Top Smart Home Cameras Compatible with Alexa, Google & IFTTT
Best Smart Home Cameras Compatible with Alexa, Google Assistant, and IFTTT
Looking for a smart home camera that seamlessly integrates with Alexa, Google Assistant, and IFTTT? Whether you want to monitor your home indoors or outdoors, control your security system with voice commands, or automate your smart home routines, Wyze offers a range of smart cameras designed to fit your needs. Explore the top Wyze cameras that combine advanced features, smart assistant compatibility, and reliable performance.
Wyze Cam v4: The Ultimate Wired Smart Camera
Experience unmatched home security with the Wyze Cam v4, the clearest Wyze Cam ever made. This wired camera delivers stunning 2.5K QHD resolution with enhanced color night vision, allowing you to see vibrant details even in low light.
Key Features:
  • 2.5K Quad HD Resolution: Crystal-clear video quality for detailed monitoring.
  • Enhanced Color Night Vision: See in color even at night, thanks to advanced hardware.
  • Motion-Activated Spotlight & Siren: Deter intruders with a bright spotlight and a loud 99 dB siren.
  • 24/7 Local Recording: Continuous recording to microSD card (up to 256GB) without subscription.
  • Wi-Fi 6 Support: Enjoy a stronger, more reliable connection.
  • Smart Assistant Compatibility: Works flawlessly with Alexa, Google Assistant, and IFTTT for voice control and automation.
  • IP65 Weather Resistance: Suitable for indoor and outdoor use.
  • Easy Setup: Screw-free magnetic mount and Bluetooth® setup for hassle-free installation.
"Wyze Cam v4 gives your home superhero vision with its enhanced night vision and smart tracking."
Wyze Cam v4 lifestyle Enjoy clear two-way talk and smart home integration with Wyze Cam v4.
Wyze Cam Floodlight v2: Brighten and Secure Your Outdoors
Illuminate your property while keeping it secure with the Wyze Cam Floodlight v2. This smart floodlight camera combines powerful lighting with 2K video clarity and wide-angle coverage.
Highlights:
  • 2800 Lumens LED Floodlights: Motion-activated and adjustable lights that turn night into day.
  • 2K Video with Color Night Vision: Capture crisp, colorful footage even in darkness.
  • 160° Wide-Angle View: Double the visibility compared to previous models.
  • Ambient Light Mode: Provides constant low-level lighting that brightens on motion detection.
  • Two-Way Talk & 105 dB Siren: Communicate with visitors or scare off intruders.
  • Dusk-to-Dawn Automation: Automatically turns lights on and off based on daylight.
  • IP65 Weatherproof: Built to withstand rain, snow, and harsh weather.
  • Smart Assistant Integration: Compatible with Alexa, Google Assistant, and IFTTT for voice commands and smart routines.
  • 24/7 Local Recording: Supports microSD cards up to 256GB for continuous recording.
"Wyze Cam Floodlight v2 lights the way to smarter home security with AI-powered light control and wide coverage."
Wyze Cam Floodlight v2 lifestyle Smart home security meets powerful lighting with Wyze Cam Floodlight v2.
Wyze Battery Cam Pro: Wireless Freedom with Smart Features
For those who prefer a wire-free solution, the Wyze Battery Cam Pro offers high-resolution video and smart home compatibility without the hassle of cables.
Features at a Glance:
  • 2.5K HDR Video Resolution: Sharp, detailed footage day and night.
  • Wire-Free Design: No hub required; powered by removable, rechargeable 6200mAh batteries lasting up to 6 months.
  • Integrated Spotlight & Siren: Built-in lighting and a 100 dB siren for enhanced security.
  • Radar + PIR Motion Detection: Advanced sensors reduce false alarms and detect movement accurately.
  • Dual-Band Wi-Fi Support: Connects to both 2.4 GHz and 5 GHz networks.
  • IP65 Weatherproof: Durable for outdoor use in various climates.
  • Smart Assistant Compatibility: Works with Alexa, Google Assistant, and IFTTT for voice control and automation.
  • Local Storage Support: Up to 256GB microSD card for continuous or event-based recording.
"Wyze Battery Cam Pro combines wireless convenience with powerful smart home integrations."
Wyze Bulb Cam: Discreet Outdoor Security with Smart Lighting
Protect your home with the innovative Wyze Bulb Cam, a 2-in-1 outdoor security camera and smart LED light bulb that fits into standard fixtures.
Why Choose Wyze Bulb Cam?
  • 2K HD Video with Color Night Vision: Clear video day and night.
  • Standard E26 Socket: Easy installation in most outdoor light fixtures.
  • Up to 800 Lumens Brightness: Provides ample lighting with motion-activated and ambient light modes.
