Best Wyze Smart Cameras for Home Security & Monitoring
Discover the Best Smart Cameras for Home Security
Smart cameras have revolutionized home security by offering advanced features like high-resolution video, night vision, motion detection, and seamless smart home integration. Whether you want to monitor your indoor spaces, keep an eye on your outdoor surroundings, or secure your entryways, Wyze offers a diverse lineup of smart cameras tailored to your needs. Explore the top Wyze smart cameras that combine cutting-edge technology with user-friendly design to keep your home safe and connected.
Wyze Cam v4: Crystal-Clear Security with Enhanced Night Vision
Experience unmatched home security with the Wyze Cam v4, designed to deliver crystal-clear 2.5K QHD resolution video both day and night. This camera features an advanced CMOS Starlight Sensor and Enhanced Color Night Vision, allowing you to see vibrant colors even in low-light conditions. The motion-activated spotlight adds an extra layer of protection by illuminating suspicious activity instantly.
  • Resolution: 2.5K QHD (2560 x 1440)
  • Field of View: Wide-angle DFOV 115.8°, HFOV 98.5°, VFOV 53.1°
  • Connectivity: Wi-Fi 6 support for faster, more reliable streaming
  • Smart Home Integration: Compatible with Alexa and Google Assistant
  • Recording: 24/7 local recording for continuous security
  • Design: Available in Black, Clear, Grey, and White with durable polycarbonate body and glass + plastic lens
Ideal for both indoor and outdoor use, the Wyze Cam v4 ensures you never miss a moment with its superior video quality and smart features.
Wyze Cam Pan v3: 360° Pan and 180° Tilt for Complete Coverage
For those who want to monitor every corner of their property, the Wyze Cam Pan v3 offers a dynamic 360° horizontal pan and 180° vertical tilt. This fully IP65 weather-resistant camera is perfect for indoor and outdoor use (outdoor use requires a separate power adapter).
  • Pan & Tilt: 360° pan and 180° tilt for full room or yard coverage
  • Weather Resistance: IP65 rating ensures durability in rain, snow, and dust
  • Video Quality: High-definition streaming with clear visuals
  • Colors: Available in sleek Black and White
  • Smart Features: Motion tracking and alerts to keep you informed in real-time
<img src="https://www.wyze.com/cdn/shop/files/IMG_4216-5_1.jpg?v=1670422469&width=1500" alt="Wyze Cam Pan v3 in snowy outdoor setting">
Wyze Cam Pan v3 providing weather-resistant outdoor security
This camera is perfect for users who want flexible, wide-area surveillance with robust weatherproofing.
Wyze Battery Cam Pro: Wire-Free Freedom with 2.5K HDR Video
Say goodbye to wiring hassles with the Wyze Battery Cam Pro, a wire-free smart camera that delivers stunning 2.5K HDR video resolution. Equipped with a removable, rechargeable 6200mAh battery, this camera offers true portability and easy installation anywhere around your home.
  • Video Resolution: 2.5K HDR (2560 x 1440)
  • Power: Removable, rechargeable battery packs for wire-free operation
  • Connectivity: Supports both 2.4 GHz and 5 GHz Wi-Fi bands
  • Detection: Radar + PIR motion detection for precise alerts
  • Additional Features: Integrated spotlight and siren for deterrence
  • Weatherproof: IP65 rating for reliable outdoor use
Ideal for users who want flexible placement without compromising on video quality or smart features.
Wyze Bulb Cam: 2-in-1 Smart LED Light and Security Camera
The Wyze Bulb Cam combines home security with smart lighting in one innovative device. This outdoor security camera doubles as a smart LED light bulb, providing 2K HD video with color night vision and instant motion alerts.
  • Video Quality: 2K HD with color night vision
  • Dual Function: Security camera + smart LED light bulb
  • Installation: Fits most standard light fixtures for easy setup
  • Storage: Supports local video storage with no subscription required
  • Certifications: FCC, IC, UL, and IP65 weatherproof rating
<img src="https://www.wyze.com/cdn/shop/files/Wyze_Bulb_Cam_Shopify-07.jpg?v=1746478547&width=1500" alt="Wyze Bulb Cam installed in outdoor light fixture">
Wyze Bulb Cam securing your home with smart lighting
Perfect for those who want discreet, multi-functional security solutions that blend seamlessly into outdoor lighting.
