Smart NV Kit: Advanced Video Doorbells and Security Cameras
Enhance your home security with the latest smart night vision (NV) kits featuring Wyze’s cutting-edge video doorbells and cameras. Whether you want to monitor your front porch, backyard, or entire home perimeter, these smart NV kits combine high-resolution video, two-way audio, and intelligent motion detection to keep you connected and protected day and night.
Wyze Video Doorbell v2: Crystal Clear 2K Wired Doorbell
Key Features
- 2K Video Resolution (2048 x 1536): Capture every detail with ultra-clear video quality.
- Wide Field of View: 135° horizontal and 166.8° diagonal for broad coverage.
- Two-Way Audio & Voice Deterrence: Speak to visitors or deter unwanted guests with motion-activated voice alerts.
- Local & Cloud Storage: Supports up to 256GB microSD card and optional cloud storage with Wyze Security Plan.
- Weather Resistant: IP65 rating ensures reliable performance in rain, snow, or shine.
- Easy Installation Kit Included: Comes with chime controller, wall plate, wedge, and all necessary hardware.
Technical Specs
- CMOS Starlight Sensor with F2.0 aperture and 2.1mm focal length.
- Night vision powered by 6 x 940nm IR lights.
- Compatible with Alexa, Google Assistant, and IFTTT.
- Operates on 16V-24V AC power.
Answer your door from anywhere with the clearest wired video doorbell that combines smart features and robust hardware.
The Front Porch Security Bundle: Complete Smart Entry Solution
What’s Included
- Wyze Video Doorbell (1080p HD) with two-way audio.
- Wyze Lock for remote locking/unlocking and lock history tracking.
- Wyze Chime for customizable doorbell sounds.
Highlights
- Remote Access: Lock or unlock your door from anywhere via the Wyze app.
- Motion & Lock Event Alerts: Stay informed with real-time notifications.
- Voice Assistant Integration: Works seamlessly with Alexa and Google Assistant.
- Weatherproof Doorbell: IP65 rating for outdoor durability.
- Multiple Sound Options: Choose from modern, classic, animal, automation, or intruder alarm sounds on the chime.
Specifications
- Doorbell camera aperture F2.0, 2.7mm focal length.
- Field of view: 120° vertical x 88° horizontal.
- Lock powered by 4 AA batteries with 5-6 months battery life.
- Chime powered by standard US power outlet.
The ultimate smart home front porch kit for security and convenience in one package.
Wyze Battery Cam Pro: Wire-Free 2.5K HDR Security Camera
Features
- 2.5K HDR Video: Ultra-high resolution for crystal-clear images.
- Wire-Free & Rechargeable: Removable 6200mAh battery lasts up to 6 months.
- Integrated Spotlight & Siren: Deter intruders with bright lights and loud siren.
- Radar + PIR Motion Detection: Advanced sensing for accurate alerts.
- Dual-Band WiFi: Supports 2.4 GHz and 5 GHz networks.
- Weather Resistant: IP65 rating for all-season outdoor use.
Technical Details
- CMOS Starlight Sensor with F1.6 lens.
- Field of view: 134° diagonal.
- Two-way audio with MEMS digital microphone.
- Supports up to 256GB microSD local storage.
Enjoy flexible, wire-free security with powerful night vision and smart detection technology.
Wyze Cam Pan v3 providing weather-resistant outdoor security.
Wyze Cam Pan v3: 360° Pan & 180° Tilt Indoor/Outdoor Camera
Standout Features
- Full 360° Horizontal & 180° Vertical Coverage: Never miss a corner.
- 1080p HD Video: Clear day and night vision with 4 IR LEDs.
- 8x Digital Zoom: Zoom in on important details.
- Two-Way Audio: Built-in speaker and microphone with noise and echo cancellation.
- IP65 Weather Resistant: Suitable for indoor and outdoor use (requires separate outdoor power adapter).
- Smart Alerts: Push notifications for motion detection.
Specs
- 1/2.9" CMOS sensor, 1.5 GHz CPU.
- Dimensions: 124mm x 60mm x 63mm.
- Supports up to 256GB microSD card in ExFAT format.
A versatile pan-tilt camera that adapts to your home’s security needs with wide coverage and smart features.
Wyze Cam Floodlight Pro: Bright, Intelligent Yard Surveillance
Features
- 2.5K QHD Video with Color Night Vision: See your yard in vivid detail anytime.
- 180° Wide-Angle Lens: Covers large outdoor areas.
- 3,000 Lumen Adjustable LED Lights: Bright floodlights that activate only for selected objects like people or vehicles.
- AI-Powered Motion Detection: Smarter alerts reduce false alarms.
- Built-in 105dB Siren: Scare off intruders effectively.
- IP65 Water Resistance: Durable for all weather conditions.
Technical Information
- Dimensions: 10.2" x 9.1" x 7.8".
- Power: Hardwired 110-120V AC.
A powerful floodlight camera that acts as your personal home security guard with intelligent lighting and alerts.
