Wyze Smart Home Security: Affordable, Integrated Protection
Smart Home Security Solutions by Wyze
Enhance your home’s safety and comfort with Wyze’s comprehensive smart home security products. Designed to seamlessly integrate and provide real-time monitoring, these devices empower you to protect your home, control your environment, and stay connected no matter where you are.
Centralized Control with Wyze Sense Hub
The Brain of Your Security System
The Wyze Sense Hub acts as the central command center for your home monitoring setup. It connects all your Wyze security components, ensuring smooth communication and instant alerts to your smartphone.
  • Price: $45.98
  • Design: White base with a grey speaker top, blending discreetly into any room
  • Function: Connects sensors and devices, sends real-time alerts for any detected activity
The Wyze Sense Hub is essential for creating a unified smart security network, making it the backbone of your home protection system.
Motion Detection with Wyze Sense Motion Sensor
Keep an Eye on Every Movement
The Wyze Sense Motion Sensor detects movement within a 25-foot range and a 120° field of view, alerting you instantly to any unexpected activity.
  • Price: $20.98
  • Detection Range: 25 feet
  • Field of View: 120°
  • Sensitivity: Adjustable to suit your environment
  • Installation: Easy adhesive back or secure screws for added stability
  • Requirement: Works with Wyze Sense Hub or Wyze Home Monitoring
Ideal for monitoring entryways, hallways, or any vulnerable spots in your home.
Secure Access with Wyze Sense Keypad
Arm and Disarm Your System Remotely
The Wyze Sense Keypad offers convenient control over your home security system, allowing you to arm or disarm remotely.
  • Price: $27.98
  • Functionality: Arm/disarm system, send alerts to first responders
  • Indoor Use: Designed for indoor installation
  • Requirement: Requires Wyze Sense Hub and Wyze Home Monitoring
Perfect for families or individuals who want quick, secure access control without needing to use a smartphone app every time.
Wyze Sense Keypad Lifestyle Smart keypad for secure access
Environmental Awareness with Wyze Sense Climate Sensor
Monitor Temperature and Humidity Anywhere
The Wyze Sense Climate Sensor helps you keep track of your home's temperature and humidity levels, ensuring a comfortable and safe environment.
  • Price: $41.98 (3 Pack)
  • Range: Up to 500 feet from the hub
  • Design: Sleek white, unobtrusive sensor with peel-and-stick adhesive
  • Placement: Suitable for basements, attics, or distant rooms
  • Requirement: Works with Wyze Sense v2 and Wyze Home Monitoring
Maintaining optimal climate conditions can prevent mold growth and protect your home’s structure.
Smart Lighting with Wyze Bulb Color
Illuminate Your Home with 16 Million Colors
While not a direct security device, the Wyze Bulb Color enhances your smart home ecosystem by providing customizable lighting that can simulate occupancy or set moods.
  • Price: Starting at $26.26 for 2-pack
  • Brightness: 1100 lumens, extra bright
  • Colors: 16 million colors with tunable white options
  • Dimensions: 2.5 x 2.5 x 5 inches
  • Color Rendering Index: 90+ for vivid, true-to-life colors
Use lighting automation to deter intruders by simulating presence when you’re away.
Wyze Bulb Color Lifestyle Vibrant smart lighting for home ambiance
Breathe Easy with Wyze Air Filter
Customize Your Air Quality for Health and Safety
The Wyze Air Filter is a smart accessory that complements your home security by improving indoor air quality, which is vital for a healthy living environment.
  • Price: From $37.99 to $63.99 depending on filter type
  • Filter Types: Allergen (Standard), Formaldehyde (Premium), Wildfire (Special Use)
  • Dimensions: 8.1" x 8.1" x 11.3"
  • Weight: Ranges from 1.5 to 1.9 lbs depending on filter
  • Features: HEPA 12 or 13 filters, activated carbon, pre-filter included
Protect your family from allergens, harmful gases, and airborne viruses with customizable filtration.
Wyze Air Filter Lifestyle Enhance air quality for healthier living
Why Choose Wyze for Smart Home Security?
Wyze offers an integrated ecosystem of affordable, reliable, and easy-to-use smart home security products. From motion detection and climate monitoring to smart lighting and air quality control, Wyze helps you create a safer, smarter home environment tailored to your lifestyle.
Experience peace of mind with Wyze’s smart home security solutions — designed to keep your home protected, comfortable, and connected.
Summary of Wyze Smart Home Security Products
ProductKey FeaturePrice (USD)
Wyze Sense HubCentral control hub$45.98
Wyze Sense Motion SensorMotion detection$20.98
Wyze Sense KeypadRemote arm/disarm$27.98
Wyze Sense Climate SensorTemperature & humidity monitoring$41.98 (3-pack)
Wyze Bulb Color16 million color smart lightingFrom $26.26
Wyze Air FilterCustomizable air purification$37.99 - $63.99
Embrace the future of home security with Wyze — smart, simple, and secure.
