Wyze Battery Cam Pro: The Ultimate Wireless Security Camera for Your Smart Home
Looking for a monitoring camera that seamlessly integrates with your Wyze smart home devices? The
Wyze Battery Cam Pro is designed to deliver pro-grade security with the convenience of wireless freedom. Whether you want to keep an eye on your front porch, backyard, or any remote location, this camera offers crystal-clear 2.5K HDR video resolution and smart features that make home monitoring smarter and easier.
Key Features of Wyze Battery Cam Pro
- 2.5K HDR Video Resolution: Capture every detail in stunning clarity, day or night, with enhanced color night vision.
- Wire-Free & No Hub Required: Install anywhere without the hassle of wires or additional hubs.
- Integrated Spotlight & Siren: Motion-activated 150-lumen LED spotlight and siren to deter intruders instantly.
- Radar + PIR Motion Detection: Dual sensors provide earlier and more precise motion alerts with customizable detection zones.
- Removable, Rechargeable Battery Packs: Hot-swap batteries to keep your camera running without downtime.
- IP65 Weatherproof: Built to withstand rain, dust, and extreme temperatures.
- Dual-Band Wi-Fi Support: Connects easily to both 2.4 GHz and 5 GHz networks for reliable streaming.
- Local Recording: Supports microSD card for continuous local video storage without subscription.
- Enhanced Two-Way Audio: Talk or listen through the built-in microphone and speaker.
"Wyze Battery Cam Pro is the ultimate battery-operated, go-anywhere security camera that protects your home with smart, reliable technology."
Flexible Power & Mounting Options
The Wyze Battery Cam Pro offers versatile power solutions. You can easily swap out rechargeable battery packs or extend your camera’s uptime by adding the
Wyze Solar Panel (sold separately). Mount it on walls, ceilings, or any outdoor spot with the durable
Wyze Universal Mount for optimal coverage.
Wyze Battery Cam Pro + Solar Panel: Continuous Power for Non-Stop Security
For those who want to maximize uptime and reduce battery charging frequency, the
Wyze Battery Cam Pro + Solar Panel bundle is the perfect choice. This combo keeps your camera powered by converting sunlight into energy, making it ideal for remote or hard-to-reach locations.
Why Choose the Solar Panel Bundle?
- Continuous Solar Power: Harness the sun’s energy to keep your camera running longer without manual recharging.
- Same Pro-Grade Features: Enjoy all the benefits of the Wyze Battery Cam Pro, including 2.5K HDR video, radar + PIR motion detection, and integrated spotlight.
- Weatherproof & Durable: Both camera and solar panel are IP65 rated for reliable outdoor use.
- Easy Setup: No electrician needed; just mount and connect via the Wyze app.
"Turn your Wyze Battery Cam Pro into a solar-powered security powerhouse and never worry about battery life again."
Experience seamless integration and smart home security with Wyze Battery Cam Pro.
Essential Accessories to Enhance Your Wyze Battery Cam Pro Experience
Wyze Removable Battery Pack
Keep your camera powered without interruption by having extra
Wyze Removable Battery Packs on hand. Each pack offers:
- 6200mAh Capacity: Up to 6 months of battery life on a single charge.
- USB-C Charging: Convenient and fast charging.
- Compact & Lightweight: Easy to swap without hassle.
Wyze Battery Charging Dock
Charge two battery packs simultaneously with the
Wyze Battery Charging Dock. This accessory is perfect for:
- Efficient Charging: Reduces downtime by preparing multiple batteries at once.
- Compact Design: Fits neatly on your desk or shelf.
- Compatibility: Works seamlessly with Wyze Battery Cam Pro battery packs.
Wyze Bird Feeder Wireless Camera Bundle: A Unique Smart Home Addition
For bird lovers and nature watchers, the
Bird Feeder Wireless Camera Bundle combines the Wyze Battery Cam Pro, Wyze Solar Panel, and a vibrant Wyze Bird Feeder. This bundle lets you:
- Watch Live Bird Activity: Stream and record every feathered visitor in 2.5K HDR.
- Weather-Resistant Setup: All components are IP65 rated for outdoor durability.
- Easy Integration: Use the Wyze app to monitor your bird feeder and home security in one place.
"A must-have for birders and smart home enthusiasts alike, blending nature observation with home security."
Boost your Wyze smart home ecosystem with reliable Wi-Fi coverage using Wyze Wi-Fi 6E Mesh Router Pro.
Seamless Integration with Wyze Smart Home Devices
The Wyze Battery Cam Pro and its accessories integrate effortlessly with other Wyze smart home products, such as the
Wyze Wi-Fi 6E Mesh Router Pro. This router ensures:
- Fast, Reliable Connectivity: Up to 2.5 Gbps speeds with tri-band Wi-Fi 6E technology.