Wyze Video Doorbell v2: Clear 2K Video for Your Front Door
Keep your entryway secure with the Wyze Video Doorbell v2, offering crystal-clear 2K video and local microSD storage. This wired video doorbell lets you answer your door from anywhere, with two-way audio and motion-activated voice deterrence.
  • Video Resolution: 2K HD for detailed video capture
  • Audio: Two-way communication for real-time interaction
  • Alerts: Instant motion alerts and voice deterrence to ward off unwanted visitors
  • Storage: Local microSD storage, no subscription needed
  • Design: Sleek black finish that fits any home exterior
This doorbell is an essential smart camera for anyone wanting to enhance front door security with clear visuals and interactive features.
Wyze Cam OG: Affordable Next-Gen Indoor/Outdoor Camera
The Wyze Cam OG is the next generation of Wyze’s popular camera line, offering quicker live streaming, 3X faster notifications, and improved two-way audio. It also features a built-in spotlight for added security.
  • Video Resolution: 1080p Full HD (1920 x 1080)
  • Field of View: Wide 120° angle
  • Performance: 20 FPS during the day, 15 FPS at night
  • Audio: Enhanced two-way audio for clear communication
  • Use: Suitable for indoor and outdoor use
  • Colors: Available in Black and White
<img src="https://www.wyze.com/cdn/shop/files/2_way_talk-03.png?v=1670674480&width=1500" alt="Wyze Cam OG with two-way audio feature">
Wyze Cam OG with clear two-way audio for home interaction
An excellent choice for budget-conscious users who want reliable, versatile smart camera coverage.
Why Choose Wyze Smart Cameras?
Wyze smart cameras stand out for their combination of high-quality video, smart home compatibility, and affordable pricing. Whether you need wired or wireless options, indoor or outdoor durability, or multi-functional devices like the Bulb Cam, Wyze offers a solution that fits your lifestyle and security needs.
“Wyze smart cameras provide peace of mind with advanced features and easy installation, making home security accessible to everyone.”
Summary of Wyze Smart Cameras
ModelResolutionKey FeaturesUse CasePrice Range (USD)
Wyze Cam v42.5K QHDEnhanced Night Vision, Wi-Fi 6Indoor/Outdoor$35.98 - $107.94
Wyze Cam Pan v3HD360° Pan, IP65 WeatherproofIndoor/Outdoor$39.98 - $114.94
Wyze Battery Cam Pro2.5K HDRWire-Free, Rechargeable BatteryOutdoor$89.98 - $219.98
Wyze Bulb Cam2K HDSmart LED Light + CameraOutdoor$49.98
Wyze Video Doorbell v22K HDTwo-Way Audio, Voice DeterrenceFront Door$44.98
Wyze Cam OG1080p HDFaster Notifications, Built-in SpotlightIndoor/Outdoor$29.98 - $89.94
Choose the Wyze smart camera that best fits your security needs and enjoy peace of mind with smart, reliable home monitoring.
FeatureWyze Cam v4Wyze Cam Pan v3Wyze Battery Cam ProWyze Bulb CamWyze Video Doorbell v2Wyze Cam OG
TypeWired CameraWired Pan & Tilt CameraBattery CameraLighting Camera (Bulb)Wired Video DoorbellWired Camera
Video Resolution2.5K QHD (2560 x 1440)2.5K (2560 x 1440)2.5K HDR (2560 x 1440)2K HD (2304 x 1296)2K (2048 x 1536)1080p (1920 x 1080)
Field of View (Diagonal)115.9°360° Pan / 180° Tilt134°166°166.8°120°
Night VisionEnhanced Color Night VisionColor Night Vision (Starlight Sensor)2 IR LEDs + 2 White LEDs (Color)Color Night Vision + IR6 x 940nm IR lights4 IR LEDs (850nm)
AudioEnhanced Two-Way TalkTwo-Way AudioTwo-Way Audio (Speaker & Mic)Two-Way AudioTwo-Way AudioBuilt-in Speaker & Mic (Upgraded)
SirenYes (Integrated)NoYes (100 dB)Yes (95 dB)Yes (Digital Voice Deterrence)Yes (90 dB user-activated)
SpotlightMotion-activated SpotlightNoIntegrated SpotlightSmart LED Light BulbNoBuilt-in Spotlight (40 Lumens)
Power SourceWiredWiredRemovable Rechargeable Battery120V AC (Bulb)Wired (16V-24V AC)Wired (5V/1A adapter)
Weather ResistanceIP65IP65IP65IP65IP65IP65
Local StoragemicroSD up to 256GBmicroSD up to 256GBmicroSD up to 256GBmicroSD up to 256GBmicroSD up to 256GBmicroSD up to 256GB
Wireless ConnectivityWi-Fi 6Wi-Fi 2.4 GHzWi-Fi 2.4 & 5 GHzWi-Fi 2.4 GHzWi-Fi 2.4 GHzWi-Fi 2.4 GHz
