Best Home Camera Systems for Complete Security by Wyze
Ultimate Home Camera System for Complete Security
When it comes to securing your home, having a reliable and versatile camera system is essential. Whether you want to monitor your front door, keep an eye on your backyard, or watch over your indoor spaces, the right home camera system offers peace of mind and smart features tailored to your needs. Explore the top Wyze cameras designed to provide crystal-clear video, smart alerts, and seamless integration with your smart home setup.
Wyze Video Doorbell v2: The Smart Wired Doorbell Solution
Answer your door from anywhere with the Wyze Video Doorbell v2, Wyze’s clearest and most capable wired video doorbell yet. Featuring stunning 2K video resolution, this doorbell captures every visitor in sharp detail. It includes local microSD storage, so you never miss a moment, even without cloud access.
Key Features:
  • 2K HD Video for crystal-clear visuals of your doorstep.
  • Two-Way Audio lets you speak directly to visitors or delivery personnel.
  • Motion-Activated Voice Deterrence to ward off unwanted guests.
  • Real-Time Alerts sent instantly to your phone.
  • Wired Installation ensures continuous power without battery worries.
This doorbell is perfect for anyone wanting a reliable, always-on video doorbell with advanced security features.
Wyze Cam v4: High-Definition Outdoor and Indoor Security
Protect your home day and night with the Wyze Cam v4, a versatile camera offering unmatched clarity and smart features. With 2.5K QHD resolution and enhanced color night vision, this camera delivers vivid video even in low light.
Highlights:
  • 2.5K QHD Video for detailed, sharp footage.
  • Enhanced Color Night Vision to see more than just black and white at night.
  • Motion-Activated Spotlight to illuminate and deter intruders.
  • 24/7 Local Recording with microSD card support.
  • Wi-Fi 6 Support for faster, more reliable connectivity.
  • Smart Assistant Compatibility with Alexa and Google Assistant.
Available in multiple colors and packs, Wyze Cam v4 is ideal for both indoor and outdoor use, providing flexible security coverage.
Wyze Cam Pan v3: 360° Pan and 180° Tilt for Full Coverage
For those who want to monitor large areas with a single camera, the Wyze Cam Pan v3 offers a dynamic solution. This indoor/outdoor camera features 360° horizontal pan and 180° vertical tilt, allowing you to control the view remotely and cover every angle.
Features:
  • 360° Pan & 180° Tilt for comprehensive room or yard coverage.
  • IP65 Weather Resistance makes it durable for outdoor use (with optional power adapter).
  • 1080p HD Video for clear, detailed images.
  • Two-Way Audio to communicate through the camera.
  • Motion Tracking to follow moving objects automatically.
Wyze Cam Pan v3 in snowy outdoor setting Stay secure in any weather with Wyze Cam Pan v3
Wyze Battery Cam Pro: Wire-Free, Powerful Security Anywhere
Enjoy the freedom of wire-free installation with the Wyze Battery Cam Pro. This camera packs a punch with 2.5K HDR video resolution and advanced radar + PIR motion detection, making it perfect for flexible placement around your property.
Why Choose Battery Cam Pro?
  • 2.5K HDR Video for vibrant, high-quality footage.
  • No Hub Required for easy setup.
  • Integrated Spotlight & Siren to alert and deter intruders.
  • Radar + PIR Motion Detection for precise movement sensing.
  • Removable, Rechargeable Battery Packs with long-lasting 6200mAh capacity.
  • Dual-Band Wi-Fi Support (2.4 & 5 GHz) for stable connections.
  • IP65 Weatherproof for reliable outdoor use.
This camera is perfect for areas where wiring is difficult or impossible, offering flexible security without compromise.
Wyze Cam Floodlight v2: Brighten and Secure Your Property
Illuminate your property while keeping it secure with the Wyze Cam Floodlight v2. Combining powerful lighting and smart camera technology, this device is designed to dominate the dark with 2800 lumens of LED brightness and 2K video with color night vision.
