0 |
What is included in the Wyze Whole Home Security Starter Kit?
The Wyze Whole Home Security Starter Kit includes a Wyze Cam v4 with 2.5K QHD resolution and color night vision, a Wyze Video Doorbell v2 with 1080p HD video and two-way audio, and a Wyze Home Monitoring Starter Kit featuring entry sensors, motion detection, and a keypad for comprehensive home monitoring.How easy is it to install Wyze smart security system kits?
Wyze smart security system kits are designed for easy installation. Most components come with mounting hardware and adhesive options, allowing you to set up cameras and sensors in minutes without the need for professional help.Do Wyze security kits provide mobile alerts?
Yes, all Wyze security kits offer real-time mobile alerts. You will receive instant notifications on your smartphone for motion detection, sound, doorbell rings, or when entry sensors are triggered, so you can monitor your home from anywhere.What are the benefits of the Wyze Whole Home Security Enhanced Kit?
The Wyze Whole Home Security Enhanced Kit combines the Wyze Cam v4 with the Wyze Cam Floodlight v2, providing high-resolution video, color night vision, and motion-activated floodlights to deter intruders and illuminate your property. It also offers mobile alerts and app control for enhanced security.What features does the Wyze Essential Security Bundle offer?
The Wyze Essential Security Bundle includes a Wyze Video Doorbell v2, Wyze Lock Bolt with fingerprint and keypad access, Wyze Cam Pan v3 with 360° coverage and motion tracking, and two Wyze Cam OG cameras with spotlights and color night vision. This bundle provides comprehensive protection, smart lock convenience, wide camera coverage, weather-resistant cameras, and mobile alerts with cloud recording.What is the Wyze Home Monitoring Core Starter Kit and what does it include?
The Wyze Home Monitoring Core Starter Kit is a sensor-based security solution that includes a Wyze Sense Hub, wireless entry sensors for doors and windows, a motion sensor with up to 25 feet range, and a wireless keypad with a backlit emergency button. It also features a loud 88db siren alarm and offers easy, wireless installation.Are Wyze security kits compatible with smart home systems?
Yes, Wyze security kits are compatible with popular smart home platforms including Alexa, Google Assistant, and IFTTT, allowing for seamless integration and automation within your smart home ecosystem.Can I expand my Wyze smart security system over time?
Absolutely. Wyze security systems are affordable and scalable, allowing you to start with a basic kit and add more cameras, sensors, and smart locks as your security needs grow.Are Wyze cameras suitable for outdoor use?
Yes, many Wyze cameras, such as the Wyze Cam OG and Wyze Cam Floodlight v2, are weather-resistant with an IP65 rating, making them suitable for reliable outdoor use.What color options are available for Wyze security cameras?
Wyze Cam v4 and other cameras are available in white, grey, and black, allowing you to choose the color that best matches your home’s interior or exterior décor.
What are the key features of the Whole Home Security Starter Kit?Can you tell me more about the Wyze Cam v4 and its capabilities?Do you have any deals, ongoing sales, discounts, or promotions?
