Best Security Camera Systems for Home & Business | Wyze
Comprehensive Security Camera Systems for Every Need
When it comes to securing your home or business, choosing the right security camera system is crucial. Whether you want to monitor your front door, keep an eye on your backyard, or illuminate dark areas with smart lighting, Wyze offers a range of advanced security cameras designed to fit every requirement and budget. Explore the best-in-class features of Wyze’s security camera lineup to find the perfect system for your peace of mind.
Wyze Video Doorbell v2: Clear, Wired Door Monitoring
Experience the next level of front door security with the Wyze Video Doorbell v2. This wired video doorbell delivers stunning 2K video resolution, allowing you to see visitors and packages in crisp detail. Equipped with local microSD storage, it ensures every moment is captured and saved securely without relying solely on cloud storage.
Key Features:
  • 2K HD Video Quality: See every detail with enhanced clarity.
  • Two-Way Audio: Communicate with visitors or delivery personnel from anywhere.
  • Real-Time Alerts: Instant notifications when motion or someone rings the doorbell.
  • Motion-Activated Voice Deterrence: Automatically warns unwanted visitors with a pre-recorded voice message.
  • Wired Installation: Reliable power source for continuous operation.
This doorbell is perfect for homeowners who want a dependable, high-resolution video doorbell that integrates seamlessly with their smart home setup.
Wyze Cam Pan v3: 360° Pan & Tilt for Indoor/Outdoor Use
For versatile coverage, the Wyze Cam Pan v3 offers a full 360° horizontal pan and 180° vertical tilt, making it ideal for monitoring large areas both indoors and outdoors. Its IP65 weather resistance ensures it withstands rain, snow, and dust, providing reliable security year-round.
Highlights:
  • 360° Pan & 180° Tilt: Complete room or yard coverage with remote control.
  • IP65 Weather Resistant: Durable for outdoor environments (requires separate outdoor power adapter).
  • Multiple Color Options: Available in sleek Black or White to match your decor.
  • Flexible Packs: Choose from single or multi-packs for comprehensive coverage.
<img src="https://www.wyze.com/cdn/shop/files/IMG_4216-5_1.jpg?v=1670422469&width=1500" alt="Wyze Cam Pan v3 in snowy outdoor setting">
Wyze Cam Pan v3 providing weather-resistant outdoor security.
Wyze Cam v4: Advanced 2.5K QHD Resolution with Night Vision
The Wyze Cam v4 is a powerhouse security camera that delivers crystal-clear 2.5K QHD video with enhanced color night vision, making it perfect for both day and night surveillance. Its motion-activated spotlight adds an extra layer of security by illuminating suspicious activity.
Features at a Glance:
  • 2.5K QHD Video: Ultra-clear footage for detailed monitoring.
  • Enhanced Color Night Vision: See vibrant colors even in low light.
  • Motion-Activated Spotlight: Automatically lights up when motion is detected.
  • 24/7 Local Recording: Continuous recording with local storage options.
  • Wi-Fi 6 Support: Faster, more reliable wireless connectivity.
  • Smart Assistant Compatible: Works with Alexa and Google Assistant.
This camera is ideal for users seeking high-resolution video and smart home integration.
Wyze Battery Cam Pro: Wire-Free, High-Resolution Security
For those who prefer a wireless setup, the Wyze Battery Cam Pro offers 2.5K HDR video resolution without the need for a hub or wiring. Its removable, rechargeable battery packs provide flexibility in placement, while integrated spotlight and siren enhance security.
Why Choose Battery Cam Pro?
  • Wire-Free Installation: No cables or hubs required.
  • 2.5K HDR Video: High-quality footage day and night.
  • Radar + PIR Motion Detection: Advanced sensors reduce false alerts.
  • Integrated Spotlight & Siren: Deter intruders with light and sound.
  • IP65 Weatherproof: Built to withstand outdoor conditions.
  • Dual-Band Wi-Fi Support: Connects to 2.4 & 5 GHz networks.
Perfect for renters or anyone needing a portable, powerful security camera solution.
