Smart Lighting Kits with Vacation Mode for Home Security
Smart Lighting Kits with Vacation Mode for Enhanced Home Security
When it comes to securing your home while you're away, smart lighting kits with vacation mode are an essential tool. These systems simulate occupancy by controlling your home’s lighting remotely, deterring potential intruders and giving you peace of mind. Wyze offers a range of smart lighting products designed to integrate seamlessly with your home security setup, featuring customizable colors, brightness, and automation modes including vacation mode.
Wyze Bulb Color: Brilliant, Customizable Smart Lighting
Vibrant 16 Million Colors & Tunable White Light
The Wyze Bulb Color is a premium smart bulb that offers an impressive 16 million colors and a tunable white range from 1800K to 6500K. Whether you want warm cozy lighting or bright daylight tones, this bulb adapts to your mood and needs.
Brightness & Energy Efficiency
With up to 1100 lumens of brightness and a dimmable feature, the Wyze Bulb Color can light up any room while consuming just 12 watts of power. Its long life expectancy of 25,000 hours ensures years of reliable use.
Connectivity & Compatibility
This bulb connects via 2.4GHz Wi-Fi and Bluetooth, compatible with Android 9.0+ and iOS 15.0+ devices. It integrates smoothly with Alexa, Google Assistant, and IFTTT, allowing voice control and automation.
Set your Wyze Bulb Color to vacation mode to simulate your presence by scheduling lights to turn on and off at random intervals. This feature is perfect for deterring burglars when you’re away. Wyze Bulb Color in Living Room Alt text: Cozy living room illuminated by colorful Wyze Bulb Color smart lighting
Wyze Light Strip: Flexible LED Accent Lighting
Dynamic Color Options & Customizable Length
The Wyze Light Strip offers 16 million colors in a flexible LED strip that can be cut to size and mounted anywhere indoors. Available in 16.4 ft and 32.8 ft lengths, it’s perfect for accent lighting under cabinets, behind sofas, or along shelves.
Easy Installation & Control
With adhesive backing and Bluetooth/Wi-Fi connectivity, the light strip is easy to install and control via the Wyze app. It also features a built-in microphone for music sync, adding ambiance to your home.
Enhance Security with Vacation Mode
Use the Wyze Light Strip’s vacation mode to create randomized lighting patterns that mimic your daily routines, making your home appear occupied even when you’re away. Wyze Light Strip in Kitchen Alt text: Modern kitchen illuminated by colorful Wyze Light Strip smart lighting
Wyze Sense Hub: The Central Command for Home Monitoring
Connect & Control Your Security Devices
The Wyze Sense Hub acts as the brain of your home monitoring system, connecting all Wyze sensors and sending real-time alerts to your phone. It supports up to 100 sensors and has a wireless range of 500 feet.
Reliable Backup & Communication
Equipped with a rechargeable battery backup lasting 10 hours, the hub ensures continuous operation during power outages. It communicates via Ethernet, Wi-Fi, Bluetooth, and RF, providing robust connectivity.
Integrate Lighting with Security
Pair the Wyze Sense Hub with your smart lighting to automate lights based on sensor triggers or schedules, including vacation mode. This integration enhances your home security by simulating occupancy and alerting you to unusual activity.
Why Choose Wyze Smart Lighting Kits for Vacation Mode?
"A well-lit home is a safe home."
Wyze smart lighting products combine vibrant, customizable lighting with smart home security features. Vacation mode is a standout feature that helps protect your home by simulating occupancy, deterring burglars, and giving you peace of mind while away.
  • Easy to install and control via the Wyze app
  • Compatible with popular voice assistants like Alexa and Google Assistant
  • Energy-efficient and long-lasting lighting solutions
  • Seamless integration with Wyze home monitoring devices
Elevate your home security with Wyze’s smart lighting kits and enjoy the confidence of a well-protected home, even when you’re on vacation.