- Wide Coverage: Covers up to 2000 sq. ft. per router and supports 75+ devices.
- Easy Setup & Management: Simple Bluetooth setup and parental controls via the Wyze app.
Together, these devices create a robust, interconnected smart home security system that you can control from anywhere.
Why Choose Wyze Battery Cam Pro for Your Smart Home?
- Wireless Freedom: No hubs or wires needed, install anywhere.
- High-Quality Video: 2.5K HDR with color night vision.
- Smart Motion Detection: Radar + PIR sensors for precise alerts.
- Flexible Power Options: Rechargeable batteries and solar panel support.
- Weatherproof Durability: IP65 rating for all-season protection.
- Wyze Ecosystem Integration: Works seamlessly with other Wyze smart devices.
Protect your home with confidence and convenience using the Wyze Battery Cam Pro and its smart accessories.
What is the Wyze Battery Cam Pro?
The Wyze Battery Cam Pro is a wireless security camera designed for smart home integration. It offers 2.5K HDR video resolution, enhanced color night vision, and advanced motion detection, making it ideal for monitoring your home or outdoor spaces without the need for wires or hubs.Does the Wyze Battery Cam Pro require a hub or wires for installation?
No, the Wyze Battery Cam Pro is completely wire-free and does not require a hub for installation. You can easily mount it anywhere for flexible home security coverage.What video quality does the Wyze Battery Cam Pro provide?
The Wyze Battery Cam Pro delivers crystal-clear 2.5K HDR video resolution, ensuring you capture every detail both day and night with enhanced color night vision.How does the Wyze Battery Cam Pro detect motion?
The camera uses a combination of radar and PIR (Passive Infrared) motion detection sensors. This dual-sensor system provides earlier and more accurate motion alerts, and you can customize detection zones for precise monitoring.Is the Wyze Battery Cam Pro weatherproof?
Yes, the Wyze Battery Cam Pro is IP65 weatherproof, making it suitable for outdoor use in rain, dust, and extreme temperatures.Can I use the Wyze Battery Cam Pro with both 2.4 GHz and 5 GHz Wi-Fi networks?
Yes, the Wyze Battery Cam Pro supports dual-band Wi-Fi, allowing you to connect to both 2.4 GHz and 5 GHz networks for reliable streaming and connectivity.Does the Wyze Battery Cam Pro support local video storage?
Yes, the camera supports local recording via a microSD card, enabling continuous video storage without the need for a subscription.What power options are available for the Wyze Battery Cam Pro?
The Wyze Battery Cam Pro features removable, rechargeable battery packs that can be hot-swapped for uninterrupted operation. You can also extend uptime by connecting the Wyze Solar Panel (sold separately) for continuous solar power.What is included in the Wyze Battery Cam Pro + Solar Panel bundle?
The Wyze Battery Cam Pro + Solar Panel bundle includes the camera and a solar panel, allowing you to harness solar energy for continuous power. This setup is ideal for remote or hard-to-reach locations and includes all the pro-grade features of the camera.How do I mount the Wyze Battery Cam Pro?
You can mount the Wyze Battery Cam Pro on walls, ceilings, or any outdoor location using the Wyze Universal Mount for optimal coverage and flexibility.What accessories are available for the Wyze Battery Cam Pro?
Essential accessories include the Wyze Removable Battery Pack for extended battery life, the Wyze Battery Charging Dock for charging two batteries simultaneously, and the Wyze Solar Panel for continuous solar-powered operation.What is the Wyze Bird Feeder Wireless Camera Bundle?
The Wyze Bird Feeder Wireless Camera Bundle combines the Wyze Battery Cam Pro, Wyze Solar Panel, and a colorful Wyze Bird Feeder. This bundle allows you to stream and record bird activity in 2.5K HDR while enjoying weather-resistant durability and easy integration with the Wyze app.How does the Wyze Battery Cam Pro integrate with other Wyze smart home devices?
The Wyze Battery Cam Pro integrates seamlessly with other Wyze smart home products, such as the Wyze Wi-Fi 6E Mesh Router Pro, providing fast, reliable connectivity and centralized control through the Wyze app.What are the benefits of using the Wyze Wi-Fi 6E Mesh Router Pro with Wyze Battery Cam Pro?
The Wyze Wi-Fi 6E Mesh Router Pro offers up to 2.5 Gbps speeds, wide coverage for up to 2000 sq. ft. per router, and support for 75+ devices. It ensures reliable connectivity for your Wyze Battery Cam Pro and other smart home devices, all managed easily via the Wyze app.Why should I choose the Wyze Battery Cam Pro for my smart home security?
The Wyze Battery Cam Pro offers wireless freedom, high-quality 2.5K HDR video, smart radar + PIR motion detection, flexible power options, weatherproof durability, and seamless integration with the Wyze smart home ecosystem, making it a top choice for reliable and convenient home security.