Wyze Cam Floodlight Pro keeps your yard safe with bright lights and smart detection.
Wyze Bulb Cam: 2-in-1 Outdoor Security Camera & Smart LED Light
Highlights
- 2K HD Video with Color Night Vision: Clear video day and night.
- Standard E26 Socket: Fits most outdoor light fixtures.
- Motion-Activated Light & Alerts: Lights up and notifies you when motion is detected.
- Up to 800 Lumens Brightness: Provides ample lighting.
- Two-Way Audio & Siren: Communicate and deter intruders.
- Local & Cloud Storage: Supports up to 256GB microSD cards and cloud backup.
- IP65 Weather Resistant: Built to withstand outdoor elements.
Specs
- Video resolution: 2304 x 1296.
- Field of view: 160° diagonal.
- Power input: 120V AC.
- Compatible with Android 7.0+ and iOS 14.0+.
Protect your home with a smart light bulb camera that blends security and illumination seamlessly.
Wyze Bulb Cam combines security and lighting in one smart device.
Why Choose a Smart NV Kit from Wyze?
Wyze smart NV kits offer a comprehensive solution for home security with advanced night vision, high-resolution video, and smart integrations. Whether you want a wired video doorbell, a wireless battery-powered camera, or a floodlight with AI detection, Wyze provides reliable, weather-resistant devices that keep you connected and in control from anywhere.
Upgrade your home security today with Wyze’s smart NV kits — the perfect blend of technology, convenience, and peace of mind.
What is a Smart NV Kit from Wyze?
A Smart NV Kit from Wyze is a comprehensive home security solution featuring advanced night vision technology, high-resolution video, and smart integrations. These kits include devices like video doorbells, security cameras, and floodlights, all designed to keep your home protected and connected day and night.What are the key features of the Wyze Video Doorbell v2?
The Wyze Video Doorbell v2 offers 2K video resolution, a wide 135° horizontal and 166.8° diagonal field of view, two-way audio with voice deterrence, local and cloud storage options, IP65 weather resistance, and easy installation with included hardware. It is compatible with Alexa, Google Assistant, and IFTTT.How does the Wyze Front Porch Security Bundle enhance entryway security?
The Wyze Front Porch Security Bundle includes a 1080p HD video doorbell, Wyze Lock for remote locking and unlocking, and Wyze Chime with customizable sounds. It provides real-time motion and lock event alerts, remote access via the Wyze app, and seamless integration with Alexa and Google Assistant for enhanced entryway security and convenience.What makes the Wyze Battery Cam Pro a good choice for outdoor security?
The Wyze Battery Cam Pro features 2.5K HDR video, wire-free installation with a rechargeable 6200mAh battery, integrated spotlight and siren, advanced radar and PIR motion detection, dual-band WiFi support, and IP65 weather resistance. It offers flexible placement and up to 6 months of battery life for reliable outdoor security.Can the Wyze Cam Pan v3 be used outdoors?
Yes, the Wyze Cam Pan v3 is IP65 weather resistant and suitable for both indoor and outdoor use. For outdoor installation, a separate outdoor power adapter is required. It provides 360° pan and 180° tilt coverage, 1080p HD video, two-way audio, and smart motion alerts.What are the benefits of the Wyze Cam Floodlight Pro?
The Wyze Cam Floodlight Pro offers 2.5K QHD video with color night vision, a 180° wide-angle lens, 3,000 lumen adjustable LED floodlights, AI-powered motion detection, a built-in 105dB siren, dual-band WiFi, and IP65 water resistance. It is designed to provide bright, intelligent yard surveillance and deter intruders effectively.How does the Wyze Bulb Cam combine security and lighting?
The Wyze Bulb Cam is a 2-in-1 device that functions as both an outdoor security camera and a smart LED light. It features 2K HD video with color night vision, fits standard E26 sockets, provides up to 800 lumens of brightness, offers motion-activated lighting and alerts, two-way audio, a built-in siren, and supports both local and cloud storage.Are Wyze security devices weather resistant?
Yes, most Wyze security devices, including the Video Doorbell v2, Battery Cam Pro, Cam Pan v3, Cam Floodlight Pro, and Bulb Cam, are IP65 weather resistant. This ensures reliable performance in various outdoor conditions such as rain, snow, and extreme temperatures.What storage options are available for Wyze security cameras?
Wyze security cameras support both local and cloud storage. Most devices can use microSD cards up to 256GB for local recording, and optional cloud storage is available through the Wyze Security Plan for added backup and remote access.Do Wyze smart security devices work with voice assistants?
Yes, Wyze smart security devices are compatible with popular voice assistants including Amazon Alexa and Google Assistant. Many devices also support IFTTT for additional smart home automation and integration.How easy is it to install Wyze smart security devices?
Wyze smart security devices are designed for easy installation. Kits typically include all necessary hardware, such as mounting plates, chime controllers, and wedges. Many devices are wire-free or use standard power sources, making setup straightforward for most users.