Standout Features:
  • 2800 Lumens LED Floodlight for bright, clear illumination.
  • 2K Video with Color Night Vision to see details even at night.
  • 160° Wide-Angle View covers large areas like driveways and yards.
  • AI-Powered Light Control and dusk-to-dawn automation.
  • Two-Way Talk to communicate with visitors or intruders.
  • IP65 Weather Resistance for all-season durability.
  • Smart Assistant Integration with Alexa, Google Assistant, and IFTTT.
Wyze Cam Floodlight v2 lighting a driveway at night Brighten your home’s exterior with Wyze Cam Floodlight v2
Wyze Cam OG: Affordable Indoor/Outdoor Security Camera
For budget-conscious users, the Wyze Cam OG offers solid performance with 1080p HD video, quick live streaming, and improved two-way audio. Suitable for both indoor and outdoor use, it’s a great entry-level camera to start your home security system.
Features:
  • 1080p Full HD Video for clear monitoring.
  • 120° Field of View to cover wide areas.
  • Built-In Spotlight for better night visibility.
  • Faster Notifications and Live Streaming for real-time awareness.
  • Indoor/Outdoor Use with weather resistance.
Why Choose a Wyze Home Camera System?
"A comprehensive home camera system combines clarity, smart features, and flexibility to keep your home safe and connected."
Wyze offers a range of cameras tailored to different needs—from wired doorbells and floodlights to wireless battery-powered cams and pan-tilt models. With high-resolution video, smart alerts, two-way audio, and weather resistance, these cameras provide reliable security solutions for every corner of your home.
Conclusion
Whether you want to monitor your front door, backyard, or indoor spaces, Wyze’s home camera system lineup has you covered. Choose from wired or wireless options, enjoy crystal-clear video quality, and integrate seamlessly with your smart home devices. Protect your home with confidence and stay connected no matter where you are.
Product Summary
FeatureWyze Video Doorbell v2Wyze Cam v4Wyze Cam Pan v3Wyze Battery Cam ProWyze Cam Floodlight v2Wyze Cam OG
TypeWired Video DoorbellWired CameraWired Pan & Tilt CameraWireless Battery CameraWired Floodlight CameraWired Camera
Video Resolution2K (2304 x 1296)2.5K QHD (2560 x 1440)1080p (1920 x 1080)2.5K HDR (2560 x 1440)2K (2304 x 1296)1080p (1920 x 1080)
Field of ViewHead-to-toe view (exact FOV not stated)115.9° (D) x 98.5° (H) x 53.1° (V)360° horizontal, 180° vertical134° DFOV, 108° HFOV, 56° VFOV160° diagonal120°
Night VisionColor Night Vision (Starlight sensor)Enhanced Color Night Vision4 IR LEDs (850 nm)2 IR LEDs + 2 White LEDsColor Night Vision4 IR LEDs (850 nm)
AudioTwo-way talkEnhanced Two-way talkTwo-way audio with noise & echo cancellationTwo-way audio with built-in speaker & micTwo-way audioTwo-way audio with noise & echo cancellation
Local StoragemicroSD slot (continuous 24/7 recording)microSD slot (up to 256GB)microSD support (up to 256GB)microSD support (up to 256GB)microSD support (up to 256GB)microSD support (up to 256GB)
Cloud StorageOptional Cam Plus subscriptionOptional Cam Plus subscriptionOptional Cam Plus subscriptionOptional Cam Plus subscriptionOptional Cam Plus subscriptionOptional Cam Plus subscription
Power SourceWiredWiredWiredBattery (Removable, Rechargeable)HardwiredWired
Weather ResistanceIP65IP65IP65IP65IP65IP65
Special FeaturesMotion-activated voice deterrence, pre-roll motion recording, chime controller includedMotion-activated spotlight, Wi-Fi 6, Auto-zoom with AI, Smoke & CO alerts360° pan, 180° tilt, 8x digital zoom, noise & echo cancellationRadar + PIR motion detection, integrated spotlight & siren, up to 6 months battery life2800 Lumens LEDs, AI-powered light control, dusk-to-dawn automation, 105dB sirenBuilt-in spotlight (40 lumens), 50% faster live streaming, smoke & CO alerts
DimensionsNot specifiedNot specified124mm x 60mm x 63mm2.5 x 1.8 x 3.5 inches9.5in x 7.7in x 7.0in1.89 in x 1.89 in x 1.89 in
WeightNot specifiedNot specified11.29 oz (320 g)0.94 lbs2.76 lbs (1.25 kg)4.1 oz (116 g)
IntegrationsAlexa, Google HomeAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google Assistant
WarrantyNot specifiedNot specified1 YearNot specified1 Year1 Year
Price (starting)$44.98$35.98$39.98$89.98$89.98$29.98
What makes Wyze home camera systems ideal for complete home security?Wyze home camera systems offer a comprehensive range of features including high-resolution video, smart alerts, two-way audio, weather resistance, and seamless integration with smart home devices. With options for both wired and wireless installation, Wyze cameras provide reliable security coverage for every area of your home, indoors and outdoors.