  • Two-Way Audio & 95 dB Siren: Communicate and deter intruders.
  • IP65 Weather Resistance: Built to endure outdoor conditions.
  • Smart Controls: Schedule, manual, or motion-activated lighting with Wyze Automations.
  • Compatible with Alexa, Google Assistant, and IFTTT: Control your camera and lighting with voice commands and smart routines.
  • Local and Cloud Storage Options: Supports microSD cards up to 256GB and cloud storage.
"Wyze Bulb Cam blends security and smart lighting in a simple, easy-to-install package."
Wyze Bulb Cam lifestyle Discreet and smart outdoor security with Wyze Bulb Cam.
Wyze Cam OG: Affordable Wired Camera with Smart Features
The Wyze Cam OG is a budget-friendly wired camera that doesn’t skimp on smart home compatibility or essential security features.
Features Include:
  • 1080p Full HD Video: Clear and smooth video streaming.
  • 120° Field of View: Wide coverage for indoor or outdoor use.
  • Built-in Spotlight & 90 dB Siren: Added security with light and sound deterrents.
  • Improved Two-Way Audio: Clear communication with noise and echo cancellation.
  • Fast Live Streaming & Notifications: 3X faster alerts and streaming.
  • IP65 Weather Resistance: Suitable for various environments.
  • Works with Alexa, Google Assistant, and IFTTT: Voice control and automation made easy.
  • Supports up to 256GB microSD Storage: Local recording without subscription.
"Wyze Cam OG offers reliable security with smart assistant support at an affordable price."
Wyze Cam Pan v3: 360° Coverage with Smart Control
For full-room or outdoor coverage, the Wyze Cam Pan v3 offers 360° pan and 180° tilt with weather resistance and smart home integration.
Standout Features:
  • 360° Pan & 180° Tilt: Complete coverage with remote control.
  • IP65 Weatherproof: Use indoors or outdoors without worry.
  • Smart Assistant Compatible: Works with Alexa, Google Assistant, and IFTTT.
  • High-Quality Video: Crisp footage with motion tracking.
  • Two-Way Audio: Communicate through the camera easily.
"Wyze Cam Pan v3 ensures no corner is left unseen with its dynamic pan and tilt capabilities."
Why Choose Wyze Smart Cameras for Your Home?
Wyze smart cameras stand out for their combination of affordability, advanced features, and seamless integration with popular smart home ecosystems like Alexa, Google Assistant, and IFTTT. Whether you want wired or wireless, indoor or outdoor, floodlight or discreet bulb-style cameras, Wyze has a solution that fits your lifestyle and security needs.
"Control your home security with your voice, automate routines, and stay connected anytime, anywhere."
Enhance your smart home security today with Wyze cameras that bring convenience, clarity, and control right to your fingertips.
FeatureWyze Cam v4Wyze Cam Floodlight v2Wyze Battery Cam ProWyze Bulb CamWyze Cam OGWyze Cam Pan v3
Video Resolution2.5K QHD (2560 x 1440)2K (1920 x 1080)2.5K HDR (2560 x 1440)2K (2304 x 1296)1080p (1920 x 1080)1080p (1920 x 1080)
Field of View (FOV)115.9° (D) x 98.5° (H) x 53.1° (V)160° wide-angle134° (DFOV), 108° (HFOV), 56° (VFOV)160° diagonal, 166° diagonal total120°120°
Night VisionEnhanced Color Night VisionColor Night Vision2 IR LEDs + 2 White LEDs (Color)Color Night Vision + IR4 IR LEDs (B&W)4 IR LEDs (B&W)
AudioEnhanced Two-Way TalkTwo-way talkTwo-way Audio with speaker & micTwo-way audioBuilt-in speaker & micBuilt-in speaker & mic
SirenYes (loud siren)105 dB siren100 dB SPL95 dB siren90 dB user-activated sirenNo siren
Spotlight / LightingMotion-activated spotlight2 x 2800 lumen floodlightsIntegrated spotlightSmart LED light bulb (up to 800 lm)Built-in 40 lumens spotlightNo spotlight
Power SourceWiredWiredBattery (Removable, Rechargeable)Wired (120V AC)Wired (AC adapter)Wired
WirelessNoNoYesNoNoNo
Weather ResistanceIP65IP65IP65IP65IP65IP65
Local StoragemicroSD up to 256 GBmicroSD up to 256 GBmicroSD up to 256 GBmicroSD up to 256 GBmicroSD up to 256 GBmicroSD up to 256 GB
Wi-Fi SupportWi-Fi 62.4 GHz2.4 & 5 GHz2.4 GHz2.4 GHz2.4 GHz
Smart Assistant IntegrationAlexa, Google Assistant, IFTTTAlexa, Google AssistantAlexa, Google Assistant, IFTTTAlexa, Google AssistantAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTT
MountingMagnetic base with metal plateWall or plug-in mountWall mount includedStandard E26 bulb socketWall mount includedScrew mount (1/4" - 20)
DimensionsNot specifiedNot specified2.5 x 1.8 x 3.5 inStandard bulb size1.89 x 1.89 x 1.89 in124 x 60 x 63 mm
WeightNot specifiedNot specified0.94 lbsNot specified4.1 oz (116 g)11.29 oz (320 g)
Special FeaturesAI Auto-Zoom, Smoke & CO alerts, Motion-activated spotlightAmbient Light Mode, 270° PIR motion detection, Dusk-to-dawn automationRadar + PIR motion detection, Up to 6 months battery life2-in-1 camera & smart bulb, Motion-activated light, Digital zoomFaster live streaming, 3X faster notifications, Built-in spotlight360° pan, 180° tilt, 110°/sec rotation speed
Price (1 Pack)$35.98$89.98$159.98$49.98$29.98$114.94
Which Wyze smart home cameras are compatible with Alexa, Google Assistant, and IFTTT?All current Wyze smart home cameras, including Wyze Cam v4, Wyze Cam Floodlight v2, Wyze Battery Cam Pro, Wyze Bulb Cam, Wyze Cam OG, and Wyze Cam Pan v3, are compatible with Alexa, Google Assistant, and IFTTT. This allows for seamless voice control and smart home automation.
What are the key features of the Wyze Cam v4?The Wyze Cam v4 offers 2.5K Quad HD resolution, enhanced color night vision, a motion-activated spotlight and 99 dB siren, 24/7 local recording to microSD card, Wi-Fi 6 support, IP65 weather resistance, and easy screw-free magnetic mounting. It also integrates with Alexa, Google Assistant, and IFTTT for smart home control.
Is the Wyze Cam Floodlight v2 suitable for outdoor use?Yes, the Wyze Cam Floodlight v2 is IP65 weatherproof, making it ideal for outdoor use. It features 2800 lumens LED floodlights, 2K video with color night vision, a 160° wide-angle view, dusk-to-dawn automation, and smart assistant compatibility.
Does the Wyze Battery Cam Pro require wiring or a hub?No, the Wyze Battery Cam Pro is a wire-free camera that does not require any wiring or a hub. It operates on removable, rechargeable batteries that can last up to 6 months and connects directly to your Wi-Fi network.
Can I use Wyze cameras for continuous local recording without a subscription?Yes, most Wyze cameras, including Wyze Cam v4, Wyze Cam Floodlight v2, Wyze Battery Cam Pro, Wyze Bulb Cam, and Wyze Cam OG, support continuous local recording to a microSD card (up to 256GB) without the need for a subscription.
What makes the Wyze Bulb Cam unique among outdoor security cameras?The Wyze Bulb Cam is a 2-in-1 device that combines a 2K HD security camera with a smart LED light bulb. It fits into standard E26 sockets, offers up to 800 lumens of brightness, features color night vision, two-way audio, a 95 dB siren, and is compatible with Alexa, Google Assistant, and IFTTT.
Are Wyze cameras weatherproof for outdoor installation?Yes, several Wyze cameras, including Wyze Cam v4, Wyze Cam Floodlight v2, Wyze Battery Cam Pro, Wyze Bulb Cam, Wyze Cam OG, and Wyze Cam Pan v3, are IP65 weather resistant, making them suitable for both indoor and outdoor use.
What is the most affordable Wyze camera with smart home integration?The Wyze Cam OG is the most budget-friendly option, offering 1080p Full HD video, a 120° field of view, built-in spotlight and siren, improved two-way audio, IP65 weather resistance, and compatibility with Alexa, Google Assistant, and IFTTT.
Which Wyze camera offers 360° pan and 180° tilt for full-room coverage?The Wyze Cam Pan v3 provides 360° pan and 180° tilt capabilities, allowing for complete room or outdoor area coverage. It also features IP65 weatherproofing, high-quality video, motion tracking, two-way audio, and smart assistant compatibility.
Why should I choose Wyze smart cameras for my home security?Wyze smart cameras offer a combination of affordability, advanced features like high-resolution video, color night vision, motion detection, and seamless integration with Alexa, Google Assistant, and IFTTT. Whether you need wired or wireless, indoor or outdoor, or specialized cameras like floodlight or bulb cams, Wyze has a solution to fit your smart home security needs.
What are the key features of the Wyze Cam v4?Can you tell me more about the Wyze Cam Floodlight v2?Are there any ongoing sales or discounts for Wyze cameras?