FeatureWyze Bulb ColorWyze Light StripWyze Sense Hub
TypeSmart LightingConnected HomeHome Monitoring
Color Options16 million colors16 million colorsN/A
Brightness (Lumens)30 lm (dim) to 1100 lm (bright)Not specified (LED accent lighting)N/A
DimmableYes (takes offense if used)Yes (via app)N/A
Color TemperatureTunable whiteSun Match (syncs to natural light cycle)N/A
CRI Rating90+Not specifiedN/A
Smart FeaturesVoice control, Vacation Mode, Grouping, Custom presets, Sleep routines, Music ModeVoice control, Vacation Mode, Sleep routines, Music Mode, Timers & AutomationsConnects sensors, sends alerts
ConnectivityWiFi 802.11 b/g/n 2.4 GHz, BluetoothWiFi 802.11 b/g/n 2.4 GHz, BluetoothEthernet, WiFi 802.11 b/g/n 2.4 GHz, Bluetooth 4.1+ BLE 5.1, 915MHz RF
Power ConsumptionEquivalent to 75WPowered via plug (corded electric)Built-in rechargeable battery (3.7V, 2600mAh)
DimensionsNot specifiedNot specified4.5” x 4” x 1” (114.3 x 101.6 x 25.4 mm)
Operating Temperature-4°F to 104°F-4°F to 104°F32°F to 104°F (0°C to 40°C)
Special FeaturesBrilliant notifications, Custom lighting scenes, Grouping with Wyze Light StripMusic Mode with built-in microphone, Peel & stick installationSupports up to 100 sensors, 88db siren
Price Range$26.26 (2-pack) to $64.98 (6-pack)$19.99 (16.4 ft) to $35.99 (32.8 ft)$45.98 (single unit)
What is vacation mode in Wyze smart lighting kits?Vacation mode is a feature in Wyze smart lighting kits that simulates occupancy by automatically turning your lights on and off at random intervals. This helps deter potential intruders by making it appear as if someone is home, enhancing your home security while you’re away.
How do Wyze smart lighting products enhance home security?Wyze smart lighting products enhance home security by offering vacation mode, which simulates your presence through randomized lighting schedules. This deters burglars and integrates with Wyze Sense Hub to automate lights based on sensor triggers or schedules, providing real-time alerts and peace of mind.
What are the key features of the Wyze Bulb Color?The Wyze Bulb Color offers 16 million colors, a tunable white range from 1800K to 6500K, up to 1100 lumens of brightness, energy efficiency at just 12 watts, and a long lifespan of 25,000 hours. It supports vacation mode, voice control with Alexa and Google Assistant, and is compatible with Android and iOS devices.
Can I control Wyze smart lighting remotely?Yes, Wyze smart lighting products can be controlled remotely via the Wyze app. You can adjust colors, brightness, set schedules, and activate vacation mode from anywhere using your smartphone.
Are Wyze smart lighting products compatible with voice assistants?Yes, Wyze smart lighting products are compatible with popular voice assistants such as Amazon Alexa and Google Assistant, allowing you to control your lights using voice commands.
What is the Wyze Light Strip and how can it be used?The Wyze Light Strip is a flexible LED accent lighting solution that offers 16 million colors and can be cut to size for custom installations. It’s ideal for accent lighting under cabinets, behind furniture, or along shelves, and features vacation mode to enhance home security.
How does the Wyze Sense Hub integrate with smart lighting?The Wyze Sense Hub acts as the central command for your home monitoring system, connecting all Wyze sensors and smart lighting. It allows you to automate lights based on sensor triggers or schedules, including vacation mode, to simulate occupancy and alert you to unusual activity.
Is installation of Wyze smart lighting kits easy?Yes, Wyze smart lighting kits are designed for easy installation. The Wyze Bulb Color fits standard light sockets, and the Wyze Light Strip comes with adhesive backing for simple mounting. Both can be set up and controlled through the Wyze app.
Are Wyze smart lighting products energy efficient?Yes, Wyze smart lighting products are energy efficient. For example, the Wyze Bulb Color uses only 12 watts of power while providing up to 1100 lumens of brightness, and has a long lifespan of 25,000 hours.
What devices are required to use Wyze smart lighting kits?To use Wyze smart lighting kits, you need a compatible smartphone (Android 9.0+ or iOS 15.0+), a 2.4GHz Wi-Fi network, and the Wyze app. For advanced automation and integration with security sensors, the Wyze Sense Hub is recommended.
Can you tell me more about the features of the Wyze Bulb Color?How does the vacation mode work with the Wyze Light Strip?Do you have any ongoing sales or promotions for smart lighting products?