ProductTypePrice (USD)Key FeaturesRequiresIndoor/Outdoor UseConnectivity/CommunicationAdditional Notes
Wyze Sense HubHome Monitoring45.98Connects monitoring components, sends alerts, core of Wyze Home Monitoring SystemNoneIndoorNot specifiedCentral hub for Wyze Sense devices
Wyze Sense Motion SensorHome Monitoring20.98Detects motion up to 25 ft, 120° FOV, adjustable sensitivity, pet-friendly installationWyze Sense HubIndoorNot specifiedAdhesive or screw mount, requires Wyze Sense v2 or Home Monitoring
Wyze Sense KeypadHome Monitoring27.98Arm/disarm system remotely, emergency button, permanent adhesive mountWyze Sense HubIndoorNot specifiedSupports up to 100 accessories, weatherproof: No
Wyze Sense Climate SensorHome Monitoring41.98 (3pk)Tracks temperature & humidity, 500 ft range, sleek design, adhesive or screw mountWyze Sense HubIndoor915MHz RFBattery CR2032, battery life ~1.5 years, indoor use only
Wyze Bulb ColorSmart Lighting26.26 (2pk)16 million colors, dimmable, tunable white, 1100 lumens, voice control, Alexa/Google/IFTTTNoneIndoor/DampWi-Fi (802.11 b/g/n 2.4GHz), BluetoothA19 bulb shape, 12W power, 25,000 hours life expectancy
Wyze Air FilterConnected Home37.99-63.99Custom air filters (Allergen, Formaldehyde, Wildfire), HEPA filters, activated carbonWyze Air Purifier (implied)IndoorNot specifiedVarious filter types, service life 4-12 months, filters for specific air quality concerns
What is the Wyze Sense Hub and why is it important for home security?The Wyze Sense Hub is the central command center for your Wyze smart home security system. It connects all Wyze security components, ensuring seamless communication and instant alerts to your smartphone. As the backbone of your home protection system, it enables real-time monitoring and centralized control of your security devices.
How does the Wyze Sense Motion Sensor enhance home security?The Wyze Sense Motion Sensor detects movement within a 25-foot range and a 120° field of view, instantly alerting you to any unexpected activity. Its adjustable sensitivity and easy installation make it ideal for monitoring entryways, hallways, or vulnerable areas in your home.
Can I arm or disarm my Wyze security system remotely?Yes, the Wyze Sense Keypad allows you to conveniently arm or disarm your security system remotely. It is designed for indoor use and provides quick, secure access control without needing to use a smartphone app every time.
What are the benefits of the Wyze Sense Climate Sensor?The Wyze Sense Climate Sensor monitors temperature and humidity levels in your home, helping you maintain a comfortable and safe environment. With a range of up to 500 feet from the hub and easy peel-and-stick installation, it is perfect for basements, attics, or distant rooms, helping prevent mold growth and protecting your home’s structure.
How can Wyze Bulb Color improve my home security?Wyze Bulb Color offers customizable smart lighting with 16 million colors and tunable white options. By automating lighting to simulate occupancy, you can deter intruders when you’re away, enhancing your home’s security while also setting the perfect ambiance.
What types of air filters does Wyze offer and how do they improve indoor air quality?Wyze Air Filter comes in Allergen (Standard), Formaldehyde (Premium), and Wildfire (Special Use) types. Featuring HEPA 12 or 13 filters, activated carbon, and a pre-filter, these air filters help protect your family from allergens, harmful gases, and airborne viruses, ensuring a healthier living environment.
Are Wyze smart home security products easy to install and use?Yes, Wyze smart home security products are designed to be affordable, reliable, and easy to install. Most devices feature simple adhesive or screw mounting options and integrate seamlessly with the Wyze Sense Hub for centralized control and real-time alerts.
What makes Wyze a good choice for smart home security solutions?Wyze offers an integrated ecosystem of smart home security products that are affordable, reliable, and user-friendly. With features like motion detection, climate monitoring, smart lighting, and air quality control, Wyze helps you create a safer, smarter, and more comfortable home environment.
Do Wyze security devices require a hub to function?Most Wyze security devices, such as the Wyze Sense Motion Sensor, Keypad, and Climate Sensor, require the Wyze Sense Hub or Wyze Home Monitoring system to function properly. The hub ensures all devices communicate efficiently and provide real-time alerts.
How much do Wyze smart home security products cost?Wyze smart home security products are competitively priced: Wyze Sense Hub ($45.98), Wyze Sense Motion Sensor ($20.98), Wyze Sense Keypad ($27.98), Wyze Sense Climate Sensor ($41.98 for a 3-pack), Wyze Bulb Color (from $26.26 for a 2-pack), and Wyze Air Filter ($37.99 to $63.99 depending on filter type).
What features does the Wyze Sense Hub offer for home security?How does the Wyze Sense Motion Sensor work in detecting movement?Do you have any deals, ongoing sales, discounts, or promotions available?