Wyze Cam Floodlight v2: Illuminate and Secure Your Property
The Wyze Cam Floodlight v2 combines powerful lighting with smart security features to keep your property safe and well-lit. With 2800 lumens of LED brightness and 2K video resolution, it dominates the dark while providing a wide 160° field of view.
Standout Features:
  • 2800 Lumens LED Floodlight: Bright illumination for driveways, garages, and yards.
  • 2K Video with Color Night Vision: Clear footage even in darkness.
  • AI-Powered Light Control: Smart automation adjusts lighting based on activity.
  • Two-Way Talk: Communicate through the camera’s built-in speaker and mic.
  • Dusk-to-Dawn Automation: Automatically turns on/off based on ambient light.
  • IP65 Weather Resistance: Reliable performance in all weather conditions.
  • Smart Assistant Integration: Compatible with Alexa, Google Assistant, and IFTTT.
<img src="https://www.wyze.com/cdn/shop/files/WyzeCamFloodlightv2Main-08.jpg?v=1743789457&width=1946" alt="Wyze Cam Floodlight v2 lighting a driveway at night">
Wyze Cam Floodlight v2 providing bright, smart security lighting.
Wyze Cam OG: Affordable Indoor/Outdoor Security
The Wyze Cam OG is the budget-friendly option that doesn’t compromise on essential features. With 1080p HD video, a 120° field of view, and improved two-way audio, it’s a solid choice for basic indoor or outdoor monitoring.
Key Benefits:
  • 1080p HD Video: Clear and reliable footage.
  • 120° Field of View: Wide coverage area.
  • Improved Two-Way Audio: Enhanced communication with visitors.
  • Built-In Spotlight: Adds extra visibility in low light.
  • Indoor/Outdoor Use: Versatile placement options.
Ideal for those seeking dependable security on a budget.
<img src="https://www.wyze.com/cdn/shop/files/2_way_talk-03.png?v=1670674480&width=1500" alt="Two-way audio lifestyle image with dog and speech bubble">
Wyze Cam OG enabling two-way communication indoors.
Conclusion
Wyze offers a comprehensive lineup of security camera systems tailored to various needs—from wired video doorbells and pan-tilt cameras to wireless battery-powered models and floodlight-integrated cameras. Whether you want high-resolution video, smart home compatibility, or weather-resistant durability, Wyze has a solution to keep your property safe and secure. Choose the Wyze security camera system that fits your lifestyle and enjoy peace of mind with cutting-edge technology and smart features.
Product Tags Summary
FeatureWyze Video Doorbell v2Wyze Cam Pan v3Wyze Cam v4Wyze Battery Cam ProWyze Cam Floodlight v2Wyze Cam OG
TypeWired Video DoorbellWired Pan & Tilt CameraWired Security CameraWireless Battery CameraWired Floodlight CameraWired Indoor/Outdoor Camera
Video Resolution2K (2304 x 1296)1080p (not explicitly stated, assumed)2.5K QHD (2560 x 1440)2.5K (2560 x 1440)2K (2304 x 1296)1080p (not explicitly stated)
Field of ViewNot specified (head-to-toe view)360° pan, 180° tiltDFOV 115.8°, HFOV 98.5°, VFOV 53.1°DFOV 134°, HFOV 108°, VFOV 56°160° diagonalNot specified
Night VisionColor Night Vision (Starlight Sensor)Color Night Vision (Starlight Sensor)Color Night Vision (4 IR LEDs + 2 white spotlight LEDs)IR LEDs + White LEDs (2 IR + 2 White)Color Night VisionNot specified
AudioTwo-way audioTwo-way audioTwo-way talk, 99dB waterproof speakerTwo-way audio with speaker & micTwo-way audioImproved two-way audio
Local StoragemicroSD slot (continuous local recording)microSD card supportmicroSD card up to 512 GBmicroSD card up to 256 GBmicroSD up to 256 GB (ExFAT)Not specified
Cloud StorageOptional Cam Plus subscriptionOptional Cam Plus subscriptionOptional subscriptionOptional subscriptionOptional subscriptionOptional subscription
Power SourceWiredWired (Outdoor Power Adapter sold separately for outdoor use)WiredWireless (Rechargeable battery)HardwiredWired
Weather ResistanceIP65IP65IP65IP65IP65Indoor/outdoor* (IP rating not specified)