BluetoothYes (Bluetooth for setup)Not specifiedBLE 5.1BLE 4.2 / BLE Low EnergyNot specifiedNot specified
Smart Assistant IntegrationAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google AssistantAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTT
DimensionsNot specifiedNot specified2.5 x 1.8 x 3.5 inNot specified4.3 x 1.7 x 0.9 in1.89 x 1.89 x 1.89 in
WeightNot specifiedNot specified0.94 lbsNot specifiedNot specified4.1 oz (116 g)
Additional FeaturesAI Auto-Zoom, Motion-activated spotlight, Smoke & CO alerts360° Pan & 180° Tilt, Motion Tracking, Privacy ModeRadar + PIR Motion Detection, Up to 6 months battery life2-in-1 camera & smart bulb, Motion-activated light, Up to 800 lm brightnessMotion-activated voice deterrence, Digital zoomFaster live streaming, 3X faster notifications, Custom detection zones
Price (1 Pack)$35.98$39.98$159.98$49.98$44.98$29.98
What are the best Wyze smart cameras for home security?Wyze offers a range of smart cameras for home security, including the Wyze Cam v4, Wyze Cam Pan v3, Wyze Battery Cam Pro, Wyze Bulb Cam, Wyze Video Doorbell v2, and Wyze Cam OG. Each model is designed for specific use cases such as indoor, outdoor, front door, or multi-functional security needs.
What features does the Wyze Cam v4 offer for home security?The Wyze Cam v4 provides 2.5K QHD resolution, enhanced color night vision with a CMOS Starlight Sensor, motion-activated spotlight, Wi-Fi 6 support, 24/7 local recording, and compatibility with Alexa and Google Assistant. It is suitable for both indoor and outdoor use.
Is the Wyze Cam Pan v3 suitable for outdoor use?Yes, the Wyze Cam Pan v3 is IP65 weather-resistant, making it suitable for both indoor and outdoor use. It offers 360° pan and 180° tilt for complete coverage, motion tracking, and real-time alerts.
What makes the Wyze Battery Cam Pro a good choice for wireless security?The Wyze Battery Cam Pro is a wire-free smart camera with 2.5K HDR video, a removable and rechargeable 6200mAh battery, radar and PIR motion detection, integrated spotlight and siren, and IP65 weatherproofing. It supports both 2.4 GHz and 5 GHz Wi-Fi bands for flexible placement and reliable performance.
How does the Wyze Bulb Cam combine lighting and security?The Wyze Bulb Cam is a 2-in-1 device that functions as both a smart LED light bulb and a security camera. It offers 2K HD video with color night vision, instant motion alerts, easy installation in standard light fixtures, and local video storage without a subscription.
What are the key features of the Wyze Video Doorbell v2?The Wyze Video Doorbell v2 features 2K HD video resolution, two-way audio for real-time communication, instant motion alerts, voice deterrence, and local microSD storage with no subscription required. It is designed to enhance front door security.
Is the Wyze Cam OG a good budget option for home security?Yes, the Wyze Cam OG is an affordable next-generation camera offering 1080p Full HD video, a wide 120° field of view, faster live streaming and notifications, enhanced two-way audio, and a built-in spotlight. It is suitable for both indoor and outdoor use.
Do Wyze smart cameras require a subscription for video storage?Many Wyze smart cameras, such as the Wyze Bulb Cam and Wyze Video Doorbell v2, support local video storage via microSD cards and do not require a subscription for basic recording features.
Are Wyze smart cameras compatible with smart home systems?Yes, Wyze smart cameras are compatible with popular smart home systems, including Alexa and Google Assistant, allowing for seamless integration and voice control.
What is the price range for Wyze smart cameras?Wyze smart cameras are affordably priced, with models ranging from $29.98 for the Wyze Cam OG to $219.98 for the Wyze Battery Cam Pro, depending on the features and bundles selected.
What features does the Wyze Cam v4 offer for night vision?Can you tell me more about the Wyze Cam Pan v3's weather resistance?Do you have any ongoing sales or discounts for Wyze smart cameras?