What are the key features of the Wyze Video Doorbell v2?The Wyze Video Doorbell v2 features 2K HD video resolution for clear visuals, two-way audio for direct communication, motion-activated voice deterrence, real-time alerts to your phone, and local microSD storage. Its wired installation ensures continuous power and reliable performance.
Can Wyze Cam v4 be used both indoors and outdoors?Yes, the Wyze Cam v4 is designed for both indoor and outdoor use. It offers 2.5K QHD video, enhanced color night vision, a motion-activated spotlight, 24/7 local recording with microSD support, Wi-Fi 6 connectivity, and compatibility with Alexa and Google Assistant.
How does the Wyze Cam Pan v3 provide full coverage?The Wyze Cam Pan v3 offers 360° horizontal pan and 180° vertical tilt, allowing you to remotely control the camera’s view and monitor large areas with a single device. It also features 1080p HD video, two-way audio, motion tracking, and IP65 weather resistance for outdoor use.
What are the benefits of the Wyze Battery Cam Pro for home security?The Wyze Battery Cam Pro provides wire-free installation, making it ideal for locations where wiring is difficult. It features 2.5K HDR video, radar and PIR motion detection, an integrated spotlight and siren, removable rechargeable battery packs, dual-band Wi-Fi support, and IP65 weatherproofing.
How does the Wyze Cam Floodlight v2 enhance outdoor security?The Wyze Cam Floodlight v2 combines a powerful 2800 lumens LED floodlight with a 2K video camera featuring color night vision. It offers a 160° wide-angle view, AI-powered light control, dusk-to-dawn automation, two-way talk, IP65 weather resistance, and integration with Alexa, Google Assistant, and IFTTT.
Is the Wyze Cam OG suitable for budget-conscious users?Yes, the Wyze Cam OG is an affordable security camera that delivers 1080p full HD video, a 120° field of view, built-in spotlight, faster notifications, and live streaming. It is weather-resistant and suitable for both indoor and outdoor use, making it a great entry-level option.
Do Wyze cameras support local storage?Many Wyze cameras, including the Wyze Video Doorbell v2 and Wyze Cam v4, support local microSD card storage, allowing for 24/7 recording and playback without relying on cloud services.
Are Wyze cameras compatible with smart home assistants?Yes, several Wyze cameras, such as the Wyze Cam v4 and Wyze Cam Floodlight v2, are compatible with popular smart home assistants like Alexa and Google Assistant, enabling voice control and smart home integration.
What weather resistance ratings do Wyze cameras offer?Wyze cameras such as the Wyze Cam Pan v3, Wyze Battery Cam Pro, and Wyze Cam Floodlight v2 feature IP65 weather resistance, ensuring reliable performance in various outdoor conditions.
What features does the Wyze Video Doorbell v2 offer?Can the Wyze Cam v4 be used both indoors and outdoors?Do you have any deals, ongoing sales, discounts, or promotions?