Special FeaturesMotion-activated voice deterrence, pre-roll recording, chime controller included360° pan & 180° tilt, motion tracking, privacy mode, Pan Scan patrolMotion-activated spotlight, Wi-Fi 6, built-in siren, wide dynamic rangeRadar + PIR motion detection, integrated spotlight & siren, up to 6 months battery life2800 lumens LED floodlight, AI-powered light control, dusk-to-dawn automation, 105dB sirenBuilt-in spotlight, faster notifications, improved 2-way audio
DimensionsNot specifiedNot specified2in x 2in x 2 3/8in2.5 x 1.8 x 3.5 inches9.5in x 7.7in x 7.0inNot specified
WeightNot specifiedNot specified0.49 lb (222 g)0.94 lbs2.76 lbs (1.25 kg)Not specified
IntegrationAlexa, Google HomeAlexa, Google AssistantAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTT
Price (approx.)$44.98$39.98 (1 pack)$35.98 (1 pack)$159.98 (1 pack)$89.98$29.98 (1 pack)
What types of security camera systems does Wyze offer?Wyze offers a comprehensive range of security camera systems, including wired video doorbells, pan and tilt cameras, high-resolution indoor/outdoor cameras, wire-free battery-powered cameras, floodlight cameras, and affordable basic models. Each system is designed to meet different security needs and budgets.
What are the key features of the Wyze Video Doorbell v2?The Wyze Video Doorbell v2 features 2K HD video quality, two-way audio, real-time alerts, motion-activated voice deterrence, and reliable wired installation. It also supports local microSD storage for secure video recording without relying solely on the cloud.
Is the Wyze Cam Pan v3 suitable for outdoor use?Yes, the Wyze Cam Pan v3 is IP65 weather resistant, making it suitable for both indoor and outdoor use. It offers 360° pan and 180° tilt for complete coverage and is available in multiple color options.
What makes the Wyze Cam v4 ideal for night surveillance?The Wyze Cam v4 is equipped with 2.5K QHD video resolution and enhanced color night vision, allowing you to see vibrant colors even in low light. It also features a motion-activated spotlight for added security during nighttime.
Does Wyze offer wireless security cameras?Yes, the Wyze Battery Cam Pro is a wire-free security camera that offers 2.5K HDR video, radar and PIR motion detection, integrated spotlight and siren, and IP65 weatherproofing. It operates on removable, rechargeable battery packs and does not require a hub or wiring.
What are the benefits of the Wyze Cam Floodlight v2?The Wyze Cam Floodlight v2 combines a powerful 2800 lumens LED floodlight with 2K video resolution and color night vision. It features AI-powered light control, two-way talk, dusk-to-dawn automation, IP65 weather resistance, and smart assistant integration with Alexa, Google Assistant, and IFTTT.
Is there an affordable Wyze security camera option?Yes, the Wyze Cam OG is a budget-friendly security camera that offers 1080p HD video, a 120° field of view, improved two-way audio, a built-in spotlight, and versatile indoor/outdoor use.
Are Wyze security cameras compatible with smart home assistants?Many Wyze security cameras, including the Wyze Cam v4 and Wyze Cam Floodlight v2, are compatible with popular smart home assistants such as Alexa and Google Assistant, allowing for seamless integration into your smart home setup.
Do Wyze cameras support local video storage?Yes, several Wyze cameras, such as the Wyze Video Doorbell v2 and Wyze Cam v4, support local microSD storage, enabling continuous or event-based recording without relying solely on cloud storage.
What weather resistance ratings do Wyze outdoor cameras have?Wyze outdoor cameras, including the Wyze Cam Pan v3, Wyze Battery Cam Pro, and Wyze Cam Floodlight v2, feature IP65 weather resistance, ensuring reliable performance in rain, snow, and dust.
What features does the Wyze Video Doorbell v2 offer for front door security?Can you explain how the two-way audio feature works on the Wyze Video Doorbell v2?Do you have any deals, ongoing sales, discounts, or promotions available for security cameras?
